Project: 5740 (Run 2, Clone 60, Gen 446)
Leinad112
Post by Leinad112 »
I think it is a WU Issue...
See:
[12:19:33] Completed 92%
[12:21:24] Completed 93%
[12:23:15] Completed 94%
[12:25:07] Completed 95%
[12:26:59] Completed 96%
[12:29:04] Completed 97%
[12:30:57] Completed 98%
[12:32:49] Completed 99%
[12:34:41] Completed 100%
[12:34:41] Successful run
[12:34:41] DynamicWrapper: Finished Work Unit: sleep=10000
[12:34:51] Reserved 154916 bytes for xtc file; Cosm status=0
[12:34:51] Allocated 154916 bytes for xtc file
[12:34:51] - Reading up to 154916 from "work/wudata_08.xtc": Read 154916
[12:34:51] Read 154916 bytes from xtc file; available packet space=786275548
[12:34:51] xtc file hash check passed.
[12:34:51] Reserved 23472 23472 786275548 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[12:34:51] Allocated 23472 bytes for arc file
[12:34:51] - Reading up to 23472 from "work/wudata_08.trr": Read 23472
[12:34:51] Read 23472 bytes from arc file; available packet space=786252076
[12:34:51] trr file hash check passed.
[12:34:51] Allocated 560 bytes for edr file
[12:34:51] Read bedfile
[12:34:51] edr file hash check passed.
[12:34:51] Allocated 0 bytes for logfile
[12:34:51] Could not open/read logfile=<work/wudata_08.log>; Cosm status=-1
[12:34:51] GuardedRun: success in DynamicWrapper
[12:34:51] GuardedRun: done
[12:34:51] Run: GuardedRun completed.
[12:34:55] - Writing 179460 bytes of core data to disk...
[12:34:55] Done: 178948 -> 177590 (compressed to 99.2 percent)
[12:34:55]   ... Done.
[12:34:56] - Shutting down core
[12:34:56]
[12:34:56] Folding@home Core Shutdown: FINISHED_UNIT
[12:35:00] CoreStatus = 64 (100)
[12:35:00] Sending work to server
[12:35:00] Project: 5747 (Run 0, Clone 15, Gen 362)
[12:35:00] - Read packet limit of 540015616... Set to 524286976.
[12:35:00] + Attempting to send results [October 5 12:35:00 UTC]
[12:35:03] + Results successfully sent
[12:35:03] Thank you for your contribution to Folding@Home.
[12:35:03] + Number of Units Completed: 99
[12:35:07] - Preparing to get new work unit...
[12:35:07] + Attempting to get work packet
[12:35:07] - Connecting to assignment server
[12:35:08] - Successful: assigned to (171.64.65.102).
[12:35:08] + News From Folding@Home: Welcome to Folding@Home
[12:35:09] Loaded queue successfully.
[12:35:12] + Closed connections
[12:35:12]
[12:35:12] + Processing work unit
[12:35:12] Core required: FahCore_11.exe
[12:35:12] Core found.
[12:35:12] Working on queue slot 09 [October 5 12:35:12 UTC]
[12:35:12] + Working ...
[12:35:12]
[12:35:12] *------------------------------*
[12:35:12] Folding@Home GPU Core - Beta
[12:35:12] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:35:12]
[12:35:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:35:12] Build host: amoeba
[12:35:12] Board Type: AMD
[12:35:12] Core      :
[12:35:12] Preparing to commence simulation
[12:35:12] - Looking at optimizations...
[12:35:12] - Created dyn
[12:35:12] - Files status OK
[12:35:12] - Expanded 70070 -> 360060 (decompressed 513.8 percent)
[12:35:12] Called DecompressByteArray: compressed_data_size=70070 data_size=360060, decompressed_data_size=360060 diff=0
[12:35:12] - Digital signature verified
[12:35:12]
[12:35:12] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:35:12]
[12:35:12] Assembly optimizations on if available.
[12:35:12] Entering M.D.
[12:35:18] Tpr hash work/wudata_09.tpr:  3641940534 1975133865 63221173 1899460497 1444717401
[12:35:18] Working on Protein
[12:35:18] Client config found, loading data.
[12:35:18] Starting GUI Server
[12:35:21] mdrun_gpu returned
[12:35:21] Nonzero force sum on GPU
[12:35:21]
[12:35:21] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:35:24] CoreStatus = 7A (122)
[12:35:24] Sending work to server
[12:35:24] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:35:24] - Read packet limit of 540015616... Set to 524286976.
[12:35:24] - Error: Could not get length of results file work/wuresults_09.dat
[12:35:24] - Error: Could not read unit 09 file. Removing from queue.
