[04:18:34] - Digital signature verified
[04:18:34]
[04:18:34] Project: 5747 (Run 1, Clone 37, Gen 457)
[04:18:34]
[04:18:34] Assembly optimizations on if available.
[04:18:34] Entering M.D.
[04:18:40] Tpr hash work/wudata_01.tpr: 3712008942 1611952753 2027068883 2900834826 2861348419
[04:18:41] Working on Protein
[04:18:41] Client config found, loading data.
[04:18:41] Starting GUI Server
[04:18:50] mdrun_gpu returned
[04:18:50] Nonzero force sum on GPU
[04:18:50]
[04:18:50] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:18:54] CoreStatus = 7A (122)
[04:18:54] Sending work to server
[04:18:54] Project: 5747 (Run 1, Clone 37, Gen 457)
[04:18:54] - Error: Could not get length of results file work/wuresults_01.dat
[04:18:54] - Error: Could not read unit 01 file. Removing from queue.
[04:18:54] EUE limit exceeded. Pausing 24 hours.
[06:51:06] - Autosending finished units... [October 5 06:51:06 UTC]
[06:51:06] Trying to send all finished work units
[06:51:06] + No unsent completed units remaining.
[06:51:06] - Autosend completed
[12:51:05] - Autosending finished units... [October 5 12:51:05 UTC]
[12:51:05] Trying to send all finished work units
[12:51:05] + No unsent completed units remaining.
[12:51:05] - Autosend completed
All clients stopped due to Stanford's upcoming September 2011 decision
m3tr0
- Hardware configuration: Phenom 9850BE @ 2,8GHz 1,280V | IMC/L3-Cache @ 2,2GHz 1,328V | 2x1GB DDR2-800 @ 5-5-5-18-22-2T Unganged | HD4850 512MB | Asus M3A32-MVP Deluxe BIOS v1406 | Intel X25-M G2 80GB | WD Caviar Green 1TB | Corsair HX620W | Windows 7 (b7100, 32-bit) | Cat 9.7
Re: Project: 5747 (Run 1, Clone 37, Gen 457)
Same here:
[07:53:58] *------------------------------*
[07:53:58] Folding@Home GPU Core - Beta
[07:53:58] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[07:53:58]
[07:53:58] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:53:58] Build host: amoeba
[07:53:58] Board Type: AMD
[07:53:58] Core :
[07:53:58] Preparing to commence simulation
[07:53:58] - Assembly optimizations manually forced on.
[07:53:58] - Not checking prior termination.
[07:53:58] - Expanded 68565 -> 357580 (decompressed 521.5 percent)
[07:53:58] Called DecompressByteArray: compressed_data_size=68565 data_size=357580, decompressed_data_size=357580 diff=0
[07:53:58] - Digital signature verified
[07:53:58]
[07:53:58] Project: 5747 (Run 1, Clone 37, Gen 457)
[07:53:58]
[07:53:58] Assembly optimizations on if available.
[07:53:58] Entering M.D.
[07:54:04] Tpr hash work/wudata_01.tpr: 3712008942 1611952753 2027068883 2900834826 2861348419
[07:54:05] Working on Protein
[07:54:07] Client config found, loading data.
[07:54:07] Starting GUI Server
[07:54:17] mdrun_gpu returned
[07:54:17] Nonzero force sum on GPU
[07:54:17]
[07:54:17] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:54:21] CoreStatus = 7A (122)
[07:54:21] Sending work to server
[07:54:21] Project: 5747 (Run 1, Clone 37, Gen 457)
[07:54:21] - Read packet limit of 540015616... Set to 524286976.
[07:54:21] - Error: Could not get length of results file work/wuresults_01.dat
[07:54:21] - Error: Could not read unit 01 file. Removing from queue.
[07:54:21] - Preparing to get new work unit...
[07:54:21] + Attempting to get work packet
[07:54:21] - Connecting to assignment server
[07:54:21] - Successful: assigned to (171.64.65.102).
[07:54:21] + News From Folding@Home: Welcome to Folding@Home
[07:54:22] Loaded queue successfully.
[07:54:24] + Closed connections
[07:53:58]
[07:53:58] Core :
[07:53:58]
[07:53:58]
[07:54:17]
Problem with the same WU over here.
- Hardware configuration: 9950x, 9950x3D, 5950x, 5800x3D
7900xtx, RX9070, Radeon 7, 5700xt, 6900xt, Intel B580 - Location: London
same problem with 4745 on 100% stable system with hd5870.
vvoelz
- Pande Group Member
I've killed the offending WU, so it won't be assigned it the future. Thanks for reporting this one. --Vince
