I tried opening a browser to both ports and I received a blank page. 4 systems are unable to send their completed WUs in.
Of course I got a1 WU's on the 4 systems for them to work on now.
Please help!!!!
171.67.108.25 80 and 8080 getting 503 error
Re: 171.67.108.25 80 and 8080 getting 503 error
-oneunit may be your friend.
171.67.108.25 is the CS for 171.64.65.56 that had been down since early this morning (EDT).
It was handling a VERY heavy load when 171.64.65.56 went down.
I got mostly 503's vs. "no connection" to the CS, and did send a couple up successfully.
171.64.65.56 came back up sometime around 915 AM your time.
Using -oneunit, I got a2's. Enjoy your a1's and be glad that you have those dual Quads.
¥our queued a2's will clear via autosend at their 6 hour interval point.
John (from the central part of the Commonwealth of Virginia, U.S.A.)
A friendly visitor to what hopefully will remain a friendly Forum.
With thanks to all of the dedicated volunteers on the staff here!!
Too late for the ones that got the A1's. I had 2 others that I was going to rebuild the system they are on but decided to start them back up. They both got A2 WUs'.
I hope that the rest of the systems get the A2s' when they finish now as well.
BW.
p.s. How about that avatar????????
BW.
Geesh, I must owe you a pm. Sorry!BrokenWolf wrote:p.s. How about that avatar????????
You can resize it and perhaps make it look even nicer.
So what happened to the A1 WUs? Did you dump them?BrokenWolf wrote:Too late for the ones that got the A1's. I had 2 others that I was going to rebuild the system they are on but decided to start them back up. They both got A2 WUs'.
BW.
