can not connect to assign.stanford.edu or assign2. or etc.
poyaochuang
I can not connect to
assign.stanford.edu:8080
assign2.stanford.edu:80
folding.stanford.edu
stanford.edu
can not ping or tracert to
stanford.edu
171.65.103.100 (from examples in issues with server forum)
can ping or tracert to (from examples in issues with server forum)
171.67.108.17
171.67.108.24
171.64.65.56
stanford.edu
stanford.edu
171.67.108.17
171.67.108.24
171.64.65.56
Re: can not connect to assign.stanford.edu or assign2. or etc.
They work for me.
Somehow your ISP is taking a different route than mine is, or you've got a firewall that's blocking your connection.
How about "tracert assign.stanford.edu"
poyaochuang
finally it worked
after delete the node's ip from dhcp server and restart
or suddenly it work
dont know the real solution
how does dhcp server assign ip to node?
lent out same ip based on mac address in its memory for reference? guessing
because this node was assigned the same ip repeatedly, and thought this specific ip was the problem
or suddenly it work
poyaochuang
machine #1: vmware esxi ubuntu9.04 6.24beta 988mb quad 2.0ghz
--- Opening Log file [October 27 06:12:22 UTC]
# Linux Console Edition #######################################################
Folding@Home Client Version 6.24beta
http://folding.stanford.edu
Launch directory: /home/poyaochuang/folding
Executable: ./fah6
Arguments: -configonly
[06:12:22] Configuring Folding@Home...
[06:15:15] - Ask before connecting: No
[06:15:15] - User name: poyaochuang (Team 3213)
[06:15:15] - User ID not found locally
[06:15:15] + Requesting User ID from server
[06:15:15] - Getting ID from AS:
[06:15:15] Connecting to http://assign.stanford.edu:8080/
[06:18:25] - Couldn't send HTTP request to server
[06:18:25] + Could not connect to Primary Assignment Server for ID
[06:18:25] Connecting to http://assign2.stanford.edu:80/
[06:18:25] + Could not connect to Secondary Assignment Server for ID
[06:18:25]
+ Could not get ID from server. Retrying...
[06:18:38] - Getting ID from AS:
[06:18:38] Connecting to http://assign.stanford.edu:8080/
[06:21:47] - Couldn't send HTTP request to server
[06:21:47] + Could not connect to Primary Assignment Server for ID
[06:21:47] Connecting to http://assign2.stanford.edu:80/
[06:21:48] - Couldn't send HTTP request to server
[06:21:48] + Could not connect to Secondary Assignment Server for ID
[06:21:48]
[06:22:13] - Getting ID from AS:
[06:22:13] Connecting to http://assign.stanford.edu:8080/
[06:25:22] - Couldn't send HTTP request to server
[06:25:22] + Could not connect to Primary Assignment Server for ID
[06:25:22] Connecting to http://assign2.stanford.edu:80/
[06:25:22] + Could not connect to Secondary Assignment Server for ID
[06:25:22]
[06:25:52] - Getting ID from AS:
[06:25:52] Connecting to http://assign.stanford.edu:8080/
[06:29:01] - Couldn't send HTTP request to server
[06:29:01] + Could not connect to Primary Assignment Server for ID
[06:29:01] Connecting to http://assign2.stanford.edu:80/
[06:29:01] + Could not connect to Secondary Assignment Server for ID
[06:29:01]
[06:29:46] - Getting ID from AS:
[06:29:46] Connecting to http://assign.stanford.edu:8080/
[06:32:55] - Couldn't send HTTP request to server
[06:32:55] + Could not connect to Primary Assignment Server for ID
[06:32:55] Connecting to http://assign2.stanford.edu:80/
[06:32:55] + Could not connect to Secondary Assignment Server for ID
[06:32:55]
[06:34:28] - Getting ID from AS:
[06:34:28] Connecting to http://assign.stanford.edu:8080/
[06:37:37] - Couldn't send HTTP request to server
[06:37:37] + Could not connect to Primary Assignment Server for ID
[06:37:37] Connecting to http://assign2.stanford.edu:80/
[06:37:37] + Could not connect to Secondary Assignment Server for ID
[06:37:37]
[06:40:26] - Getting ID from AS:
[06:40:26] Connecting to http://assign.stanford.edu:8080/
[06:43:35] - Couldn't send HTTP request to server
[06:43:35] + Could not connect to Primary Assignment Server for ID
[06:43:35] Connecting to http://assign2.stanford.edu:80/
[06:43:35] + Could not connect to Secondary Assignment Server for ID
[06:43:35]
[06:49:10] - Getting ID from AS:
[06:49:10] Connecting to http://assign.stanford.edu:8080/
[06:52:19] - Couldn't send HTTP request to server
[06:52:19] + Could not connect to Primary Assignment Server for ID
[06:52:19] Connecting to http://assign2.stanford.edu:80/
[06:52:19] + Could not connect to Secondary Assignment Server for ID
[06:52:19]
[07:03:00] - Getting ID from AS:
[07:03:00] Connecting to http://assign.stanford.edu:8080/
[07:06:09] - Couldn't send HTTP request to server
[07:06:09] + Could not connect to Primary Assignment Server for ID
[07:06:09] Connecting to http://assign2.stanford.edu:80/
[07:06:15] - Couldn't send HTTP request to server
[07:06:15] + Could not connect to Secondary Assignment Server for ID
[07:06:15]
[07:27:41] - Getting ID from AS:
[07:27:41] Connecting to http://assign.stanford.edu:8080/
[07:30:50] - Couldn't send HTTP request to server
[07:30:50] + Could not connect to Primary Assignment Server for ID
[07:30:50] Connecting to http://assign2.stanford.edu:80/
[07:30:51] - Couldn't send HTTP request to server
[07:30:51] + Could not connect to Secondary Assignment Server for ID
[07:30:51]
[08:13:34] - Getting ID from AS:
[08:13:34] Connecting to http://assign.stanford.edu:8080/
[08:16:44] - Couldn't send HTTP request to server
[08:16:44] + Could not connect to Primary Assignment Server for ID
[08:16:44] Connecting to http://assign2.stanford.edu:80/
[08:16:44] + Could not connect to Secondary Assignment Server for ID
[08:16:44] - Fatal: Could not get new user ID
[08:16:44] Configuring Folding@Home...
[09:22:15] - Ask before connecting: No
[09:22:15] - User name: poyaochuang (Team 3213)
[09:22:15] - User ID not found locally
[09:22:15] + Requesting User ID from server
[09:22:15] - Getting ID from AS:
[09:22:15] Connecting to http://assign.stanford.edu:8080/
[09:25:25] - Couldn't send HTTP request to server
[09:25:25] + Could not connect to Primary Assignment Server for ID
[09:25:25] Connecting to http://assign2.stanford.edu:80/
[09:25:25] + Could not connect to Secondary Assignment Server for ID
[09:25:25]
[09:25:34] - Getting ID from AS:
[09:25:34] Connecting to http://assign.stanford.edu:8080/
[09:28:43] - Couldn't send HTTP request to server
[09:28:43] + Could not connect to Primary Assignment Server for ID
[09:28:43] Connecting to http://assign2.stanford.edu:80/
[09:28:43] + Could not connect to Secondary Assignment Server for ID
[09:28:43]
[09:28:58] - Getting ID from AS:
[09:28:58] Connecting to http://assign.stanford.edu:8080/
[09:32:07] - Couldn't send HTTP request to server
[09:32:07] + Could not connect to Primary Assignment Server for ID
[09:32:07] Connecting to http://assign2.stanford.edu:80/
[09:32:09] - Couldn't send HTTP request to server
[09:32:09] + Could not connect to Secondary Assignment Server for ID
[09:32:09]
[09:32:34] - Getting ID from AS:
[09:32:34] Connecting to http://assign.stanford.edu:8080/
[09:35:43] - Couldn't send HTTP request to server
[09:35:43] + Could not connect to Primary Assignment Server for ID
[09:35:43] Connecting to http://assign2.stanford.edu:80/
[09:35:44] - Couldn't send HTTP request to server
[09:35:44] + Could not connect to Secondary Assignment Server for ID
[09:35:44]
[09:36:27] - Getting ID from AS:
[09:36:27] Connecting to http://assign.stanford.edu:8080/
[09:39:37] - Couldn't send HTTP request to server
[09:39:37] + Could not connect to Primary Assignment Server for ID
[09:39:37] Connecting to http://assign2.stanford.edu:80/
[09:39:37] + Could not connect to Secondary Assignment Server for ID
[09:39:37]
[09:41:12] - Getting ID from AS:
[09:41:12] Connecting to http://assign.stanford.edu:8080/
[09:44:21] - Couldn't send HTTP request to server
[09:44:21] + Could not connect to Primary Assignment Server for ID
[09:44:21] Connecting to http://assign2.stanford.edu:80/
[09:44:21] + Could not connect to Secondary Assignment Server for ID
[09:44:21]
[09:47:16] - Getting ID from AS:
[09:47:16] Connecting to http://assign.stanford.edu:8080/
[09:50:25] - Couldn't send HTTP request to server
[09:50:25] + Could not connect to Primary Assignment Server for ID
[09:50:25] Connecting to http://assign2.stanford.edu:80/
[09:50:25] + Could not connect to Secondary Assignment Server for ID
[09:50:25]
[09:55:45] - Getting ID from AS:
[09:55:45] Connecting to http://assign.stanford.edu:8080/
[09:58:54] - Couldn't send HTTP request to server
[09:58:54] + Could not connect to Primary Assignment Server for ID
[09:58:54] Connecting to http://assign2.stanford.edu:80/
[09:58:55] - Couldn't send HTTP request to server
[09:58:55] + Could not connect to Secondary Assignment Server for ID
[09:58:55]
[10:09:42] - Getting ID from AS:
[10:09:42] Connecting to http://assign.stanford.edu:8080/
[10:12:52] - Couldn't send HTTP request to server
[10:12:52] + Could not connect to Primary Assignment Server for ID
[10:12:52] Connecting to http://assign2.stanford.edu:80/
[10:12:52] + Could not connect to Secondary Assignment Server for ID
[10:12:52]
[10:34:23] - Getting ID from AS:
[10:34:23] Connecting to http://assign.stanford.edu:8080/
[10:37:32] - Couldn't send HTTP request to server
[10:37:32] + Could not connect to Primary Assignment Server for ID
[10:37:32] Connecting to http://assign2.stanford.edu:80/
[10:37:32] + Could not connect to Secondary Assignment Server for ID
[10:37:32]
[11:20:16] - Getting ID from AS:
[11:20:16] Connecting to http://assign.stanford.edu:8080/
[11:23:25] - Couldn't send HTTP request to server
[11:23:25] + Could not connect to Primary Assignment Server for ID
[11:23:25] Connecting to http://assign2.stanford.edu:80/
[11:23:26] - Couldn't send HTTP request to server
[11:23:26] + Could not connect to Secondary Assignment Server for ID
[11:23:26] - Fatal: Could not get new user ID
[11:23:26] Configuring Folding@Home...
[00:58:15] - Ask before connecting: No
[00:58:15] - User name: poyaochuang (Team 3213)
[00:58:15] - User ID not found locally
[00:58:15] + Requesting User ID from server
[00:58:15] - Getting ID from AS:
[00:58:15] Connecting to http://assign.stanford.edu:8080/
[01:01:24] - Couldn't send HTTP request to server
[01:01:24] + Could not connect to Primary Assignment Server for ID
[01:01:24] Connecting to http://assign2.stanford.edu:80/
[01:01:25] - Couldn't send HTTP request to server
[01:01:25] + Could not connect to Secondary Assignment Server for ID
poyaochuang
machine #2 windows xp 6.23console e5300 2048mb
[09:40:42] - Ask before connecting: No
[09:40:42] - User name: poyaochuang (Team 3213)
[09:40:42] - User ID: 243BFA7A3FDE8FF6
[09:40:42] - Machine ID: 1
[09:40:42]
[09:40:42] Loaded queue successfully.
[09:40:42]
[09:40:42] + Processing work unit
[09:40:42] Core required: FahCore_78.exe
[09:40:42] Core found.
[09:40:43] Working on queue slot 01 [October 27 09:40:43 UTC]
[09:40:43] + Working ...
[09:40:43]
[09:40:43] *------------------------------*
[09:40:43] Folding@Home Gromacs Core
[09:40:43] Version 1.90 (March 8, 2006)
[09:40:43]
[09:40:43] Preparing to commence simulation
[09:40:43] - Looking at optimizations...
[09:40:43] - Files status OK
[09:40:45] - Expanded 2974782 -> 15090201 (decompressed 507.2 percent)
[09:40:46]
[09:40:46] Project: 2493 (Run 194, Clone 18, Gen 3)
[09:40:46]
[09:40:47] Assembly optimizations on if available.
