[15:55:05] - Preparing to get new work unit...
[15:55:05] + Attempting to get work packet
[15:55:05] - Will indicate memory of 2013 MB
[15:55:05] - Connecting to assignment server
[15:55:05] Connecting to http://assign.stanford.edu:8080/
[15:55:05] Posted data.
[15:55:05] Initial: 40AB; - Successful: assigned to (171.64.65.56).
[15:55:05] + News From Folding@Home: Welcome to Folding@Home
[15:55:05] Loaded queue successfully.
[15:55:05] Connecting to http://171.64.65.56:8080/
[15:55:12] Posted data.
[15:55:12] Initial: 0000; - Receiving payload (expected size: 1505864)
[15:55:14] - Downloaded at ~735 kB/s
[15:55:14] - Averaged speed for that direction ~639 kB/s
[15:55:14] + Received work.
[15:55:14] Trying to send all finished work units
[15:55:14] + No unsent completed units remaining.
[15:55:14] + Closed connections
[15:55:14]
[15:55:14] + Processing work unit
[15:55:14] At least 4 processors must be requested.Core required: FahCore_a2.exe
[15:55:14] Core found.
[15:55:14] Working on queue slot 03 [August 16 15:55:14 UTC]
[15:55:14] + Working ...
[15:55:14] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 03 -checkpoint 30 -forceasm -verbose -lifeline 5612 -version 624'
[15:55:14]
[15:55:14] *------------------------------*
[15:55:14] t.
[15:55:24] - Assembly optimizations manually forced on.
[15:55:24] - Not checking prior termination.
[15:55:24] - Expanded 1505352 -> 24024621 (decompressed 1595.9 percent)
[15:55:24] Called DecompressByteArray: compressed_data_size=1505352 data_size=24024621, decompressed_data_size=24024621 diff=0
[15:55:25] - Digital signature verified
[15:55:25]
[15:55:25] Project: 2677 (Run 5, Clone 54, Gen 34)
[15:55:25]
[15:55:25] Assembly optimizations on if available.
[15:55:25] Entering M.D.
[15:55:46] Completed 0 out of 250000 steps (0%)
[16:40:18] ruptedDynamicWrapper: Finished Work Unit: sleep=10000
[16:40:18] ome Core Shutdown: INTERRUPTED
[16:40:50] ***** Got a SIGTERM signal (15)
[16:40:50] Killing all core threads
