171.64.65.102
Grandpa_01
171.64.65.102
Post by Grandpa_01 »
The above mentioned servers appear to be having problems
[17:49:46] Completed 100%
[17:49:46] Successful run
[17:49:46] DynamicWrapper: Finished Work Unit: sleep=10000
[17:49:55] Reserved 153868 bytes for xtc file; Cosm status=0
[17:49:55] Allocated 153868 bytes for xtc file
[17:49:55] - Reading up to 153868 from "work/wudata_04.xtc": Read 153868
[17:49:55] Read 153868 bytes from xtc file; available packet space=786276596
[17:49:55] xtc file hash check passed.
[17:49:55] Reserved 23472 23472 786276596 bytes for arc file=<work/wudata_04.trr> Cosm status=0
[17:49:55] Allocated 23472 bytes for arc file
[17:49:55] - Reading up to 23472 from "work/wudata_04.trr": Read 23472
[17:49:55] Read 23472 bytes from arc file; available packet space=786253124
[17:49:55] trr file hash check passed.
[17:49:55] Allocated 560 bytes for edr file
[17:49:55] Read bedfile
[17:49:55] edr file hash check passed.
[17:49:55] Allocated 0 bytes for logfile
[17:49:55] Could not open/read logfile=<work/wudata_04.log>; Cosm status=-1
[17:49:55] GuardedRun: success in DynamicWrapper
[17:49:55] GuardedRun: done
[17:49:55] Run: GuardedRun completed.
[17:50:00] - Writing 178412 bytes of core data to disk...
[17:50:00] Done: 177900 -> 176497 (compressed to 99.2 percent)
[17:50:00]   ... Done.
[17:50:00] - Shutting down core
[17:50:00]
[17:50:00] Folding@home Core Shutdown: FINISHED_UNIT
[17:50:05] CoreStatus = 64 (100)
[17:50:05] Unit 4 finished with 93 percent of time to deadline remaining.
[17:50:05] Updated performance fraction: 0.901899
[17:50:05] Sending work to server
[17:50:05] Project: 5740 (Run 0, Clone 30, Gen 519)
[17:50:05] + Attempting to send results [October 17 17:50:05 UTC]
[17:50:05] - Reading file work/wuresults_04.dat from core
[17:50:05]   (Read 177009 bytes from disk)
[17:50:05] Connecting to http://171.64.65.102:8080/
[17:50:06] - Couldn't send HTTP request to server
[17:50:06] + Could not connect to Work Server (results)
[17:50:06]     (171.64.65.102:8080)
[17:50:06] + Retrying using alternative port
[17:50:06] Connecting to http://171.64.65.102:80/
[17:50:07] - Couldn't send HTTP request to server
[17:50:07] + Could not connect to Work Server (results)
[17:50:07]     (171.64.65.102:80)
[17:50:07] - Error: Could not transmit unit 04 (completed October 17) to work server.
[17:50:07] - 1 failed uploads of this unit.
[17:50:07]   Keeping unit 04 in queue.
[17:50:07] Trying to send all finished work units
[17:50:07] Project: 5740 (Run 0, Clone 30, Gen 519)
[17:50:07] + Attempting to send results [October 17 17:50:07 UTC]
[17:50:07] - Reading file work/wuresults_04.dat from core
[17:50:07]   (Read 177009 bytes from disk)
[17:50:07] Connecting to http://171.64.65.102:8080/
[17:50:09] - Couldn't send HTTP request to server
[17:50:09] + Could not connect to Work Server (results)
[17:50:09]     (171.64.65.102:8080)
[17:50:09] + Retrying using alternative port
[17:50:09] Connecting to http://171.64.65.102:80/
[17:50:10] - Couldn't send HTTP request to server
[17:50:10] + Could not connect to Work Server (results)
[17:50:10]     (171.64.65.102:80)
[17:50:10] - Error: Could not transmit unit 04 (completed October 17) to work server.
[17:50:10] - 2 failed uploads of this unit.
[17:50:10] + Attempting to send results [October 17 17:50:10 UTC]
[17:50:10] - Reading file work/wuresults_04.dat from core
[17:50:10]   (Read 177009 bytes from disk)
[17:50:10] Connecting to http://171.67.108.17:8080/
[17:50:10]   (Got status 503)
[17:50:10]     (171.67.108.17:8080)
[17:50:10] + Retrying using alternative port
[17:50:10] Connecting to http://171.67.108.17:80/
[17:50:10]     (171.67.108.17:80)
[17:50:10]   Could not transmit unit 04 to Collection server; keeping in queue.
