FoldingForum Notifier is an extension to Google Chrome. It checks for new posts and inbox messages. Here are some tips for using FoldingForum Notifier:
To open directly "View new posts", press Ctrl while clicking.
To open directly your inbox, press Shift while clicking.
To open both, press Ctrl and Shift while clicking.
If you forget them, you can always check them in About, which is shown when the icon is clicked.
Note: You must first enable extensions by adding --enable-extensions parameter to chrome.exe.
Download: FoldingForum Notifier
Also, FoldingForum Notifier have auto update option, so you don't have to worry about updating to latest version.
Bug reports and suggestions goes here.