[12:35:24] - Preparing to get new work unit...
[12:35:24] + Attempting to get work packet
[12:35:24] - Connecting to assignment server
[12:35:25] - Successful: assigned to (171.64.65.102).
[12:35:25] + News From Folding@Home: Welcome to Folding@Home
[12:35:25] Loaded queue successfully.
[12:35:28] + Closed connections
[12:35:33]
[12:35:33] + Processing work unit
[12:35:33] Core required: FahCore_11.exe
[12:35:33] Core found.
[12:35:33] Working on queue slot 00 [October 5 12:35:33 UTC]
[12:35:33] + Working ...
[12:35:33]
[12:35:33] *------------------------------*
[12:35:33] Folding@Home GPU Core - Beta
[12:35:33] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:35:33]
[12:35:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:35:33] Build host: amoeba
[12:35:33] Board Type: AMD
[12:35:33] Core      :
[12:35:33] Preparing to commence simulation
[12:35:33] - Looking at optimizations...
[12:35:33] - Created dyn
[12:35:33] - Files status OK
[12:35:33] - Expanded 70070 -> 360060 (decompressed 513.8 percent)
[12:35:33] Called DecompressByteArray: compressed_data_size=70070 data_size=360060, decompressed_data_size=360060 diff=0
[12:35:33] - Digital signature verified
[12:35:33]
[12:35:33] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:35:33]
[12:35:33] Assembly optimizations on if available.
[12:35:33] Entering M.D.
[12:35:39] Tpr hash work/wudata_00.tpr:  3641940534 1975133865 63221173 1899460497 1444717401
[12:35:39] Working on Protein
[12:35:39] Client config found, loading data.
[12:35:39] Starting GUI Server
[12:35:42] mdrun_gpu returned
[12:35:42] Nonzero force sum on GPU
[12:35:42]
[12:35:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:35:45] CoreStatus = 7A (122)
[12:35:45] Sending work to server
[12:35:45] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:35:45] - Read packet limit of 540015616... Set to 524286976.
[12:35:45] - Error: Could not get length of results file work/wuresults_00.dat
[12:35:45] - Error: Could not read unit 00 file. Removing from queue.
[12:35:45] - Preparing to get new work unit...
[12:35:45] + Attempting to get work packet
[12:35:45] - Connecting to assignment server
[12:35:46] - Successful: assigned to (171.64.65.102).
[12:35:46] + News From Folding@Home: Welcome to Folding@Home
[12:35:46] Loaded queue successfully.
[12:35:48] + Closed connections
[12:35:53]
[12:35:53] + Processing work unit
[12:35:53] Core required: FahCore_11.exe
[12:35:53] Core found.
[12:35:53] Working on queue slot 01 [October 5 12:35:53 UTC]
[12:35:53] + Working ...
[12:35:54]
[12:35:54] *------------------------------*
[12:35:54] Folding@Home GPU Core - Beta
[12:35:54] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:35:54]
[12:35:54] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:35:54] Build host: amoeba
[12:35:54] Board Type: AMD
[12:35:54] Core      :
[12:35:54] Preparing to commence simulation
[12:35:54] - Looking at optimizations...
[12:35:54] - Created dyn
[12:35:54] - Files status OK
[12:35:54] - Expanded 70070 -> 360060 (decompressed 513.8 percent)
[12:35:54] Called DecompressByteArray: compressed_data_size=70070 data_size=360060, decompressed_data_size=360060 diff=0
[12:35:54] - Digital signature verified
[12:35:54]
[12:35:54] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:35:54]
[12:35:54] Assembly optimizations on if available.
[12:35:54] Entering M.D.
[12:36:00] Tpr hash work/wudata_01.tpr:  3641940534 1975133865 63221173 1899460497 1444717401
[12:36:00] Working on Protein
[12:36:00] Client config found, loading data.
[12:36:00] Starting GUI Server
[12:36:03] mdrun_gpu returned
[12:36:03] Nonzero force sum on GPU
[12:36:03]
[12:36:03] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:36:06] CoreStatus = 7A (122)
[12:36:06] Sending work to server
[12:36:06] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:36:06] - Read packet limit of 540015616... Set to 524286976.
[12:36:06] - Error: Could not get length of results file work/wuresults_01.dat
[12:36:06] - Error: Could not read unit 01 file. Removing from queue.
[12:36:06] - Preparing to get new work unit...
[12:36:06] + Attempting to get work packet
[12:36:06] - Connecting to assignment server
[12:36:07] - Successful: assigned to (171.64.65.102).
[12:36:07] + News From Folding@Home: Welcome to Folding@Home
[12:36:07] Loaded queue successfully.
