Project: 5745 (Run 4, Clone 46, Gen 360)
rhavern
Post by rhavern »
Previously stable machine, WinXP 32, current patches & SP, HD3850 AGP, AMD 3200XP, experimental DLLs
21:49:12] Completed 100%
[21:49:12] Successful run
[21:49:12] DynamicWrapper: Finished Work Unit: sleep=10000
[21:49:22] Reserved 153640 bytes for xtc file; Cosm status=0
[21:49:22] Allocated 153640 bytes for xtc file
[21:49:22] - Reading up to 153640 from "work/wudata_01.xtc": Read 153640
[21:49:22] Read 153640 bytes from xtc file; available packet space=786276824
[21:49:22] xtc file hash check passed.
[21:49:22] Reserved 23472 23472 786276824 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[21:49:22] Allocated 23472 bytes for arc file
[21:49:22] - Reading up to 23472 from "work/wudata_01.trr": Read 23472
[21:49:22] Read 23472 bytes from arc file; available packet space=786253352
[21:49:22] trr file hash check passed.
[21:49:22] Allocated 560 bytes for edr file
[21:49:22] Read bedfile
[21:49:22] edr file hash check passed.
[21:49:22] Allocated 40322 bytes for logfile
[21:49:22] Read logfile
[21:49:22] GuardedRun: success in DynamicWrapper
[21:49:22] GuardedRun: done
[21:49:22] Run: GuardedRun completed.
[21:49:26] - Writing 218506 bytes of core data to disk...
[21:49:26] Done: 217994 -> 186939 (compressed to 85.7 percent)
[21:49:26]   ... Done.
[21:49:26] - Shutting down core
[21:49:26]
[21:49:26] Folding@home Core Shutdown: FINISHED_UNIT
[21:49:30] CoreStatus = 64 (100)
[21:49:30] Unit 1 finished with 92 percent of time to deadline remaining.
[21:49:30] Updated performance fraction: 0.899872
[21:49:30] Sending work to server
[21:49:30] Project: 5740 (Run 3, Clone 36, Gen 439)
[21:49:30] - Read packet limit of 540015616... Set to 524286976.
[21:49:30] + Attempting to send results [August 27 21:49:30 UTC]
[21:49:30]   (Read 187451 bytes from disk)
[21:49:30] Connecting to http://171.64.65.102:8080/
[21:49:38] - Uploaded at ~23 kB/s
[21:49:38] - Averaged speed for that direction ~24 kB/s
[21:49:38] + Results successfully sent
[21:49:38] Thank you for your contribution to Folding@Home.
[21:49:38] + Number of Units Completed: 655
[21:49:42] Trying to send all finished work units
[21:49:42] + No unsent completed units remaining.
[21:49:42] - Preparing to get new work unit...
[21:49:42] + Attempting to get work packet
[21:49:42] - Will indicate memory of 1023 MB
[21:49:42] - Connecting to assignment server
[21:49:42] Connecting to http://assign-GPU.stanford.edu:8080/
[21:49:43] - Successful: assigned to (171.64.65.102).
[21:49:43] + News From Folding@Home: Welcome to Folding@Home
[21:49:43] Loaded queue successfully.
[21:49:43] Connecting to http://171.64.65.102:8080/
[21:49:44] - Receiving payload (expected size: 69047)
[21:49:45] - Downloaded at ~67 kB/s
[21:49:45] - Averaged speed for that direction ~23679 kB/s
[21:49:45] + Received work.
[21:49:45] Trying to send all finished work units
[21:49:45] + No unsent completed units remaining.
[21:49:45] + Closed connections
[21:49:45]
[21:49:45] + Processing work unit
[21:49:45] Core required: FahCore_11.exe
[21:49:45] Core found.
[21:49:45] Working on queue slot 02 [August 27 21:49:45 UTC]
[21:49:45] + Working ...
[21:49:45] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -checkpoint 30 -service -verbose -lifeline 644 -version 623'
[21:49:45]
[21:49:45] *------------------------------*
[21:49:45] Folding@Home GPU Core - Beta
[21:49:45] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:49:45]
[21:49:45] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:49:45] Build host: amoeba
[21:49:45] Board Type: AMD
[21:49:45] Core      :
[21:49:45] Preparing to commence simulation
[21:49:45] - Looking at optimizations...
[21:49:45] - Created dyn
[21:49:45] - Files status OK
[21:49:45] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[21:49:45] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[21:49:45] - Digital signature verified
[21:49:45]
[21:49:45] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:49:45]
[21:49:45] Assembly optimizations on if available.
[21:49:45] Entering M.D.
