Project: 2677 (R1, C30, G31) not sure, upgrade core!
Bull45
Hardware configuration: 2XQ6600stock-GTX280oc-2XGTX8800oc-GT9600stock
Post by Bull45 »
This will aslo not starting
[21:15:46]
[21:15:46] *------------------------------*
[21:15:46] Folding@Home Gromacs SMP Core
[21:15:46] Version 2.07 (Sun Apr 19 14:51:09 PDT 2009)
[21:15:46]
[21:15:46] Preparing to commence simulation
[21:15:46] - Ensuring status. Please wait.
[21:15:47] Called DecompressByteArray: compressed_data_size=1502178 data_size=24032525, decompressed_data_size=24032525 diff=0
[21:15:47] - Digital signature verified
[21:15:47]
[21:15:47] Project: 2677 (Run 1, Clone 30, Gen 31)
[21:15:47]
[21:15:47] Assembly optimizations on if available.
[21:15:47] Entering M.D.
[21:15:59] (Run 1, Clone 30, Gen 31)
[21:15:59]
[21:15:59] Entering M.D.
[21:50:53] - Autosending finished units... [August 26 21:50:53 UTC]
[21:50:53] Trying to send all finished work units
[21:50:53] + No unsent completed units remaining.
[21:50:53] - Autosend completed
[03:50:53] - Autosending finished units... [August 27 03:50:53 UTC]
[03:50:53] Trying to send all finished work units
[03:50:53] + No unsent completed units remaining.
[03:50:53] - Autosend completed
Edit:Sorry Im probably in error, on a another machine a i recive the same Wu, i try to force upgrade core and the wu staring.
On my différent machine only one ave upgraded automaticaly, then i force upgrade on all other
;) Have a nice day
Re: Project: 2677 (R1, C30, G31) not sure, upgrade core!
It's a bad WU affected by the "folds on 1 core" issue : viewtopic.php?f=19&t=11098
tank1023
Post by tank1023 »
Current Work Unit
Tag: P2677R24C13G29
Download time: August 31 17:37:24
Due time: September 3 17:37:24
Progress: 12% [|_________]
I have several VMware clients over the last week or so have issues. The one above is the latest. My question is do I suck it up and let it fold or delete it? I havemt been able to just delete the work folder in the past (I get the same project back). How can I delete it with out having to re install VM from scratch? Last, what is Stanford doing about all of these bad WU's? Kind of frustrating to keep geting them. Thanks.
BrokenWolf
Post by BrokenWolf »
If this is the one with the ~1.5MB download then trash it. It will not complete on time.
BrokenWolf
Ravage7779
Post by Ravage7779 »
You need to delete the queue.dat and machineindependent.dat files otherwise it will try to keep downloading the same bad WU. Same with either removing the files in the work folder or just "rm work/ -r -f". I have had enough of these and this is the only way to clear these bad ones out for now. Mr. Kasson is working on an updated to keep these from clogging up our folding systems.
BrokenWolf
tank1023 wrote:Last, what is Stanford doing about all of these bad WU's? Kind of frustrating to keep geting them. Thanks.
It has been answered several places on this forum: Stanford is working on a new core which will contain a permanent fix for this problem.