[09:40:47] Entering M.D.
[09:41:08] (Starting from checkpoint)
[09:41:08] Protein: system
[09:41:08]
[09:41:08] Writing local files
[09:41:08] Completed 247500 out of 250000 steps (99%)
[09:41:10] Extra SSE boost OK.
[10:08:42] Writing local files
[10:08:42] Completed 250000 out of 250000 steps (100%)
[10:08:42] Writing final coordinates.
[10:08:43] Past main M.D. loop
[10:09:43]
[10:09:43] Finished Work Unit:
[10:09:43] - Reading up to 2297808 from "work/wudata_01.arc": Read 2297808
[10:09:43] - Reading up to 136008 from "work/wudata_01.xtc": Read 136008
[10:09:43] goefile size: 0
[10:09:43] logfile size: 47537
[10:09:43] Leaving Run
[10:09:46] - Writing 2499529 bytes of core data to disk...
[10:09:46] ... Done.
[10:09:46] - Shutting down core
[10:09:46]
[10:09:46] Folding@home Core Shutdown: FINISHED_UNIT
[10:09:49] CoreStatus = 64 (100)
[10:09:49] Sending work to server
[10:09:49] Project: 2493 (Run 194, Clone 18, Gen 3)
[10:09:49] - Read packet limit of 540015616... Set to 524286976.
[10:09:49] + Attempting to send results [October 27 10:09:49 UTC]
[10:10:09] + Results successfully sent
[10:10:09] Thank you for your contribution to Folding@Home.
[10:10:09] + Number of Units Completed: 3
[10:10:13] - Preparing to get new work unit...
[10:10:13] + Attempting to get work packet
[10:10:13] - Connecting to assignment server
[10:10:34] - Couldn't send HTTP request to server
[10:10:34] + Could not connect to Assignment Server
[10:10:35] - Couldn't send HTTP request to server
[10:10:35] + Could not connect to Assignment Server 2
[10:10:35] + Couldn't get work instructions.
[10:10:35] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[10:10:46] + Attempting to get work packet
[10:10:46] - Connecting to assignment server
[10:11:07] - Couldn't send HTTP request to server
[10:11:07] + Could not connect to Assignment Server
[10:11:08] - Couldn't send HTTP request to server
[10:11:08] + Could not connect to Assignment Server 2
[10:11:08] + Couldn't get work instructions.
[10:11:08] - Attempt #2 to get work failed, and no other work to do.
[10:11:19] + Attempting to get work packet
[10:11:19] - Connecting to assignment server
[10:11:40] - Couldn't send HTTP request to server
[10:11:40] + Could not connect to Assignment Server
[10:11:41] - Couldn't send HTTP request to server
[10:11:41] + Could not connect to Assignment Server 2
[10:11:41] + Couldn't get work instructions.
[10:11:41] - Attempt #3 to get work failed, and no other work to do.
[10:12:12] + Attempting to get work packet
[10:12:12] - Connecting to assignment server
[10:12:33] - Couldn't send HTTP request to server
[10:12:33] + Could not connect to Assignment Server
[10:12:35] - Couldn't send HTTP request to server
[10:12:35] + Could not connect to Assignment Server 2
[10:12:35] + Couldn't get work instructions.
[10:12:35] - Attempt #4 to get work failed, and no other work to do.
[10:13:26] + Attempting to get work packet
[10:13:26] - Connecting to assignment server
[10:13:47] - Couldn't send HTTP request to server
[10:13:47] + Could not connect to Assignment Server
[10:13:48] - Couldn't send HTTP request to server
[10:13:48] + Could not connect to Assignment Server 2
[10:13:48] + Couldn't get work instructions.
[10:13:48] - Attempt #5 to get work failed, and no other work to do.
[10:15:09] + Attempting to get work packet
[10:15:09] - Connecting to assignment server
[10:15:30] - Couldn't send HTTP request to server
[10:15:30] + Could not connect to Assignment Server
[10:15:31] - Couldn't send HTTP request to server
[10:15:31] + Could not connect to Assignment Server 2
[10:15:31] + Couldn't get work instructions.
[10:15:31] - Attempt #6 to get work failed, and no other work to do.
[10:18:26] + Attempting to get work packet
[10:18:26] - Connecting to assignment server
[10:18:47] - Couldn't send HTTP request to server
[10:18:47] + Could not connect to Assignment Server
[10:18:48] - Couldn't send HTTP request to server
[10:18:48] + Could not connect to Assignment Server 2
[10:18:48] + Couldn't get work instructions.
[10:18:48] - Attempt #7 to get work failed, and no other work to do.
[10:24:13] + Attempting to get work packet
[10:24:13] - Connecting to assignment server
[10:24:34] - Couldn't send HTTP request to server
[10:24:34] + Could not connect to Assignment Server
[10:24:36] - Couldn't send HTTP request to server
[10:24:36] + Could not connect to Assignment Server 2
[10:24:36] + Couldn't get work instructions.
[10:24:36] - Attempt #8 to get work failed, and no other work to do.
[10:35:29] + Attempting to get work packet
[10:35:29] - Connecting to assignment server
[10:35:50] - Couldn't send HTTP request to server
[10:35:50] + Could not connect to Assignment Server
[10:35:52] - Couldn't send HTTP request to server
[10:35:52] + Could not connect to Assignment Server 2
[10:35:52] + Couldn't get work instructions.
[10:35:52] - Attempt #9 to get work failed, and no other work to do.
[10:57:24] + Attempting to get work packet
[10:57:24] - Connecting to assignment server
[10:57:45] - Couldn't send HTTP request to server
[10:57:45] + Could not connect to Assignment Server
[10:57:47] - Couldn't send HTTP request to server
[10:57:47] + Could not connect to Assignment Server 2
[10:57:47] + Couldn't get work instructions.
[10:57:47] - Attempt #10 to get work failed, and no other work to do.
[11:40:40] + Attempting to get work packet
[11:40:40] - Connecting to assignment server
[11:41:01] - Couldn't send HTTP request to server
[11:41:01] + Could not connect to Assignment Server
[11:41:08] - Couldn't send HTTP request to server
[11:41:08] + Could not connect to Assignment Server 2
[11:41:08] + Couldn't get work instructions.
[11:41:08] - Attempt #11 to get work failed, and no other work to do.
[12:29:10] + Attempting to get work packet
[12:29:10] - Connecting to assignment server
[12:29:31] - Couldn't send HTTP request to server
[12:29:31] + Could not connect to Assignment Server
[12:29:32] - Couldn't send HTTP request to server
[12:29:32] + Could not connect to Assignment Server 2
[12:29:32] + Couldn't get work instructions.
[12:29:32] - Attempt #12 to get work failed, and no other work to do.
[13:17:39] + Attempting to get work packet
[13:17:39] - Connecting to assignment server
[13:18:00] - Couldn't send HTTP request to server
[13:18:00] + Could not connect to Assignment Server
[13:18:07] - Couldn't send HTTP request to server
[13:18:07] + Could not connect to Assignment Server 2
[13:18:07] + Couldn't get work instructions.
[13:18:07] - Attempt #13 to get work failed, and no other work to do.
[14:06:15] + Attempting to get work packet
[14:06:15] - Connecting to assignment server
[14:06:36] - Couldn't send HTTP request to server
[14:06:36] + Could not connect to Assignment Server
[14:06:43] - Couldn't send HTTP request to server
[14:06:43] + Could not connect to Assignment Server 2
[14:06:43] + Couldn't get work instructions.
[14:06:43] - Attempt #14 to get work failed, and no other work to do.
[14:54:56] + Attempting to get work packet
[14:54:56] - Connecting to assignment server
[14:55:17] - Couldn't send HTTP request to server
[14:55:17] + Could not connect to Assignment Server
[14:55:24] - Couldn't send HTTP request to server
[14:55:24] + Could not connect to Assignment Server 2
[14:55:24] + Couldn't get work instructions.
[14:55:24] - Attempt #15 to get work failed, and no other work to do.
[15:43:37] + Attempting to get work packet
[15:43:37] - Connecting to assignment server
[15:43:58] - Couldn't send HTTP request to server
[15:43:58] + Could not connect to Assignment Server
[15:44:05] - Couldn't send HTTP request to server
[15:44:05] + Could not connect to Assignment Server 2
[15:44:05] + Couldn't get work instructions.
[15:44:05] - Attempt #16 to get work failed, and no other work to do.
[16:32:10] + Attempting to get work packet
[16:32:10] - Connecting to assignment server
[16:32:31] - Couldn't send HTTP request to server
[16:32:31] + Could not connect to Assignment Server
[16:32:44] - Couldn't send HTTP request to server
[16:32:44] + Could not connect to Assignment Server 2
[16:32:44] + Couldn't get work instructions.
[16:32:44] - Attempt #17 to get work failed, and no other work to do.
[17:20:47] + Attempting to get work packet
[17:20:47] - Connecting to assignment server
[17:21:08] - Couldn't send HTTP request to server
[17:21:08] + Could not connect to Assignment Server
[17:21:15] - Couldn't send HTTP request to server
[17:21:15] + Could not connect to Assignment Server 2
[17:21:15] + Couldn't get work instructions.
[17:21:15] - Attempt #18 to get work failed, and no other work to do.
[18:09:25] + Attempting to get work packet
[18:09:25] - Connecting to assignment server
[18:09:46] - Couldn't send HTTP request to server
[18:09:46] + Could not connect to Assignment Server
[18:09:53] - Couldn't send HTTP request to server
[18:09:53] + Could not connect to Assignment Server 2
[18:09:53] + Couldn't get work instructions.
[18:09:53] - Attempt #19 to get work failed, and no other work to do.
[18:58:05] + Attempting to get work packet
[18:58:05] - Connecting to assignment server
[18:58:26] - Couldn't send HTTP request to server
[18:58:26] + Could not connect to Assignment Server
[18:58:34] - Couldn't send HTTP request to server
[18:58:34] + Could not connect to Assignment Server 2
[18:58:34] + Couldn't get work instructions.
[18:58:34] - Attempt #20 to get work failed, and no other work to do.
[19:46:40] + Attempting to get work packet
[19:46:40] - Connecting to assignment server
[19:47:02] - Couldn't send HTTP request to server
[19:47:02] + Could not connect to Assignment Server
[19:47:08] - Couldn't send HTTP request to server
[19:47:08] + Could not connect to Assignment Server 2
[19:47:08] + Couldn't get work instructions.
[19:47:08] - Attempt #21 to get work failed, and no other work to do.
[20:35:17] + Attempting to get work packet
[20:35:17] - Connecting to assignment server
[20:35:38] - Couldn't send HTTP request to server
[20:35:38] + Could not connect to Assignment Server
[20:35:45] - Couldn't send HTTP request to server
[20:35:45] + Could not connect to Assignment Server 2
[20:35:45] + Couldn't get work instructions.
[20:35:45] - Attempt #22 to get work failed, and no other work to do.
[21:23:46] + Attempting to get work packet
[21:23:46] - Connecting to assignment server
[21:24:07] - Couldn't send HTTP request to server
[21:24:07] + Could not connect to Assignment Server
[21:24:14] - Couldn't send HTTP request to server
[21:24:14] + Could not connect to Assignment Server 2
[21:24:14] + Couldn't get work instructions.
[21:24:14] - Attempt #23 to get work failed, and no other work to do.
[22:12:14] + Attempting to get work packet
[22:12:14] - Connecting to assignment server
[22:12:35] - Couldn't send HTTP request to server
[22:12:35] + Could not connect to Assignment Server
[22:12:49] - Couldn't send HTTP request to server
[22:12:49] + Could not connect to Assignment Server 2
[22:12:49] + Couldn't get work instructions.
[22:12:49] - Attempt #24 to get work failed, and no other work to do.
[23:00:52] + Attempting to get work packet
[23:00:52] - Connecting to assignment server
[23:01:13] - Couldn't send HTTP request to server
[23:01:13] + Could not connect to Assignment Server
[23:01:20] - Couldn't send HTTP request to server
[23:01:20] + Could not connect to Assignment Server 2
[23:01:20] + Couldn't get work instructions.
[23:01:20] - Attempt #25 to get work failed, and no other work to do.
[23:49:30] + Attempting to get work packet
[23:49:30] - Connecting to assignment server
[23:49:51] - Couldn't send HTTP request to server
[23:49:51] + Could not connect to Assignment Server
[23:49:53] - Couldn't send HTTP request to server
[23:49:53] + Could not connect to Assignment Server 2
[23:49:53] + Couldn't get work instructions.
[23:49:53] - Attempt #26 to get work failed, and no other work to do.