[17:50:10] + Sent 0 of 1 completed units to the server
[17:50:10] - Preparing to get new work unit...
[17:50:10] + Attempting to get work packet
[17:50:10] - Will indicate memory of 4087 MB
[17:50:10] - Connecting to assignment server
[17:50:10] Connecting to http://assign-GPU.stanford.edu:8080/
[17:50:10] Posted data.
[17:50:10] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:50:10] + Couldn't get work instructions.
[17:50:10] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[17:50:16] + Attempting to get work packet
[17:50:16] - Will indicate memory of 4087 MB
[17:50:16] - Connecting to assignment server
[17:50:16] Connecting to http://assign-GPU.stanford.edu:8080/
[17:50:17] Posted data.
[17:50:17] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:50:17] + Couldn't get work instructions.
[17:50:17] - Attempt #2  to get work failed, and no other work to do.
[17:50:28] + Attempting to get work packet
[17:50:28] - Will indicate memory of 4087 MB
[17:50:28] - Connecting to assignment server
[17:50:28] Connecting to http://assign-GPU.stanford.edu:8080/
[17:50:28] Posted data.
[17:50:28] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:50:28] + Couldn't get work instructions.
[17:50:28] - Attempt #3  to get work failed, and no other work to do.
[17:50:59] + Attempting to get work packet
[17:50:59] - Will indicate memory of 4087 MB
[17:50:59] - Connecting to assignment server
[17:50:59] Connecting to http://assign-GPU.stanford.edu:8080/
[17:50:59] Posted data.
[17:50:59] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:50:59] + Couldn't get work instructions.
[17:50:59] - Attempt #4  to get work failed, and no other work to do.
[17:51:52] + Attempting to get work packet
[17:51:52] - Will indicate memory of 4087 MB
[17:51:52] - Connecting to assignment server
[17:51:52] Connecting to http://assign-GPU.stanford.edu:8080/
[17:51:52] Posted data.
[17:51:52] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:51:52] + Couldn't get work instructions.
[17:51:52] - Attempt #5  to get work failed, and no other work to do.
[17:52:46] ***** Got a SIGTERM signal (2)
[17:52:46] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [October 17 17:54:13 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Users\Barbie\Desktop\GPU\GPU 1
Arguments: -forcegpu ati_r600 -gpu 1 -verbosity 9
[17:54:13] - Ask before connecting: No
[17:54:13] - User name: Grandpa (Team 51394)
[17:54:13] - User ID: 4794FF892EC9B3C3
[17:54:13] - Machine ID: 4
[17:54:13]
[17:54:14] Loaded queue successfully.
[17:54:14] Initialization complete
[17:54:14] - Preparing to get new work unit...
[17:54:14] + Attempting to get work packet
[17:54:14] - Autosending finished units... [October 17 17:54:14 UTC]
[17:54:14] Trying to send all finished work units
[17:54:14] - Will indicate memory of 4087 MB
[17:54:14] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 4, Stepping: 2
[17:54:14] - Connecting to assignment server
[17:54:14] Connecting to http://assign-GPU.stanford.edu:8080/
[17:54:14] Project: 5740 (Run 0, Clone 30, Gen 519)
[17:54:14] + Attempting to send results [October 17 17:54:14 UTC]
[17:54:14] - Reading file work/wuresults_04.dat from core
[17:54:14]   (Read 177009 bytes from disk)
[17:54:14] Connecting to http://171.64.65.102:8080/
[17:54:14] Posted data.
[17:54:14] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:54:14] + Couldn't get work instructions.
[17:54:14] - Attempt #1  to get work failed, and no other work to do.
[17:54:15] - Couldn't send HTTP request to server
[17:54:15] + Could not connect to Work Server (results)
[17:54:15]     (171.64.65.102:8080)
[17:54:15] + Retrying using alternative port
[17:54:15] Connecting to http://171.64.65.102:80/
[17:54:16] - Couldn't send HTTP request to server
[17:54:16] + Could not connect to Work Server (results)
[17:54:16]     (171.64.65.102:80)
[17:54:16] - Error: Could not transmit unit 04 (completed October 17) to work server.
[17:54:16] - 3 failed uploads of this unit.
[17:54:16] + Attempting to send results [October 17 17:54:16 UTC]
[17:54:16] - Reading file work/wuresults_04.dat from core
[17:54:16]   (Read 177009 bytes from disk)
[17:54:16] Connecting to http://171.67.108.17:8080/
[17:54:16]   (Got status 503)
[17:54:16]     (171.67.108.17:8080)
[17:54:16] + Retrying using alternative port
[17:54:16] Connecting to http://171.67.108.17:80/
[17:54:16]     (171.67.108.17:80)
[17:54:16]   Could not transmit unit 04 to Collection server; keeping in queue.
[17:54:16] + Sent 0 of 1 completed units to the server
[17:54:16] - Autosend completed
[17:54:22] + Attempting to get work packet
[17:54:22] - Will indicate memory of 4087 MB
[17:54:22] - Connecting to assignment server
[17:54:22] Connecting to http://assign-GPU.stanford.edu:8080/
[17:54:22] Posted data.
[17:54:22] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:54:22] + Couldn't get work instructions.
[17:54:22] - Attempt #2  to get work failed, and no other work to do.
[17:54:42] + Attempting to get work packet
[17:54:42] - Will indicate memory of 4087 MB
[17:54:42] - Connecting to assignment server
[17:54:42] Connecting to http://assign-GPU.stanford.edu:8080/
[17:54:42] Posted data.
[17:54:42] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:54:42] + Couldn't get work instructions.
[17:54:42] - Attempt #3  to get work failed, and no other work to do.
[17:55:09] + Attempting to get work packet
[17:55:09] - Will indicate memory of 4087 MB
[17:55:09] - Connecting to assignment server
[17:55:09] Connecting to http://assign-GPU.stanford.edu:8080/
[17:55:10] Posted data.
[17:55:10] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:55:10] + Couldn't get work instructions.
[17:55:10] - Attempt #4  to get work failed, and no other work to do.
[17:55:53] + Attempting to get work packet
[17:55:53] - Will indicate memory of 4087 MB
[17:55:53] - Connecting to assignment server
[17:55:53] Connecting to http://assign-GPU.stanford.edu:8080/
[17:55:54] Posted data.
[17:55:54] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:55:54] + Couldn't get work instructions.
[17:55:54] - Attempt #5  to get work failed, and no other work to do.
[18:21:54] Completed 100%
[18:21:54] Successful run
[18:21:54] DynamicWrapper: Finished Work Unit: sleep=10000
[18:22:04] Reserved 153884 bytes for xtc file; Cosm status=0
[18:22:04] Allocated 153884 bytes for xtc file
[18:22:04] - Reading up to 153884 from "work/wudata_08.xtc": Read 153884
[18:22:04] Read 153884 bytes from xtc file; available packet space=786276580
[18:22:04] xtc file hash check passed.
[18:22:04] Reserved 23472 23472 786276580 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[18:22:04] Allocated 23472 bytes for arc file
[18:22:04] - Reading up to 23472 from "work/wudata_08.trr": Read 23472
[18:22:04] Read 23472 bytes from arc file; available packet space=786253108
[18:22:04] trr file hash check passed.
[18:22:04] Allocated 560 bytes for edr file
[18:22:04] Read bedfile
[18:22:04] edr file hash check passed.
[18:22:04] Allocated 0 bytes for logfile
[18:22:04] Could not open/read logfile=<work/wudata_08.log>; Cosm status=-1
[18:22:04] GuardedRun: success in DynamicWrapper
[18:22:04] GuardedRun: done
[18:22:04] Run: GuardedRun completed.
[18:22:09] - Writing 178428 bytes of core data to disk...
[18:22:09] Done: 177916 -> 176578 (compressed to 99.2 percent)
[18:22:09]   ... Done.
[18:22:09] - Shutting down core
[18:22:09]
[18:22:09] Folding@home Core Shutdown: FINISHED_UNIT
[18:22:12] CoreStatus = 64 (100)
[18:22:12] Unit 8 finished with 94 percent of time to deadline remaining.
