Project: 2671 (Run 52, Clone 78, Gen 109) system exploding
tear
Hardware configuration: None
Post by tear »
Bonds rotated >90 degrees warnings/1-4 interactions/WMCNBS ending in segfault.
Haven't had a chance to reproduce as I don't take periodic backups on this machine
EDIT: ok, I could do that if I undeleted relevant queue entry (too lazy to do that just yet)
Log excerpt follows (full log available upon request).
[05:06:50] Completed 175000 out of 250000 steps  (70%)
[05:14:42] Completed 177500 out of 250000 steps  (71%)
[05:22:34] Completed 180000 out of 250000 steps  (72%)
[05:30:27] Completed 182500 out of 250000 steps  (73%)
Step 27432900, time 54865.8 (ps)  LINCS WARNING
relative constraint deviation after LINCS:
rms 0.360012, max 18.521997 (between atoms 7103 and 7104)
bonds that rotated more than 90 degrees:
 atom 1 atom 2  angle  previous, current, constraint length
   7100   7102   90.0    0.1090   1.9903      0.1090
Warning: 1-4 interaction between 7102 and 7104 at distance 3.926 which is larger than the 1-4 table size 2.200 nm
These are ignored for the rest of the simulation
This usually means your system is exploding,
if not, you should increase table-extension in your mdp file
or with user tables increase the table size
Step 27432901, time 54865.8 (ps)  LINCS WARNING
rms 0.036675, max 2.022461 (between atoms 22784 and 22785)
  22784  22785   90.0    0.1080   0.3264      0.1080
rms 4409648120517.936523, max 291538319966208.000000 (between atoms 7100 and 7102)
  22232  22233   90.0    0.1090   1.8879      0.1090
  22239  22240   90.2    0.1090 2274.1292      0.1090
  22239  22241   90.1    0.1090 2566.5967      0.1090
  22239  22242   90.0    0.1090 23362.0273      0.1090
  22289  22290   90.0    0.1090   4.8147      0.1090
  22292  22294   90.0    0.1090 1389668736.0000      0.1090
  22295  22296   90.0    0.1090   6.3375      0.1090
  22298  22299   90.0    0.1010 48893708.0000      0.1010
   7029   7030   90.0    0.1090 147.3939      0.1090
   7031   7032   90.0    0.1090   1.8789      0.1090
   7031   7033   90.0    0.1090   0.6695      0.1090
   7100   7101   90.0    0.1158 4885670526976.0000      0.1090
   7100   7102   90.0    1.9903 31777676591104.0000      0.1090
   7103   7105   90.0    0.1007 1009561763840.0000      0.1010
   7103   7106   90.0    0.0981 806190579712.0000      0.1010
   7250   7251   90.0    0.0960 49772952.0000      0.0960
   7081   7084   90.0    0.1090 52815224832.0000      0.1090
   7055   7057   90.0    0.1090 4303412.5000      0.1090
   7065   7066   90.0    0.1090 22171224.0000      0.1090
   7133   7135   90.0    0.1090   0.1205      0.1090
   7202   7203   90.0    0.1010 29740.4414      0.1010
   7204   7205   90.0    0.1090 1272635392.0000      0.1090
   7239   7240   90.0    0.1090   2.2167      0.1090
   7241   7243   90.0    0.1090   4.7556      0.1090
   7245   7246   90.0    0.1080 11248352.0000      0.1080
   7237   7238   90.0    0.1010 208.3328      0.1010
t = 54865.805 ps: Water molecule starting at atom 113161 can not be settled.
Check for bad contacts and/or reduce the timestep.
[0]0:Return code = 0, signaled with Segmentation fault
[0]1:Return code = 0, signaled with Segmentation fault
[0]2:Return code = 0, signaled with Quit
[0]3:Return code = 0, signaled with Quit
[05:31:47] CoreStatus = 0 (0)
tear
One man's ceiling is another man's floor.
Re: Project: 2671 (Run 52, Clone 78, Gen 109) system exploding
That was the huge explosion I heard coming from so far away ? :lol:
tear
Post by tear »
:) That's the one!