[00:38:06] + Attempting to get work packet
[00:38:06] - Connecting to assignment server
[00:38:28] - Couldn't send HTTP request to server
[00:38:28] + Could not connect to Assignment Server
[00:38:34] - Couldn't send HTTP request to server
[00:38:34] + Could not connect to Assignment Server 2
[00:38:34] + Couldn't get work instructions.
[00:38:34] - Attempt #27 to get work failed, and no other work to do.
Waiting before retry.-
poyaochuang
machine #3 windows xp pentium m1400mhz 512mb 6.23console
Launch directory: C:\FAH
Service: C:\FAH\fah6
Arguments: -svcstart -d C:\FAH -verbosity 9
Launched as a service.
Entered C:\FAH to do work.
[08:46:43] - Ask before connecting: No
[08:46:43] - User name: poyaochuang (Team 3213)
[08:46:43] - User ID: 24A199D520F4CFEA
[08:46:43] - Machine ID: 1
[08:46:43]
[08:46:43] Loaded queue successfully.
[08:46:43] - Preparing to get new work unit...
[08:46:43] - Autosending finished units... [October 27 08:46:43 UTC]
[08:46:43] Trying to send all finished work units
[08:46:43] + No unsent completed units remaining.
[08:46:43] - Autosend completed
[08:46:43] + Attempting to get work packet
[08:46:43] - Will indicate memory of 510 MB
[08:46:43] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 9, Stepping: 5
[08:46:43] - Connecting to assignment server
[08:46:43] Connecting to http://assign.stanford.edu:8080/
[08:47:04] - Couldn't send HTTP request to server
[08:47:04] + Could not connect to Assignment Server
[08:47:04] Connecting to http://assign2.stanford.edu:80/
[08:47:05] - Couldn't send HTTP request to server
[08:47:05] + Could not connect to Assignment Server 2
[08:47:05] + Couldn't get work instructions.
[08:47:05] - Attempt #1 to get work failed, and no other work to do.
[08:47:17] + Attempting to get work packet
[08:47:17] - Will indicate memory of 510 MB
[08:47:17] - Connecting to assignment server
[08:47:17] Connecting to http://assign.stanford.edu:8080/
[08:47:38] - Couldn't send HTTP request to server
[08:47:38] + Could not connect to Assignment Server
[08:47:38] Connecting to http://assign2.stanford.edu:80/
[08:47:45] - Couldn't send HTTP request to server
[08:47:45] + Could not connect to Assignment Server 2
[08:47:45] + Couldn't get work instructions.
[08:47:45] - Attempt #2 to get work failed, and no other work to do.
[08:48:01] + Attempting to get work packet
[08:48:01] - Will indicate memory of 510 MB
[08:48:01] - Connecting to assignment server
[08:48:01] Connecting to http://assign.stanford.edu:8080/
[08:48:22] - Couldn't send HTTP request to server
[08:48:22] + Could not connect to Assignment Server
[08:48:22] Connecting to http://assign2.stanford.edu:80/
[08:48:23] - Couldn't send HTTP request to server
[08:48:23] + Could not connect to Assignment Server 2
[08:48:23] + Couldn't get work instructions.
[08:48:23] - Attempt #3 to get work failed, and no other work to do.
[08:48:48] + Attempting to get work packet
[08:48:48] - Will indicate memory of 510 MB
[08:48:48] - Connecting to assignment server
[08:48:48] Connecting to http://assign.stanford.edu:8080/
[08:49:09] - Couldn't send HTTP request to server
[08:49:09] + Could not connect to Assignment Server
[08:49:09] Connecting to http://assign2.stanford.edu:80/
[08:49:10] - Couldn't send HTTP request to server
[08:49:10] + Could not connect to Assignment Server 2
[08:49:10] + Couldn't get work instructions.
[08:49:10] - Attempt #4 to get work failed, and no other work to do.
[08:49:52] + Attempting to get work packet
[08:49:52] - Will indicate memory of 510 MB
[08:49:52] - Connecting to assignment server
[08:49:52] Connecting to http://assign.stanford.edu:8080/
[08:50:13] - Couldn't send HTTP request to server
[08:50:13] + Could not connect to Assignment Server
[08:50:13] Connecting to http://assign2.stanford.edu:80/
[08:50:27] - Couldn't send HTTP request to server
[08:50:27] + Could not connect to Assignment Server 2
[08:50:27] + Couldn't get work instructions.
[08:50:27] - Attempt #5 to get work failed, and no other work to do.
[08:51:55] + Attempting to get work packet
[08:51:55] - Will indicate memory of 510 MB
[08:51:55] - Connecting to assignment server
[08:51:55] Connecting to http://assign.stanford.edu:8080/
[08:52:16] - Couldn't send HTTP request to server
[08:52:16] + Could not connect to Assignment Server
[08:52:16] Connecting to http://assign2.stanford.edu:80/
[08:52:18] - Couldn't send HTTP request to server
[08:52:18] + Could not connect to Assignment Server 2
[08:52:18] + Couldn't get work instructions.
[08:52:18] - Attempt #6 to get work failed, and no other work to do.
[08:55:08] + Attempting to get work packet
[08:55:08] - Will indicate memory of 510 MB
[08:55:08] - Connecting to assignment server
[08:55:08] Connecting to http://assign.stanford.edu:8080/
[08:55:29] - Couldn't send HTTP request to server
[08:55:29] + Could not connect to Assignment Server
[08:55:29] Connecting to http://assign2.stanford.edu:80/
[08:55:37] - Couldn't send HTTP request to server
[08:55:37] + Could not connect to Assignment Server 2
[08:55:37] + Couldn't get work instructions.
[08:55:37] - Attempt #7 to get work failed, and no other work to do.
[09:01:07] + Attempting to get work packet
[09:01:07] - Will indicate memory of 510 MB
[09:01:07] - Connecting to assignment server
[09:01:07] Connecting to http://assign.stanford.edu:8080/
[09:01:28] - Couldn't send HTTP request to server
[09:01:28] + Could not connect to Assignment Server
[09:01:28] Connecting to http://assign2.stanford.edu:80/
[09:01:40] - Couldn't send HTTP request to server
[09:01:40] + Could not connect to Assignment Server 2
[09:01:40] + Couldn't get work instructions.
[09:01:40] - Attempt #8 to get work failed, and no other work to do.
[09:12:28] + Attempting to get work packet
[09:12:28] - Will indicate memory of 510 MB
[09:12:28] - Connecting to assignment server
[09:12:28] Connecting to http://assign.stanford.edu:8080/
[09:12:49] - Couldn't send HTTP request to server
[09:12:49] + Could not connect to Assignment Server
[09:12:49] Connecting to http://assign2.stanford.edu:80/
[09:12:51] - Couldn't send HTTP request to server
[09:12:51] + Could not connect to Assignment Server 2
[09:12:51] + Couldn't get work instructions.
[09:12:51] - Attempt #9 to get work failed, and no other work to do.
[09:34:23] + Attempting to get work packet
[09:34:23] - Will indicate memory of 510 MB
[09:34:23] - Connecting to assignment server
[09:34:23] Connecting to http://assign.stanford.edu:8080/
[09:34:44] - Couldn't send HTTP request to server
[09:34:44] + Could not connect to Assignment Server
[09:34:44] Connecting to http://assign2.stanford.edu:80/
[09:34:46] - Couldn't send HTTP request to server
[09:34:46] + Could not connect to Assignment Server 2
[09:34:46] + Couldn't get work instructions.
[09:34:46] - Attempt #10 to get work failed, and no other work to do.
[10:17:33] + Attempting to get work packet
[10:17:33] - Will indicate memory of 510 MB
[10:17:33] - Connecting to assignment server
[10:17:33] Connecting to http://assign.stanford.edu:8080/
[10:17:54] - Couldn't send HTTP request to server
[10:17:54] + Could not connect to Assignment Server
[10:17:54] Connecting to http://assign2.stanford.edu:80/
[10:18:00] - Couldn't send HTTP request to server
[10:18:00] + Could not connect to Assignment Server 2
[10:18:00] + Couldn't get work instructions.
[10:18:00] - Attempt #11 to get work failed, and no other work to do.
[11:06:11] + Attempting to get work packet
[11:06:11] - Will indicate memory of 510 MB
[11:06:11] - Connecting to assignment server
[11:06:11] Connecting to http://assign.stanford.edu:8080/
[11:06:32] - Couldn't send HTTP request to server
[11:06:32] + Could not connect to Assignment Server
[11:06:32] Connecting to http://assign2.stanford.edu:80/
[11:06:34] - Couldn't send HTTP request to server
[11:06:34] + Could not connect to Assignment Server 2
[11:06:34] + Couldn't get work instructions.
[11:06:34] - Attempt #12 to get work failed, and no other work to do.
[11:54:40] + Attempting to get work packet
[11:54:40] - Will indicate memory of 510 MB
[11:54:40] - Connecting to assignment server
[11:54:40] Connecting to http://assign.stanford.edu:8080/
[11:55:01] - Couldn't send HTTP request to server
[11:55:01] + Could not connect to Assignment Server
[11:55:01] Connecting to http://assign2.stanford.edu:80/
[11:55:08] - Couldn't send HTTP request to server
[11:55:08] + Could not connect to Assignment Server 2
[11:55:08] + Couldn't get work instructions.
[11:55:08] - Attempt #13 to get work failed, and no other work to do.
[12:43:21] + Attempting to get work packet
[12:43:21] - Will indicate memory of 510 MB
[12:43:21] - Connecting to assignment server
[12:43:21] Connecting to http://assign.stanford.edu:8080/
[12:43:42] - Couldn't send HTTP request to server
[12:43:42] + Could not connect to Assignment Server
[12:43:42] Connecting to http://assign2.stanford.edu:80/
[12:43:43] - Couldn't send HTTP request to server
[12:43:43] + Could not connect to Assignment Server 2
[12:43:43] + Couldn't get work instructions.
[12:43:43] - Attempt #14 to get work failed, and no other work to do.
[13:31:44] + Attempting to get work packet
[13:31:44] - Will indicate memory of 510 MB
[13:31:44] - Connecting to assignment server
[13:31:44] Connecting to http://assign.stanford.edu:8080/
[13:32:05] - Couldn't send HTTP request to server
[13:32:05] + Could not connect to Assignment Server
[13:32:05] Connecting to http://assign2.stanford.edu:80/
[13:32:12] - Couldn't send HTTP request to server
[13:32:12] + Could not connect to Assignment Server 2
[13:32:12] + Couldn't get work instructions.
[13:32:12] - Attempt #15 to get work failed, and no other work to do.
[14:20:17] + Attempting to get work packet
[14:20:17] - Will indicate memory of 510 MB
[14:20:17] - Connecting to assignment server
[14:20:17] Connecting to http://assign.stanford.edu:8080/
[14:20:38] - Couldn't send HTTP request to server
[14:20:38] + Could not connect to Assignment Server
[14:20:38] Connecting to http://assign2.stanford.edu:80/
[14:20:45] - Couldn't send HTTP request to server
[14:20:45] + Could not connect to Assignment Server 2
[14:20:45] + Couldn't get work instructions.
[14:20:45] - Attempt #16 to get work failed, and no other work to do.
[14:46:43] - Autosending finished units... [October 27 14:46:43 UTC]
[14:46:43] Trying to send all finished work units
[14:46:43] + No unsent completed units remaining.
[14:46:43] - Autosend completed
[15:08:51] + Attempting to get work packet
[15:08:51] - Will indicate memory of 510 MB
[15:08:51] - Connecting to assignment server
[15:08:51] Connecting to http://assign.stanford.edu:8080/
[15:09:12] - Couldn't send HTTP request to server
[15:09:12] + Could not connect to Assignment Server
[15:09:12] Connecting to http://assign2.stanford.edu:80/
[15:09:19] - Couldn't send HTTP request to server
[15:09:19] + Could not connect to Assignment Server 2
[15:09:19] + Couldn't get work instructions.
[15:09:19] - Attempt #17 to get work failed, and no other work to do.
[15:57:29] + Attempting to get work packet
[15:57:29] - Will indicate memory of 510 MB
[15:57:29] - Connecting to assignment server
[15:57:29] Connecting to http://assign.stanford.edu:8080/
[15:57:50] - Couldn't send HTTP request to server
[15:57:50] + Could not connect to Assignment Server
[15:57:50] Connecting to http://assign2.stanford.edu:80/
[15:57:57] - Couldn't send HTTP request to server
[15:57:57] + Could not connect to Assignment Server 2
[15:57:57] + Couldn't get work instructions.
[15:57:57] - Attempt #18 to get work failed, and no other work to do.
