Hi there I have run into a strange problem with FahMom.
I used to have it start along with all of the clients when I logged in. For some unknown reason it just stopped loading onto the desktop when Vista started? When you run task manager it’s there using up to 50% of the available processing power.
As there is no software installing to do with this little application, i’ve down loaded a new version and run into the same problem?
Any ideas
Ash
FahMom issues
Re: FahMom issues
Post in the fahmon thread. The developer subscribes to that thread, and will answer quicker.
Zagen30
Re: FahMom issues
Occasionally FahMon will start taking up loads of CPU time for me as well. My solution is to uninstall and reinstall FahMon, and it usually fixes the issue.