[18:22:12] Updated performance fraction: 0.853804
[18:22:12] Sending work to server
[18:22:12] Project: 5745 (Run 2, Clone 41, Gen 430)
[18:22:12] + Attempting to send results [October 17 18:22:12 UTC]
[18:22:12] - Reading file work/wuresults_08.dat from core
[18:22:12]   (Read 177090 bytes from disk)
[18:22:12] Connecting to http://171.64.65.102:8080/
[18:22:14] - Couldn't send HTTP request to server
[18:22:14] + Could not connect to Work Server (results)
[18:22:14]     (171.64.65.102:8080)
[18:22:14] + Retrying using alternative port
[18:22:14] Connecting to http://171.64.65.102:80/
[18:22:16] - Couldn't send HTTP request to server
[18:22:16] + Could not connect to Work Server (results)
[18:22:16]     (171.64.65.102:80)
[18:22:16] - Error: Could not transmit unit 08 (completed October 17) to work server.
[18:22:16] - 1 failed uploads of this unit.
[18:22:16]   Keeping unit 08 in queue.
[18:22:16] Trying to send all finished work units
[18:22:16] Project: 5745 (Run 2, Clone 41, Gen 430)
[18:22:16] + Attempting to send results [October 17 18:22:16 UTC]
[18:22:16] - Reading file work/wuresults_08.dat from core
[18:22:16]   (Read 177090 bytes from disk)
[18:22:16] Connecting to http://171.64.65.102:8080/
[18:22:18] - Couldn't send HTTP request to server
[18:22:18] + Could not connect to Work Server (results)
[18:22:18]     (171.64.65.102:8080)
[18:22:18] + Retrying using alternative port
[18:22:18] Connecting to http://171.64.65.102:80/
[18:22:20] - Couldn't send HTTP request to server
[18:22:20] + Could not connect to Work Server (results)
[18:22:20]     (171.64.65.102:80)
[18:22:20] - Error: Could not transmit unit 08 (completed October 17) to work server.
[18:22:20] - 2 failed uploads of this unit.
[18:22:20] + Attempting to send results [October 17 18:22:20 UTC]
[18:22:20] - Reading file work/wuresults_08.dat from core
[18:22:20]   (Read 177090 bytes from disk)
[18:22:20] Connecting to http://171.67.108.17:8080/
[18:22:20]   (Got status 503)
[18:22:20]     (171.67.108.17:8080)
[18:22:20] + Retrying using alternative port
[18:22:20] Connecting to http://171.67.108.17:80/
[18:22:20]     (171.67.108.17:80)
[18:22:20]   Could not transmit unit 08 to Collection server; keeping in queue.
[18:22:20] + Sent 0 of 1 completed units to the server
[18:22:20] - Preparing to get new work unit...
[18:22:20] + Attempting to get work packet
[18:22:20] - Will indicate memory of 4095 MB
[18:22:20] - Connecting to assignment server
[18:22:20] Connecting to http://assign-GPU.stanford.edu:8080/
[18:22:21] Posted data.
[18:22:21] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:22:21] + Couldn't get work instructions.
[18:22:21] - Attempt #1  to get work failed, and no other work to do.
[18:22:36] + Attempting to get work packet
[18:22:36] - Will indicate memory of 4095 MB
[18:22:36] - Connecting to assignment server
[18:22:36] Connecting to http://assign-GPU.stanford.edu:8080/
[18:22:36] Posted data.
[18:22:36] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:22:36] + Couldn't get work instructions.
[18:22:36] - Attempt #2  to get work failed, and no other work to do.
[18:23:01] + Attempting to get work packet
[18:23:01] - Will indicate memory of 4095 MB
[18:23:01] - Connecting to assignment server
[18:23:01] Connecting to http://assign-GPU.stanford.edu:8080/
[18:23:02] Posted data.
[18:23:02] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:23:02] + Couldn't get work instructions.
[18:23:02] - Attempt #3  to get work failed, and no other work to do.
[18:23:34] + Attempting to get work packet
[18:23:34] - Will indicate memory of 4095 MB
[18:23:34] - Connecting to assignment server
[18:23:34] Connecting to http://assign-GPU.stanford.edu:8080/
[18:23:34] Posted data.
[18:23:34] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:23:34] + Couldn't get work instructions.
[18:23:34] - Attempt #4  to get work failed, and no other work to do.