[16:46:01] + Attempting to get work packet
[16:46:01] - Will indicate memory of 510 MB
[16:46:01] - Connecting to assignment server
[16:46:01] Connecting to http://assign.stanford.edu:8080/
[16:46:22] - Couldn't send HTTP request to server
[16:46:22] + Could not connect to Assignment Server
[16:46:22] Connecting to http://assign2.stanford.edu:80/
[16:46:28] - Couldn't send HTTP request to server
[16:46:28] + Could not connect to Assignment Server 2
[16:46:28] + Couldn't get work instructions.
[16:46:28] - Attempt #19 to get work failed, and no other work to do.
[17:34:30] + Attempting to get work packet
[17:34:30] - Will indicate memory of 510 MB
[17:34:30] - Connecting to assignment server
[17:34:30] Connecting to http://assign.stanford.edu:8080/
[17:34:51] - Couldn't send HTTP request to server
[17:34:51] + Could not connect to Assignment Server
[17:34:51] Connecting to http://assign2.stanford.edu:80/
[17:34:58] - Couldn't send HTTP request to server
[17:34:58] + Could not connect to Assignment Server 2
[17:34:58] + Couldn't get work instructions.
[17:34:58] - Attempt #20 to get work failed, and no other work to do.
[18:23:02] + Attempting to get work packet
[18:23:02] - Will indicate memory of 510 MB
[18:23:02] - Connecting to assignment server
[18:23:02] Connecting to http://assign.stanford.edu:8080/
[18:23:23] - Couldn't send HTTP request to server
[18:23:23] + Could not connect to Assignment Server
[18:23:23] Connecting to http://assign2.stanford.edu:80/
[18:23:30] - Couldn't send HTTP request to server
[18:23:30] + Could not connect to Assignment Server 2
[18:23:30] + Couldn't get work instructions.
[18:23:30] - Attempt #21 to get work failed, and no other work to do.
[19:11:39] + Attempting to get work packet
[19:11:39] - Will indicate memory of 510 MB
[19:11:39] - Connecting to assignment server
[19:11:39] Connecting to http://assign.stanford.edu:8080/
[19:12:00] - Couldn't send HTTP request to server
[19:12:00] + Could not connect to Assignment Server
[19:12:00] Connecting to http://assign2.stanford.edu:80/
[19:12:07] - Couldn't send HTTP request to server
[19:12:07] + Could not connect to Assignment Server 2
[19:12:07] + Couldn't get work instructions.
[19:12:07] - Attempt #22 to get work failed, and no other work to do.
[20:00:10] + Attempting to get work packet
[20:00:10] - Will indicate memory of 510 MB
[20:00:10] - Connecting to assignment server
[20:00:10] Connecting to http://assign.stanford.edu:8080/
[20:00:31] - Couldn't send HTTP request to server
[20:00:31] + Could not connect to Assignment Server
[20:00:31] Connecting to http://assign2.stanford.edu:80/
[20:00:38] - Couldn't send HTTP request to server
[20:00:38] + Could not connect to Assignment Server 2
[20:00:38] + Couldn't get work instructions.
[20:00:38] - Attempt #23 to get work failed, and no other work to do.
[20:46:43] - Autosending finished units... [October 27 20:46:43 UTC]
[20:46:43] Trying to send all finished work units
[20:46:43] + No unsent completed units remaining.
[20:46:43] - Autosend completed
[20:48:41] + Attempting to get work packet
[20:48:41] - Will indicate memory of 510 MB
[20:48:41] - Connecting to assignment server
[20:48:41] Connecting to http://assign.stanford.edu:8080/
[20:49:02] - Couldn't send HTTP request to server
[20:49:02] + Could not connect to Assignment Server
[20:49:02] Connecting to http://assign2.stanford.edu:80/
[20:49:09] - Couldn't send HTTP request to server
[20:49:09] + Could not connect to Assignment Server 2
[20:49:09] + Couldn't get work instructions.
[20:49:09] - Attempt #24 to get work failed, and no other work to do.
[21:37:14] + Attempting to get work packet
[21:37:14] - Will indicate memory of 510 MB
[21:37:14] - Connecting to assignment server
[21:37:14] Connecting to http://assign.stanford.edu:8080/
[21:37:34] - Couldn't send HTTP request to server
[21:37:34] + Could not connect to Assignment Server
[21:37:34] Connecting to http://assign2.stanford.edu:80/
[21:37:41] - Couldn't send HTTP request to server
[21:37:41] + Could not connect to Assignment Server 2
[21:37:41] + Couldn't get work instructions.
[21:37:41] - Attempt #25 to get work failed, and no other work to do.
[22:25:56] + Attempting to get work packet
[22:25:56] - Will indicate memory of 510 MB
[22:25:56] - Connecting to assignment server
[22:25:56] Connecting to http://assign.stanford.edu:8080/
[22:26:16] - Couldn't send HTTP request to server
[22:26:16] + Could not connect to Assignment Server
[22:26:16] Connecting to http://assign2.stanford.edu:80/
[22:26:18] - Couldn't send HTTP request to server
[22:26:18] + Could not connect to Assignment Server 2
[22:26:18] + Couldn't get work instructions.
[22:26:18] - Attempt #26 to get work failed, and no other work to do.
[23:14:19] + Attempting to get work packet
[23:14:19] - Will indicate memory of 510 MB
[23:14:19] - Connecting to assignment server
[23:14:19] Connecting to http://assign.stanford.edu:8080/
[23:14:40] - Couldn't send HTTP request to server
[23:14:40] + Could not connect to Assignment Server
[23:14:40] Connecting to http://assign2.stanford.edu:80/
[23:14:53] - Couldn't send HTTP request to server
[23:14:53] + Could not connect to Assignment Server 2
[23:14:53] + Couldn't get work instructions.
[23:14:53] - Attempt #27 to get work failed, and no other work to do.
[00:02:55] + Attempting to get work packet
[00:02:55] - Will indicate memory of 510 MB
[00:02:55] - Connecting to assignment server
[00:02:55] Connecting to http://assign.stanford.edu:8080/
[00:03:16] - Couldn't send HTTP request to server
[00:03:16] + Could not connect to Assignment Server
[00:03:16] Connecting to http://assign2.stanford.edu:80/
[00:03:18] - Couldn't send HTTP request to server
[00:03:18] + Could not connect to Assignment Server 2
[00:03:18] + Couldn't get work instructions.
[00:03:18] - Attempt #28 to get work failed, and no other work to do.
[00:51:24] + Attempting to get work packet
[00:51:24] - Will indicate memory of 510 MB
[00:51:24] - Connecting to assignment server
[00:51:24] Connecting to http://assign.stanford.edu:8080/
[00:51:45] - Couldn't send HTTP request to server
[00:51:45] + Could not connect to Assignment Server
[00:51:45] Connecting to http://assign2.stanford.edu:80/
[00:51:47] - Couldn't send HTTP request to server
[00:51:47] + Could not connect to Assignment Server 2
[00:51:47] + Couldn't get work instructions.
[00:51:47] - Attempt #29 to get work failed, and no other work to do.
poyaochuang
machine #4 windows xp pentium 4 2.4mhz 767m 6.23console
[00:53:39] - Ask before connecting: No
[00:53:39] - User name: poyaochuang (Team 3213)
[00:53:39] - User ID: 307E24B6127D04AC
[00:53:39] - Machine ID: 1
[00:53:39]
[00:53:40] Loaded queue successfully.
[00:53:40] - Preparing to get new work unit...
[00:53:40] + Attempting to get work packet
[00:53:40] - Autosending finished units... [October 28 00:53:40 UTC]
[00:53:40] Trying to send all finished work units
[00:53:40] + No unsent completed units remaining.
[00:53:40] - Autosend completed
[00:53:40] - Will indicate memory of 199 MB
[00:53:40] - Detect CPU. Vendor: GenuineIntel, Family: 15, Model: 2, Stepping: 7
[00:53:40] - Connecting to assignment server
[00:53:40] Connecting to http://assign.stanford.edu:8080/
[00:53:40] - Could not CosmHTTPOpen
[00:53:40] + Could not connect to Assignment Server
[00:53:40] Connecting to http://assign2.stanford.edu:80/
[00:53:40] + Could not connect to Assignment Server 2
[00:53:40] + Couldn't get work instructions.
[00:53:40] - Attempt #1 to get work failed, and no other work to do.
[00:53:53] + Attempting to get work packet
[00:53:53] - Will indicate memory of 199 MB
[00:53:53] - Connecting to assignment server
[00:53:53] Connecting to http://assign.stanford.edu:8080/
[00:54:14] - Couldn't send HTTP request to server
[00:54:14] + Could not connect to Assignment Server
[00:54:14] Connecting to http://assign2.stanford.edu:80/
[00:54:15] - Couldn't send HTTP request to server
[00:54:15] + Could not connect to Assignment Server 2
[00:54:15] + Couldn't get work instructions.
[00:54:15] - Attempt #2 to get work failed, and no other work to do.
[00:54:40] + Attempting to get work packet
[00:54:40] - Will indicate memory of 199 MB
[00:54:40] - Connecting to assignment server
[00:54:40] Connecting to http://assign.stanford.edu:8080/
[00:55:01] - Couldn't send HTTP request to server
[00:55:01] + Could not connect to Assignment Server
[00:55:01] Connecting to http://assign2.stanford.edu:80/
[00:55:02] - Couldn't send HTTP request to server
[00:55:02] + Could not connect to Assignment Server 2
[00:55:02] + Couldn't get work instructions.
[00:55:02] - Attempt #3 to get work failed, and no other work to do.
[00:55:36] + Attempting to get work packet
[00:55:36] - Will indicate memory of 199 MB
[00:55:36] - Connecting to assignment server
[00:55:36] Connecting to http://assign.stanford.edu:8080/
[00:55:57] - Couldn't send HTTP request to server
[00:55:57] + Could not connect to Assignment Server
[00:55:57] Connecting to http://assign2.stanford.edu:80/
[00:55:59] - Couldn't send HTTP request to server
[00:55:59] + Could not connect to Assignment Server 2
[00:55:59] + Couldn't get work instructions.
[00:55:59] - Attempt #4 to get work failed, and no other work to do.
[00:56:48] + Attempting to get work packet
[00:56:48] - Will indicate memory of 199 MB
[00:56:48] - Connecting to assignment server
[00:56:48] Connecting to http://assign.stanford.edu:8080/
[00:57:09] - Couldn't send HTTP request to server
[00:57:09] + Could not connect to Assignment Server
[00:57:09] Connecting to http://assign2.stanford.edu:80/
[00:57:10] - Couldn't send HTTP request to server
[00:57:10] + Could not connect to Assignment Server 2
[00:57:10] + Couldn't get work instructions.
[00:57:10] - Attempt #5 to get work failed, and no other work to do.
[00:58:35] + Attempting to get work packet
[00:58:35] - Will indicate memory of 199 MB
[00:58:35] - Connecting to assignment server
[00:58:35] Connecting to http://assign.stanford.edu:8080/
[00:58:56] - Couldn't send HTTP request to server
[00:58:56] + Could not connect to Assignment Server
[00:58:56] Connecting to http://assign2.stanford.edu:80/
[00:58:58] - Couldn't send HTTP request to server
[00:58:58] + Could not connect to Assignment Server 2
[00:58:58] + Couldn't get work instructions.
[00:58:58] - Attempt #6 to get work failed, and no other work to do.
[01:01:40] + Attempting to get work packet
[01:01:40] - Will indicate memory of 199 MB
[01:01:40] - Connecting to assignment server
[01:01:40] Connecting to http://assign.stanford.edu:8080/
[01:02:01] - Couldn't send HTTP request to server
[01:02:01] + Could not connect to Assignment Server
[01:02:01] Connecting to http://assign2.stanford.edu:80/
[01:02:02] - Couldn't send HTTP request to server
[01:02:02] + Could not connect to Assignment Server 2
[01:02:02] + Couldn't get work instructions.
[01:02:02] - Attempt #7 to get work failed, and no other work to do.
[01:07:23] + Attempting to get work packet
[01:07:23] - Will indicate memory of 199 MB
[01:07:23] - Connecting to assignment server
[01:07:23] Connecting to http://assign.stanford.edu:8080/
[01:07:44] - Couldn't send HTTP request to server
[01:07:44] + Could not connect to Assignment Server
[01:07:44] Connecting to http://assign2.stanford.edu:80/
[01:07:46] - Couldn't send HTTP request to server
[01:07:46] + Could not connect to Assignment Server 2
[01:07:46] + Couldn't get work instructions.
[01:07:46] - Attempt #8 to get work failed, and no other work to do.
[01:18:36] + Attempting to get work packet
[01:18:36] - Will indicate memory of 199 MB
[01:18:36] - Connecting to assignment server
[01:18:36] Connecting to http://assign.stanford.edu:8080/
[01:18:57] - Couldn't send HTTP request to server
[01:18:57] + Could not connect to Assignment Server
[01:18:57] Connecting to http://assign2.stanford.edu:80/
[01:18:59] - Couldn't send HTTP request to server
[01:18:59] + Could not connect to Assignment Server 2
[01:18:59] + Couldn't get work instructions.
[01:18:59] - Attempt #9 to get work failed, and no other work to do.
poyaochuang
machine #5 windows xp core2dual e4500 2048mb 6.23console
[03:30:37] - Ask before connecting: No
[03:30:37] - User name: poyaochuang (Team 3213)
[03:30:37] - User ID: 14E0BEA27BCBFEB9
[03:30:37] - Machine ID: 1
[03:30:37]
[03:30:37] Work directory not found. Creating...
[03:30:37] Could not open work queue, generating new queue...
[03:30:38] - Preparing to get new work unit...
[03:30:38] + Attempting to get work packet
[03:30:38] - Will indicate memory of 399 MB
[03:30:38] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 13
[03:30:38] - Connecting to assignment server
[03:30:38] Connecting to http://assign.stanford.edu:8080/
[03:30:38] - Autosending finished units... [October 26 03:30:38 UTC]
[03:30:38] Trying to send all finished work units
[03:30:38] + No unsent completed units remaining.
[03:30:38] - Autosend completed
[03:30:59] - Couldn't send HTTP request to server
[03:30:59] + Could not connect to Assignment Server
[03:30:59] Connecting to http://assign2.stanford.edu:80/
[03:31:00] Posted data.
[03:31:00] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[03:31:00] + News From Folding@Home: Welcome to Folding@Home
[03:31:00] Loaded queue successfully.
[03:31:00] Connecting to http://171.67.108.13:80/
[03:31:01] Posted data.
[03:31:01] Initial: 0000; + Could not connect to Work Server
[03:31:01] - Attempt #1 to get work failed, and no other work to do.
[03:31:12] + Attempting to get work packet
[03:31:12] - Will indicate memory of 399 MB
[03:31:12] - Connecting to assignment server
[03:31:12] Connecting to http://assign.stanford.edu:8080/
[03:31:33] - Couldn't send HTTP request to server
[03:31:33] + Could not connect to Assignment Server
[03:31:33] Connecting to http://assign2.stanford.edu:80/
[03:31:38] Posted data.
[03:31:38] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[03:31:38] + News From Folding@Home: Welcome to Folding@Home
[03:31:38] Loaded queue successfully.
[03:31:38] Connecting to http://171.67.108.13:80/
[03:31:38] Initial: 0000; + Could not connect to Work Server
[03:31:38] - Attempt #2 to get work failed, and no other work to do.
[03:31:55] + Attempting to get work packet
[03:31:55] - Will indicate memory of 399 MB
[03:31:55] - Connecting to assignment server
[03:31:55] Connecting to http://assign.stanford.edu:8080/
[03:32:16] - Couldn't send HTTP request to server
[03:32:16] + Could not connect to Assignment Server
[03:32:16] Connecting to http://assign2.stanford.edu:80/
[03:32:17] Posted data.
[03:32:17] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[03:32:17] + News From Folding@Home: Welcome to Folding@Home
[03:32:18] Loaded queue successfully.
[03:32:18] Connecting to http://171.67.108.13:80/
[03:32:19] Posted data.
[03:32:19] Initial: 0000; + Could not connect to Work Server
[03:32:19] - Attempt #3 to get work failed, and no other work to do.
[03:32:44] + Attempting to get work packet
[03:32:44] - Will indicate memory of 399 MB
[03:32:44] - Connecting to assignment server
[03:32:44] Connecting to http://assign.stanford.edu:8080/
[03:33:05] - Couldn't send HTTP request to server
[03:33:05] + Could not connect to Assignment Server
[03:33:05] Connecting to http://assign2.stanford.edu:80/
[03:33:05] Posted data.
[03:33:05] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[03:33:05] + News From Folding@Home: Welcome to Folding@Home
[03:33:06] Loaded queue successfully.
[03:33:06] Connecting to http://171.67.108.13:80/
[03:33:20] Posted data.
[03:33:20] Initial: 0000; + Could not connect to Work Server
[03:33:20] - Attempt #4 to get work failed, and no other work to do.
[03:34:09] + Attempting to get work packet
[03:34:09] - Will indicate memory of 399 MB
[03:34:09] - Connecting to assignment server
[03:34:09] Connecting to http://assign.stanford.edu:8080/
[03:34:30] - Couldn't send HTTP request to server
[03:34:30] + Could not connect to Assignment Server
[03:34:30] Connecting to http://assign2.stanford.edu:80/
[03:34:30] Posted data.
[03:34:30] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[03:34:30] + News From Folding@Home: Welcome to Folding@Home
[03:34:31] Loaded queue successfully.
[03:34:31] Connecting to http://171.67.108.13:80/
[03:34:34] Posted data.
[03:34:34] Initial: 0000; + Could not connect to Work Server
[03:34:34] - Attempt #5 to get work failed, and no other work to do.
[03:35:56] + Attempting to get work packet
[03:35:56] - Will indicate memory of 399 MB
[03:35:56] - Connecting to assignment server
[03:35:56] Connecting to http://assign.stanford.edu:8080/
[03:36:17] - Couldn't send HTTP request to server
[03:36:17] + Could not connect to Assignment Server
[03:36:17] Connecting to http://assign2.stanford.edu:80/
[03:36:18] Posted data.
[03:36:18] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[03:36:18] + News From Folding@Home: Welcome to Folding@Home
[03:36:18] Loaded queue successfully.
[03:36:18] Connecting to http://171.67.108.13:80/
[03:36:19] Posted data.
[03:36:19] Initial: 0000; + Could not connect to Work Server
[03:36:19] - Attempt #6 to get work failed, and no other work to do.
[03:39:01] + Attempting to get work packet
[03:39:01] - Will indicate memory of 399 MB
[03:39:01] - Connecting to assignment server
[03:39:01] Connecting to http://assign.stanford.edu:8080/
[03:39:22] - Couldn't send HTTP request to server
[03:39:22] + Could not connect to Assignment Server
[03:39:22] Connecting to http://assign2.stanford.edu:80/
[03:39:23] Posted data.
[03:39:23] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[03:39:23] + News From Folding@Home: Welcome to Folding@Home
[03:39:24] Loaded queue successfully.
[03:39:24] Connecting to http://171.67.108.13:80/
[03:39:24] Posted data.
[03:39:24] Initial: 0000; + Could not connect to Work Server
[03:39:24] - Attempt #7 to get work failed, and no other work to do.
[03:44:56] + Attempting to get work packet
[03:44:56] - Will indicate memory of 399 MB
[03:44:56] - Connecting to assignment server
[03:44:56] Connecting to http://assign.stanford.edu:8080/
[03:45:17] - Couldn't send HTTP request to server
[03:45:17] + Could not connect to Assignment Server
[03:45:17] Connecting to http://assign2.stanford.edu:80/
[03:45:19] Posted data.
[03:45:19] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[03:45:19] + News From Folding@Home: Welcome to Folding@Home
[03:45:19] Loaded queue successfully.
[03:45:19] Connecting to http://171.67.108.13:80/
[03:45:20] Posted data.
[03:45:20] Initial: 0000; + Could not connect to Work Server
[03:45:20] - Attempt #8 to get work failed, and no other work to do.
[03:56:04] + Attempting to get work packet
[03:56:04] - Will indicate memory of 399 MB
[03:56:04] - Connecting to assignment server
[03:56:04] Connecting to http://assign.stanford.edu:8080/
[03:56:25] - Couldn't send HTTP request to server
[03:56:25] + Could not connect to Assignment Server
[03:56:25] Connecting to http://assign2.stanford.edu:80/
[03:56:26] Posted data.
[03:56:26] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[03:56:26] + News From Folding@Home: Welcome to Folding@Home
[03:56:26] Loaded queue successfully.
[03:56:26] Connecting to http://171.67.108.13:80/
[03:56:27] Posted data.
[03:56:27] Initial: 0000; + Could not connect to Work Server
[03:56:27] - Attempt #9 to get work failed, and no other work to do.
[04:18:02] + Attempting to get work packet
[04:18:02] - Will indicate memory of 399 MB
[04:18:02] - Connecting to assignment server
[04:18:02] Connecting to http://assign.stanford.edu:8080/
[04:18:23] - Couldn't send HTTP request to server
[04:18:23] + Could not connect to Assignment Server
[04:18:23] Connecting to http://assign2.stanford.edu:80/
[04:18:24] Posted data.
[04:18:24] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[04:18:24] + News From Folding@Home: Welcome to Folding@Home
[04:18:24] Loaded queue successfully.
[04:18:24] Connecting to http://171.67.108.13:80/
[04:18:26] Posted data.
[04:18:26] Initial: 0000; + Could not connect to Work Server
[04:18:26] - Attempt #10 to get work failed, and no other work to do.
[05:01:16] + Attempting to get work packet
[05:01:16] - Will indicate memory of 399 MB
[05:01:16] - Connecting to assignment server
[05:01:16] Connecting to http://assign.stanford.edu:8080/
[05:01:37] - Couldn't send HTTP request to server
[05:01:37] + Could not connect to Assignment Server
[05:01:37] Connecting to http://assign2.stanford.edu:80/
[05:03:37] Posted data.
[05:04:46] Initial: 003A; + Could not connect to Assignment Server 2
[05:04:46] + Couldn't get work instructions.
[05:04:46] - Attempt #11 to get work failed, and no other work to do.
[05:52:49] + Attempting to get work packet
[05:52:49] - Will indicate memory of 399 MB
[05:52:49] - Connecting to assignment server
[05:52:49] Connecting to http://assign.stanford.edu:8080/
[05:53:10] - Couldn't send HTTP request to server
[05:53:10] + Could not connect to Assignment Server
[05:53:10] Connecting to http://assign2.stanford.edu:80/
[05:55:10] Posted data.
[05:56:19] Initial: 003A; + Could not connect to Assignment Server 2
[05:56:19] + Couldn't get work instructions.
[05:56:19] - Attempt #12 to get work failed, and no other work to do.
[06:44:28] + Attempting to get work packet
[06:44:28] - Will indicate memory of 399 MB
[06:44:28] - Connecting to assignment server
[06:44:28] Connecting to http://assign.stanford.edu:8080/
[06:44:49] - Couldn't send HTTP request to server
[06:44:49] + Could not connect to Assignment Server
[06:44:49] Connecting to http://assign2.stanford.edu:80/
[06:46:50] Posted data.
[06:47:59] Initial: 003A; + Could not connect to Assignment Server 2
[06:47:59] + Couldn't get work instructions.
[06:47:59] - Attempt #13 to get work failed, and no other work to do.
[07:36:04] + Attempting to get work packet
[07:36:04] - Will indicate memory of 399 MB
[07:36:04] - Connecting to assignment server
[07:36:04] Connecting to http://assign.stanford.edu:8080/
[07:36:25] - Couldn't send HTTP request to server
[07:36:25] + Could not connect to Assignment Server
[07:36:25] Connecting to http://assign2.stanford.edu:80/
[07:36:26] Posted data.
[07:36:26] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[07:36:26] + News From Folding@Home: Welcome to Folding@Home
[07:36:26] Loaded queue successfully.
[07:36:26] Connecting to http://171.67.108.13:80/
[07:36:27] Posted data.
[07:36:27] Initial: 0000; + Could not connect to Work Server
[07:36:27] - Attempt #14 to get work failed, and no other work to do.
[08:24:37] + Attempting to get work packet
[08:24:37] - Will indicate memory of 399 MB
[08:24:37] - Connecting to assignment server
[08:24:37] Connecting to http://assign.stanford.edu:8080/
[08:24:58] - Couldn't send HTTP request to server
[08:24:58] + Could not connect to Assignment Server
[08:24:58] Connecting to http://assign2.stanford.edu:80/
[08:26:58] Posted data.
[08:28:07] Initial: 003A; + Could not connect to Assignment Server 2
[08:28:07] + Couldn't get work instructions.
[08:28:07] - Attempt #15 to get work failed, and no other work to do.
[09:16:07] + Attempting to get work packet
[09:16:07] - Will indicate memory of 399 MB
[09:16:07] - Connecting to assignment server
[09:16:07] Connecting to http://assign.stanford.edu:8080/
[09:16:28] - Couldn't send HTTP request to server
[09:16:28] + Could not connect to Assignment Server
[09:16:28] Connecting to http://assign2.stanford.edu:80/
[09:18:29] Posted data.
[09:19:38] Initial: 003A; + Could not connect to Assignment Server 2
[09:19:38] + Couldn't get work instructions.
[09:19:38] - Attempt #16 to get work failed, and no other work to do.
