Project: 5772 (Run 4, Clone 225, Gen 404)
heikosch
Hardware configuration: i7-3930K@4.1GHz
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz
Post by heikosch »
Hi,
for Project: 5772 (Run 4, Clone 225, Gen 404) I got "SHAKE violations on GPU".
Neverever I had a problem with WUs of project 5772.
Bad WU?
--- Opening Log file [September 18 21:09:46 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Users\Heiko\AppData\Roaming\Folding@home-gpu
Arguments: -advmethods -verbosity 9
[21:09:46] - Ask before connecting: No
[21:09:46] - User name: heikosch (Team 157354)
[21:09:46] - User ID: 635D16606EBE1EFA
[21:09:46] - Machine ID: 6
[21:09:46]
[21:09:46] Loaded queue successfully.
[21:09:46] Initialization complete
[21:09:46] - Preparing to get new work unit...
[21:09:46] - Autosending finished units... [September 18 21:09:46 UTC]
[21:09:46] + Attempting to get work packet
[21:09:46] Trying to send all finished work units
[21:09:46] + No unsent completed units remaining.
[21:09:46] - Autosend completed
[21:09:46] - Will indicate memory of 4093 MB
[21:09:46] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 7
[21:09:46] - Connecting to assignment server
[21:09:46] Connecting to http://assign-GPU.stanford.edu:8080/
[21:09:47] Posted data.
[21:09:47] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[21:09:47] + News From Folding@Home: Welcome to Folding@Home
[21:09:47] Loaded queue successfully.
[21:09:47] Connecting to http://171.67.108.11:8080/
[21:09:48] Posted data.
[21:09:48] Initial: 0000; - Receiving payload (expected size: 45965)
[21:09:49] - Downloaded at ~44 kB/s
[21:09:49] - Averaged speed for that direction ~41 kB/s
[21:09:49] + Received work.
[21:09:49] + Closed connections
[21:09:49]
[21:09:49] + Processing work unit
[21:09:49] Core required: FahCore_11.exe
[21:09:49] Core found.
[21:09:49] Working on queue slot 05 [September 18 21:09:49 UTC]
[21:09:49] + Working ...
[21:09:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 6 -verbose -lifeline 5692 -version 623'
[21:09:49]
[21:09:49] *------------------------------*
[21:09:49] Folding@Home GPU Core - Beta
[21:09:49] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[21:09:49]
[21:09:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:09:49] Build host: amoeba
[21:09:49] Board Type: Nvidia
[21:09:49] Core      :
[21:09:49] Preparing to commence simulation
[21:09:49] - Looking at optimizations...
[21:09:49] - Created dyn
[21:09:49] - Files status OK
[21:09:49] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[21:09:49] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[21:09:49] - Digital signature verified
[21:09:49]
[21:09:49] Project: 5772 (Run 4, Clone 225, Gen 404)
[21:09:49]
[21:09:49] Assembly optimizations on if available.
[21:09:49] Entering M.D.
[21:09:55] Working on Protein
[21:09:56] Client config found, loading data.
[21:09:56] Starting GUI Server
[21:09:56] mdrun_gpu returned
[21:09:56] SHAKE violations on GPU
[21:09:56]
[21:09:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:09:59] CoreStatus = 7A (122)
[21:09:59] Sending work to server
[21:09:59] Project: 5772 (Run 4, Clone 225, Gen 404)
[21:09:59] - Read packet limit of 540015616... Set to 524286976.
[21:09:59] - Error: Could not get length of results file work/wuresults_05.dat
[21:09:59] - Error: Could not read unit 05 file. Removing from queue.
[21:09:59] Trying to send all finished work units
[21:09:59] + No unsent completed units remaining.
[21:09:59] - Preparing to get new work unit...
[21:09:59] + Attempting to get work packet
[21:09:59] - Will indicate memory of 4093 MB
[21:09:59] - Connecting to assignment server
[21:09:59] Connecting to http://assign-GPU.stanford.edu:8080/
[21:10:00] Posted data.
[21:10:00] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[21:10:00] + News From Folding@Home: Welcome to Folding@Home
[21:10:00] Loaded queue successfully.
[21:10:00] Connecting to http://171.67.108.11:8080/
[21:10:01] Posted data.
[21:10:01] Initial: 0000; - Receiving payload (expected size: 45965)
[21:10:02] - Downloaded at ~44 kB/s
[21:10:02] - Averaged speed for that direction ~42 kB/s
[21:10:02] + Received work.
[21:10:02] Trying to send all finished work units
[21:10:02] + No unsent completed units remaining.
[21:10:02] + Closed connections
[21:10:07]
[21:10:07] + Processing work unit
[21:10:07] Core required: FahCore_11.exe
[21:10:07] Core found.
[21:10:07] Working on queue slot 06 [September 18 21:10:07 UTC]
[21:10:07] + Working ...
[21:10:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -checkpoint 6 -verbose -lifeline 5692 -version 623'
[21:10:07]
[21:10:07] *------------------------------*
[21:10:07] Folding@Home GPU Core - Beta
[21:10:07] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[21:10:07]
[21:10:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:10:07] Build host: amoeba
[21:10:07] Board Type: Nvidia
[21:10:07] Core      :
[21:10:07] Preparing to commence simulation
[21:10:07] - Looking at optimizations...
[21:10:07] - Created dyn
[21:10:07] - Files status OK
[21:10:07] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[21:10:07] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[21:10:07] - Digital signature verified
[21:10:07]
[21:10:07] Project: 5772 (Run 4, Clone 225, Gen 404)
[21:10:07]
[21:10:07] Assembly optimizations on if available.
[21:10:07] Entering M.D.
[21:10:14] Working on Protein
[21:10:14] Client config found, loading data.
[21:10:14] mdrun_gpu returned
[21:10:14] SHAKE violations on GPU
[21:10:14]
[21:10:14] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:10:17] CoreStatus = 7A (122)
[21:10:17] Sending work to server
[21:10:17] Project: 5772 (Run 4, Clone 225, Gen 404)
[21:10:17] - Read packet limit of 540015616... Set to 524286976.
[21:10:17] - Error: Could not get length of results file work/wuresults_06.dat
[21:10:17] - Error: Could not read unit 06 file. Removing from queue.
[21:10:17] Trying to send all finished work units
[21:10:17] + No unsent completed units remaining.
[21:10:17] - Preparing to get new work unit...
