171.67.108.21
BrokenWolf
171.67.108.21
Post by BrokenWolf »
Can we please give this server a whack or 2 with a big hammer? It is not giving out WUs.
Thanks,
BW
Re: 171.67.108.21
How long did your client keep trying that server? There are several other servers that could be assigning work to your client and you're supposed to get work from one of them when you can't get work at the first choice. I've seen PG statements saying that you shouldn't even bother reporting this sort of problem unless you waited at least 10 minutes.
Re: 171.67.108.21
This is a known issue with this new server ... vvoelz should have fixed it now.
BrokenWolf
Re: 171.67.108.21
Bruce, It was over 3 hours the first times this started happening and at least an hour on other times before I stopped it and reconfigured the client. I would add -advmethods and -oneunit to get a WU and when it was done I'd remove the -advmethods and try again. For these most recent posts it was over 1 hour each time. I am not one to cry wolf when I do not get a WU right after I upload one. I have seen it take up 7 minutes one time to get a new WU. 2 hours is stretching it though.
From FAHlog.txt for the days in question.
--- Opening Log file [August 16 23:36:54 UTC]
                          http://folding.stanford.edu
Launch directory: C:\GPU
Service: C:\GPU\Folding@home-Win32-GPU.exe
Arguments: -svcstart -d C:\GPU -verbosity 9
Launched as a service.
Entered C:\GPU to do work.
[23:36:54] - Ask before connecting: No
[23:36:54] - User name: BrokenWolf (Team 1971)
[23:36:54] - User ID: 5DA2BA710C7BF496
[23:36:54] - Machine ID: 2
[23:36:54]
[23:36:54] Loaded queue successfully.
[23:36:54]
[23:36:54] - Autosending finished units... [August 16 23:36:54 UTC]
[23:36:54] + Processing work unit[23:36:54] Trying to send all finished work units
[23:36:54] + No unsent completed units remaining.[23:36:54] Core required: FahCore_11.exe
[23:36:54] - Autosend completed
[23:36:54] Core found.
[23:36:54] Working on queue slot 09 [August 16 23:36:54 UTC]
[23:36:54] + Working ...
[23:36:54] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -checkpoint 15 -service -verbose -lifeline 2276 -version 623'
[23:36:54]
[23:36:54] *------------------------------*
[23:36:54] Folding@Home GPU Core - Beta
[23:36:54] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[23:36:54]
[23:36:54] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:36:54] Build host: amoeba
[23:36:54] Board Type: Nvidia
[23:36:54] Core      :
[23:36:54] Preparing to commence simulation
[23:36:54] - Looking at optimizations...
[23:36:54] - Files status OK
[23:36:54] - Expanded 98637 -> 492276 (decompressed 499.0 percent)
[23:36:54] Called DecompressByteArray: compressed_data_size=98637 data_size=492276, decompressed_data_size=492276 diff=0
[23:36:54] - Digital signature verified
[23:36:54]
[23:36:54] Project: 5750 (Run 14, Clone 172, Gen 456)
[23:36:54]
[23:36:54] Assembly optimizations on if available.
[23:36:54] Entering M.D.
[23:37:00] Will resume from checkpoint file
[23:37:01] Working on Protein
[23:37:03] Client config found, loading data.
[23:37:03] Starting GUI Server
[23:37:04] Resuming from checkpoint
[23:37:04] Verified work/wudata_09.log
[23:37:04] Verified work/wudata_09.edr
[23:37:04] Verified work/wudata_09.xtc
[23:37:04] Completed 25%
[23:40:17] Completed 26%
[23:43:35] Completed 27%
[23:46:58] Completed 28%
[23:50:32] Completed 29%
[23:54:09] Completed 30%
[23:57:44] Completed 31%
[00:01:18] Completed 32%
[00:04:34] Completed 33%
[00:07:47] Completed 34%
[00:11:00] Completed 35%
[00:14:13] Completed 36%
[00:17:37] Completed 37%
[00:20:50] Completed 38%
[00:23:32] Received EVENT= from OS -- shutting down w/ INTERRUPTED signal; events=[CtrlC= Close= Break= Shutdown= LogOff=]
[00:23:32] Folding@home Core Shutdown: INTERRUPTED
[00:23:36] CoreStatus = 66 (102)
[00:23:36] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (2)
[00:23:36] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [August 17 00:25:49 UTC]
[00:25:49] - Ask before connecting: No
[00:25:49] - User name: BrokenWolf (Team 1971)
[00:25:49] - User ID: 5DA2BA710C7BF496
[00:25:49] - Machine ID: 2
[00:25:49]
[00:25:49] Loaded queue successfully.
[00:25:49]
[00:25:49] + Processing work unit
[00:25:49] Core required: FahCore_11.exe
[00:25:49] - Autosending finished units... [August 17 00:25:49 UTC]
[00:25:49] Trying to send all finished work units
[00:25:49] + No unsent completed units remaining.
[00:25:49] Core found.
[00:25:49] - Autosend completed
[00:25:50] Working on queue slot 09 [August 17 00:25:50 UTC]
[00:25:50] + Working ...
[00:25:50] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -checkpoint 15 -service -verbose -lifeline 268 -version 623'
[00:25:50]
[00:25:50] *------------------------------*
[00:25:50] Folding@Home GPU Core - Beta
[00:25:50] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:25:50]
[00:25:50] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:25:50] Build host: amoeba
[00:25:50] Board Type: Nvidia
[00:25:50] Core      :
[00:25:50] Preparing to commence simulation
[00:25:50] - Looking at optimizations...
[00:25:51] - Files status OK
[00:25:51] - Expanded 98637 -> 492276 (decompressed 499.0 percent)
[00:25:51] Called DecompressByteArray: compressed_data_size=98637 data_size=492276, decompressed_data_size=492276 diff=0
[00:25:51] - Digital signature verified
[00:25:51]
[00:25:51] Project: 5750 (Run 14, Clone 172, Gen 456)
[00:25:51]
[00:25:51] Assembly optimizations on if available.
[00:25:51] Entering M.D.
[00:25:57] Will resume from checkpoint file
[00:25:57] Working on Protein
[00:26:00] Client config found, loading data.
[00:26:00] Starting GUI Server
[00:26:00] Resuming from checkpoint
[00:26:01] Verified work/wudata_09.log
[00:26:01] Verified work/wudata_09.edr
[00:26:01] Verified work/wudata_09.xtc
[00:26:01] Completed 38%
[00:29:14] Completed 39%
[00:32:27] Completed 40%
[00:35:40] Completed 41%
[00:38:52] Completed 42%
[00:42:05] Completed 43%
[00:45:18] Completed 44%
[00:48:31] Completed 45%
[00:51:44] Completed 46%
[00:54:57] Completed 47%
[00:58:09] Completed 48%
[01:01:22] Completed 49%
[01:04:35] Completed 50%
[01:07:48] Completed 51%
[01:11:01] Completed 52%
[01:14:14] Completed 53%
[01:17:26] Completed 54%
[01:20:39] Completed 55%
[01:23:52] Completed 56%
[01:27:05] Completed 57%
[01:30:18] Completed 58%
[01:33:30] Completed 59%
[01:36:43] Completed 60%
[01:39:56] Completed 61%
[01:43:09] Completed 62%
[01:46:22] Completed 63%
[01:49:35] Completed 64%
[01:52:47] Completed 65%
[01:56:00] Completed 66%
[01:59:13] Completed 67%
[02:02:26] Completed 68%
[02:05:39] Completed 69%
[02:08:51] Completed 70%
[02:12:04] Completed 71%
[02:15:17] Completed 72%
[02:18:30] Completed 73%
[02:21:43] Completed 74%
[02:24:56] Completed 75%
[02:28:08] Completed 76%
[02:31:21] Completed 77%
[02:34:34] Completed 78%
[02:37:47] Completed 79%
[02:41:00] Completed 80%
[02:44:13] Completed 81%
[02:47:25] Completed 82%
[02:50:38] Completed 83%
[02:53:51] Completed 84%
[02:57:04] Completed 85%
[03:00:17] Completed 86%
[03:03:30] Completed 87%
[03:06:43] Completed 88%
[03:09:55] Completed 89%
[03:13:08] Completed 90%
[03:16:21] Completed 91%
[03:19:34] Completed 92%
[03:22:47] Completed 93%
[03:26:00] Completed 94%
[03:29:12] Completed 95%
[03:32:25] Completed 96%
[03:35:38] Completed 97%
[03:38:51] Completed 98%
[03:42:04] Completed 99%
[03:45:16] Completed 100%
[03:45:17] Successful run
[03:45:17] DynamicWrapper: Finished Work Unit: sleep=10000
[03:45:27] Reserved 111932 bytes for xtc file; Cosm status=0
[03:45:27] Allocated 111932 bytes for xtc file
[03:45:27] - Reading up to 111932 from "work/wudata_09.xtc": Read 111932
[03:45:27] Read 111932 bytes from xtc file; available packet space=786318532
[03:45:27] xtc file hash check passed.
