Server 171.67.108.11 can not be connected
ascetic
Post by ascetic »
So many results had been jammed. Log as followed:
[09:56:00] + Attempting to send results [September 25 09:56:00 UTC]
[09:56:05] + Could not connect to Work Server (results)
[09:56:05] (171.67.108.11:8080)
[09:56:05] + Retrying using alternative port
[09:56:07] - Couldn't send HTTP request to server
[09:56:07] + Could not connect to Work Server (results)
[09:56:07] (171.67.108.11:80)
[09:56:07] - Error: Could not transmit unit 01 (completed September 24) to work server.
[09:56:07] - Read packet limit of 540015616... Set to 524286976.
[09:56:07] + Attempting to send results [September 25 09:56:07 UTC]
[09:56:07] (Got status 503)
[09:56:07] (171.67.108.25:8080)
[09:56:07] + Retrying using alternative port
[09:56:08] - Couldn't send HTTP request to server
[09:56:08] (Got status 503)
[09:56:08] + Could not connect to Work Server (results)
[09:56:08] (171.67.108.25:80)
[09:56:08] Could not transmit unit 01 to Collection server; keeping in queue.
[09:56:08] Project: 5768 (Run 11, Clone 61, Gen 940)
[09:56:08] - Read packet limit of 540015616... Set to 524286976.
[09:56:08] + Attempting to send results [September 25 09:56:08 UTC]
[09:56:13] + Could not connect to Work Server (results)
[09:56:13] (171.67.108.11:8080)
[09:56:13] + Retrying using alternative port
[09:56:15] - Couldn't send HTTP request to server
[09:56:15] + Could not connect to Work Server (results)
[09:56:15] (171.67.108.11:80)
[09:56:15] - Error: Could not transmit unit 04 (completed September 24) to work server.
[09:56:15] - Read packet limit of 540015616... Set to 524286976.
bollix47
Re: Server 171.67.108.11 can not be connected
Post by bollix47 »
Is this the first time you've had this problem? Do your uploads normally work fine?
A number of Servers are marked as "DOWN" at Stanford. Although .11 is not one of them your problem may be related. This should be sorted once someone there notices but it's still pretty early on the west coast so I think until the situation is rectified patience is a virtue.
You can check the Server Status link at the top of this page to see when the "DOWN" servers are back in action.
If you still can't upload after a few tries once the servers are restarted post back and someone will assist is finding out why you are having a problem.
p.s. Welcome to the forum.
ascetic
Post by ascetic »
bollix47 wrote:Is this the first time you've had this problem? Do your uploads normally work fine?
2 results just be replied to 171.64.65.106 today. I think the client enviroment setting should be fine.
bollix47
Post by bollix47 »
Okay, that's good to hear. I suspect there's a problem with their .108 subnet as I too have a few WUs that can't upload.
Restarting the client may get you a WU from another server.
Otherwise, all that we can do is wait patiently. :ewink:
