can you fix my 1 new message problem
can you fix my 1 new message problem it says i have 1 new message but i do not
Re: can you fix my 1 new message problem
It might be one of the spam PMs I removed ... or the sender deleted his message before you were able to read it.
Or your PM box is full, and you need to remove some message to receive the queued one.
uncle fuzzy
My inbox is not full, and I also have the annoying "1 new message" message that I can't get rid of.
I think the question is, how do we get rid of the notification?
Could you tell me who the sender was ? (I hope you kept the notification email
P5-133XL
Machine #2:
Machine 3:
I have the same thing that I'd like fixed: Missing message I had made the assumption that it could not be fixed.
can you just reset all my msgs to been read please must be an php gui to do it , if deleting PM is the same as Deleting Post in full threads its likely that its been hidden Not deleted but i can see that it has not been read yet as it still shows that
uncle fuzzy
I was set for no email notification. I've changed it, but that's no help for telling you who the sender was.
uncle fuzzy
P5-133XL
Machine #2:
Machine 3:
