FaH and Boinc
FaH and Boinc
Is it possible to have both running at the same time on a dedicated P4 HT machine?
Re: FaH and Boinc
Possible yes ... logic no.
Both FAH and BOINC probably use the same units to compute their work ... so you'll basically slow them both by sharing a single physical core with HT.
Re: FaH and Boinc
I can live with that.
If I start using Boinc on one machine, who gets credit for any WUs produced?Or is that a no point for team effort?
- Hardware configuration: Mainboard: Asus M2R32-MVP (AMD 580X CrossFire Chipset)
CPU: AMD Athlon X2 3800+@2.4GHz
CPU cooler: Arctic Cooling Freezer 64 Pro PWM
RAM: 2x1 GB Team XTreme Dark 800MHz@5-5-5-16 in Dual Channel mode
Video Card: Sapphire HD 2600 XT@850MHz GDDR4@2200MHz
HDD: WESTERN DIGITAL 640GB Caviar® Black™ SATA2 7200rpm 32MB
OS: Microsoft Windows 7 Ultimate x64
Clients (always latest version): SMP2
Dell Inspiron 1000 (Celeron@2.2GHz) - Location: Vratsa, Bulgaria.
Re: FaH and Boinc
Keep in mind that the main point of F@H is science, not some credits, thus the faster you return the WU, the better is for science.
- Hardware configuration: 2018 Mac Mini / MacOS Catalina
3.2 GHz 6-Core Intel Core i7 - Location: California, United States
Re: FaH and Boinc
With only one actual physical core, we prefer you choose one or the other, but not both.
Re: FaH and Boinc
FAH and BOINC are completely different. FAH credits will go to the username you create when starting FAH, and BOINC credits to the username you created when starting BOINC. The two usernames can be the same, or different.hrlow2 wrote:I can live with that.
Re: FaH and Boinc
I'm using 2x Pentium Xeon 2.4 GHz HT Enabled CPUs(HT ON) + Ati Radeon HD4850 AGP.
I'm running 1 GPU + 1 CPU F@H Clients, and two ABC@Home under BOINC Platform.(F@H has a higher priority)
I see no difference in F@H PPD (No more than 5%), because ABC@Home is mainly integer intensive. F@H is mainly floating point intensive, so if you gonna run ABC@Home, that's ok.
I don't know about any other project, that is mainly integer intenvise. If somebody knew, please let us know
ABC conjecture is very important!
Greetings
Greetings
Re: FaH and Boinc
I know nothing about ABC#Home, but if it is integer intensive as you say, then you are correct. HyperThreading is especially useful for this sort of combination where one application is mostly integer and the other is mostly Floats (including SSE) and both register as using 100% of half of the CPU. HT is almost useless if you run two heavy integer applications or two heavy float applications simultaneously.
Re: FaH and Boinc
Maybe you can share this info on the ABC@home forum as well.
Re: FaH and Boinc
Could you explain a bit more about this ABC#Home?
Re: FaH and Boinc
hrlow2 wrote:Could you explain a bit more about this ABC#Home?
That would be a good question to post on the ABC@home forum.
Re: FaH and Boinc
Time to stop this discussion ... it's not a BOINC support forum and the original question that was about has been answered.
