I was following the installation instructions below,
http://folding.stanford.edu/English/Win ... PICH#ntoc2
everything was going great till running
fah6 -configonly -smp
in the cmd prompt under administrated rights.
Here is the following.
C:\FAH>install.bat
Stopping MPICH2 Process Manager, Argonne National Lab.
MPICH2 Process Manager, Argonne National Lab stopped.
MPICH2 Process Manager, Argonne National Lab removed.
MPICH2 Process Manager, Argonne National Lab installed.
account (domain\user) [Antec\Admin]:
password:
confirm password:
Password encrypted into the Registry.
If you see this twice, MPI is working
Press any key to continue . . .
C:\FAH>fah6 -configonly -smp
C:\FAH>
I do not receive anything after> fah6 -configonly -smp
I tried this cmd "-configonly -smp" without quotes with the shortcut in administration as well too but same avail shows the cmd prompt real fast then disappears.
Any idea's?
SMP client installation (MPICH version)
kpe1950
- Hardware configuration: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Motherboard: P5N32-E SLI
Processor: Pentium D CPU 3.40GHz OCED @4.40GHz@1033MHzFSB
Memory: G.Skill F2-8500CL5D-4GBPQ 4 Gig
Video Card: GeForce 6600 LE OCED@ Core@444MHz Memory@535
http://valid.canardpc.com/show_oc.php?id=701874
Re: SMP client installation (MPICH version)
Read the NOTE on the client download page.
You'll need to download one more file.
kpe1950
Thank You.
Setting up now with fah6 -config now
does it need -smp at the end because if i do i get
Note: Please read the license agreement (fah6 -license). Further
use of this software requires that you have read and accepted this agreement.
Folding@Home User Configuration
Bad argument: -smp
Bad Argument(s) received
Folding@Home Version 5.91beta6
Usage: fah6 [-option1] [-option2] ...
Options:
-config Configure user information
-configonly Configure user information, then exit
-help Dispaly this usage screen
-queueinfo Get information on queued work units
-delete x Delete item #x from work queue
-send x Send result #x to server then exit. Use x=all to send all results
-verbosity x Sets the output level, from 1 to 9 (max). The default is 3
-pause Pause after finishing & trying to send current unit
-oneunit Exit after completing one unit
-forceasm Force core assembly optimizations to be used if available
-advmethods Use new advanced scientific cores and/or work units if available
-gpu x Run GPU code on the specified display number
-service Run in service mode (for programs such as firedaemon)
-local Use configuration files from local directory
Please note the above recognized flags and try again.
Press any key to exit.
Edit:
I got it to work finally now im folding with smp
, thanks for the help guys.
Bad argument: -smp
Options:
Edit:
Is there some reason you are running the older unsupported SMP client? --> v5.91beta6
The newest is v6.24.
kpe1950
Holy Jeevuss um I have no idea, I downloaded the 6.23 then inserted tehdrop in update...
Folding@Home Client Version 5.91beta6 <<wth
There must be something left from behind of something?
This is what I installed FAH6.23beta-win32-SMP-mpich + drop in update
kpe1950
Ok I see, I have downloaded and installed the MPICH and Not the (for Deino MPI) 5.92v. , because of the name, thought had a selection between the two , wiki has for MPICH. wiki so wrong outdated or something maybe its my fault.
Edit:
OKOK I am so confused Now, i am using this page http://folding.stanford.edu/English/DownloadWinOther is that the right download section? reason for the 5.91 the 64 bit. is Windows XP/2003/Vista/2008 SMP client console version 6.23 beta for MPICH (32-bit or 64-bit). but then it says 5.91 and not 6.24 I am very confused now...
Edit:
Yes, correct page. Still didn't read the NOTE on that download page yet, eh?
Here it is for your convenience:
Install.
Then download this v6.24 update: http://www.stanford.edu/~kasson/folding ... 32-x86.exe
Drop in the .exe on top of the previous version.
Run.
You're Welcome.
Download this: http://www.stanford.edu/group/pandegrou ... -mpich.exeNOTE: Please use the v6.23 installer package to setup the SMP client. Then download the v6.24 "drop-in" binary below to replace the expired v6.23 client executable. A new installer package with v6.24 will follow shortly.
Install.
Run.
You're Welcome.
kpe1950
Nice.
Thank you.
Thank you.