[21:10:17] + Attempting to get work packet
[21:10:17] - Will indicate memory of 4093 MB
[21:10:17] - Connecting to assignment server
[21:10:17] Connecting to http://assign-GPU.stanford.edu:8080/
[21:10:18] Posted data.
[21:10:18] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[21:10:18] + News From Folding@Home: Welcome to Folding@Home
[21:10:18] Loaded queue successfully.
[21:10:18] Connecting to http://171.67.108.11:8080/
[21:10:19] Posted data.
[21:10:19] Initial: 0000; - Receiving payload (expected size: 45965)
[21:10:20] - Downloaded at ~44 kB/s
[21:10:20] - Averaged speed for that direction ~42 kB/s
[21:10:20] + Received work.
[21:10:20] Trying to send all finished work units
[21:10:20] + No unsent completed units remaining.
[21:10:20] + Closed connections
[21:10:25]
[21:10:25] + Processing work unit
[21:10:25] Core required: FahCore_11.exe
[21:10:25] Core found.
[21:10:25] Working on queue slot 07 [September 18 21:10:25 UTC]
[21:10:25] + Working ...
[21:10:25] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -checkpoint 6 -verbose -lifeline 5692 -version 623'
[21:10:25]
[21:10:25] *------------------------------*
[21:10:25] Folding@Home GPU Core - Beta
[21:10:25] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[21:10:25]
[21:10:25] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:10:25] Build host: amoeba
[21:10:25] Board Type: Nvidia
[21:10:25] Core      :
[21:10:25] Preparing to commence simulation
[21:10:25] - Looking at optimizations...
[21:10:25] - Created dyn
[21:10:25] - Files status OK
[21:10:25] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[21:10:25] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[21:10:25] - Digital signature verified
[21:10:25]
[21:10:25] Project: 5772 (Run 4, Clone 225, Gen 404)
[21:10:25]
[21:10:25] Assembly optimizations on if available.
[21:10:25] Entering M.D.
[21:10:32] Working on Protein
[21:10:32] Client config found, loading data.
[21:10:32] mdrun_gpu returned
[21:10:32] SHAKE violations on GPU
[21:10:32]
[21:10:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:10:32] Starting GUI Server
[21:10:35] CoreStatus = 7A (122)
[21:10:35] Sending work to server
[21:10:35] Project: 5772 (Run 4, Clone 225, Gen 404)
[21:10:35] - Read packet limit of 540015616... Set to 524286976.
[21:10:35] - Error: Could not get length of results file work/wuresults_07.dat
[21:10:35] - Error: Could not read unit 07 file. Removing from queue.
[21:10:35] Trying to send all finished work units
[21:10:35] + No unsent completed units remaining.
[21:10:35] - Preparing to get new work unit...
[21:10:35] + Attempting to get work packet
[21:10:35] - Will indicate memory of 4093 MB
[21:10:35] - Connecting to assignment server
[21:10:35] Connecting to http://assign-GPU.stanford.edu:8080/
[21:10:36] Posted data.
[21:10:36] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[21:10:36] + News From Folding@Home: Welcome to Folding@Home
[21:10:36] Loaded queue successfully.
[21:10:36] Connecting to http://171.67.108.11:8080/
[21:10:37] Posted data.
[21:10:37] Initial: 0000; - Receiving payload (expected size: 45965)
[21:10:39] - Downloaded at ~22 kB/s
[21:10:39] - Averaged speed for that direction ~38 kB/s
[21:10:39] + Received work.
[21:10:39] Trying to send all finished work units
[21:10:39] + No unsent completed units remaining.
[21:10:39] + Closed connections
[21:10:44]
[21:10:44] + Processing work unit
[21:10:44] Core required: FahCore_11.exe
[21:10:44] Core found.
[21:10:44] Working on queue slot 08 [September 18 21:10:44 UTC]
[21:10:44] + Working ...
[21:10:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 6 -verbose -lifeline 5692 -version 623'
[21:10:44]
[21:10:44] *------------------------------*
[21:10:44] Folding@Home GPU Core - Beta
[21:10:44] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[21:10:44]
[21:10:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:10:44] Build host: amoeba
[21:10:44] Board Type: Nvidia
[21:10:44] Core      :
[21:10:44] Preparing to commence simulation
[21:10:44] - Looking at optimizations...
[21:10:44] - Created dyn
[21:10:44] - Files status OK
[21:10:44] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[21:10:44] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[21:10:44] - Digital signature verified
[21:10:44]
[21:10:44] Project: 5772 (Run 4, Clone 225, Gen 404)
[21:10:44]
[21:10:44] Assembly optimizations on if available.
[21:10:44] Entering M.D.
[21:10:50] Working on Protein
[21:10:51] Client config found, loading data.
[21:10:51] Starting GUI Server
[21:10:51] mdrun_gpu returned
[21:10:51] SHAKE violations on GPU
[21:10:51]
[21:10:51] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:10:54] CoreStatus = 7A (122)
[21:10:54] Sending work to server
[21:10:54] Project: 5772 (Run 4, Clone 225, Gen 404)
[21:10:54] - Read packet limit of 540015616... Set to 524286976.
[21:10:54] - Error: Could not get length of results file work/wuresults_08.dat
[21:10:54] - Error: Could not read unit 08 file. Removing from queue.
[21:10:54] Trying to send all finished work units
[21:10:54] + No unsent completed units remaining.
[21:10:54] - Preparing to get new work unit...
[21:10:54] + Attempting to get work packet
[21:10:54] - Will indicate memory of 4093 MB
[21:10:54] - Connecting to assignment server
[21:10:54] Connecting to http://assign-GPU.stanford.edu:8080/
[21:10:55] Posted data.
[21:10:55] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[21:10:55] + News From Folding@Home: Welcome to Folding@Home
[21:10:55] Loaded queue successfully.
[21:10:55] Connecting to http://171.67.108.11:8080/
[21:10:56] Posted data.
[21:10:56] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[21:10:56] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[21:11:13] + Attempting to get work packet
[21:11:13] - Will indicate memory of 4093 MB
[21:11:13] - Connecting to assignment server
[21:11:13] Connecting to http://assign-GPU.stanford.edu:8080/
[21:11:14] Posted data.
[21:11:14] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[21:11:14] + News From Folding@Home: Welcome to Folding@Home
[21:11:14] Loaded queue successfully.
[21:11:14] Connecting to http://171.67.108.11:8080/
[21:11:15] Posted data.
[21:11:15] Initial: 0000; - Receiving payload (expected size: 45968)
[21:11:17] - Downloaded at ~22 kB/s
[21:11:17] - Averaged speed for that direction ~35 kB/s
[21:11:17] + Received work.