[18:24:25] + Attempting to get work packet
[18:24:25] - Will indicate memory of 4095 MB
[18:24:25] - Connecting to assignment server
[18:24:25] Connecting to http://assign-GPU.stanford.edu:8080/
[18:24:26] Posted data.
[18:24:26] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:24:26] + Couldn't get work instructions.
[18:24:26] - Attempt #5  to get work failed, and no other work to do.
[18:25:58] + Attempting to get work packet
[18:25:58] - Will indicate memory of 4095 MB
[18:25:58] - Connecting to assignment server
[18:25:58] Connecting to http://assign-GPU.stanford.edu:8080/
[18:25:59] Posted data.
[18:25:59] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:25:59] + Couldn't get work instructions.
[18:25:59] - Attempt #6  to get work failed, and no other work to do.
[18:28:40] + Attempting to get work packet
[18:28:40] - Will indicate memory of 4095 MB
[18:28:40] - Connecting to assignment server
[18:28:40] Connecting to http://assign-GPU.stanford.edu:8080/
[18:28:41] Posted data.
[18:28:41] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:28:41] + Couldn't get work instructions.
[18:28:41] - Attempt #7  to get work failed, and no other work to do.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Re: 171.67.108.17:80 / 171.64.65.102:80 / assign-GPU.stanford.ed
I didn't notice it, but my ATI GPU is also down :(
According to my information, this was fixed about 4 hours ago.
I got a WU at 9pm UTC.
Rejecting again :
171.64.65.102 GPU vspg2v2 vvoelz full Reject
Accepting again:
171.64.65.102 GPU vspg2v2 vvoelz full Accepting
Grandpa_01
Well are ther any servers working today. I did not see any anouncement about Stanford working on them today.
[17:36:59] + Attempting to send results [November 1 17:36:59 UTC]
[17:36:59] - Reading file work/wuresults_08.dat from core
[17:36:59]   (Read 178906 bytes from disk)
[17:36:59] Connecting to http://171.64.65.102:8080/
[17:37:00] - Couldn't send HTTP request to server
[17:37:00] + Could not connect to Work Server (results)
[17:37:00]     (171.64.65.102:8080)
[17:37:00] + Retrying using alternative port
[17:37:00] Connecting to http://171.64.65.102:80/
[17:37:01] - Couldn't send HTTP request to server
[17:37:01] + Could not connect to Work Server (results)
[17:37:01]     (171.64.65.102:80)
[17:37:01] - Error: Could not transmit unit 08 (completed November 1) to work server.
[17:37:01] - 1 failed uploads of this unit.
[17:37:01]   Keeping unit 08 in queue.
[17:37:01] Trying to send all finished work units
[17:37:01] Project: 5731 (Run 2, Clone 0, Gen 357)
[17:37:01] + Attempting to send results [November 1 17:37:01 UTC]
[17:37:01] - Reading file work/wuresults_08.dat from core
[17:37:01]   (Read 178906 bytes from disk)
[17:37:01] Connecting to http://171.64.65.102:8080/
[17:37:02] - Couldn't send HTTP request to server
[17:37:02] + Could not connect to Work Server (results)
[17:37:02]     (171.64.65.102:8080)
[17:37:02] + Retrying using alternative port
[17:37:02] Connecting to http://171.64.65.102:80/
[17:37:03] - Couldn't send HTTP request to server
[17:37:03] + Could not connect to Work Server (results)
[17:37:03]     (171.64.65.102:80)
[17:37:03] - Error: Could not transmit unit 08 (completed November 1) to work server.
[17:37:03] - 2 failed uploads of this unit.
[17:37:03] + Attempting to send results [November 1 17:37:03 UTC]
[17:37:03] - Reading file work/wuresults_08.dat from core
[17:37:03]   (Read 178906 bytes from disk)
[17:37:03] Connecting to http://171.67.108.17:8080/
[17:37:03]   (Got status 503)
[17:37:03]     (171.67.108.17:8080)
[17:37:03] + Retrying using alternative port
[17:37:03] Connecting to http://171.67.108.17:80/
[17:37:04] - Couldn't send HTTP request to server
[17:37:04]   (Got status 503)
[17:37:04] + Could not connect to Work Server (results)
[17:37:04]     (171.67.108.17:80)
[17:37:04]   Could not transmit unit 08 to Collection server; keeping in queue.
