Project 3863, Run 395, Clone 5, Gen 0--Problem?
DrBB1
Post by DrBB1 »
Two " Project: 3863 (Run 395, Clone 5, Gen 0)" loaded and aborted in quick succession. Is there a known problem? Note that "Project: 3863 (Run 443, Clone 11, Gen 18)" loaded and is apparently running fine.
[01:43:15] - Preparing to get new work unit...
[01:43:15] + Attempting to get work packet
[01:43:16] - Connecting to assignment server
[01:43:16] - Successful: assigned to (128.143.48.226).
[01:43:16] + News From Folding@Home: Welcome to Folding@Home
[01:43:16] Loaded queue successfully.
[01:43:17] + Closed connections
[01:43:17]
[01:43:17] + Processing work unit
[01:43:17] Core required: FahCore_7c.exe
[01:43:17] Core found.
[01:43:17] Working on queue slot 02 [September 13 01:43:17 UTC]
[01:43:17] + Working ...
[01:43:18]
[01:43:18] *------------------------------*
[01:43:18] Folding@Home Double Gromacs Core C
[01:43:18] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[01:43:18]
[01:43:18] Preparing to commence simulation
[01:43:18] - Files status OK
[01:43:18] - Expanded 112254 -> 640028 (decompressed 570.1 percent)
[01:43:18]
[01:43:18] Project: 3863 (Run 395, Clone 5, Gen 0)
[01:43:18]
[01:43:18] Assembly optimizations on if available.
[01:43:18] Entering M.D.
[01:43:25] Working on p3863_fkbprelative_ligand
[01:43:25] Completed 0 out of 1500000 steps  (0%)
[01:43:25] Extra SSE2 boost OK
[01:44:00] mdrun returned -1
[01:44:00] Going to send back what have done.
[01:44:00] logfile size: 29717
[01:44:00] - Writing 30255 bytes of core data to disk...
[01:44:00] Done: 29743 -> 3837 (compressed to 12.9 percent)
[01:44:00]   ... Done.
[01:44:00]
[01:44:00] Folding@home Core Shutdown: EARLY_UNIT_END
[01:44:02] CoreStatus = 72 (114)
[01:44:02] Sending work to server
[01:44:02] Project: 3863 (Run 395, Clone 5, Gen 0)
[01:44:02] + Attempting to send results [September 13 01:44:02 UTC]
[01:44:02] + Results successfully sent
[01:44:02] Thank you for your contribution to Folding@Home.
[01:44:06] - Preparing to get new work unit...
[01:44:06] + Attempting to get work packet
[01:44:06] - Connecting to assignment server
[01:44:07] - Successful: assigned to (128.143.48.226).
[01:44:07] + News From Folding@Home: Welcome to Folding@Home
[01:44:07] Loaded queue successfully.
[01:44:08] + Closed connections
[01:44:13]
[01:44:13] + Processing work unit
[01:44:13] Core required: FahCore_7c.exe
[01:44:13] Core found.
[01:44:13] Working on queue slot 03 [September 13 01:44:13 UTC]
[01:44:13] + Working ...
[01:44:13]
[01:44:13] *------------------------------*
[01:44:13] Folding@Home Double Gromacs Core C
[01:44:13] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[01:44:13]
[01:44:13] Preparing to commence simulation
[01:44:13] - Files status OK
[01:44:13] - Expanded 112254 -> 640028 (decompressed 570.1 percent)
[01:44:13]
[01:44:13] Project: 3863 (Run 395, Clone 5, Gen 0)
[01:44:13]
[01:44:13] Assembly optimizations on if available.
[01:44:13] Entering M.D.
[01:44:19] Working on p3863_fkbprelative_ligand
[01:44:19] Completed 0 out of 1500000 steps  (0%)
[01:44:19] Extra SSE2 boost OK
[01:44:55] mdrun returned -1
[01:44:55] Going to send back what have done.
[01:44:55] logfile size: 29717
[01:44:55] - Writing 30255 bytes of core data to disk...
[01:44:55] Done: 29743 -> 3829 (compressed to 12.8 percent)
[01:44:55]   ... Done.
[01:44:55]
[01:44:55] Folding@home Core Shutdown: EARLY_UNIT_END
[01:44:57] CoreStatus = 72 (114)
[01:44:57] Sending work to server
[01:44:57] Project: 3863 (Run 395, Clone 5, Gen 0)
[01:44:57] + Attempting to send results [September 13 01:44:57 UTC]
[01:44:57] + Results successfully sent
[01:44:57] Thank you for your contribution to Folding@Home.
[01:45:01] - Preparing to get new work unit...
[01:45:01] + Attempting to get work packet
[01:45:01] - Connecting to assignment server
[01:45:02] - Successful: assigned to (128.143.48.226).
[01:45:02] + News From Folding@Home: Welcome to Folding@Home
[01:45:02] Loaded queue successfully.
[01:45:03] + Closed connections
[01:45:08]
[01:45:08] + Processing work unit
[01:45:08] Core required: FahCore_7c.exe
[01:45:08] Core found.
[01:45:08] Working on queue slot 04 [September 13 01:45:08 UTC]
[01:45:08] + Working ...
[01:45:08]
[01:45:08] *------------------------------*
[01:45:08] Folding@Home Double Gromacs Core C
[01:45:08] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[01:45:08]
[01:45:08] Preparing to commence simulation
[01:45:08] - Files status OK
[01:45:08] - Expanded 230834 -> 634796 (decompressed 275.0 percent)
[01:45:08]
[01:45:08] Project: 3863 (Run 443, Clone 11, Gen 18)
[01:45:08]
[01:45:08] Assembly optimizations on if available.
[01:45:08] Entering M.D.
[01:45:14] Working on p3863_fkbprelative_ligand
[01:45:14] Completed 0 out of 1500000 steps  (0%)
[01:45:14] Extra SSE2 boost OK
[02:00:15] Timer requesting checkpoint
[02:04:50] Completed 15000 out of 1500000 steps  (1%)
[02:19:51] Timer requesting checkpoint
[02:24:26] Completed 30000 out of 1500000 steps  (2%)
[02:39:26] Timer requesting checkpoint
[02:44:01] Completed 45000 out of 1500000 steps  (3%)
[02:59:02] Timer requesting checkpoint
[03:03:37] Completed 60000 out of 1500000 steps  (4%)
[03:09:40] + Paused
DrBB1