[03:45:27] Reserved 33528 33528 786318532 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[03:45:27] Allocated 33528 bytes for arc file
[03:45:27] - Reading up to 33528 from "work/wudata_09.trr": Read 33528
[03:45:27] Read 33528 bytes from arc file; available packet space=786285004
[03:45:27] trr file hash check passed.
[03:45:27] Allocated 560 bytes for edr file
[03:45:27] Read bedfile
[03:45:27] edr file hash check passed.
[03:45:27] Allocated 31556 bytes for logfile
[03:45:27] Read logfile
[03:45:27] GuardedRun: success in DynamicWrapper
[03:45:27] GuardedRun: done
[03:45:27] Run: GuardedRun completed.
[03:45:31] - Writing 178088 bytes of core data to disk...
[03:45:31] Done: 177576 -> 154858 (compressed to 87.2 percent)
[03:45:31]   ... Done.
[03:45:31] - Shutting down core
[03:45:31]
[03:45:31] Folding@home Core Shutdown: FINISHED_UNIT
[03:45:34] CoreStatus = 64 (100)
[03:45:34] Unit 9 finished with 92 percent of time to deadline remaining.
[03:45:34] Updated performance fraction: 0.930243
[03:45:34] Sending work to server
[03:45:34] Project: 5750 (Run 14, Clone 172, Gen 456)
[03:45:34] + Attempting to send results [August 17 03:45:34 UTC]
[03:45:34] - Reading file work/wuresults_09.dat from core
[03:45:34]   (Read 155370 bytes from disk)
[03:45:34] Connecting to http://171.67.108.11:8080/
[03:45:37] Posted data.
[03:45:37] Initial: 0000; - Uploaded at ~50 kB/s
[03:45:37] - Averaged speed for that direction ~43 kB/s
[03:45:37] + Results successfully sent
[03:45:37] Thank you for your contribution to Folding@Home.
[03:45:37] + Number of Units Completed: 279
[03:45:41] Trying to send all finished work units
[03:45:41] + No unsent completed units remaining.
[03:45:41] - Preparing to get new work unit...
[03:45:41] + Attempting to get work packet
[03:45:41] - Will indicate memory of 8125 MB
[03:45:41] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[03:45:41] - Connecting to assignment server
[03:45:41] Connecting to http://assign-GPU.stanford.edu:8080/
[03:45:42] Posted data.
[03:45:42] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[03:45:42] + News From Folding@Home: Welcome to Folding@Home
[03:45:42] Loaded queue successfully.
[03:45:42] Connecting to http://171.67.108.21:8080/
[03:47:42] Posted data.
[04:07:42] Initial: 001A; + Could not connect to Work Server
[04:27:42] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[04:27:56] + Attempting to get work packet
[04:27:56] - Will indicate memory of 8125 MB
[04:27:56] - Connecting to assignment server
[04:27:56] Connecting to http://assign-GPU.stanford.edu:8080/
[04:27:57] Posted data.
[04:27:57] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[04:27:57] + News From Folding@Home: Welcome to Folding@Home
[04:27:57] Loaded queue successfully.
[04:27:57] Connecting to http://171.67.108.21:8080/
[04:29:57] Posted data.