[12:36:10] + Closed connections
[12:36:15]
[12:36:15] + Processing work unit
[12:36:15] Core required: FahCore_11.exe
[12:36:15] Core found.
[12:36:15] Working on queue slot 02 [October 5 12:36:15 UTC]
[12:36:15] + Working ...
[12:36:15]
[12:36:15] *------------------------------*
[12:36:15] Folding@Home GPU Core - Beta
[12:36:15] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:36:15]
[12:36:15] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:36:15] Build host: amoeba
[12:36:15] Board Type: AMD
[12:36:15] Core      :
[12:36:15] Preparing to commence simulation
[12:36:15] - Looking at optimizations...
[12:36:15] - Created dyn
[12:36:15] - Files status OK
[12:36:15] - Expanded 70070 -> 360060 (decompressed 513.8 percent)
[12:36:15] Called DecompressByteArray: compressed_data_size=70070 data_size=360060, decompressed_data_size=360060 diff=0
[12:36:15] - Digital signature verified
[12:36:15]
[12:36:15] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:36:15]
[12:36:15] Assembly optimizations on if available.
[12:36:15] Entering M.D.
[12:36:21] Tpr hash work/wudata_02.tpr:  3641940534 1975133865 63221173 1899460497 1444717401
[12:36:21] Working on Protein
[12:36:21] Client config found, loading data.
[12:36:21] Starting GUI Server
[12:36:24] mdrun_gpu returned
[12:36:24] Nonzero force sum on GPU
[12:36:24]
[12:36:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:36:27] CoreStatus = 7A (122)
[12:36:27] Sending work to server
[12:36:27] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:36:27] - Read packet limit of 540015616... Set to 524286976.
[12:36:27] - Error: Could not get length of results file work/wuresults_02.dat
[12:36:27] - Error: Could not read unit 02 file. Removing from queue.
[12:36:27] - Preparing to get new work unit...
[12:36:27] + Attempting to get work packet
[12:36:27] - Connecting to assignment server
[12:36:28] - Successful: assigned to (171.64.65.102).
[12:36:28] + News From Folding@Home: Welcome to Folding@Home
[12:36:29] Loaded queue successfully.
[12:36:31] + Closed connections
[12:36:36]
[12:36:36] + Processing work unit
[12:36:36] Core required: FahCore_11.exe
[12:36:36] Core found.
[12:36:36] Working on queue slot 03 [October 5 12:36:36 UTC]
[12:36:36] + Working ...
[12:36:37]
[12:36:37] *------------------------------*
[12:36:37] Folding@Home GPU Core - Beta
[12:36:37] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:36:37]
[12:36:37] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:36:37] Build host: amoeba
[12:36:37] Board Type: AMD
[12:36:37] Core      :
[12:36:37] Preparing to commence simulation
[12:36:37] - Looking at optimizations...
[12:36:37] - Created dyn
[12:36:37] - Files status OK
[12:36:37] - Expanded 70070 -> 360060 (decompressed 513.8 percent)
[12:36:37] Called DecompressByteArray: compressed_data_size=70070 data_size=360060, decompressed_data_size=360060 diff=0
[12:36:37] - Digital signature verified
[12:36:37]
[12:36:37] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:36:37]
[12:36:37] Assembly optimizations on if available.
[12:36:37] Entering M.D.
[12:36:43] Tpr hash work/wudata_03.tpr:  3641940534 1975133865 63221173 1899460497 1444717401
[12:36:43] Working on Protein
[12:36:44] Client config found, loading data.
[12:36:44] Starting GUI Server
[12:36:46] mdrun_gpu returned
[12:36:46] Nonzero force sum on GPU
[12:36:46]
[12:36:46] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:36:49] CoreStatus = 7A (122)
[12:36:49] Sending work to server
[12:36:49] Project: 5740 (Run 2, Clone 60, Gen 446)
[12:36:49] - Read packet limit of 540015616... Set to 524286976.
[12:36:49] + Attempting to send results [October 5 12:36:49 UTC]
[12:36:49] - Error: Could not read results file work/wuresults_03.dat from disk
[12:36:49] - Error: Could not read unit 03 file. Removing from queue.
[12:36:49] EUE limit exceeded. Pausing 24 hours.
mathwhiz
Re: Project: 5740 (Run 2, Clone 60, Gen 446)
Post by mathwhiz »
I've had this workunit have the same problems for me several times as well.
mathwhiz
Post by mathwhiz »
Just got this work unit again causing the same problems.
vvoelz
Pande Group Member
Post by vvoelz »
I've stopped this WU from ever being assigned again. Thanks for the notification. --VInce