[21:49:51] Tpr hash work/wudata_02.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[21:49:52] Working on Protein
[21:49:54] Client config found, loading data.
[21:49:54] Starting GUI Server
[21:50:02] mdrun_gpu returned
[21:50:02] Nonzero force sum on GPU
[21:50:02]
[21:50:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:50:05] CoreStatus = 7A (122)
[21:50:05] Sending work to server
[21:50:05] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:50:05] - Read packet limit of 540015616... Set to 524286976.
[21:50:05] - Error: Could not get length of results file work/wuresults_02.dat
[21:50:05] - Error: Could not read unit 02 file. Removing from queue.
[21:50:05] Trying to send all finished work units
[21:50:05] + No unsent completed units remaining.
[21:50:05] - Preparing to get new work unit...
[21:50:05] + Attempting to get work packet
[21:50:05] - Will indicate memory of 1023 MB
[21:50:05] - Connecting to assignment server
[21:50:05] Connecting to http://assign-GPU.stanford.edu:8080/
[21:50:06] - Successful: assigned to (171.64.65.102).
[21:50:06] + News From Folding@Home: Welcome to Folding@Home
[21:50:06] Loaded queue successfully.
[21:50:06] Connecting to http://171.64.65.102:8080/
[21:50:06] - Receiving payload (expected size: 69047)
[21:50:07] - Downloaded at ~67 kB/s
[21:50:07] - Averaged speed for that direction ~18956 kB/s
[21:50:07] + Received work.
[21:50:07] Trying to send all finished work units
[21:50:07] + No unsent completed units remaining.
[21:50:07] + Closed connections
[21:50:12]
[21:50:12] + Processing work unit
[21:50:12] Core required: FahCore_11.exe
[21:50:12] Core found.
[21:50:12] Working on queue slot 03 [August 27 21:50:12 UTC]
[21:50:12] + Working ...
[21:50:12] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -service -verbose -lifeline 644 -version 623'
[21:50:12]
[21:50:12] *------------------------------*
[21:50:12] Folding@Home GPU Core - Beta
[21:50:12] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:50:12]
[21:50:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:50:12] Build host: amoeba
[21:50:12] Board Type: AMD
[21:50:12] Core      :
[21:50:12] Preparing to commence simulation
[21:50:12] - Looking at optimizations...
[21:50:12] - Created dyn
[21:50:12] - Files status OK
[21:50:12] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[21:50:12] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[21:50:12] - Digital signature verified
[21:50:12]
[21:50:12] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:50:12]
[21:50:13] Assembly optimizations on if available.
[21:50:13] Entering M.D.
[21:50:19] Tpr hash work/wudata_03.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[21:50:19] Working on Protein
[21:50:24] Client config found, loading data.
[21:50:24] Starting GUI Server
[21:50:32] mdrun_gpu returned
[21:50:32] Nonzero force sum on GPU
[21:50:32]
[21:50:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:50:34] CoreStatus = 7A (122)
[21:50:34] Sending work to server
[21:50:34] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:50:34] - Read packet limit of 540015616... Set to 524286976.
[21:50:34] - Error: Could not get length of results file work/wuresults_03.dat
[21:50:34] - Error: Could not read unit 03 file. Removing from queue.
[21:50:34] Trying to send all finished work units
[21:50:34] + No unsent completed units remaining.
[21:50:34] - Preparing to get new work unit...
[21:50:34] + Attempting to get work packet
[21:50:34] - Will indicate memory of 1023 MB
[21:50:34] - Connecting to assignment server
[21:50:34] Connecting to http://assign-GPU.stanford.edu:8080/
[21:50:35] - Successful: assigned to (171.64.65.102).
[21:50:35] + News From Folding@Home: Welcome to Folding@Home
[21:50:35] Loaded queue successfully.
[21:50:35] Connecting to http://171.64.65.102:8080/
[21:50:36] - Receiving payload (expected size: 69047)
[21:50:37] - Downloaded at ~67 kB/s
[21:50:37] - Averaged speed for that direction ~15179 kB/s
[21:50:37] + Received work.
[21:50:37] Trying to send all finished work units
[21:50:37] + No unsent completed units remaining.
[21:50:37] + Closed connections
[21:50:42]
[21:50:42] + Processing work unit
[21:50:42] Core required: FahCore_11.exe
[21:50:42] Core found.
[21:50:42] Working on queue slot 04 [August 27 21:50:42 UTC]
[21:50:42] + Working ...