[21:11:17] Trying to send all finished work units
[21:11:17] + No unsent completed units remaining.
[21:11:17] + Closed connections
[21:11:22]
[21:11:22] + Processing work unit
[21:11:22] Core required: FahCore_11.exe
[21:11:22] Core found.
[21:11:22] Working on queue slot 09 [September 18 21:11:22 UTC]
[21:11:22] + Working ...
[21:11:22] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -checkpoint 6 -verbose -lifeline 5692 -version 623'
[21:11:22]
[21:11:22] *------------------------------*
[21:11:22] Folding@Home GPU Core - Beta
[21:11:22] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[21:11:22]
[21:11:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:11:22] Build host: amoeba
[21:11:22] Board Type: Nvidia
[21:11:22] Core      :
[21:11:22] Preparing to commence simulation
[21:11:22] - Looking at optimizations...
[21:11:22] - Created dyn
[21:11:22] - Files status OK
[21:11:22] - Expanded 45456 -> 251112 (decompressed 552.4 percent)
[21:11:22] Called DecompressByteArray: compressed_data_size=45456 data_size=251112, decompressed_data_size=251112 diff=0
[21:11:22] - Digital signature verified
[21:11:22]
Heiko
Image Image
SidVicious
Re: Project: 5772 (Run 4, Clone 225, Gen 404)
Post by SidVicious »
Already reported here 10 days ago:
viewtopic.php?f=19&t=11414
And here, back in May(!):
viewtopic.php?f=19&t=10056
I'm doing science and I'm still folding
I feel FANTASTIC and I'm still folding
While you are dying I'll still be folding
and when you're dead I'll still be folding
STILL FOLDING, still folding
susato
Post by susato »
Thanks for the history Sid - Passed along to Vince at the PG.
AZBrandon
Post by AZBrandon »
I just got a batch of SHAKE violations on 5772 WU's also. All 5 of them were Project 5772, Run 4, Clone 225, Gen 404. I didn't think it was even possible to get the exact same WU multiple times like that, same P-R-C-G and everything, in fact it looks like the exact same PRCG as heikosch reported a week ago and by patonb two weeks ago!
[20:14:01] - Preparing to get new work unit...
[20:14:01] + Attempting to get work packet
[20:14:01] - Will indicate memory of 896 MB
[20:14:01] - Connecting to assignment server
[20:14:01] Connecting to http://assign-GPU.stanford.edu:8080/
[20:14:02] Posted data.
[20:14:02] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[20:14:02] + News From Folding@Home: Welcome to Folding@Home
[20:14:02] Loaded queue successfully.
[20:14:02] Connecting to http://171.67.108.11:8080/
[20:14:02] Initial: 0000; - Receiving payload (expected size: 45965)
[20:14:03] - Downloaded at ~44 kB/s
[20:14:03] - Averaged speed for that direction ~90 kB/s
[20:14:03] + Received work.
[20:14:03] Trying to send all finished work units
[20:14:03] + No unsent completed units remaining.
[20:14:03] + Closed connections
[20:14:03]
[20:14:03] + Processing work unit
[20:14:03] Core required: FahCore_11.exe
[20:14:03] Core found.
[20:14:03] Working on queue slot 00 [September 23 20:14:03 UTC]
[20:14:03] + Working ...
[20:14:03] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 3116 -version 623'
[20:14:03]
[20:14:03] *------------------------------*
[20:14:03] Folding@Home GPU Core - Beta
[20:14:03] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[20:14:03]
[20:14:03] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:14:03] Build host: amoeba
[20:14:03] Board Type: Nvidia
[20:14:03] Core      :
[20:14:03] Preparing to commence simulation
[20:14:03] - Looking at optimizations...
[20:14:03] - Created dyn
[20:14:03] - Files status OK
[20:14:03] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[20:14:03] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[20:14:03] - Digital signature verified
[20:14:03]
[20:14:03] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:14:03]
[20:14:03] Assembly optimizations on if available.
[20:14:03] Entering M.D.
[20:14:10] Working on Protein
[20:14:10] Client config found, loading data.
[20:14:10] mdrun_gpu returned
[20:14:10] SHAKE violations on GPU
[20:14:10]
[20:14:10] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:14:13] CoreStatus = 7A (122)
[20:14:13] Sending work to server
[20:14:13] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:14:13] - Error: Could not get length of results file work/wuresults_00.dat
[20:14:13] - Error: Could not read unit 00 file. Removing from queue.
[20:14:13] Trying to send all finished work units
[20:14:13] + No unsent completed units remaining.
[20:14:13] - Preparing to get new work unit...
[20:14:13] + Attempting to get work packet
[20:14:13] - Will indicate memory of 896 MB
[20:14:13] - Connecting to assignment server
[20:14:13] Connecting to http://assign-GPU.stanford.edu:8080/
[20:14:13] Posted data.
[20:14:13] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[20:14:13] + News From Folding@Home: Welcome to Folding@Home
[20:14:14] Loaded queue successfully.
[20:14:14] Connecting to http://171.67.108.11:8080/
[20:14:14] Posted data.
[20:14:14] Initial: 0000; - Receiving payload (expected size: 45965)
[20:14:14] Conversation time very short, giving reduced weight in bandwidth avg
[20:14:14] - Downloaded at ~89 kB/s
[20:14:14] - Averaged speed for that direction ~90 kB/s
[20:14:14] + Received work.
[20:14:14] Trying to send all finished work units
[20:14:14] + No unsent completed units remaining.
[20:14:14] + Closed connections
[20:14:19]
[20:14:19] + Processing work unit
[20:14:19] Core required: FahCore_11.exe
[20:14:19] Core found.
[20:14:19] Working on queue slot 01 [September 23 20:14:19 UTC]
[20:14:19] + Working ...
[20:14:19] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 3116 -version 623'
[20:14:19]
[20:14:19] *------------------------------*
[20:14:19] Folding@Home GPU Core - Beta
[20:14:19] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[20:14:19]
[20:14:19] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:14:19] Build host: amoeba
[20:14:19] Board Type: Nvidia
[20:14:19] Core      :
[20:14:19] Preparing to commence simulation
[20:14:19] - Looking at optimizations...
[20:14:19] - Created dyn
[20:14:19] - Files status OK
[20:14:19] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[20:14:19] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[20:14:19] - Digital signature verified
[20:14:19]
[20:14:19] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:14:19]
[20:14:19] Assembly optimizations on if available.
[20:14:19] Entering M.D.