[04:49:57] Initial: 001A; + Could not connect to Work Server
[05:09:57] - Attempt #2  to get work failed, and no other work to do.
[05:10:20] + Attempting to get work packet
[05:10:20] - Will indicate memory of 8125 MB
[05:10:20] - Connecting to assignment server
[05:10:20] Connecting to http://assign-GPU.stanford.edu:8080/
[05:10:21] Posted data.
[05:10:21] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[05:10:21] + News From Folding@Home: Welcome to Folding@Home
[05:10:21] Loaded queue successfully.
[05:10:21] Connecting to http://171.67.108.21:8080/
[05:12:21] Posted data.
[05:32:06] Service stop request received.
[05:32:06] ***** Got a SIGTERM signal (2)
[05:32:06] Killing all core threads
--- Opening Log file [August 17 16:37:23 UTC]
[16:37:23] - Ask before connecting: No
[16:37:23] - User name: BrokenWolf (Team 1971)
[16:37:23] - User ID: 5DA2BA710C7BF496
[16:37:23] - Machine ID: 2
[16:37:23]
[16:37:23] Work directory not found. Creating...
[16:37:23] Could not open work queue, generating new queue...
[16:37:23] - Preparing to get new work unit...
[16:37:23] + Attempting to get work packet
[16:37:23] - Will indicate memory of 8125 MB
[16:37:23] - Autosending finished units... [August 17 16:37:23 UTC]
[16:37:23] - Detect CPU.[16:37:23] Trying to send all finished work units
[16:37:23] + No unsent completed units remaining.
[16:37:23] - Connecting to assignment server
[16:37:23] - Autosend completed
[16:37:23] Connecting to http://assign-GPU.stanford.edu:8080/
[16:37:24] Posted data.
[16:37:24] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[16:37:24] + News From Folding@Home: Welcome to Folding@Home
[16:37:24] Loaded queue successfully.
[16:37:24] Connecting to http://171.67.108.21:8080/
[16:39:24] Posted data.
[16:59:24] Initial: 001A; + Could not connect to Work Server
[17:19:24] - Attempt #1  to get work failed, and no other work to do.
[17:19:33] + Attempting to get work packet
[17:19:33] - Will indicate memory of 8125 MB
[17:19:33] - Connecting to assignment server
[17:19:33] Connecting to http://assign-GPU.stanford.edu:8080/
[17:19:34] Posted data.
[17:19:34] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[17:19:34] + News From Folding@Home: Welcome to Folding@Home
[17:19:34] Loaded queue successfully.
[17:19:34] Connecting to http://171.67.108.21:8080/
[17:21:34] Posted data.
[17:41:34] Initial: 001A; + Could not connect to Work Server
[18:01:34] - Attempt #2  to get work failed, and no other work to do.
[18:01:57] + Attempting to get work packet
[18:01:57] - Will indicate memory of 8125 MB
[18:01:57] - Connecting to assignment server
[18:01:57] Connecting to http://assign-GPU.stanford.edu:8080/
[18:01:58] Posted data.
[18:01:58] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[18:01:58] + News From Folding@Home: Welcome to Folding@Home
[18:01:58] Loaded queue successfully.
[18:01:58] Connecting to http://171.67.108.21:8080/
[18:03:58] Posted data.
[18:23:58] Initial: 001A; + Could not connect to Work Server
[18:43:58] - Attempt #3  to get work failed, and no other work to do.
[18:44:19] + Attempting to get work packet
[18:44:19] - Will indicate memory of 8125 MB
[18:44:19] - Connecting to assignment server
[18:44:19] Connecting to http://assign-GPU.stanford.edu:8080/
[18:44:19] Posted data.
[18:44:19] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[18:44:19] + News From Folding@Home: Welcome to Folding@Home
[18:44:20] Loaded queue successfully.
[18:44:20] Connecting to http://171.67.108.21:8080/
[18:46:20] Posted data.
[18:50:36] Service stop request received.
[18:50:36] ***** Got a SIGTERM signal (2)
[18:50:36] Killing all core threads
And here is where I added -advmethods back in and the client was able to get a WU.