[21:50:42] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -checkpoint 30 -service -verbose -lifeline 644 -version 623'
[21:50:42]
[21:50:42] *------------------------------*
[21:50:42] Folding@Home GPU Core - Beta
[21:50:42] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:50:42]
[21:50:42] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:50:42] Build host: amoeba
[21:50:42] Board Type: AMD
[21:50:42] Core      :
[21:50:42] Preparing to commence simulation
[21:50:42] - Looking at optimizations...
[21:50:42] - Created dyn
[21:50:42] - Files status OK
[21:50:42] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[21:50:42] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[21:50:42] - Digital signature verified
[21:50:42]
[21:50:42] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:50:42]
[21:50:43] Assembly optimizations on if available.
[21:50:43] Entering M.D.
[21:50:48] Tpr hash work/wudata_04.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[21:50:48] Working on Protein
[21:50:49] Client config found, loading data.
[21:50:49] Starting GUI Server
[21:50:58] mdrun_gpu returned
[21:50:58] Nonzero force sum on GPU
[21:50:58]
[21:50:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:51:00] CoreStatus = 7A (122)
[21:51:00] Sending work to server
[21:51:00] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:51:00] - Read packet limit of 540015616... Set to 524286976.
[21:51:00] - Error: Could not get length of results file work/wuresults_04.dat
[21:51:00] - Error: Could not read unit 04 file. Removing from queue.
[21:51:00] Trying to send all finished work units
[21:51:00] + No unsent completed units remaining.
[21:51:00] - Preparing to get new work unit...
[21:51:00] + Attempting to get work packet
[21:51:00] - Will indicate memory of 1023 MB
[21:51:00] - Connecting to assignment server
[21:51:00] Connecting to http://assign-GPU.stanford.edu:8080/
[21:51:01] - Successful: assigned to (171.64.65.102).
[21:51:01] + News From Folding@Home: Welcome to Folding@Home
[21:51:01] Loaded queue successfully.
[21:51:01] Connecting to http://171.64.65.102:8080/
[21:51:01] - Receiving payload (expected size: 69047)
[21:51:03] - Downloaded at ~33 kB/s
[21:51:03] - Averaged speed for that direction ~12149 kB/s
[21:51:03] + Received work.
[21:51:03] Trying to send all finished work units
[21:51:03] + No unsent completed units remaining.
[21:51:03] + Closed connections
[21:51:07]
[21:51:07] + Processing work unit
[21:51:07] Core required: FahCore_11.exe
[21:51:07] Core found.
[21:51:07] Working on queue slot 05 [August 27 21:51:07 UTC]
[21:51:07] + Working ...
[21:51:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -checkpoint 30 -service -verbose -lifeline 644 -version 623'
[21:51:08]
[21:51:08] *------------------------------*
[21:51:08] Folding@Home GPU Core - Beta
[21:51:08] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:51:08]
[21:51:08] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:51:08] Build host: amoeba
[21:51:08] Board Type: AMD
[21:51:08] Core      :
[21:51:08] Preparing to commence simulation
[21:51:08] - Looking at optimizations...
[21:51:08] - Created dyn
[21:51:08] - Files status OK
[21:51:08] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[21:51:08] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[21:51:08] - Digital signature verified
[21:51:08]
[21:51:08] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:51:08]
[21:51:08] Assembly optimizations on if available.
[21:51:08] Entering M.D.
[21:51:14] Tpr hash work/wudata_05.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[21:51:14] Working on Protein
[21:51:23] Client config found, loading data.
[21:51:23] Starting GUI Server
[21:51:32] mdrun_gpu returned
[21:51:32] Nonzero force sum on GPU
[21:51:32]
[21:51:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:51:36] CoreStatus = 7A (122)
[21:51:36] Sending work to server
[21:51:36] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:51:36] - Read packet limit of 540015616... Set to 524286976.
[21:51:36] - Error: Could not get length of results file work/wuresults_05.dat
[21:51:36] - Error: Could not read unit 05 file. Removing from queue.
[21:51:36] Trying to send all finished work units
[21:51:36] + No unsent completed units remaining.
[21:51:36] - Preparing to get new work unit...
[21:51:36] + Attempting to get work packet
[21:51:36] - Will indicate memory of 1023 MB
[21:51:36] - Connecting to assignment server
[21:51:36] Connecting to http://assign-GPU.stanford.edu:8080/
[21:51:36] - Successful: assigned to (171.64.65.102).
[21:51:36] + News From Folding@Home: Welcome to Folding@Home
[21:51:36] Loaded queue successfully.
[21:51:36] Connecting to http://171.64.65.102:8080/
[21:51:37] - Receiving payload (expected size: 69047)
[21:51:38] - Downloaded at ~67 kB/s
[21:51:38] - Averaged speed for that direction ~9733 kB/s
[21:51:38] + Received work.