[20:14:26] Working on Protein
[20:14:26] Client config found, loading data.
[20:14:26] mdrun_gpu returned
[20:14:26] SHAKE violations on GPU
[20:14:26]
[20:14:26] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:14:29] CoreStatus = 7A (122)
[20:14:29] Sending work to server
[20:14:29] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:14:29] - Error: Could not get length of results file work/wuresults_01.dat
[20:14:29] - Error: Could not read unit 01 file. Removing from queue.
[20:14:29] Trying to send all finished work units
[20:14:29] + No unsent completed units remaining.
[20:14:29] - Preparing to get new work unit...
[20:14:29] + Attempting to get work packet
[20:14:29] - Will indicate memory of 896 MB
[20:14:29] - Connecting to assignment server
[20:14:29] Connecting to http://assign-GPU.stanford.edu:8080/
[20:14:30] Posted data.
[20:14:30] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[20:14:30] + News From Folding@Home: Welcome to Folding@Home
[20:14:30] Loaded queue successfully.
[20:14:30] Connecting to http://171.67.108.11:8080/
[20:14:30] Initial: 0000; - Receiving payload (expected size: 45965)
[20:14:30] Conversation time very short, giving reduced weight in bandwidth avg
[20:14:30] - Downloaded at ~89 kB/s
[20:14:30] - Averaged speed for that direction ~90 kB/s
[20:14:30] + Received work.
[20:14:30] Trying to send all finished work units
[20:14:30] + No unsent completed units remaining.
[20:14:30] + Closed connections
[20:14:35]
[20:14:35] + Processing work unit
[20:14:35] Core required: FahCore_11.exe
[20:14:35] Core found.
[20:14:35] Working on queue slot 02 [September 23 20:14:35 UTC]
[20:14:35] + Working ...
[20:14:35] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 3116 -version 623'
[20:14:35]
[20:14:35] *------------------------------*
[20:14:35] Folding@Home GPU Core - Beta
[20:14:35] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[20:14:35]
[20:14:35] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:14:35] Build host: amoeba
[20:14:35] Board Type: Nvidia
[20:14:35] Core      :
[20:14:35] Preparing to commence simulation
[20:14:35] - Looking at optimizations...
[20:14:35] - Created dyn
[20:14:35] - Files status OK
[20:14:35] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[20:14:35] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[20:14:35] - Digital signature verified
[20:14:35]
[20:14:35] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:14:35]
[20:14:35] Assembly optimizations on if available.
[20:14:35] Entering M.D.
[20:14:42] Working on Protein
[20:14:42] Client config found, loading data.
[20:14:42] mdrun_gpu returned
[20:14:42] SHAKE violations on GPU
[20:14:42]
[20:14:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:14:45] CoreStatus = 7A (122)
[20:14:45] Sending work to server
[20:14:45] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:14:45] - Error: Could not get length of results file work/wuresults_02.dat
[20:14:45] - Error: Could not read unit 02 file. Removing from queue.
[20:14:45] Trying to send all finished work units
[20:14:45] + No unsent completed units remaining.
[20:14:45] - Preparing to get new work unit...
[20:14:45] + Attempting to get work packet
[20:14:45] - Will indicate memory of 896 MB
[20:14:45] - Connecting to assignment server
[20:14:45] Connecting to http://assign-GPU.stanford.edu:8080/
[20:14:46] Posted data.
[20:14:46] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[20:14:46] + News From Folding@Home: Welcome to Folding@Home
[20:14:46] Loaded queue successfully.
[20:14:46] Connecting to http://171.67.108.11:8080/
[20:14:46] Initial: 0000; - Receiving payload (expected size: 45965)
[20:14:46] Conversation time very short, giving reduced weight in bandwidth avg
[20:14:46] - Downloaded at ~89 kB/s
[20:14:46] - Averaged speed for that direction ~90 kB/s
[20:14:46] + Received work.
[20:14:46] Trying to send all finished work units
[20:14:46] + No unsent completed units remaining.
[20:14:46] + Closed connections
[20:14:51]
[20:14:51] + Processing work unit
[20:14:51] Core required: FahCore_11.exe
[20:14:51] Core found.
[20:14:51] Working on queue slot 03 [September 23 20:14:51 UTC]
[20:14:51] + Working ...
[20:14:51] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 3116 -version 623'
[20:14:51]
[20:14:51] *------------------------------*
[20:14:51] Folding@Home GPU Core - Beta
[20:14:51] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[20:14:51]
[20:14:51] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:14:51] Build host: amoeba
[20:14:51] Board Type: Nvidia
[20:14:51] Core      :
[20:14:51] Preparing to commence simulation
[20:14:51] - Looking at optimizations...
[20:14:51] - Created dyn
[20:14:51] - Files status OK
[20:14:51] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[20:14:51] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[20:14:51] - Digital signature verified
[20:14:51]
[20:14:51] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:14:51]
[20:14:51] Assembly optimizations on if available.
[20:14:51] Entering M.D.
[20:14:58] Working on Protein
[20:14:58] Client config found, loading data.
[20:14:58] mdrun_gpu returned
[20:14:58] SHAKE violations on GPU
[20:14:58]
[20:14:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:15:01] CoreStatus = 7A (122)
[20:15:01] Sending work to server
[20:15:01] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:15:01] - Error: Could not get length of results file work/wuresults_03.dat
[20:15:01] - Error: Could not read unit 03 file. Removing from queue.
[20:15:01] Trying to send all finished work units
[20:15:01] + No unsent completed units remaining.
[20:15:01] - Preparing to get new work unit...
[20:15:01] + Attempting to get work packet
[20:15:01] - Will indicate memory of 896 MB
[20:15:01] - Connecting to assignment server
[20:15:01] Connecting to http://assign-GPU.stanford.edu:8080/
[20:15:02] Posted data.
[20:15:02] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[20:15:02] + News From Folding@Home: Welcome to Folding@Home
[20:15:02] Loaded queue successfully.
[20:15:02] Connecting to http://171.67.108.11:8080/
[20:15:02] Initial: 0000; - Receiving payload (expected size: 45965)
[20:15:02] Conversation time very short, giving reduced weight in bandwidth avg
[20:15:02] - Downloaded at ~89 kB/s
[20:15:02] - Averaged speed for that direction ~90 kB/s
[20:15:02] + Received work.
[20:15:02] Trying to send all finished work units
[20:15:02] + No unsent completed units remaining.