--- Opening Log file [August 17 18:56:55 UTC]
Arguments: -svcstart -d C:\GPU -verbosity 9 -advmethods
[18:56:55] - Ask before connecting: No
[18:56:55] - User name: BrokenWolf (Team 1971)
[18:56:55] - User ID: 5DA2BA710C7BF496
[18:56:55] - Machine ID: 2
[18:56:55]
[18:56:55] Loaded queue successfully.
[18:56:55] - Preparing to get new work unit...
[18:56:55] - Autosending finished units... [August 17 18:56:55 UTC]
[18:56:55] + Attempting to get work packet
[18:56:55] Trying to send all finished work units
[18:56:55] + No unsent completed units remaining.
[18:56:55] - Will indicate memory of 8125 MB
[18:56:55] - Autosend completed
[18:56:55] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[18:56:55] - Connecting to assignment server
[18:56:55] Connecting to http://assign-GPU.stanford.edu:8080/
[18:56:55] Posted data.
[18:56:55] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[18:56:55] + News From Folding@Home: Welcome to Folding@Home
[18:56:56] Loaded queue successfully.
[18:56:56] Connecting to http://171.67.108.11:8080/
[18:56:56] Posted data.
[18:56:56] Initial: 0000; - Receiving payload (expected size: 96977)
[18:56:57] - Downloaded at ~94 kB/s
[18:56:57] - Averaged speed for that direction ~94 kB/s
[18:56:57] + Received work.
[18:56:57] + Closed connections
[18:56:57]
[18:56:57] + Processing work unit
[18:56:57] Core required: FahCore_11.exe
[18:56:57] Core not found.
[18:56:57] - Core is not present or corrupted.
[18:56:57] - Attempting to download new core...
[18:56:57] + Downloading new core: FahCore_11.exe
[18:56:57] Downloading core (/~pande/Win32/x86/NVIDIA/G80/Core_11.fah from www.stanford.edu)
[18:56:58] Initial: AFDE; + 10240 bytes downloaded
[18:56:58] Initial: 8CE4; + 20480 bytes downloaded
[18:56:58] Initial: D8CE; + 30720 bytes downloaded
[18:56:58] Initial: 268C; + 40960 bytes downloaded
[18:56:58] Initial: F040; + 51200 bytes downloaded
[18:56:58] Initial: 8F3D; + 61440 bytes downloaded
[18:56:58] Initial: E22C; + 71680 bytes downloaded
[18:56:58] Initial: 232D; + 81920 bytes downloaded
[18:56:59] Initial: 7B96; + 92160 bytes downloaded
[18:56:59] Initial: 35ED; + 102400 bytes downloaded
[18:56:59] Initial: 12C7; + 112640 bytes downloaded
[18:56:59] Initial: CE46; + 122880 bytes downloaded
[18:56:59] Initial: 4CD5; + 133120 bytes downloaded
[18:56:59] Initial: 0CD7; + 143360 bytes downloaded
[18:56:59] Initial: 0D37; + 153600 bytes downloaded
[18:56:59] Initial: 2D4A; + 163840 bytes downloaded
[18:56:59] Initial: 602C; + 174080 bytes downloaded
[18:56:59] Initial: 4001; + 184320 bytes downloaded
[18:56:59] Initial: D84F; + 194560 bytes downloaded
[18:56:59] Initial: 2151; + 204800 bytes downloaded
[18:57:00] Initial: 2ABF; + 215040 bytes downloaded
[18:57:00] Initial: 5CA8; + 225280 bytes downloaded
[18:57:00] Initial: 40D4; + 235520 bytes downloaded
[18:57:00] Initial: 1804; + 245760 bytes downloaded
[18:57:00] Initial: 1478; + 256000 bytes downloaded
[18:57:00] Initial: D0B4; + 266240 bytes downloaded
[18:57:00] Initial: B858; + 276480 bytes downloaded
[18:57:00] Initial: 1830; + 286720 bytes downloaded
[18:57:00] Initial: BA4E; + 296960 bytes downloaded
[18:57:00] Initial: 3985; + 307200 bytes downloaded
