There are big differences (30%) in the PPD my PC can achieve, depending on the type of WU.
My PC is obviously highly sub-optimal for some types of WU.
Is it possible to select/reject WUs based on how well my PC can process them?
e
Possible to select specific WU types?
metal03326
- Hardware configuration: Mainboard: Asus M2R32-MVP (AMD 580X CrossFire Chipset)
CPU: AMD Athlon X2 3800+@2.4GHz
CPU cooler: Arctic Cooling Freezer 64 Pro PWM
RAM: 2x1 GB Team XTreme Dark 800MHz@5-5-5-16 in Dual Channel mode
Video Card: Sapphire HD 2600 XT@850MHz GDDR4@2200MHz
HDD: WESTERN DIGITAL 640GB Caviar® Black™ SATA2 7200rpm 32MB
OS: Microsoft Windows 7 Ultimate x64
Clients (always latest version): SMP2
Dell Inspiron 1000 (Celeron@2.2GHz) - Location: Vratsa, Bulgaria.
Re: Possible to select specific WU types?
No. You can only select the size of the WU. If your PPD is better with the smaller Wus (main is), configure your client to receive small WUs. Other options are normal and big WUs. I'm talking for the console client. System tray client only have option to allow big WUs.
PS: Welcome to the forum.
Standford sends out the WUs in the order that best moves the science of the project forward. The time sensitive and serial nature of the work units also goes against WU selection as an option. Sorry.
Christopher N. Lewis
This is not the correct interpretation. Even on the same hardware some WU will take longer than others, and thus show a difference in the PPD gained. If you look at the deadlines and points awarded you will see that this is the expected behaviour.2.718 wrote:There are big differences (30%) in the PPD my PC can achieve, depending on the type of WU.