[21:51:38] Trying to send all finished work units
[21:51:38] + No unsent completed units remaining.
[21:51:38] + Closed connections
[21:51:43]
[21:51:43] + Processing work unit
[21:51:43] Core required: FahCore_11.exe
[21:51:43] Core found.
[21:51:43] Working on queue slot 06 [August 27 21:51:43 UTC]
[21:51:43] + Working ...
[21:51:43] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -checkpoint 30 -service -verbose -lifeline 644 -version 623'
[21:51:43]
[21:51:43] *------------------------------*
[21:51:43] Folding@Home GPU Core - Beta
[21:51:43] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[21:51:43]
[21:51:43] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:51:43] Build host: amoeba
[21:51:43] Board Type: AMD
[21:51:43] Core      :
[21:51:43] Preparing to commence simulation
[21:51:43] - Looking at optimizations...
[21:51:43] - Created dyn
[21:51:43] - Files status OK
[21:51:43] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[21:51:43] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[21:51:43] - Digital signature verified
[21:51:43]
[21:51:43] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:51:43]
[21:51:44] Assembly optimizations on if available.
[21:51:44] Entering M.D.
[21:51:50] Tpr hash work/wudata_06.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[21:51:50] Working on Protein
[21:51:51] Client config found, loading data.
[21:51:51] Starting GUI Server
[21:51:59] mdrun_gpu returned
[21:51:59] Nonzero force sum on GPU
[21:51:59]
[21:51:59] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:52:01] CoreStatus = 7A (122)
[21:52:01] Sending work to server
[21:52:01] Project: 5745 (Run 4, Clone 46, Gen 360)
[21:52:01] - Read packet limit of 540015616... Set to 524286976.
[21:52:01] - Error: Could not get length of results file work/wuresults_06.dat
[21:52:01] - Error: Could not read unit 06 file. Removing from queue.
[21:52:01] EUE limit exceeded. Pausing 24 hours.
[01:16:43] - Autosending finished units... [August 28 01:16:43 UTC]
[01:16:43] Trying to send all finished work units
[01:16:43] + No unsent completed units remaining.
[01:16:43] - Autosend completed
[07:14:44] - Autosending finished units... [August 28 07:14:44 UTC]
[07:14:44] Trying to send all finished work units
[07:14:44] + No unsent completed units remaining.
[07:14:44] - Autosend completed
[13:12:43] - Autosending finished units... [August 28 13:12:43 UTC]
[13:12:43] Trying to send all finished work units
[13:12:43] + No unsent completed units remaining.
[13:12:43] - Autosend completed
Update: I manually deleted the failed workunits using the fah.exe -delete x command and restarted. I got another of the same RCG, which failed immediately, then got a different project. This seems to be working fine.
--- Opening Log file [August 28 17:15:19 UTC]
                          http://folding.stanford.edu
Launch directory: C:\FAH-GPU
Service: C:\FAH-GPU\Folding@home-Win32-GPU.exe
Arguments: -svcstart -d C:\FAH-GPU -verbosity 8
Launched as a service.
Entered C:\FAH-GPU to do work.
[17:15:19] - Ask before connecting: No
[17:15:19] - User name: rhavern (Team 14)
[17:15:19] - User ID: 19A0133B08D576E7
[17:15:19] - Machine ID: 2
[17:15:19]
[17:15:19] Loaded queue successfully.
[17:15:19] - Preparing to get new work unit...
[17:15:19] + Attempting to get work packet
[17:15:19] - Will indicate memory of 1023 MB
[17:15:19] - Detect CPU. Vendor: AuthenticAMD, Family: 6, Model: 10, Stepping: 0
[17:15:19] - Connecting to assignment server
[17:15:19] Connecting to http://assign-GPU.stanford.edu:8080/
[17:15:19] - Autosending finished units... [August 28 17:15:19 UTC]
[17:15:19] Trying to send all finished work units
[17:15:19] + No unsent completed units remaining.
[17:15:19] - Autosend completed
[17:15:20] - Successful: assigned to (171.64.65.102).
[17:15:20] + News From Folding@Home: Welcome to Folding@Home
[17:15:20] Loaded queue successfully.
[17:15:20] Connecting to http://171.64.65.102:8080/
[17:15:20] - Receiving payload (expected size: 69047)
[17:15:21] - Downloaded at ~67 kB/s
[17:15:21] - Averaged speed for that direction ~7800 kB/s
[17:15:21] + Received work.
[17:15:21] + Closed connections
[17:15:21]
[17:15:21] + Processing work unit
[17:15:21] Core required: FahCore_11.exe
[17:15:21] Core found.
