128.143.48.226 - Can't connect
Tobit
Post by Tobit »
Server status page is showing Full operation but state is currently in Reject mode.
[12:59:05] Project: 3861 (Run 199, Clone 12, Gen 19)
[12:59:05] + Attempting to send results [October 15 12:59:05 UTC]
[12:59:06] - Couldn't send HTTP request to server
[12:59:06] + Could not connect to Work Server (results)
[12:59:06]     (128.143.48.226:8080)
[12:59:06] + Retrying using alternative port
[12:59:07] - Couldn't send HTTP request to server
[12:59:07] + Could not connect to Work Server (results)
[12:59:07]     (128.143.48.226:80)
[12:59:07] - Error: Could not transmit unit 01 (completed October 15) to work server.
[12:59:07] + Attempting to send results [October 15 12:59:07 UTC]
[12:59:08] - Server does not have record of this unit. Will try again later.
[12:59:08]   Could not transmit unit 01 to Collection server; keeping in queue.
[12:59:08] - Preparing to get new work unit...
Tobit
Re: 128.143.48.226 - Can't connect
Post by Tobit »
This server still in Reject mode. However, looking at the log, it switched to Accepting mode for about 50 to 60 minutes around Noon time PDT and, unfortunately, my client missed this brief window. It's been in Reject since roughly 0500 otherwise.
Tobit
Post by Tobit »
Appears to be resolved, results finally sent.
jwwPhotos
Post by jwwPhotos »
I am getting failures in trying to transmit to this one.
[17:53:25] + Attempting to send results [October 17 17:53:25 UTC]
[17:53:25] - Reading file work/wuresults_02.dat from core
[17:53:25]   (Read 1104801 bytes from disk)
[17:53:25] Connecting to http://128.143.48.226:8080/
[17:53:25] - Couldn't send HTTP request to server
[17:53:25] + Could not connect to Work Server (results)
[17:53:25]     (128.143.48.226:8080)
[17:53:25] + Retrying using alternative port
[17:53:25] Connecting to http://128.143.48.226:80/
[17:53:25]     (128.143.48.226:80)
[17:53:25] - Error: Could not transmit unit 02 (completed October 17) to work server.
[17:53:25] - 5 failed uploads of this unit.
[17:53:25] Connecting to http://128.143.48.227:8080/
[17:53:25]     (128.143.48.227:8080)
[17:53:25] Connecting to http://128.143.48.227:80/
[17:53:25]     (128.143.48.227:80)
[17:53:25]   Could not transmit unit 02 to Collection server; keeping in queue.
[17:53:25] Project: 1751 (Run 2, Clone 55, Gen 7)
jwwPhotos
Post by jwwPhotos »
Sorry for the double post, but I just now realized I have two queue's failing to connect to this server. Here is the log contents of the other WU. This one has had 35 failures.
[17:53:26] + Attempting to send results [October 17 17:53:26 UTC]
[17:53:26] - Reading file work/wuresults_08.dat from core
[17:53:26]   (Read 2468469 bytes from disk)
[17:53:26] Connecting to http://128.143.48.226:8080/
[17:53:26] - Couldn't send HTTP request to server
[17:53:26] + Could not connect to Work Server (results)
[17:53:26]     (128.143.48.226:8080)
[17:53:26] + Retrying using alternative port
[17:53:26] Connecting to http://128.143.48.226:80/
[17:53:26]     (128.143.48.226:80)
[17:53:26] - Error: Could not transmit unit 08 (completed October 12) to work server.
[17:53:26] - 35 failed uploads of this unit.
[17:53:26] Connecting to http://128.143.48.227:8080/
[17:53:26]     (128.143.48.227:8080)
[17:53:26] Connecting to http://128.143.48.227:80/
[17:53:26]     (128.143.48.227:80)
[17:53:26]   Could not transmit unit 08 to Collection server; keeping in queue.
I am able to open both http://128.143.48.226 and http://128.143.48.226:8080/ from here. The server status page shows that there was a problem prior to Fri Oct 16 18:15:10 PDT 2009 (which works out to be Sat Oct 17 01:15:10 UTC) so I can't explain your problem. The server seems to have been fine for about 23 hours now. Are you still experiencing the problem? Have you restarted the client and/or rebooted?
jwwPhotos
Post by jwwPhotos »
Yes... rebooted and restarted client. Not sure why it couldn't transmit when you replied, but is still not working and currently the server shows Reject on the connect column.
128.143.48.226 classic fold1 michael.shirts full Reject
Apparently fixed :)
128.143.48.226 classic fold1 michael.shirts full Accepting
jwwPhotos
Post by jwwPhotos »
I still cannot connect to http://128.143.48.226 via the cpu client version 6.23 (-verbosity 9 included as well as Do Not Lock to Specfic cores as I have a quad Intel chip)
Per the Do this First - I CAN connect to the above via my browser and recieve the OK
I CAN ping to this server via IPconfig
I HAVE tried this with my firewall disabled
I HAVE rebooted and repeated above steps
I HAVE restarted the client and repeated the above steps
I HAVE succesfully sent other WU's back to other servers
I HAVE tried going direct to my DSL modem and not using my router and get the same exact results.
My router is a DLink DIR 655.
I see NO issues in the router log
I find NO errors in my system log
I DO find errors transmitting in the Folding client which I have enclosed below.
[01:51:48] + Attempting to send results [October 22 01:51:48 UTC]
[01:51:48] - Reading file work/wuresults_02.dat from core
[01:51:48]   (Read 1104801 bytes from disk)
[01:51:48] Connecting to http://128.143.48.226:8080/
[01:51:48] - Couldn't send HTTP request to server
[01:51:48] + Could not connect to Work Server (results)
[01:51:48]     (128.143.48.226:8080)
[01:51:48] + Retrying using alternative port
[01:51:48] Connecting to http://128.143.48.226:80/
[01:51:48]     (128.143.48.226:80)
[01:51:48] - Error: Could not transmit unit 02 (completed October 17) to work server.
[01:51:48] - 35 failed uploads of this unit.