[20:15:02] + Closed connections
[20:15:07]
[20:15:07] + Processing work unit
[20:15:07] Core required: FahCore_11.exe
[20:15:07] Core found.
[20:15:07] Working on queue slot 04 [September 23 20:15:07 UTC]
[20:15:07] + Working ...
[20:15:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 3116 -version 623'
[20:15:07]
[20:15:07] *------------------------------*
[20:15:07] Folding@Home GPU Core - Beta
[20:15:07] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[20:15:07]
[20:15:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:15:07] Build host: amoeba
[20:15:07] Board Type: Nvidia
[20:15:07] Core      :
[20:15:07] Preparing to commence simulation
[20:15:07] - Looking at optimizations...
[20:15:07] - Created dyn
[20:15:07] - Files status OK
[20:15:07] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[20:15:07] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[20:15:07] - Digital signature verified
[20:15:07]
[20:15:07] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:15:07]
[20:15:07] Assembly optimizations on if available.
[20:15:07] Entering M.D.
[20:15:14] Working on Protein
[20:15:14] Client config found, loading data.
[20:15:14] mdrun_gpu returned
[20:15:14] SHAKE violations on GPU
[20:15:14]
[20:15:14] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:15:17] CoreStatus = 7A (122)
[20:15:17] Sending work to server
[20:15:17] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:15:17] - Error: Could not get length of results file work/wuresults_04.dat
[20:15:17] - Error: Could not read unit 04 file. Removing from queue.
[20:15:17] EUE limit exceeded. Pausing 24 hours.
[20:20:06] ***** Got a SIGTERM signal (2)
[20:20:06] Killing all core threads
Folding@Home Client Shutdown.
heikosch
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz
Post by heikosch »
AZBrandon wrote:I just got a batch of SHAKE violations on 5772 WU's also. All 5 of them were Project 5772, Run 4, Clone 225, Gen 404. I didn't think it was even possible to get the exact same WU multiple times like that, same P-R-C-G and everything, in fact it looks like the exact same PRCG as heikosch reported a week ago and by patonb two weeks ago!
Hopefully they´ll stop to hand out this WU again and again.
Heiko
Image Image
bollix47
Post by bollix47 »
This WU kept downloading today until the client finally shutdown for 24 hours.
After restarting it downloaded the WU one more time and finally moved on to something different.
Haven't noticed any other instability problems with this GPU but judging by the reports it must be a bad WU.
[20:37:01] Folding@Home GPU Core - Beta
[20:37:01] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[20:37:01]
[20:37:01] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:37:01] Build host: amoeba
[20:37:01] Board Type: Nvidia
[20:37:01] Core      :
[20:37:01] Preparing to commence simulation
[20:37:01] - Looking at optimizations...
[20:37:01] - Created dyn
[20:37:01] - Files status OK
[20:37:01] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[20:37:01] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[20:37:01] - Digital signature verified
[20:37:01]
[20:37:01] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:37:01]
[20:37:01] Assembly optimizations on if available.
[20:37:01] Entering M.D.
[20:37:07] Working on Protein
[20:37:08] Client config found, loading data.
[20:37:08] Starting GUI Server
[20:37:08] mdrun_gpu returned
[20:37:08] Nonzero force sum on GPU
[20:37:08]
[20:37:08] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:37:11] CoreStatus = 7A (122)
[20:37:11] Sending work to server
[20:37:11] Project: 5772 (Run 4, Clone 225, Gen 404)
[20:37:11] - Read packet limit of 540015616... Set to 524286976.
[20:37:11] - Error: Could not get length of results file work/wuresults_04.dat
[20:37:11] - Error: Could not read unit 04 file. Removing from queue.
[20:37:11] EUE limit exceeded. Pausing 24 hours.
[20:57:03] - Autosending finished units... [September 27 20:57:03 UTC]
[20:57:03] Trying to send all finished work units
[20:57:03] + No unsent completed units remaining.
[20:57:03] - Autosend completed
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Just got a batch of 5 tries on this same WU. Shut down my client, but fortunately, I found it quickly.
[03:24:16] Working on queue slot 08 [September 29 03:24:16 UTC]
[03:24:16] + Working ...
[03:24:16] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 15 -verbose -lifeline 5176 -version 620'
[03:24:16]
[03:24:16] *------------------------------*
[03:24:16] Folding@Home GPU Core - Beta
[03:24:16] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[03:24:16]
[03:24:16] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[03:24:16] Build host: amoeba
[03:24:16] Board Type: Nvidia
[03:24:16] Core      :
[03:24:16] Preparing to commence simulation
[03:24:16] - Looking at optimizations...
[03:24:16] - Created dyn
[03:24:16] - Files status OK
[03:24:16] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[03:24:16] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[03:24:16] - Digital signature verified
[03:24:16]
[03:24:16] Project: 5772 (Run 4, Clone 225, Gen 404)
[03:24:16]
[03:24:16] Assembly optimizations on if available.
[03:24:16] Entering M.D.
[03:24:22] Working on Protein
[03:24:23] Client config found, loading data.
[03:24:23] mdrun_gpu returned
[03:24:23] SHAKE violations on GPU
[03:24:23]
[03:24:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[03:24:26] CoreStatus = 7A (122)
[03:24:26] Sending work to server
[03:24:26] Project: 5772 (Run 4, Clone 225, Gen 404)
[03:24:26] - Read packet limit of 540015616... Set to 524286976.
[03:24:26] - Error: Could not get length of results file work/wuresults_08.dat
[03:24:26] - Error: Could not read unit 08 file. Removing from queue.
[03:24:26] EUE limit exceeded. Pausing 24 hours.
[04:45:47] ***** Got a SIGTERM signal (2)
[04:45:47] Killing all core threads
hackman2007
Post by hackman2007 »
Same here, this WU keeps trying to download on one of my GPU's.
I hate this WU.
Teddy
Post by Teddy »
[19:06:05] - Not checking prior termination.
[19:06:05] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[19:06:05] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[19:06:05] - Digital signature verified
[19:06:05]
[19:06:05] Project: 5772 (Run 4, Clone 225, Gen 404)
[19:06:05]
[19:06:05] Assembly optimizations on if available.
[19:06:05] Entering M.D.
[19:06:11] Working on Protein
[19:06:12] Client config found, loading data.
[19:06:12] Starting GUI Server
[19:06:52] Completed 1%
[19:06:52] mdrun_gpu returned
[19:06:52] NANs detected on GPU
[19:06:52]
[19:06:52] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:06:55] CoreStatus = 7A (122)
[19:06:55] Sending work to server
[19:06:55] Project: 5772 (Run 4, Clone 225, Gen 404)
[19:06:55] - Read packet limit of 540015616... Set to 524286976.