[17:37:04] + Sent 0 of 1 completed units to the server
[17:37:04] - Preparing to get new work unit...
[17:37:04] + Attempting to get work packet
[17:37:04] - Will indicate memory of 4087 MB
[17:37:04] - Connecting to assignment server
[17:37:04] Connecting to http://assign-GPU.stanford.edu:8080/
[17:37:04] Posted data.
[17:37:04] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:37:04] + Couldn't get work instructions.
[17:37:04] - Attempt #1  to get work failed, and no other work to do.
[17:37:10] + Attempting to get work packet
[17:37:10] - Will indicate memory of 4087 MB
[17:37:10] - Connecting to assignment server
[17:37:10] Connecting to http://assign-GPU.stanford.edu:8080/
[17:37:10] Posted data.
[17:37:10] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:37:10] + Couldn't get work instructions.
[17:37:10] - Attempt #2  to get work failed, and no other work to do.
[17:37:27] + Attempting to get work packet
[17:37:27] - Will indicate memory of 4087 MB
[17:37:27] - Connecting to assignment server
[17:37:27] Connecting to http://assign-GPU.stanford.edu:8080/
[17:37:27] Posted data.
[17:37:27] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:37:27] + Couldn't get work instructions.
[17:37:27] - Attempt #3  to get work failed, and no other work to do.
[17:37:49] + Attempting to get work packet
[17:37:49] - Will indicate memory of 4087 MB
[17:37:49] - Connecting to assignment server
[17:37:49] Connecting to http://assign-GPU.stanford.edu:8080/
[17:37:49] Posted data.
[17:37:49] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:37:49] + Couldn't get work instructions.
[17:37:49] - Attempt #4  to get work failed, and no other work to do.
[17:38:41] + Attempting to get work packet
[17:38:41] - Will indicate memory of 4087 MB
[17:38:41] - Connecting to assignment server
[17:38:41] Connecting to http://assign-GPU.stanford.edu:8080/
[17:38:41] Posted data.
[17:38:41] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:38:41] + Couldn't get work instructions.
[17:38:41] - Attempt #5  to get work failed, and no other work to do.
[17:40:10] + Attempting to get work packet
[17:40:10] - Will indicate memory of 4087 MB
[17:40:10] - Connecting to assignment server
[17:40:10] Connecting to http://assign-GPU.stanford.edu:8080/
[17:40:10] Posted data.
[17:40:10] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:40:10] + Couldn't get work instructions.
[17:40:10] - Attempt #6  to get work failed, and no other work to do.
[17:43:04] + Attempting to get work packet
[17:43:04] - Will indicate memory of 4087 MB
[17:43:04] - Connecting to assignment server
[17:43:04] Connecting to http://assign-GPU.stanford.edu:8080/
[17:43:04] Posted data.
[17:43:04] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[17:43:04] + Couldn't get work instructions.
[17:43:04] - Attempt #7  to get work failed, and no other work to do.
Grandpa_01 wrote:Well are ther any servers working today. I did not see any anouncement about Stanford working on them today.
I've notified the appropriate members of the Pande Group.
Grandpa_01
They are down again
Grandpa_01
171.64.65.102 in reject
Just noticed my ATI cards are not getting any work.
Grandpa_01
Re: 171.64.65.102
Down again hopefully it will come back to life :lol:
Re: 171.64.65.102
Grandpa_01 wrote:Down again hopefully it will come back to life :lol:
I've reported it, but it's late and everybody is probably sleeping off their Thanksgiving dinner.
It appears to have been down since about 18:20 PST and it's now 21:05. I think it will automatically reset itself in another hour or so, even if nobody gets my message. (Otherwise, they'll get it in the morning.)
Grandpa_01
Re: 171.64.65.102
It's running again
davebodger
Hardware configuration: Machine 1: MSI X299 Carbon, i7 7820X @ 4.6GHz all cores, 64Gb DDR4, RTX2080Ti graphics, Win 10 64bit, custom watercooling.
Machine 2: Core i7 980 @ 4.1GHz, 24Gb DDR4, GTX1060 graphics, Win 10 64 bit.
Re: 171.64.65.102
Post by davebodger »
It went into "Reject" again today, between approx 18:00 and 21:30 (GMT).