[17:15:21] Working on queue slot 07 [August 28 17:15:21 UTC]
[17:15:21] + Working ...
[17:15:21] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -checkpoint 30 -service -verbose -lifeline 2440 -version 623'
[17:15:21]
[17:15:21] *------------------------------*
[17:15:21] Folding@Home GPU Core - Beta
[17:15:21] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[17:15:21]
[17:15:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:15:21] Build host: amoeba
[17:15:21] Board Type: AMD
[17:15:21] Core      :
[17:15:21] Preparing to commence simulation
[17:15:21] - Looking at optimizations...
[17:15:21] - Created dyn
[17:15:21] - Files status OK
[17:15:21] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[17:15:21] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[17:15:21] - Digital signature verified
[17:15:21]
[17:15:21] Project: 5745 (Run 4, Clone 46, Gen 360)
[17:15:21]
[17:15:22] Assembly optimizations on if available.
[17:15:22] Entering M.D.
[17:15:28] Tpr hash work/wudata_07.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[17:15:28] Working on Protein
[17:15:28] Client config found, loading data.
[17:15:29] Starting GUI Server
[17:15:38] mdrun_gpu returned
[17:15:38] Nonzero force sum on GPU
[17:15:38]
[17:15:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:15:42] CoreStatus = 7A (122)
[17:15:42] Sending work to server
[17:15:42] Project: 5745 (Run 4, Clone 46, Gen 360)
[17:15:42] - Read packet limit of 540015616... Set to 524286976.
[17:15:42] - Error: Could not get length of results file work/wuresults_07.dat
[17:15:42] - Error: Could not read unit 07 file. Removing from queue.
[17:15:42] Trying to send all finished work units
[17:15:42] + No unsent completed units remaining.
[17:15:42] - Preparing to get new work unit...
[17:15:42] + Attempting to get work packet
[17:15:42] - Will indicate memory of 1023 MB
[17:15:42] - Connecting to assignment server
[17:15:42] Connecting to http://assign-GPU.stanford.edu:8080/
[17:15:42] - Successful: assigned to (171.64.65.102).
[17:15:42] + News From Folding@Home: Welcome to Folding@Home
[17:15:42] Loaded queue successfully.
[17:15:42] Connecting to http://171.64.65.102:8080/
[17:15:43] - Error: Bad packet type from server, expected work assignment
[17:15:43] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[17:15:49] + Attempting to get work packet
[17:15:49] - Will indicate memory of 1023 MB
[17:15:49] - Connecting to assignment server
[17:15:49] Connecting to http://assign-GPU.stanford.edu:8080/
[17:15:49] - Successful: assigned to (171.64.65.102).
[17:15:49] + News From Folding@Home: Welcome to Folding@Home
[17:15:49] Loaded queue successfully.
[17:15:49] Connecting to http://171.64.65.102:8080/
[17:15:50] - Receiving payload (expected size: 70638)
[17:15:51] - Downloaded at ~68 kB/s
[17:15:51] - Averaged speed for that direction ~6253 kB/s
[17:15:51] + Received work.
[17:15:51] Trying to send all finished work units
[17:15:51] + No unsent completed units remaining.
[17:15:51] + Closed connections
[17:15:56]
[17:15:56] + Processing work unit
[17:15:56] Core required: FahCore_11.exe
[17:15:56] Core found.
[17:15:56] Working on queue slot 08 [August 28 17:15:56 UTC]
[17:15:56] + Working ...
[17:15:56] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -checkpoint 30 -service -verbose -lifeline 2440 -version 623'
[17:15:56]
[17:15:56] *------------------------------*
[17:15:56] Folding@Home GPU Core - Beta
[17:15:56] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[17:15:56]
[17:15:56] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:15:56] Build host: amoeba
[17:15:56] Board Type: AMD
[17:15:56] Core      :
[17:15:56] Preparing to commence simulation
[17:15:56] - Looking at optimizations...
[17:15:56] - Created dyn
[17:15:56] - Files status OK
[17:15:56] - Expanded 70126 -> 360060 (decompressed 513.4 percent)
[17:15:56] Called DecompressByteArray: compressed_data_size=70126 data_size=360060, decompressed_data_size=360060 diff=0
[17:15:56] - Digital signature verified
[17:15:56]
[17:15:56] Project: 5740 (Run 3, Clone 14, Gen 459)
[17:15:56]
[17:15:56] Assembly optimizations on if available.
[17:15:56] Entering M.D.
[17:16:02] Tpr hash work/wudata_08.tpr:  2455167289 1865377164 737194406 456241970 1372202708
[17:16:02] Working on Protein
[17:16:03] Client config found, loading data.