[19:06:55] - Error: Could not get length of results file work/wuresults_01.dat
[19:06:55] - Error: Could not read unit 01 file. Removing from queue.
[19:06:55] Trying to send all finished work units
[19:06:55] + No unsent completed units remaining.
[19:06:55] - Preparing to get new work unit...
[19:06:55] + Attempting to get work packet
[19:06:55] - Will indicate memory of 1022 MB
[19:06:55] - Connecting to assignment server
[19:06:55] Connecting to http://assign-GPU.stanford.edu:8080/
[19:06:55] Posted data.
[19:06:55] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[19:06:55] + News From Folding@Home: Welcome to Folding@Home
[19:06:56] Loaded queue successfully.
[19:06:56] Connecting to http://171.67.108.11:8080/
[19:06:56] Posted data.
[19:06:56] Initial: 0000; - Receiving payload (expected size: 45965)
[19:06:57] - Downloaded at ~44 kB/s
[19:06:57] - Averaged speed for that direction ~41 kB/s
[19:06:57] + Received work.
[19:06:57] Trying to send all finished work units
[19:06:57] + No unsent completed units remaining.
[19:06:57] + Closed connections
[19:07:02]
[19:07:02] + Processing work unit
[19:07:02] Core required: FahCore_11.exe
[19:07:02] Core found.
[19:07:02] Working on queue slot 02 [October 4 19:07:02 UTC]
[19:07:02] + Working ...
[19:07:02] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 3 -forceasm -verbose -lifeline 6424 -version 623'
[19:07:02]
[19:07:02] *------------------------------*
[19:07:02] Folding@Home GPU Core - Beta
[19:07:02] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[19:07:02]
[19:07:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:07:02] Build host: amoeba
[19:07:02] Board Type: Nvidia
[19:07:02] Core      :
[19:07:02] Preparing to commence simulation
[19:07:02] - Assembly optimizations manually forced on.
[19:07:02] - Not checking prior termination.
[19:07:02] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[19:07:02] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[19:07:02] - Digital signature verified
[19:07:02]
[19:07:02] Project: 5772 (Run 4, Clone 225, Gen 404)
[19:07:02]
[19:07:02] Assembly optimizations on if available.
[19:07:02] Entering M.D.
[19:07:09] Working on Protein
[19:07:09] Client config found, loading data.
[19:07:10] Starting GUI Server
[19:07:50] Completed 1%
[19:07:50] mdrun_gpu returned
[19:07:50] NANs detected on GPU
Yep I go this bastard work unit too I wish Stanford would remove this one from the servers too!
anko1
Post by anko1 »
Yes, it's baaaaccckkkk....
[07:02:27] Working on queue slot 07 [October 4 07:02:27 UTC]
[07:02:27] + Working ...
[07:02:27] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -checkpoint 15 -verbose -lifeline 4640 -version 620'
[07:02:27]
[07:02:27] *------------------------------*
[07:02:27] Folding@Home GPU Core - Beta
[07:02:27] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[07:02:27]
[07:02:27] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:02:27] Build host: amoeba
[07:02:27] Board Type: Nvidia
[07:02:27] Core      :
[07:02:27] Preparing to commence simulation
[07:02:27] - Looking at optimizations...
[07:02:27] - Created dyn
[07:02:27] - Files status OK
[07:02:27] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[07:02:27] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[07:02:27] - Digital signature verified
[07:02:27]
[07:02:27] Project: 5772 (Run 4, Clone 225, Gen 404)
[07:02:27]
[07:02:27] Assembly optimizations on if available.
[07:02:27] Entering M.D.
[07:02:34] Working on Protein
[07:02:34] Client config found, loading data.
[07:02:34] mdrun_gpu returned
[07:02:34] SHAKE violations on GPU
[07:02:34]
[07:02:34] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:02:37] CoreStatus = 7A (122)
[07:02:37] Sending work to server
[07:02:37] Project: 5772 (Run 4, Clone 225, Gen 404)
[07:02:37] - Read packet limit of 540015616... Set to 524286976.
[07:02:37] - Error: Could not get length of results file work/wuresults_07.dat
[07:02:37] - Error: Could not read unit 07 file. Removing from queue.
Teddy
Post by Teddy »
So you were the (un)lucky one who got it after I dumped it....
anko1
Post by anko1 »
:-D
b101uk
Post by b101uk »
i get the same to :roll:
[06:10:19] + Attempting to send results [October 5 06:10:19 UTC]
[06:10:19] - Reading file work/wuresults_07.dat from core
[06:10:19]   (Read 179207 bytes from disk)
[06:10:19] Connecting to http://171.64.65.106:8080/
[06:10:24] Posted data.
[06:10:24] Initial: 0000; - Uploaded at ~35 kB/s
[06:10:24] - Averaged speed for that direction ~32 kB/s
[06:10:24] + Results successfully sent
[06:10:24] Thank you for your contribution to Folding@Home.
[06:10:24] + Number of Units Completed: 137
[06:10:28] Trying to send all finished work units
[06:10:28] + No unsent completed units remaining.
[06:10:28] - Preparing to get new work unit...
[06:10:28] + Attempting to get work packet
[06:10:28] - Will indicate memory of 1000 MB
[06:10:28] - Connecting to assignment server
[06:10:28] Connecting to http://assign-GPU.stanford.edu:8080/
[06:10:29] Posted data.
[06:10:29] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[06:10:29] + News From Folding@Home: Welcome to Folding@Home
[06:10:30] Loaded queue successfully.
[06:10:30] Connecting to http://171.67.108.11:8080/
[06:10:30] Posted data.
[06:10:30] Initial: 0000; - Receiving payload (expected size: 45965)
[06:10:31] - Downloaded at ~44 kB/s
[06:10:31] - Averaged speed for that direction ~48 kB/s
[06:10:31] + Received work.
[06:10:31] Trying to send all finished work units
[06:10:31] + No unsent completed units remaining.
[06:10:31] + Closed connections
[06:10:31]
[06:10:31] + Processing work unit
[06:10:31] Core required: FahCore_11.exe
[06:10:31] Core found.
[06:10:31] Working on queue slot 08 [October 5 06:10:31 UTC]
[06:10:31] + Working ...