I was getting "Status 503".
I had 3 GPU clients waiting but it's started serving again now and all my GPUs are back at work, slaving away. :)
DeeGee
Hardware configuration: Asus Crosshair Hero VIII, AMD Ryzen 3950x, 2x8GB 3600MHz DDR4, Radeon VII, Win10
Asus Crosshair Hero VII, Amd Ryzen 3900x, 2x16GB 3200MHz DDR4, GeForce 980 TI, Kubuntu 19.10
Re: 171.64.65.102
Post by DeeGee »
Is this server having issues again?
[15:21:43] + Attempting to send results [December 3 15:21:43 UTC]
[15:21:45] - Couldn't send HTTP request to server
[15:21:45] + Could not connect to Work Server (results)
[15:21:45]     (171.64.65.102:8080)
[15:21:45] + Retrying using alternative port
[15:21:47] - Couldn't send HTTP request to server
[15:21:47] + Could not connect to Work Server (results)
[15:21:47]     (171.64.65.102:80)
[15:21:47] - Error: Could not transmit unit 05 (completed December 3) to work server.
[15:21:47]   Keeping unit 05 in queue.
[15:21:47] Project: 5744 (Run 4, Clone 54, Gen 523)
[15:21:47] - Read packet limit of 540015616... Set to 524286976.
[15:21:47] + Attempting to send results [December 3 15:21:47 UTC]
[15:21:48] - Couldn't send HTTP request to server
[15:21:48] + Could not connect to Work Server (results)
[15:21:48]     (171.64.65.102:8080)
[15:21:48] + Retrying using alternative port
[15:21:50] - Couldn't send HTTP request to server
[15:21:50] + Could not connect to Work Server (results)
[15:21:50]     (171.64.65.102:80)
[15:21:50] - Error: Could not transmit unit 05 (completed December 3) to work server.
[15:21:50] - Read packet limit of 540015616... Set to 524286976.
[15:21:50] + Attempting to send results [December 3 15:21:50 UTC]
[15:21:51] - Couldn't send HTTP request to server
[15:21:51]   (Got status 503)
[15:21:51] + Could not connect to Work Server (results)
[15:21:51]     (171.67.108.17:8080)
[15:21:51] + Retrying using alternative port
[15:21:51]     (171.67.108.17:80)
[15:21:51]   Could not transmit unit 05 to Collection server; keeping in queue.
[15:21:51] - Preparing to get new work unit...
[15:21:51] + Attempting to get work packet
[15:21:51] - Connecting to assignment server
[15:21:52] + No appropriate work server was available; will try again in a bit.
[15:21:52] + Couldn't get work instructions.
[15:21:52] - Attempt #1  to get work failed, and no other work to do.
[15:22:10] + Attempting to get work packet
[15:22:10] - Connecting to assignment server
[15:22:10] + No appropriate work server was available; will try again in a bit.
[15:22:10] + Couldn't get work instructions.
[15:22:10] - Attempt #2  to get work failed, and no other work to do.
[15:22:25] + Attempting to get work packet
[15:22:25] - Connecting to assignment server
[15:22:26] + No appropriate work server was available; will try again in a bit.
[15:22:26] + Couldn't get work instructions.
[15:22:26] - Attempt #3  to get work failed, and no other work to do.
[15:22:49] + Attempting to get work packet
[15:22:49] - Connecting to assignment server
[15:22:50] + No appropriate work server was available; will try again in a bit.
[15:22:50] + Couldn't get work instructions.
[15:22:50] - Attempt #4  to get work failed, and no other work to do.
[15:23:43] + Attempting to get work packet
[15:23:43] - Connecting to assignment server
[15:23:44] + No appropriate work server was available; will try again in a bit.
[15:23:44] + Couldn't get work instructions.
[15:23:44] - Attempt #5  to get work failed, and no other work to do.
[15:25:18] + Attempting to get work packet
[15:25:18] - Connecting to assignment server
[15:25:19] + No appropriate work server was available; will try again in a bit.
[15:25:19] + Couldn't get work instructions.
[15:25:19] - Attempt #6  to get work failed, and no other work to do.
[15:28:13] + Attempting to get work packet
[15:28:13] - Connecting to assignment server
[15:28:14] + No appropriate work server was available; will try again in a bit.