[17:16:03] Starting GUI Server
[17:18:56] Completed 1%
[17:22:21] Completed 2%
Folding since 1 WU=1 point
DeeGee
Hardware configuration: Asus Crosshair Hero VIII, AMD Ryzen 3950x, 2x8GB 3600MHz DDR4, Radeon VII, Win10
Asus Crosshair Hero VII, Amd Ryzen 3900x, 2x16GB 3200MHz DDR4, GeForce 980 TI, Kubuntu 19.10
Re: Project: 5745 (Run 4, Clone 46, Gen 360)
Post by DeeGee »
Same work unit came to me during the night and caused so many EUE's it paused the client.
[01:04:25] Completed 99%
[01:07:20] Completed 100%
[01:07:21] Successful run
[01:07:21] DynamicWrapper: Finished Work Unit: sleep=10000
[01:07:31] Reserved 219028 bytes for xtc file; Cosm status=0
[01:07:31] Allocated 219028 bytes for xtc file
[01:07:31] - Reading up to 219028 from "work/wudata_01.xtc": Read 219028
[01:07:31] Read 219028 bytes from xtc file; available packet space=786211436
[01:07:31] xtc file hash check passed.
[01:07:31] Reserved 33528 33528 786211436 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[01:07:31] Allocated 33528 bytes for arc file
[01:07:31] - Reading up to 33528 from "work/wudata_01.trr": Read 33528
[01:07:31] Read 33528 bytes from arc file; available packet space=786177908
[01:07:31] trr file hash check passed.
[01:07:31] Allocated 560 bytes for edr file
[01:07:31] Read bedfile
[01:07:31] edr file hash check passed.
[01:07:31] Allocated 15736 bytes for logfile
[01:07:31] Read logfile
[01:07:31] GuardedRun: success in DynamicWrapper
[01:07:31] GuardedRun: done
[01:07:31] Run: GuardedRun completed.
[01:07:32] - Writing 269364 bytes of core data to disk...
[01:07:32] Done: 268852 -> 259635 (compressed to 96.5 percent)
[01:07:32]   ... Done.
[01:07:32] - Shutting down core
[01:07:32]
[01:07:32] Folding@home Core Shutdown: FINISHED_UNIT
[01:07:35] CoreStatus = 64 (100)
[01:07:35] Sending work to server
[01:07:35] Project: 5736 (Run 0, Clone 64, Gen 349)
[01:07:35] - Read packet limit of 540015616... Set to 524286976.
[01:07:35] + Attempting to send results [September 30 01:07:35 UTC]
[01:07:43] + Results successfully sent
[01:07:43] Thank you for your contribution to Folding@Home.
[01:07:43] + Number of Units Completed: 725
[01:07:47] - Preparing to get new work unit...
[01:07:47] + Attempting to get work packet
[01:07:47] - Connecting to assignment server
[01:07:48] - Successful: assigned to (171.64.65.102).
[01:07:48] + News From Folding@Home: Welcome to Folding@Home
[01:07:48] Loaded queue successfully.
[01:07:51] + Closed connections
[01:07:51]
[01:07:51] + Processing work unit
[01:07:51] Core required: FahCore_11.exe
[01:07:51] Core found.
[01:07:51] Working on queue slot 02 [September 30 01:07:51 UTC]
[01:07:51] + Working ...
[01:07:51]
[01:07:51] *------------------------------*
[01:07:51] Folding@Home GPU Core - Beta
[01:07:51] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[01:07:51]
[01:07:51] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:07:51] Build host: amoeba
[01:07:51] Board Type: AMD
[01:07:51] Core      :
[01:07:51] Preparing to commence simulation
[01:07:51] - Looking at optimizations...
[01:07:51] - Created dyn
[01:07:51] - Files status OK
[01:07:51] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[01:07:51] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[01:07:51] - Digital signature verified
[01:07:51]
[01:07:51] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:07:51]
[01:07:51] Assembly optimizations on if available.
[01:07:51] Entering M.D.
[01:07:57] Tpr hash work/wudata_02.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[01:07:58] Working on Protein
[01:07:58] Client config found, loading data.
[01:07:58] Starting GUI Server
[01:08:02] mdrun_gpu returned
[01:08:02] Nonzero force sum on GPU
[01:08:02]
[01:08:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:08:06] CoreStatus = 7A (122)
[01:08:06] Sending work to server
[01:08:06] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:08:06] - Read packet limit of 540015616... Set to 524286976.
[01:08:06] - Error: Could not get length of results file work/wuresults_02.dat
[01:08:06] - Error: Could not read unit 02 file. Removing from queue.