[18:57:00] Initial: 232C; + 317440 bytes downloaded
[18:57:01] Initial: 63DF; + 327680 bytes downloaded
[18:57:01] Initial: 0AAF; + 337920 bytes downloaded
[18:57:01] Initial: 7F28; + 348160 bytes downloaded
[18:57:01] Initial: 9005; + 358400 bytes downloaded
[18:57:01] Initial: 8084; + 368640 bytes downloaded
[18:57:01] Initial: FBCE; + 378880 bytes downloaded
[18:57:01] Initial: F76F; + 389120 bytes downloaded
[18:57:01] Initial: C594; + 399360 bytes downloaded
[18:57:01] Initial: B0BC; + 409600 bytes downloaded
[18:57:01] Initial: DD0D; + 419840 bytes downloaded
[18:57:01] Initial: DCF5; + 430080 bytes downloaded
[18:57:01] Initial: 6D67; + 440320 bytes downloaded
[18:57:01] Initial: A987; + 450560 bytes downloaded
[18:57:01] Initial: E0CA; + 460800 bytes downloaded
[18:57:02] Initial: 6090; + 471040 bytes downloaded
[18:57:02] Initial: 83FD; + 481280 bytes downloaded
[18:57:02] Initial: D0F9; + 491520 bytes downloaded
[18:57:02] Initial: A4B9; + 501760 bytes downloaded
[18:57:02] Initial: 7046; + 512000 bytes downloaded
[18:57:02] Initial: 3F00; + 522240 bytes downloaded
[18:57:02] Initial: 07F1; + 532480 bytes downloaded
[18:57:02] Initial: 6E7D; + 542720 bytes downloaded
[18:57:02] Initial: 4416; + 552960 bytes downloaded
[18:57:02] Initial: 353A; + 563200 bytes downloaded
[18:57:03] Initial: 6C4D; + 573440 bytes downloaded
[18:57:03] Initial: 305A; + 583680 bytes downloaded
[18:57:03] Initial: 3D23; + 593920 bytes downloaded
[18:57:03] Initial: A242; + 604160 bytes downloaded
[18:57:03] Initial: 1E02; + 614400 bytes downloaded
[18:57:03] Initial: 75E0; + 624640 bytes downloaded
[18:57:03] Initial: 8F3A; + 634880 bytes downloaded
[18:57:03] Initial: 1E1B; + 642475 bytes downloaded
[18:57:04] Verifying core Core_11.fah...
[18:57:04] Signature is VALID
[18:57:04]
[18:57:04] Trying to unzip core FahCore_11.exe
[18:57:04] Decompressed FahCore_11.exe (1843200 bytes) successfully
[18:57:09] + Core successfully engaged
[18:57:14]
[18:57:14] + Processing work unit
[18:57:14] Core required: FahCore_11.exe
[18:57:14] Core found.
[18:57:14] Working on queue slot 01 [August 17 18:57:14 UTC]
[18:57:14] + Working ...
[18:57:14] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -service -verbose -lifeline 1196 -version 623'
[18:57:14]
[18:57:14] *------------------------------*
[18:57:14] Folding@Home GPU Core - Beta
[18:57:14] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[18:57:14]
[18:57:14] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[18:57:14] Build host: amoeba
[18:57:14] Board Type: Nvidia
[18:57:14] Core      :
[18:57:14] Preparing to commence simulation
[18:57:14] - Looking at optimizations...
[18:57:14] - Created dyn
[18:57:14] - Files status OK
[18:57:14] - Expanded 96465 -> 489240 (decompressed 507.1 percent)
[18:57:14] Called DecompressByteArray: compressed_data_size=96465 data_size=489240, decompressed_data_size=489240 diff=0
[18:57:14] - Digital signature verified
[18:57:14]
[18:57:14] Project: 5753 (Run 4, Clone 131, Gen 518)
[18:57:14]
[18:57:14] Assembly optimizations on if available.
[18:57:14] Entering M.D.
[18:57:20] Working on Protein
[18:57:23] Client config found, loading data.
[18:57:23] Starting GUI Server
[19:00:39] Completed 1%