[15:28:14] + Couldn't get work instructions.
[15:28:14] - Attempt #7  to get work failed, and no other work to do.
[15:33:45] + Attempting to get work packet
[15:33:45] - Connecting to assignment server
[15:33:46] + No appropriate work server was available; will try again in a bit.
[15:33:46] + Couldn't get work instructions.
[15:33:46] - Attempt #8  to get work failed, and no other work to do.
[15:44:31] + Attempting to get work packet
[15:44:31] - Connecting to assignment server
[15:44:32] + No appropriate work server was available; will try again in a bit.
[15:44:32] + Couldn't get work instructions.
[15:44:32] - Attempt #9  to get work failed, and no other work to do.
--- Opening Log file [December 3 15:56:16 UTC]
Launch directory: C:\Program Files (x86)\Folding@Home\GPU
Executable: C:\Program Files (x86)\Folding@Home\GPU\Folding@home-Win32-GPU.exe
[15:56:16] - Ask before connecting: No
[15:56:16] - User name: DeeGee (Team 365)
[15:56:16] - User ID: 74C666C72AEF2B65
[15:56:16] - Machine ID: 3
[15:56:16]
[15:56:16] Loaded queue successfully.
[15:56:16] - Preparing to get new work unit...
[15:56:16] + Attempting to get work packet
[15:56:16] - Connecting to assignment server
[15:56:16] Project: 5744 (Run 4, Clone 54, Gen 523)
[15:56:16] - Read packet limit of 540015616... Set to 524286976.
[15:56:16] + Attempting to send results [December 3 15:56:16 UTC]
[15:56:17] + No appropriate work server was available; will try again in a bit.
[15:56:17] + Couldn't get work instructions.
[15:56:17] - Attempt #1  to get work failed, and no other work to do.
[15:56:18] - Couldn't send HTTP request to server
[15:56:18] + Could not connect to Work Server (results)
[15:56:18]     (171.64.65.102:8080)
[15:56:18] + Retrying using alternative port
[15:56:20] - Couldn't send HTTP request to server
[15:56:20] + Could not connect to Work Server (results)
[15:56:20]     (171.64.65.102:80)
[15:56:20] - Error: Could not transmit unit 05 (completed December 3) to work server.
[15:56:20] - Read packet limit of 540015616... Set to 524286976.
[15:56:20] + Attempting to send results [December 3 15:56:20 UTC]
[15:56:20]   (Got status 503)
[15:56:20]     (171.67.108.17:8080)
[15:56:20] + Retrying using alternative port
[15:56:21] - Couldn't send HTTP request to server
[15:56:21]   (Got status 503)
[15:56:21] + Could not connect to Work Server (results)
[15:56:21]     (171.67.108.17:80)
[15:56:21]   Could not transmit unit 05 to Collection server; keeping in queue.
[15:56:24] + Attempting to get work packet
[15:56:24] - Connecting to assignment server
[15:56:25] + No appropriate work server was available; will try again in a bit.
[15:56:25] + Couldn't get work instructions.
[15:56:25] - Attempt #2  to get work failed, and no other work to do.
[15:56:40] + Attempting to get work packet
[15:56:40] - Connecting to assignment server
[15:56:41] + No appropriate work server was available; will try again in a bit.
[15:56:41] + Couldn't get work instructions.
[15:56:41] - Attempt #3  to get work failed, and no other work to do.
[15:57:14] + Attempting to get work packet
[15:57:14] - Connecting to assignment server
[15:57:15] + No appropriate work server was available; will try again in a bit.
[15:57:15] + Couldn't get work instructions.
[15:57:15] - Attempt #4  to get work failed, and no other work to do.
[15:58:00] + Attempting to get work packet
[15:58:00] - Connecting to assignment server
[15:58:01] + No appropriate work server was available; will try again in a bit.
[15:58:01] + Couldn't get work instructions.
[15:58:01] - Attempt #5  to get work failed, and no other work to do.
[15:59:28] + Attempting to get work packet
[15:59:28] - Connecting to assignment server
[15:59:29] + No appropriate work server was available; will try again in a bit.
[15:59:29] + Couldn't get work instructions.
[15:59:29] - Attempt #6  to get work failed, and no other work to do.
[edit] Ah, the status page shows it's rejecting connections.