[01:08:06] - Preparing to get new work unit...
[01:08:06] + Attempting to get work packet
[01:08:06] - Connecting to assignment server
[01:08:07] - Successful: assigned to (171.64.65.102).
[01:08:07] + News From Folding@Home: Welcome to Folding@Home
[01:08:07] Loaded queue successfully.
[01:08:09] + Closed connections
[01:08:14]
[01:08:14] + Processing work unit
[01:08:14] Core required: FahCore_11.exe
[01:08:14] Core found.
[01:08:14] Working on queue slot 03 [September 30 01:08:14 UTC]
[01:08:14] + Working ...
[01:08:14]
[01:08:14] *------------------------------*
[01:08:14] Folding@Home GPU Core - Beta
[01:08:14] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[01:08:14]
[01:08:14] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:08:14] Build host: amoeba
[01:08:14] Board Type: AMD
[01:08:14] Core      :
[01:08:14] Preparing to commence simulation
[01:08:14] - Looking at optimizations...
[01:08:14] - Created dyn
[01:08:14] - Files status OK
[01:08:14] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[01:08:14] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[01:08:14] - Digital signature verified
[01:08:14]
[01:08:14] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:08:14]
[01:08:14] Assembly optimizations on if available.
[01:08:14] Entering M.D.
[01:08:20] Tpr hash work/wudata_03.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[01:08:20] Working on Protein
[01:08:21] Client config found, loading data.
[01:08:21] Starting GUI Server
[01:08:24] mdrun_gpu returned
[01:08:24] Nonzero force sum on GPU
[01:08:24]
[01:08:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:08:29] CoreStatus = 7A (122)
[01:08:29] Sending work to server
[01:08:29] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:08:29] - Read packet limit of 540015616... Set to 524286976.
[01:08:29] - Error: Could not get length of results file work/wuresults_03.dat
[01:08:29] - Error: Could not read unit 03 file. Removing from queue.
[01:08:29] - Preparing to get new work unit...
[01:08:29] + Attempting to get work packet
[01:08:29] - Connecting to assignment server
[01:08:30] - Successful: assigned to (171.64.65.102).
[01:08:30] + News From Folding@Home: Welcome to Folding@Home
[01:08:30] Loaded queue successfully.
[01:08:32] + Closed connections
[01:08:37]
[01:08:37] + Processing work unit
[01:08:37] Core required: FahCore_11.exe
[01:08:37] Core found.
[01:08:37] Working on queue slot 04 [September 30 01:08:37 UTC]
[01:08:37] + Working ...
[01:08:37]
[01:08:37] *------------------------------*
[01:08:37] Folding@Home GPU Core - Beta
[01:08:37] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[01:08:37]
[01:08:37] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:08:37] Build host: amoeba
[01:08:37] Board Type: AMD
[01:08:37] Core      :
[01:08:37] Preparing to commence simulation
[01:08:37] - Looking at optimizations...
[01:08:37] - Created dyn
[01:08:37] - Files status OK
[01:08:37] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[01:08:37] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[01:08:37] - Digital signature verified
[01:08:37]
[01:08:37] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:08:37]
[01:08:37] Assembly optimizations on if available.
[01:08:37] Entering M.D.
[01:08:43] Tpr hash work/wudata_04.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[01:08:43] Working on Protein
[01:08:44] Client config found, loading data.
[01:08:44] Starting GUI Server
[01:08:47] mdrun_gpu returned
[01:08:47] Nonzero force sum on GPU
[01:08:47]
[01:08:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:08:52] CoreStatus = 7A (122)
[01:08:52] Sending work to server
[01:08:52] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:08:52] - Read packet limit of 540015616... Set to 524286976.
[01:08:52] - Error: Could not get length of results file work/wuresults_04.dat
[01:08:52] - Error: Could not read unit 04 file. Removing from queue.
[01:08:52] - Preparing to get new work unit...
[01:08:52] + Attempting to get work packet
[01:08:52] - Connecting to assignment server
[01:08:53] - Successful: assigned to (171.64.65.102).
[01:08:53] + News From Folding@Home: Welcome to Folding@Home
[01:08:53] Loaded queue successfully.
[01:08:55] + Closed connections
[01:09:00]
[01:09:00] + Processing work unit
[01:09:00] Core required: FahCore_11.exe
[01:09:00] Core found.
[01:09:00] Working on queue slot 05 [September 30 01:09:00 UTC]
[01:09:00] + Working ...
[01:09:00]
[01:09:00] *------------------------------*
[01:09:00] Folding@Home GPU Core - Beta
[01:09:00] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[01:09:00]
[01:09:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:09:00] Build host: amoeba
[01:09:00] Board Type: AMD
[01:09:00] Core      :
[01:09:00] Preparing to commence simulation
[01:09:00] - Looking at optimizations...
