Project: 2671 (Run 37, Clone 79, Gen 79)
SpockLogic
Post by SpockLogic »
--- Opening Log file [September 14 20:44:56 UTC]
# Mac OS X SMP Console Edition ################################################
                       Folding@Home Client Version 6.20
                          http://folding.stanford.edu
Launch directory: /Users/xxxxx/Library/InCrease/unit4
Executable: /Users/xxxxx/Library/InCrease/unit4/fah6
Arguments: -local -advmethods -forceasm -verbosity 9 -smp
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[20:44:56] - Ask before connecting: No
[20:44:56] - User name: SpockLogic (Team 1971)
[20:44:56] - User ID: 19EE296642E8B458
[20:44:56] - Machine ID: 4
[20:44:56]
[20:44:56] Loaded queue successfully.
[20:44:56]
[20:44:56] - Autosending finished units... [20:44:56]
[20:44:56] + Processing work unit
[20:44:56] Trying to send all finished work units
[20:44:56] Core required: FahCore_a2.exe
[20:44:56] + No unsent completed units remaining.
[20:44:56] - Autosend completed
[20:44:56] Core found.
[20:44:56] - Using generic ./mpiexec
[20:44:56] Working on queue slot 08 [September 14 20:44:56 UTC]
[20:44:56] + Working ...
[20:44:56] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 08 -checkpoint 15 -forceasm -verbose -lifeline 31366 -version 620'
[20:44:57]
[20:44:57] *------------------------------*
[20:44:57] Folding@Home Gromacs SMP Core
[20:44:57] Version 2.11 (Fri Sep 4 09:50:46 PDT 2009)
[20:44:57]
[20:44:57] Preparing to commence simulation
[20:44:57] - Ensuring status. Please wait.
[20:45:06] - Assembly optimizations manually forced on.
[20:45:06] - Not checking prior termination.
[20:45:07] - Expanded 1513359 -> 24038109 (decompressed 1588.3 percent)
[20:45:07] Called DecompressByteArray: compressed_data_size=1513359 data_size=24038109, decompressed_data_size=24038109 diff=0
[20:45:08] - Digital signature verified
[20:45:08]
[20:45:08] Project: 2671 (Run 37, Clone 79, Gen 79)
[20:45:08]
[20:45:08] Assembly optimizations on if available.
[20:45:08] Entering M.D.
[20:46:00] Completed 0 out of 250000 steps  (0%)
[20:46:04] CoreStatus = FF (255)
[20:46:04] Client-core communications error: ERROR 0xff
[20:46:04] This is a sign of more serious problems, shutting down.
Re: Project: 2671 (Run 37, Clone 79, Gen 79)
According to this post, Dr. Kasson had started cleaning out problems like this in project 2671 but he probably hadn't finished at the time it was assigned to you.