[06:10:31] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 2012 -version 623'
[06:10:31]
[06:10:31] *------------------------------*
[06:10:31] Folding@Home GPU Core - Beta
[06:10:31] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:10:31]
[06:10:31] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:10:31] Build host: amoeba
[06:10:31] Board Type: Nvidia
[06:10:31] Core      :
[06:10:31] Preparing to commence simulation
[06:10:31] - Assembly optimizations manually forced on.
[06:10:31] - Not checking prior termination.
[06:10:31] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[06:10:31] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[06:10:31] - Digital signature verified
[06:10:31]
[06:10:31] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:10:31]
[06:10:31] Assembly optimizations on if available.
[06:10:31] Entering M.D.
[06:10:38] Working on Protein
[06:10:38] Client config found, loading data.
[06:10:38] mdrun_gpu returned
[06:10:38] Nonzero force sum on GPU
[06:10:38]
[06:10:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:10:42] CoreStatus = 7A (122)
[06:10:42] Sending work to server
[06:10:42] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:10:42] - Read packet limit of 540015616... Set to 524286976.
[06:10:42] - Error: Could not get length of results file work/wuresults_08.dat
[06:10:42] - Error: Could not read unit 08 file. Removing from queue.
[06:10:42] Trying to send all finished work units
[06:10:42] + No unsent completed units remaining.
[06:10:42] - Preparing to get new work unit...
[06:10:42] + Attempting to get work packet
[06:10:42] - Will indicate memory of 1000 MB
[06:10:42] - Connecting to assignment server
[06:10:42] Connecting to http://assign-GPU.stanford.edu:8080/
[06:10:42] Posted data.
[06:10:42] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[06:10:42] + News From Folding@Home: Welcome to Folding@Home
[06:10:43] Loaded queue successfully.
[06:10:43] Connecting to http://171.67.108.11:8080/
[06:10:43] Posted data.
[06:10:43] Initial: 0000; - Receiving payload (expected size: 45965)
[06:10:44] - Downloaded at ~44 kB/s
[06:10:44] - Averaged speed for that direction ~47 kB/s
[06:10:44] + Received work.
[06:10:44] Trying to send all finished work units
[06:10:44] + No unsent completed units remaining.
[06:10:44] + Closed connections
[06:10:49]
[06:10:49] + Processing work unit
[06:10:49] Core required: FahCore_11.exe
[06:10:49] Core found.
[06:10:49] Working on queue slot 09 [October 5 06:10:49 UTC]
[06:10:49] + Working ...
[06:10:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 2012 -version 623'
[06:10:49]
[06:10:49] *------------------------------*
[06:10:49] Folding@Home GPU Core - Beta
[06:10:49] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:10:49]
[06:10:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:10:49] Build host: amoeba
[06:10:49] Board Type: Nvidia
[06:10:49] Core      :
[06:10:49] Preparing to commence simulation
[06:10:49] - Assembly optimizations manually forced on.
[06:10:49] - Not checking prior termination.
[06:10:49] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[06:10:49] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[06:10:49] - Digital signature verified
[06:10:49]
[06:10:49] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:10:49]
[06:10:49] Assembly optimizations on if available.
[06:10:49] Entering M.D.
[06:10:56] Working on Protein
[06:10:56] Client config found, loading data.
[06:10:56] mdrun_gpu returned
[06:10:56] Nonzero force sum on GPU
[06:10:56]
[06:10:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:11:00] CoreStatus = 7A (122)
[06:11:00] Sending work to server
[06:11:00] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:11:00] - Read packet limit of 540015616... Set to 524286976.
[06:11:00] - Error: Could not get length of results file work/wuresults_09.dat
[06:11:00] - Error: Could not read unit 09 file. Removing from queue.
[06:11:00] Trying to send all finished work units
[06:11:00] + No unsent completed units remaining.
[06:11:00] - Preparing to get new work unit...
[06:11:00] + Attempting to get work packet
[06:11:00] - Will indicate memory of 1000 MB
[06:11:00] - Connecting to assignment server
[06:11:00] Connecting to http://assign-GPU.stanford.edu:8080/
[06:11:00] Posted data.
[06:11:00] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[06:11:00] + News From Folding@Home: Welcome to Folding@Home
[06:11:00] Loaded queue successfully.
[06:11:00] Connecting to http://171.67.108.11:8080/
[06:11:01] Posted data.
[06:11:01] Initial: 0000; - Receiving payload (expected size: 45965)
[06:11:02] - Downloaded at ~44 kB/s
[06:11:02] - Averaged speed for that direction ~47 kB/s
[06:11:02] + Received work.
[06:11:02] Trying to send all finished work units
[06:11:02] + No unsent completed units remaining.
[06:11:02] + Closed connections
[06:11:07]
[06:11:07] + Processing work unit
[06:11:07] Core required: FahCore_11.exe
[06:11:07] Core found.
[06:11:07] Working on queue slot 00 [October 5 06:11:07 UTC]
[06:11:07] + Working ...
[06:11:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -priority 96 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 2012 -version 623'
[06:11:07]
[06:11:07] *------------------------------*
[06:11:07] Folding@Home GPU Core - Beta
[06:11:07] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:11:07]
[06:11:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:11:07] Build host: amoeba
[06:11:07] Board Type: Nvidia
[06:11:07] Core      :
[06:11:07] Preparing to commence simulation
[06:11:07] - Assembly optimizations manually forced on.
[06:11:07] - Not checking prior termination.
[06:11:07] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[06:11:07] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[06:11:07] - Digital signature verified
[06:11:07]
[06:11:07] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:11:07]
[06:11:07] Assembly optimizations on if available.
[06:11:07] Entering M.D.
[06:11:14] Working on Protein
[06:11:14] Client config found, loading data.
[06:11:14] mdrun_gpu returned
[06:11:14] Nonzero force sum on GPU
[06:11:14]
[06:11:14] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:11:18] CoreStatus = 7A (122)
[06:11:18] Sending work to server
[06:11:18] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:11:18] - Read packet limit of 540015616... Set to 524286976.
[06:11:18] - Error: Could not get length of results file work/wuresults_00.dat
[06:11:18] - Error: Could not read unit 00 file. Removing from queue.
[06:11:18] Trying to send all finished work units
[06:11:18] + No unsent completed units remaining.
[06:11:18] - Preparing to get new work unit...
[06:11:18] + Attempting to get work packet
[06:11:18] - Will indicate memory of 1000 MB
[06:11:18] - Connecting to assignment server
[06:11:18] Connecting to http://assign-GPU.stanford.edu:8080/
[06:11:18] Posted data.