[01:09:00] - Created dyn
[01:09:00] - Files status OK
[01:09:00] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[01:09:00] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[01:09:00] - Digital signature verified
[01:09:00]
[01:09:00] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:09:00]
[01:09:00] Assembly optimizations on if available.
[01:09:00] Entering M.D.
[01:09:06] Tpr hash work/wudata_05.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[01:09:06] Working on Protein
[01:09:08] Client config found, loading data.
[01:09:08] Starting GUI Server
[01:09:11] mdrun_gpu returned
[01:09:11] Nonzero force sum on GPU
[01:09:11]
[01:09:11] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:09:15] CoreStatus = 7A (122)
[01:09:15] Sending work to server
[01:09:15] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:09:15] - Read packet limit of 540015616... Set to 524286976.
[01:09:15] - Error: Could not get length of results file work/wuresults_05.dat
[01:09:15] - Error: Could not read unit 05 file. Removing from queue.
[01:09:15] - Preparing to get new work unit...
[01:09:15] + Attempting to get work packet
[01:09:15] - Connecting to assignment server
[01:09:16] - Successful: assigned to (171.64.65.102).
[01:09:16] + News From Folding@Home: Welcome to Folding@Home
[01:09:16] Loaded queue successfully.
[01:09:18] + Closed connections
[01:09:23]
[01:09:23] + Processing work unit
[01:09:23] Core required: FahCore_11.exe
[01:09:23] Core found.
[01:09:23] Working on queue slot 06 [September 30 01:09:23 UTC]
[01:09:23] + Working ...
[01:09:24]
[01:09:24] *------------------------------*
[01:09:24] Folding@Home GPU Core - Beta
[01:09:24] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[01:09:24]
[01:09:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:09:24] Build host: amoeba
[01:09:24] Board Type: AMD
[01:09:24] Core      :
[01:09:24] Preparing to commence simulation
[01:09:24] - Looking at optimizations...
[01:09:24] - Created dyn
[01:09:24] - Files status OK
[01:09:24] - Expanded 68535 -> 357580 (decompressed 521.7 percent)
[01:09:24] Called DecompressByteArray: compressed_data_size=68535 data_size=357580, decompressed_data_size=357580 diff=0
[01:09:24] - Digital signature verified
[01:09:24]
[01:09:24] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:09:24]
[01:09:24] Assembly optimizations on if available.
[01:09:24] Entering M.D.
[01:09:30] Tpr hash work/wudata_06.tpr:  3093445337 740017563 3891334339 2079336442 2375787072
[01:09:30] Working on Protein
[01:09:31] Client config found, loading data.
[01:09:31] Starting GUI Server
[01:09:34] mdrun_gpu returned
[01:09:34] Nonzero force sum on GPU
[01:09:34]
[01:09:34] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:09:38] CoreStatus = 7A (122)
[01:09:38] Sending work to server
[01:09:38] Project: 5745 (Run 4, Clone 46, Gen 360)
[01:09:38] - Read packet limit of 540015616... Set to 524286976.
[01:09:38] - Error: Could not get length of results file work/wuresults_06.dat
[01:09:38] - Error: Could not read unit 06 file. Removing from queue.
[01:09:38] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
SparkyJJO
Post by SparkyJJO »
I just got this unit. Put my client to sleep for 24 hours for being "unstable" :roll:
Would be really nice if the client were to actually download a different unit by itself after a couple bad tries, instead of trying the dud over and over, blaming the hardware, and forcing a manual removal of the unit to finally get it to download a new one.
====================Folding since 2006====================
Tynat
Post by Tynat »
Wow, this has been going on for over 3 months. I also received this WU and it EUE'd 5 times pausing the client for 24 hours. Then upon restart of the client I received it one more time before I was finally assigned a different WU. The log information is the same as the others have posted, but if you need my log segment let me know and I'll post it.
All clients stopped due to Stanford's upcoming September 2011 decision
codysluder
Post by codysluder »
SparkyJJO wrote:I just got this unit. Put my client to sleep for 24 hours for being "unstable" :roll:
What do you suggest the client should do with hardware that is truly unstable? Here's an example where the client should have shut down an unstable machine but didn't. If I were writing the software, I'm not sure how to tell one from the other. The problem isn't always due to a bad WU, and it's very, very difficult to know which is the actual issue.
mathwhiz
Post by mathwhiz »
This WU popped up again - I just got it with the same results. All other work units I get process just fine.
Rich
I marked it as bad.