[09:30:37] - Autosending finished units... [October 26 09:30:37 UTC]
[09:30:37] Trying to send all finished work units
[09:30:37] + No unsent completed units remaining.
[09:30:37] - Autosend completed
[10:07:53] + Attempting to get work packet
[10:07:53] - Will indicate memory of 399 MB
[10:07:53] - Connecting to assignment server
[10:07:53] Connecting to http://assign.stanford.edu:8080/
[10:08:14] - Couldn't send HTTP request to server
[10:08:14] + Could not connect to Assignment Server
[10:08:14] Connecting to http://assign2.stanford.edu:80/
[10:10:14] Posted data.
[10:11:23] Initial: 003A; + Could not connect to Assignment Server 2
[10:11:23] + Couldn't get work instructions.
[10:11:23] - Attempt #17 to get work failed, and no other work to do.
[10:59:29] + Attempting to get work packet
[10:59:29] - Will indicate memory of 399 MB
[10:59:29] - Connecting to assignment server
[10:59:29] Connecting to http://assign.stanford.edu:8080/
[10:59:50] - Couldn't send HTTP request to server
[10:59:50] + Could not connect to Assignment Server
[10:59:50] Connecting to http://assign2.stanford.edu:80/
[11:01:50] Posted data.
[11:02:59] Initial: 003A; + Could not connect to Assignment Server 2
[11:02:59] + Couldn't get work instructions.
[11:02:59] - Attempt #18 to get work failed, and no other work to do.
[11:51:02] + Attempting to get work packet
[11:51:02] - Will indicate memory of 399 MB
[11:51:02] - Connecting to assignment server
[11:51:02] Connecting to http://assign.stanford.edu:8080/
[11:51:23] - Couldn't send HTTP request to server
[11:51:23] + Could not connect to Assignment Server
[11:51:23] Connecting to http://assign2.stanford.edu:80/
[11:53:23] Posted data.
[11:54:32] Initial: 003A; + Could not connect to Assignment Server 2
[11:54:32] + Couldn't get work instructions.
[11:54:32] - Attempt #19 to get work failed, and no other work to do.
[12:42:45] + Attempting to get work packet
[12:42:45] - Will indicate memory of 399 MB
[12:42:45] - Connecting to assignment server
[12:42:45] Connecting to http://assign.stanford.edu:8080/
[12:43:06] - Couldn't send HTTP request to server
[12:43:06] + Could not connect to Assignment Server
[12:43:06] Connecting to http://assign2.stanford.edu:80/
[12:45:06] Posted data.
[12:46:15] Initial: 003A; + Could not connect to Assignment Server 2
[12:46:15] + Couldn't get work instructions.
[12:46:15] - Attempt #20 to get work failed, and no other work to do.
[13:34:25] + Attempting to get work packet
[13:34:25] - Will indicate memory of 399 MB
[13:34:25] - Connecting to assignment server
[13:34:25] Connecting to http://assign.stanford.edu:8080/
[13:34:46] - Couldn't send HTTP request to server
[13:34:46] + Could not connect to Assignment Server
[13:34:46] Connecting to http://assign2.stanford.edu:80/
[13:36:47] Posted data.
[13:37:56] Initial: 003A; + Could not connect to Assignment Server 2
[13:37:56] + Couldn't get work instructions.
[13:37:56] - Attempt #21 to get work failed, and no other work to do.
[14:26:08] + Attempting to get work packet
[14:26:08] - Will indicate memory of 399 MB
[14:26:08] - Connecting to assignment server
[14:26:08] Connecting to http://assign.stanford.edu:8080/
[14:26:29] - Couldn't send HTTP request to server
[14:26:29] + Could not connect to Assignment Server
[14:26:29] Connecting to http://assign2.stanford.edu:80/
[14:28:29] Posted data.
[14:29:38] Initial: 003A; + Could not connect to Assignment Server 2
[14:29:38] + Couldn't get work instructions.
[14:29:38] - Attempt #22 to get work failed, and no other work to do.
[15:17:48] + Attempting to get work packet
[15:17:48] - Will indicate memory of 399 MB
[15:17:48] - Connecting to assignment server
[15:17:48] Connecting to http://assign.stanford.edu:8080/
[15:18:10] - Couldn't send HTTP request to server
[15:18:10] + Could not connect to Assignment Server
[15:18:10] Connecting to http://assign2.stanford.edu:80/
[15:20:10] Posted data.
[15:21:19] Initial: 003A; + Could not connect to Assignment Server 2
[15:21:19] + Couldn't get work instructions.
[15:21:19] - Attempt #23 to get work failed, and no other work to do.
[15:30:39] - Autosending finished units... [October 26 15:30:39 UTC]
[15:30:39] Trying to send all finished work units
[15:30:39] + No unsent completed units remaining.
[15:30:39] - Autosend completed
[16:09:20] + Attempting to get work packet
[16:09:20] - Will indicate memory of 399 MB
[16:09:20] - Connecting to assignment server
[16:09:20] Connecting to http://assign.stanford.edu:8080/
[16:09:41] - Couldn't send HTTP request to server
[16:09:41] + Could not connect to Assignment Server
[16:09:41] Connecting to http://assign2.stanford.edu:80/
[16:11:42] Posted data.
[16:12:51] Initial: 003A; + Could not connect to Assignment Server 2
[16:12:51] + Couldn't get work instructions.
[16:12:51] - Attempt #24 to get work failed, and no other work to do.
[17:00:53] + Attempting to get work packet
[17:00:53] - Will indicate memory of 399 MB
[17:00:53] - Connecting to assignment server
[17:00:53] Connecting to http://assign.stanford.edu:8080/
[17:01:13] - Couldn't send HTTP request to server
[17:01:13] + Could not connect to Assignment Server
[17:01:13] Connecting to http://assign2.stanford.edu:80/
[17:03:14] Posted data.
[17:04:23] Initial: 003A; + Could not connect to Assignment Server 2
[17:04:23] + Couldn't get work instructions.
[17:04:23] - Attempt #25 to get work failed, and no other work to do.
[17:52:25] + Attempting to get work packet
[17:52:25] - Will indicate memory of 399 MB
[17:52:25] - Connecting to assignment server
[17:52:25] Connecting to http://assign.stanford.edu:8080/
[17:52:46] - Couldn't send HTTP request to server
[17:52:46] + Could not connect to Assignment Server
[17:52:46] Connecting to http://assign2.stanford.edu:80/
[17:52:47] Posted data.
[17:52:47] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[17:52:47] + News From Folding@Home: Welcome to Folding@Home
[17:52:47] Loaded queue successfully.
[17:52:47] Connecting to http://171.67.108.13:80/
[17:52:48] Posted data.
[17:52:48] Initial: 0000; + Could not connect to Work Server
[17:52:48] - Attempt #26 to get work failed, and no other work to do.
[18:40:56] + Attempting to get work packet
[18:40:56] - Will indicate memory of 399 MB
[18:40:56] - Connecting to assignment server
[18:40:56] Connecting to http://assign.stanford.edu:8080/
[18:41:17] - Couldn't send HTTP request to server
[18:41:17] + Could not connect to Assignment Server
[18:41:17] Connecting to http://assign2.stanford.edu:80/
[18:41:18] Posted data.
[18:41:18] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[18:41:18] + News From Folding@Home: Welcome to Folding@Home
[18:41:18] Loaded queue successfully.
[18:41:18] Connecting to http://171.67.108.13:80/
[18:41:19] Posted data.
[18:41:19] Initial: 0000; + Could not connect to Work Server
[18:41:19] - Attempt #27 to get work failed, and no other work to do.
[19:29:27] + Attempting to get work packet
[19:29:27] - Will indicate memory of 399 MB
[19:29:27] - Connecting to assignment server
[19:29:27] Connecting to http://assign.stanford.edu:8080/
[19:29:49] - Couldn't send HTTP request to server
[19:29:49] + Could not connect to Assignment Server
[19:29:49] Connecting to http://assign2.stanford.edu:80/
[19:31:49] Posted data.
[19:32:58] Initial: 003A; + Could not connect to Assignment Server 2
[19:32:58] + Couldn't get work instructions.
[19:32:58] - Attempt #28 to get work failed, and no other work to do.
[20:21:09] + Attempting to get work packet
[20:21:09] - Will indicate memory of 399 MB
[20:21:09] - Connecting to assignment server
[20:21:09] Connecting to http://assign.stanford.edu:8080/
[20:21:30] - Couldn't send HTTP request to server
[20:21:30] + Could not connect to Assignment Server
[20:21:30] Connecting to http://assign2.stanford.edu:80/
[20:23:31] Posted data.
[20:24:40] Initial: 003A; + Could not connect to Assignment Server 2
[20:24:40] + Couldn't get work instructions.
[20:24:40] - Attempt #29 to get work failed, and no other work to do.
[21:12:45] + Attempting to get work packet
[21:12:45] - Will indicate memory of 399 MB
[21:12:45] - Connecting to assignment server
[21:12:45] Connecting to http://assign.stanford.edu:8080/
[21:13:06] - Couldn't send HTTP request to server
[21:13:06] + Could not connect to Assignment Server
[21:13:06] Connecting to http://assign2.stanford.edu:80/
[21:13:07] Posted data.
[21:13:07] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[21:13:07] + News From Folding@Home: Welcome to Folding@Home
[21:13:07] Loaded queue successfully.
[21:13:07] Connecting to http://171.67.108.13:80/
[21:13:08] Posted data.
[21:13:08] Initial: 0000; + Could not connect to Work Server
[21:13:08] - Attempt #30 to get work failed, and no other work to do.
[21:30:31] - Autosending finished units... [October 26 21:30:31 UTC]
[21:30:31] Trying to send all finished work units
[21:30:31] + No unsent completed units remaining.
[21:30:31] - Autosend completed
[22:01:18] + Attempting to get work packet
[22:01:18] - Will indicate memory of 399 MB
[22:01:18] - Connecting to assignment server
[22:01:18] Connecting to http://assign.stanford.edu:8080/
[22:01:39] - Couldn't send HTTP request to server
[22:01:39] + Could not connect to Assignment Server
[22:01:39] Connecting to http://assign2.stanford.edu:80/
[22:01:40] Posted data.
[22:01:40] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[22:01:40] + News From Folding@Home: Welcome to Folding@Home
[22:01:40] Loaded queue successfully.
[22:01:40] Connecting to http://171.67.108.13:80/
[22:01:42] - Couldn't send HTTP request to server
[22:01:42] + Could not connect to Work Server
[22:01:42] - Attempt #31 to get work failed, and no other work to do.
[22:49:51] + Attempting to get work packet
[22:49:51] - Will indicate memory of 399 MB
[22:49:51] - Connecting to assignment server
[22:49:51] Connecting to http://assign.stanford.edu:8080/
[22:50:12] - Couldn't send HTTP request to server
[22:50:12] + Could not connect to Assignment Server
[22:50:12] Connecting to http://assign2.stanford.edu:80/
[22:50:13] Posted data.
[22:50:13] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[22:50:13] + News From Folding@Home: Welcome to Folding@Home
[22:50:13] Loaded queue successfully.
[22:50:13] Connecting to http://171.67.108.13:80/
[22:50:15] - Couldn't send HTTP request to server
[22:50:15] + Could not connect to Work Server
[22:50:15] - Attempt #32 to get work failed, and no other work to do.
[23:38:22] + Attempting to get work packet
[23:38:22] - Will indicate memory of 399 MB
[23:38:22] - Connecting to assignment server
[23:38:22] Connecting to http://assign.stanford.edu:8080/
[23:38:43] - Couldn't send HTTP request to server
[23:38:43] + Could not connect to Assignment Server
[23:38:43] Connecting to http://assign2.stanford.edu:80/
[23:38:44] Posted data.
[23:38:44] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[23:38:44] + News From Folding@Home: Welcome to Folding@Home
[23:38:44] Loaded queue successfully.
[23:38:44] Connecting to http://171.67.108.13:80/
[23:38:51] - Couldn't send HTTP request to server
[23:38:51] + Could not connect to Work Server
[23:38:51] - Attempt #33 to get work failed, and no other work to do.
[00:27:06] + Attempting to get work packet
[00:27:06] - Will indicate memory of 399 MB
[00:27:06] - Connecting to assignment server
[00:27:06] Connecting to http://assign.stanford.edu:8080/
[00:27:28] - Couldn't send HTTP request to server
[00:27:28] + Could not connect to Assignment Server
[00:27:28] Connecting to http://assign2.stanford.edu:80/
[00:29:28] Posted data.
[00:30:37] Initial: 003A; + Could not connect to Assignment Server 2
[00:30:37] + Couldn't get work instructions.
[00:30:37] - Attempt #34 to get work failed, and no other work to do.