[06:11:18] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[06:11:18] + News From Folding@Home: Welcome to Folding@Home
[06:11:19] Loaded queue successfully.
[06:11:19] Connecting to http://171.67.108.11:8080/
[06:11:19] Posted data.
[06:11:19] Initial: 0000; - Receiving payload (expected size: 45965)
[06:11:20] - Downloaded at ~44 kB/s
[06:11:20] - Averaged speed for that direction ~46 kB/s
[06:11:20] + Received work.
[06:11:20] Trying to send all finished work units
[06:11:20] + No unsent completed units remaining.
[06:11:20] + Closed connections
[06:11:25]
[06:11:25] + Processing work unit
[06:11:25] Core required: FahCore_11.exe
[06:11:25] Core found.
[06:11:25] Working on queue slot 01 [October 5 06:11:25 UTC]
[06:11:25] + Working ...
[06:11:25] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 2012 -version 623'
[06:11:25]
[06:11:25] *------------------------------*
[06:11:25] Folding@Home GPU Core - Beta
[06:11:25] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:11:25]
[06:11:25] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:11:25] Build host: amoeba
[06:11:25] Board Type: Nvidia
[06:11:25] Core      :
[06:11:25] Preparing to commence simulation
[06:11:25] - Assembly optimizations manually forced on.
[06:11:25] - Not checking prior termination.
[06:11:25] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[06:11:25] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[06:11:25] - Digital signature verified
[06:11:25]
[06:11:25] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:11:25]
[06:11:25] Assembly optimizations on if available.
[06:11:25] Entering M.D.
[06:11:32] Working on Protein
[06:11:32] Client config found, loading data.
[06:11:32] mdrun_gpu returned
[06:11:32] Nonzero force sum on GPU
[06:11:32]
[06:11:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:11:35] CoreStatus = 7A (122)
[06:11:35] Sending work to server
[06:11:35] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:11:35] - Read packet limit of 540015616... Set to 524286976.
[06:11:35] - Error: Could not get length of results file work/wuresults_01.dat
[06:11:35] - Error: Could not read unit 01 file. Removing from queue.
[06:11:35] Trying to send all finished work units
[06:11:35] + No unsent completed units remaining.
[06:11:35] - Preparing to get new work unit...
[06:11:35] + Attempting to get work packet
[06:11:35] - Will indicate memory of 1000 MB
[06:11:35] - Connecting to assignment server
[06:11:35] Connecting to http://assign-GPU.stanford.edu:8080/
[06:11:36] Posted data.
[06:11:36] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[06:11:36] + News From Folding@Home: Welcome to Folding@Home
[06:11:36] Loaded queue successfully.
[06:11:36] Connecting to http://171.67.108.11:8080/
[06:11:37] Posted data.
[06:11:37] Initial: 0000; - Receiving payload (expected size: 45965)
[06:11:38] - Downloaded at ~44 kB/s
[06:11:38] - Averaged speed for that direction ~46 kB/s
[06:11:38] + Received work.
[06:11:38] Trying to send all finished work units
[06:11:38] + No unsent completed units remaining.
[06:11:38] + Closed connections
[06:11:43]
[06:11:43] + Processing work unit
[06:11:43] Core required: FahCore_11.exe
[06:11:43] Core found.
[06:11:43] Working on queue slot 02 [October 5 06:11:43 UTC]
[06:11:43] + Working ...
[06:11:43] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 2012 -version 623'
[06:11:43]
[06:11:43] *------------------------------*
[06:11:43] Folding@Home GPU Core - Beta
[06:11:43] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:11:43]
[06:11:43] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:11:43] Build host: amoeba
[06:11:43] Board Type: Nvidia
[06:11:43] Core      :
[06:11:43] Preparing to commence simulation
[06:11:43] - Assembly optimizations manually forced on.
[06:11:43] - Not checking prior termination.
[06:11:43] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[06:11:43] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[06:11:43] - Digital signature verified
[06:11:43]
[06:11:43] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:11:43]
[06:11:43] Assembly optimizations on if available.
[06:11:43] Entering M.D.
[06:11:50] Working on Protein
[06:11:50] Client config found, loading data.
[06:11:50] mdrun_gpu returned
[06:11:50] Nonzero force sum on GPU
[06:11:50]
[06:11:50] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:11:53] CoreStatus = 7A (122)
[06:11:53] Sending work to server
[06:11:53] Project: 5772 (Run 4, Clone 225, Gen 404)
[06:11:53] - Read packet limit of 540015616... Set to 524286976.
[06:11:53] - Error: Could not get length of results file work/wuresults_02.dat
[06:11:53] - Error: Could not read unit 02 file. Removing from queue.
[06:11:53] EUE limit exceeded. Pausing 24 hours.
[06:24:43] ***** Got a SIGTERM signal (2)
[06:24:43] Killing all core threads
anko1
Post by anko1 »
Still out there:
[00:44:51] Working on queue slot 08 [October 8 00:44:51 UTC]
[00:44:51] + Working ...
[00:44:51] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 15 -verbose -lifeline 2756 -version 620'
[00:44:51]
[00:44:51] *------------------------------*
[00:44:51] Folding@Home GPU Core - Beta
[00:44:51] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:44:51]
[00:44:51] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:44:51] Build host: amoeba
[00:44:51] Board Type: Nvidia
[00:44:51] Core      :
[00:44:51] Preparing to commence simulation
[00:44:51] - Looking at optimizations...
[00:44:51] - Created dyn
[00:44:51] - Files status OK
[00:44:51] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[00:44:51] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[00:44:51] - Digital signature verified
[00:44:51]
[00:44:51] Project: 5772 (Run 4, Clone 225, Gen 404)
[00:44:51]
[00:44:51] Assembly optimizations on if available.
[00:44:51] Entering M.D.
[00:44:58] Working on Protein
[00:44:58] Client config found, loading data.
[00:44:58] mdrun_gpu returned
[00:44:58] SHAKE violations on GPU
[00:44:58]
[00:44:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:45:01] CoreStatus = 7A (122)
[00:45:01] Sending work to server
[00:45:01] Project: 5772 (Run 4, Clone 225, Gen 404)
[00:45:01] - Read packet limit of 540015616... Set to 524286976.
[00:45:01] - Error: Could not get length of results file work/wuresults_08.dat
[00:45:01] - Error: Could not read unit 08 file. Removing from queue.
Edit: repeated [04:47:36] Working on queue slot 02 [October 9 04:47:36 UTC]
susato
Post by susato »
PM sent to the researcher. Thanks for the reports, folks - they are much appreciated.
