F@H Application Question?
kpe1950
Hardware configuration: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Motherboard: P5N32-E SLI
Processor: Pentium D CPU 3.40GHz OCED @4.40GHz@1033MHzFSB
Memory: G.Skill F2-8500CL5D-4GBPQ 4 Gig
Video Card: GeForce 6600 LE OCED@ Core@444MHz Memory@535
http://valid.canardpc.com/show_oc.php?id=701874
Post by kpe1950 »
Ok, I am running a Pentium D 945 processor, it is a dual core processor.
At the moment right now I am running Two 6.23v F@H console clients as services, one for each core "No HT".
My question is, Would it be better to run the FAH6.23beta-win32-SMP-mpich vs the two console clients? I am aware of the bugs on smp-mpich.
Should I stick to what I am using atm.
I read this but does not state how old dual core is old.
FAH6.23beta-win32-SMP-mpich:
You must have a computer with at least a recent dual core processor or better to run the SMP client. This also means older single core processors will not meet the very short work unit deadlines.
My processor is 24/7 stable@ http://valid.canardpc.com/show_oc.php?id=699091
patonb
Re: F@H Application Question?
Post by patonb »
You can always try.. I run a smp on an e2180 dual @ 2.0Ghz, and easilycome in under deadline.... Thats the important thing, the deadlines are like 7 days.
If you can do it, giver.
kpe1950
Post by kpe1950 »
Alright I will give err a shot and thanx for the example. 8-)
If my memories are correct, the minimum clock speed for a Pentium D to make Windows SMP deadlines was 2.5 GHz ... ;)