[01:18:44] + Attempting to get work packet
[01:18:44] - Will indicate memory of 399 MB
[01:18:44] - Connecting to assignment server
[01:18:44] Connecting to http://assign.stanford.edu:8080/
[01:19:05] - Couldn't send HTTP request to server
[01:19:05] + Could not connect to Assignment Server
[01:19:05] Connecting to http://assign2.stanford.edu:80/
[01:19:06] Posted data.
[01:19:06] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[01:19:06] + News From Folding@Home: Welcome to Folding@Home
[01:19:06] Loaded queue successfully.
[01:19:06] Connecting to http://171.67.108.13:80/
[01:19:07] Posted data.
[01:19:07] Initial: 0000; + Could not connect to Work Server
[01:19:07] - Attempt #35 to get work failed, and no other work to do.
[02:07:16] + Attempting to get work packet
[02:07:16] - Will indicate memory of 399 MB
[02:07:16] - Connecting to assignment server
[02:07:16] Connecting to http://assign.stanford.edu:8080/
[02:07:37] - Couldn't send HTTP request to server
[02:07:37] + Could not connect to Assignment Server
[02:07:37] Connecting to http://assign2.stanford.edu:80/
[02:07:44] - Couldn't send HTTP request to server
[02:07:44] + Could not connect to Assignment Server 2
[02:07:44] + Couldn't get work instructions.
[02:07:44] - Attempt #36 to get work failed, and no other work to do.
[02:56:00] + Attempting to get work packet
[02:56:00] - Will indicate memory of 399 MB
[02:56:00] - Connecting to assignment server
[02:56:00] Connecting to http://assign.stanford.edu:8080/
[02:56:21] - Couldn't send HTTP request to server
[02:56:21] + Could not connect to Assignment Server
[02:56:21] Connecting to http://assign2.stanford.edu:80/
[02:56:23] - Couldn't send HTTP request to server
[02:56:23] + Could not connect to Assignment Server 2
[02:56:23] + Couldn't get work instructions.
[02:56:23] - Attempt #37 to get work failed, and no other work to do.
[03:30:43] - Autosending finished units... [October 27 03:30:43 UTC]
[03:30:43] Trying to send all finished work units
[03:30:43] + No unsent completed units remaining.
[03:30:43] - Autosend completed
[03:44:29] + Attempting to get work packet
[03:44:29] - Will indicate memory of 399 MB
[03:44:29] - Connecting to assignment server
[03:44:29] Connecting to http://assign.stanford.edu:8080/
[03:44:50] - Couldn't send HTTP request to server
[03:44:50] + Could not connect to Assignment Server
[03:44:50] Connecting to http://assign2.stanford.edu:80/
[03:44:57] - Couldn't send HTTP request to server
[03:44:57] + Could not connect to Assignment Server 2
[03:44:57] + Couldn't get work instructions.
[03:44:57] - Attempt #38 to get work failed, and no other work to do.
[04:33:00] + Attempting to get work packet
[04:33:00] - Will indicate memory of 399 MB
[04:33:00] - Connecting to assignment server
[04:33:00] Connecting to http://assign.stanford.edu:8080/
[04:33:21] - Couldn't send HTTP request to server
[04:33:21] + Could not connect to Assignment Server
[04:33:21] Connecting to http://assign2.stanford.edu:80/
[04:33:28] - Couldn't send HTTP request to server
[04:33:28] + Could not connect to Assignment Server 2
[04:33:28] + Couldn't get work instructions.
[04:33:28] - Attempt #39 to get work failed, and no other work to do.
[05:21:22] + Attempting to get work packet
[05:21:22] - Will indicate memory of 399 MB
[05:21:22] - Connecting to assignment server
[05:21:22] Connecting to http://assign.stanford.edu:8080/
[05:21:43] - Couldn't send HTTP request to server
[05:21:43] + Could not connect to Assignment Server
[05:21:43] Connecting to http://assign2.stanford.edu:80/
[05:21:45] - Couldn't send HTTP request to server
[05:21:45] + Could not connect to Assignment Server 2
[05:21:45] + Couldn't get work instructions.
[05:21:45] - Attempt #40 to get work failed, and no other work to do.
[06:09:50] + Attempting to get work packet
[06:09:50] - Will indicate memory of 399 MB
[06:09:50] - Connecting to assignment server
[06:09:50] Connecting to http://assign.stanford.edu:8080/
[06:10:11] - Couldn't send HTTP request to server
[06:10:11] + Could not connect to Assignment Server
[06:10:11] Connecting to http://assign2.stanford.edu:80/
[06:10:17] - Couldn't send HTTP request to server
[06:10:17] + Could not connect to Assignment Server 2
[06:10:17] + Couldn't get work instructions.
[06:10:17] - Attempt #41 to get work failed, and no other work to do.
[06:58:11] + Attempting to get work packet
[06:58:11] - Will indicate memory of 399 MB
[06:58:11] - Connecting to assignment server
[06:58:11] Connecting to http://assign.stanford.edu:8080/
[06:58:32] - Couldn't send HTTP request to server
[06:58:32] + Could not connect to Assignment Server
[06:58:32] Connecting to http://assign2.stanford.edu:80/
[06:58:34] - Couldn't send HTTP request to server
[06:58:34] + Could not connect to Assignment Server 2
[06:58:34] + Couldn't get work instructions.
[06:58:34] - Attempt #42 to get work failed, and no other work to do.
[07:46:31] + Attempting to get work packet
[07:46:31] - Will indicate memory of 399 MB
[07:46:31] - Connecting to assignment server
[07:46:31] Connecting to http://assign.stanford.edu:8080/
[07:46:52] - Couldn't send HTTP request to server
[07:46:52] + Could not connect to Assignment Server
[07:46:52] Connecting to http://assign2.stanford.edu:80/
[07:46:53] - Couldn't send HTTP request to server
[07:46:53] + Could not connect to Assignment Server 2
[07:46:53] + Couldn't get work instructions.
[07:46:53] - Attempt #43 to get work failed, and no other work to do.
[08:34:48] + Attempting to get work packet
[08:34:48] - Will indicate memory of 399 MB
[08:34:48] - Connecting to assignment server
[08:34:48] Connecting to http://assign.stanford.edu:8080/
[08:35:09] - Couldn't send HTTP request to server
[08:35:09] + Could not connect to Assignment Server
[08:35:09] Connecting to http://assign2.stanford.edu:80/
[08:35:16] - Couldn't send HTTP request to server
[08:35:16] + Could not connect to Assignment Server 2
[08:35:16] + Couldn't get work instructions.
[08:35:16] - Attempt #44 to get work failed, and no other work to do.
[09:23:10] + Attempting to get work packet
[09:23:10] - Will indicate memory of 399 MB
[09:23:10] - Connecting to assignment server
[09:23:10] Connecting to http://assign.stanford.edu:8080/
[09:23:31] - Couldn't send HTTP request to server
[09:23:31] + Could not connect to Assignment Server
[09:23:31] Connecting to http://assign2.stanford.edu:80/
[09:23:38] - Couldn't send HTTP request to server
[09:23:38] + Could not connect to Assignment Server 2
[09:23:38] + Couldn't get work instructions.
[09:23:38] - Attempt #45 to get work failed, and no other work to do.
[09:29:50] - Autosending finished units... [October 27 09:29:50 UTC]
[09:29:50] Trying to send all finished work units
[09:29:50] + No unsent completed units remaining.
[09:29:50] - Autosend completed
[10:11:33] + Attempting to get work packet
[10:11:33] - Will indicate memory of 399 MB
[10:11:33] - Connecting to assignment server
[10:11:33] Connecting to http://assign.stanford.edu:8080/
[10:11:54] - Couldn't send HTTP request to server
[10:11:54] + Could not connect to Assignment Server
[10:11:54] Connecting to http://assign2.stanford.edu:80/
[10:11:55] - Couldn't send HTTP request to server
[10:11:55] + Could not connect to Assignment Server 2
[10:11:55] + Couldn't get work instructions.
[10:11:55] - Attempt #46 to get work failed, and no other work to do.
[10:59:53] + Attempting to get work packet
[10:59:53] - Will indicate memory of 399 MB
[10:59:53] - Connecting to assignment server
[10:59:53] Connecting to http://assign.stanford.edu:8080/
[11:00:14] - Couldn't send HTTP request to server
[11:00:14] + Could not connect to Assignment Server
[11:00:14] Connecting to http://assign2.stanford.edu:80/
[11:00:28] - Couldn't send HTTP request to server
[11:00:28] + Could not connect to Assignment Server 2
[11:00:28] + Couldn't get work instructions.
[11:00:28] - Attempt #47 to get work failed, and no other work to do.
[11:48:26] + Attempting to get work packet
[11:48:26] - Will indicate memory of 399 MB
[11:48:26] - Connecting to assignment server
[11:48:26] Connecting to http://assign.stanford.edu:8080/
[11:48:47] - Couldn't send HTTP request to server
[11:48:47] + Could not connect to Assignment Server
[11:48:47] Connecting to http://assign2.stanford.edu:80/
[11:48:48] - Couldn't send HTTP request to server
[11:48:48] + Could not connect to Assignment Server 2
[11:48:48] + Couldn't get work instructions.
[11:48:48] - Attempt #48 to get work failed, and no other work to do.
[12:36:42] + Attempting to get work packet
[12:36:42] - Will indicate memory of 399 MB
[12:36:42] - Connecting to assignment server
[12:36:42] Connecting to http://assign.stanford.edu:8080/
[12:37:03] - Couldn't send HTTP request to server
[12:37:03] + Could not connect to Assignment Server
[12:37:03] Connecting to http://assign2.stanford.edu:80/
[12:37:10] - Couldn't send HTTP request to server
[12:37:10] + Could not connect to Assignment Server 2
[12:37:10] + Couldn't get work instructions.
[12:37:10] - Attempt #49 to get work failed, and no other work to do.
[13:25:04] + Attempting to get work packet
[13:25:04] - Will indicate memory of 399 MB
[13:25:04] - Connecting to assignment server
[13:25:04] Connecting to http://assign.stanford.edu:8080/
[13:25:25] - Couldn't send HTTP request to server
[13:25:25] + Could not connect to Assignment Server
[13:25:25] Connecting to http://assign2.stanford.edu:80/
[13:25:38] - Couldn't send HTTP request to server
[13:25:38] + Could not connect to Assignment Server 2
[13:25:38] + Couldn't get work instructions.
[13:25:38] - Attempt #50 to get work failed, and no other work to do.
[14:13:46] + Attempting to get work packet
[14:13:46] - Will indicate memory of 399 MB
[14:13:46] - Connecting to assignment server
[14:13:46] Connecting to http://assign.stanford.edu:8080/
[14:14:07] - Couldn't send HTTP request to server
[14:14:07] + Could not connect to Assignment Server
[14:14:07] Connecting to http://assign2.stanford.edu:80/
[14:14:14] - Couldn't send HTTP request to server
[14:14:14] + Could not connect to Assignment Server 2
[14:14:14] + Couldn't get work instructions.
[14:14:14] - Attempt #51 to get work failed, and no other work to do.
[15:02:17] + Attempting to get work packet
[15:02:17] - Will indicate memory of 399 MB
[15:02:17] - Connecting to assignment server
[15:02:17] Connecting to http://assign.stanford.edu:8080/
[15:02:38] - Couldn't send HTTP request to server
[15:02:38] + Could not connect to Assignment Server
[15:02:38] Connecting to http://assign2.stanford.edu:80/
[15:02:40] - Couldn't send HTTP request to server
[15:02:40] + Could not connect to Assignment Server 2
[15:02:40] + Couldn't get work instructions.
[15:02:40] - Attempt #52 to get work failed, and no other work to do.
[15:28:58] - Autosending finished units... [October 27 15:28:58 UTC]
[15:28:58] Trying to send all finished work units
[15:28:58] + No unsent completed units remaining.
[15:28:58] - Autosend completed
[15:50:40] + Attempting to get work packet
[15:50:40] - Will indicate memory of 399 MB
[15:50:40] - Connecting to assignment server
[15:50:40] Connecting to http://assign.stanford.edu:8080/
[15:51:01] - Couldn't send HTTP request to server
[15:51:01] + Could not connect to Assignment Server
[15:51:01] Connecting to http://assign2.stanford.edu:80/
[15:51:02] - Couldn't send HTTP request to server
[15:51:02] + Could not connect to Assignment Server 2
[15:51:02] + Couldn't get work instructions.
[15:51:02] - Attempt #53 to get work failed, and no other work to do.
[16:39:03] + Attempting to get work packet
[16:39:03] - Will indicate memory of 399 MB
[16:39:03] - Connecting to assignment server
[16:39:03] Connecting to http://assign.stanford.edu:8080/
[16:39:24] - Couldn't send HTTP request to server
[16:39:24] + Could not connect to Assignment Server
[16:39:24] Connecting to http://assign2.stanford.edu:80/
[16:39:25] - Couldn't send HTTP request to server
[16:39:25] + Could not connect to Assignment Server 2
[16:39:25] + Couldn't get work instructions.
[16:39:25] - Attempt #54 to get work failed, and no other work to do.
[17:27:29] + Attempting to get work packet
[17:27:29] - Will indicate memory of 399 MB
[17:27:29] - Connecting to assignment server
[17:27:29] Connecting to http://assign.stanford.edu:8080/
[17:27:50] - Couldn't send HTTP request to server
[17:27:50] + Could not connect to Assignment Server
[17:27:50] Connecting to http://assign2.stanford.edu:80/
[17:27:52] - Couldn't send HTTP request to server
[17:27:52] + Could not connect to Assignment Server 2
[17:27:52] + Couldn't get work instructions.
[17:27:52] - Attempt #55 to get work failed, and no other work to do.
[18:19:38] + Attempting to get work packet
[18:19:38] - Will indicate memory of 399 MB
[18:19:38] - Connecting to assignment server
[18:19:38] Connecting to http://assign.stanford.edu:8080/
[18:19:59] - Couldn't send HTTP request to server
[18:19:59] + Could not connect to Assignment Server
[18:19:59] Connecting to http://assign2.stanford.edu:80/
[18:20:01] - Couldn't send HTTP request to server
[18:20:01] + Could not connect to Assignment Server 2
[18:20:01] + Couldn't get work instructions.
[18:20:01] - Attempt #56 to get work failed, and no other work to do.
[19:08:11] + Attempting to get work packet
[19:08:11] - Will indicate memory of 399 MB
[19:08:11] - Connecting to assignment server
[19:08:11] Connecting to http://assign.stanford.edu:8080/
[19:08:32] - Couldn't send HTTP request to server
[19:08:32] + Could not connect to Assignment Server
[19:08:32] Connecting to http://assign2.stanford.edu:80/
[19:08:39] - Couldn't send HTTP request to server
[19:08:39] + Could not connect to Assignment Server 2
[19:08:39] + Couldn't get work instructions.
[19:08:39] - Attempt #57 to get work failed, and no other work to do.
Waiting before retry.
[19:57:00] + Attempting to get work packet
[19:57:00] - Will indicate memory of 399 MB
[19:57:00] - Connecting to assignment server
[19:57:00] Connecting to http://assign.stanford.edu:8080/
[19:57:21] - Couldn't send HTTP request to server
[19:57:21] + Could not connect to Assignment Server
[19:57:21] Connecting to http://assign2.stanford.edu:80/
[19:57:22] - Couldn't send HTTP request to server
[19:57:22] + Could not connect to Assignment Server 2
[19:57:22] + Couldn't get work instructions.
[19:57:22] - Attempt #58 to get work failed, and no other work to do.
[20:43:31] + Attempting to get work packet
[20:43:31] - Will indicate memory of 399 MB
[20:43:31] - Connecting to assignment server
[20:43:31] Connecting to http://assign.stanford.edu:8080/
[20:43:52] - Couldn't send HTTP request to server
[20:43:52] + Could not connect to Assignment Server
[20:43:52] Connecting to http://assign2.stanford.edu:80/
[20:43:53] - Couldn't send HTTP request to server
[20:43:53] + Could not connect to Assignment Server 2
[20:43:53] + Couldn't get work instructions.
[20:43:53] - Attempt #59 to get work failed, and no other work to do.
[21:30:25] - Autosending finished units... [October 27 21:30:25 UTC]
[21:30:25] Trying to send all finished work units
[21:30:25] + No unsent completed units remaining.
[21:30:25] - Autosend completed
[21:31:48] + Attempting to get work packet
[21:31:48] - Will indicate memory of 399 MB
[21:31:48] - Connecting to assignment server
[21:31:48] Connecting to http://assign.stanford.edu:8080/
[21:32:09] - Couldn't send HTTP request to server
[21:32:09] + Could not connect to Assignment Server
[21:32:09] Connecting to http://assign2.stanford.edu:80/
[21:32:16] - Couldn't send HTTP request to server
[21:32:16] + Could not connect to Assignment Server 2
[21:32:16] + Couldn't get work instructions.
[21:32:16] - Attempt #60 to get work failed, and no other work to do.
[22:20:14] + Attempting to get work packet
[22:20:14] - Will indicate memory of 399 MB
[22:20:14] - Connecting to assignment server
[22:20:14] Connecting to http://assign.stanford.edu:8080/
[22:20:35] - Couldn't send HTTP request to server
[22:20:35] + Could not connect to Assignment Server
[22:20:35] Connecting to http://assign2.stanford.edu:80/
[22:20:36] - Couldn't send HTTP request to server
[22:20:36] + Could not connect to Assignment Server 2
[22:20:36] + Couldn't get work instructions.
[22:20:36] - Attempt #61 to get work failed, and no other work to do.
[23:08:38] + Attempting to get work packet
[23:08:38] - Will indicate memory of 399 MB
[23:08:38] - Connecting to assignment server
[23:08:38] Connecting to http://assign.stanford.edu:8080/
[23:08:59] - Couldn't send HTTP request to server
[23:08:59] + Could not connect to Assignment Server
[23:08:59] Connecting to http://assign2.stanford.edu:80/
[23:09:12] - Couldn't send HTTP request to server
[23:09:12] + Could not connect to Assignment Server 2
[23:09:12] + Couldn't get work instructions.
[23:09:12] - Attempt #62 to get work failed, and no other work to do.
[23:57:07] + Attempting to get work packet
[23:57:07] - Will indicate memory of 399 MB
[23:57:07] - Connecting to assignment server
[23:57:07] Connecting to http://assign.stanford.edu:8080/
[23:57:28] - Couldn't send HTTP request to server
[23:57:28] + Could not connect to Assignment Server
[23:57:28] Connecting to http://assign2.stanford.edu:80/
[23:57:41] - Couldn't send HTTP request to server
[23:57:41] + Could not connect to Assignment Server 2
[23:57:41] + Couldn't get work instructions.
[23:57:41] - Attempt #63 to get work failed, and no other work to do.
[00:45:53] + Attempting to get work packet
[00:45:53] - Will indicate memory of 399 MB
[00:45:53] - Connecting to assignment server
[00:45:53] Connecting to http://assign.stanford.edu:8080/
[00:46:16] - Couldn't send HTTP request to server
[00:46:16] + Could not connect to Assignment Server
[00:46:16] Connecting to http://assign2.stanford.edu:80/
[00:46:18] - Couldn't send HTTP request to server
[00:46:18] + Could not connect to Assignment Server 2
[00:46:18] + Couldn't get work instructions.
[00:46:18] - Attempt #64 to get work failed, and no other work to do.
[01:34:50] + Attempting to get work packet
[01:34:50] - Will indicate memory of 399 MB
[01:34:50] - Connecting to assignment server
[01:34:50] Connecting to http://assign.stanford.edu:8080/
[01:35:11] - Couldn't send HTTP request to server
[01:35:11] + Could not connect to Assignment Server
[01:35:11] Connecting to http://assign2.stanford.edu:80/
[01:35:13] - Couldn't send HTTP request to server
[01:35:13] + Could not connect to Assignment Server 2
[01:35:13] + Couldn't get work instructions.
[01:35:13] - Attempt #65 to get work failed, and no other work to do.
Waiting before retry.Re: can not connect to assign.stanford.edu or assign2. or etc.
Sorry about that. In Linux, that would be traceroute assign.stanford.edubruce wrote:How about "tracert assign.stanford.edu"
poyaochuang
tracert works
traceroute did not work?
Paste the output in a post.
poyaochuang
poyaochuang@poyaochuang-desktop:~$ traceroute -m 90 assign.stanford.edu
traceroute to assign.stanford.edu (171.67.108.200), 90 hops max, 60 byte packets
1 192.168.1.252 (192.168.1.252) 1.674 ms 2.874 ms 3.254 ms
2 * * *
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
31 * * *
32 * * *
33 * * *
34 * * *
35 * * *
36 * * *
37 * * *
38 * * *
39 * * *
40 * * *
41 * * *
42 * * *
43 * * *
44 * * *
45 * * *
46 * * *
47 * * *
48 * * *
49 * * *
50 * * *
51 * * *
52 * * *
53 * * *
54 * * *
55 * * *
56 * * *
57 * * *
58 * * *
59 * * *
60 * * *
61 * * *
62 * * *
63 * * *
64 * * *
65 * * *
66 * * *
67 * * *
68 * * *
69 * * *
70 * * *
71 * * *
72 * * *
73 * * *
74 * * *
75 * * *
76 * * *
77 * * *
78 * * *
79 * * *
80 * * *
81 * * *
82 * * *
83 * * *
84 * * *
85 * * *
86 * * *
87 * * *
88 * * *
89 * * *
90 * * *
I have the same issue. Can't connect to assigment server.
Here are my tracert (BTW, impressive long path).
Trace works and I can get connected but no new work packets can be downloaded.
My local IPs removed from the list
[06:53:17] Loaded queue successfully.
[06:53:17] Initialization complete
[06:53:17] - Preparing to get new work unit...
[06:53:17] + Attempting to get work packet
[06:53:17] - Connecting to assignment server
[06:53:37] - Couldn't send HTTP request to server
[06:53:37] + Could not connect to Assignment Server
[06:53:39] - Couldn't send HTTP request to server
[06:53:39] + Could not connect to Assignment Server 2
[06:53:39] + Couldn't get work instructions.
[06:53:39] - Attempt #1 to get work failed, and no other work to do.
[06:53:55] + Attempting to get work packet
[06:53:56] - Connecting to assignment server
[06:54:16] - Couldn't send HTTP request to server
[06:54:16] + Could not connect to Assignment Server
[06:54:18] - Couldn't send HTTP request to server
[06:54:18] + Could not connect to Assignment Server 2
[06:54:18] + Couldn't get work instructions.
[06:54:18] - Attempt #2 to get work failed, and no other work to do.
Waiting before retry.Trace works and I can get connected but no new work packets can be downloaded.
C:\tracert assign.stanford.edu
Tracing route to vsp10v-vz00.stanford.edu [171.67.108.200]
over a maximum of 30 hops:
10 11 ms 11 ms 12 ms 80.169.20.181
11 20 ms 12 ms 11 ms netnod-ix-ge-a-sth-1500.cogent.com [194.68.123.155]
12 30 ms 31 ms 31 ms te2-2.ccr02.ham01.atlas.cogentco.com [130.117.0.149]
13 43 ms 43 ms 45 ms te3-2.ccr02.ams03.atlas.cogentco.com [130.117.50.33]
14 154 ms 160 ms 153 ms te2-1.ccr02.lon02.atlas.cogentco.com [130.117.50.158]
15 159 ms 159 ms 160 ms te2-3.mpd01.lon02.atlas.cogentco.com [130.117.50.118]
16 167 ms 161 ms 161 ms te2-3.mpd02.lon01.atlas.cogentco.com [130.117.0.253]
17 158 ms 159 ms 158 ms te2-2.ccr02.jfk02.atlas.cogentco.com [130.117.2.105]
18 158 ms 156 ms 162 ms te1-8.ccr02.ord01.atlas.cogentco.com [154.54.29.149]
19 160 ms 159 ms 160 ms te3-4.ccr02.mci01.atlas.cogentco.com [154.54.5.173]
20 194 ms 191 ms 191 ms te2-2.ccr02.sfo01.atlas.cogentco.com [154.54.6.42]
21 197 ms 198 ms 199 ms te4-4.mpd01.sfo01.atlas.cogentco.com [154.54.7.245]
22 198 ms 199 ms 199 ms te8-1.ccr02.sfo01.atlas.cogentco.com [154.54.7.242]
23 196 ms 192 ms 192 ms te9-1.mpd01.sjc04.atlas.cogentco.com [154.54.0.178]
24 198 ms 198 ms 198 ms Stanford_University2.demarc.cogentco.com [66.250.7.138]
25 200 ms 213 ms 199 ms bbrb-isp.Stanford.EDU [171.64.1.155]
26 * * * Request timed out.
27 208 ms 214 ms 208 ms vsp10v.Stanford.EDU [171.67.108.18]
28 199 ms 199 ms 199 ms vsp10v-vz00.Stanford.EDU [171.67.108.200]
Trace complete.-
chillerworks.com
assign2.stanford.edu status is FAIL since Mon Oct 26 17:30:09 PST 2009
http://fah-web.stanford.edu/logs/171.64.65.121.log.html
Do you know when it come back? We can't fold without it...
If auto restart doesn't occur, you'll have to wait until someone wakes up (it's 2:15 @ Stanford).
