I was unable to upload 2681 for almost 11 hours. I sincerely hope this doesn't impact my bonus.
[06:58:29] Completed 250000 out of 250000 steps (100%)
[06:58:36] DynamicWrapper: Finished Work Unit: sleep=10000
[06:58:46]
[06:58:46] Finished Work Unit:
[06:58:46] - Reading up to 52713120 from "work/wudata_07.trr": Read 52713120
[06:58:46] trr file hash check passed.
[06:58:46] - Reading up to 42867716 from "work/wudata_07.xtc": Read 42867716
[06:58:46] xtc file hash check passed.
[06:58:46] edr file hash check passed.
[06:58:46] logfile size: 191706
[06:58:46] Leaving Run
[06:58:50] - Writing 95932426 bytes of core data to disk...
[06:58:51] ... Done.
[07:04:53] - Shutting down core
[07:04:53]
[07:04:53] Folding@home Core Shutdown: FINISHED_UNIT
[07:05:24] CoreStatus = 64 (100)
[07:05:24] Unit 7 finished with 62 percent of time to deadline remaining.
[07:05:24] Updated performance fraction: 0.877680
[07:05:24] Sending work to server
[07:05:24] Project: 2681 (Run 0, Clone 4, Gen 18)
[07:05:24] + Attempting to send results [July 27 07:05:24 UTC]
[07:05:24] - Reading file work/wuresults_07.dat from core
[07:05:24] (Read 95932426 bytes from disk)
[07:05:24] Connecting to http://171.67.108.22:8080/
[07:08:25] - Couldn't send HTTP request to server
[07:08:25] (Got status 504)
[07:08:25] + Could not connect to Work Server (results)
[07:08:25] (171.67.108.22:8080)
[07:08:25] + Retrying using alternative port
[07:08:25] Connecting to http://171.67.108.22:80/
[07:11:26] - Couldn't send HTTP request to server
[07:11:26] (Got status 504)
[07:11:26] + Could not connect to Work Server (results)
[07:11:26] (171.67.108.22:80)
[07:11:26] - Error: Could not transmit unit 07 (completed July 27) to work server.
[07:11:26] - 1 failed uploads of this unit.
[07:11:26] Keeping unit 07 in queue.
[07:11:26] Trying to send all finished work units
[07:11:26] Project: 2681 (Run 0, Clone 4, Gen 18)
[07:11:26] + Attempting to send results [July 27 07:11:26 UTC]
[07:11:26] - Reading file work/wuresults_07.dat from core
[07:11:26] (Read 95932426 bytes from disk)
[07:11:26] Connecting to http://171.67.108.22:8080/
[07:14:27] - Couldn't send HTTP request to server
[07:14:27] (Got status 504)
[07:14:27] + Could not connect to Work Server (results)
[07:14:27] (171.67.108.22:8080)
[07:14:27] + Retrying using alternative port
[07:14:27] Connecting to http://171.67.108.22:80/
[07:17:28] - Couldn't send HTTP request to server
[07:17:28] (Got status 504)
[07:17:28] + Could not connect to Work Server (results)
[07:17:28] (171.67.108.22:80)
[07:17:28] - Error: Could not transmit unit 07 (completed July 27) to work server.
[07:17:28] - 2 failed uploads of this unit.
[07:17:28] + Attempting to send results [July 27 07:17:28 UTC]
[07:17:28] - Reading file work/wuresults_07.dat from core
[07:17:28] (Read 95932426 bytes from disk)
[07:17:28] Connecting to http://171.67.108.25:8080/
[07:17:29] - Couldn't send HTTP request to server
[07:17:29] (Got status 503)
[07:17:29] + Could not connect to Work Server (results)
[07:17:29] (171.67.108.25:8080)
[07:17:29] + Retrying using alternative port
[07:17:29] Connecting to http://171.67.108.25:80/
[07:18:11] Posted data.
[07:18:11] Initial: 0000; - Server does not have record of this unit. Will try again later.
[07:18:11] Could not transmit unit 07 to Collection server; keeping in queue.
[07:18:11] + Sent 0 of 1 completed units to the server
[07:18:11] - Preparing to get new work unit...
[07:18:11] Cleaning up work directory
[07:18:11] + Attempting to get work packet
[07:18:11] - Will indicate memory of 28000 MB
[07:18:11] - Connecting to assignment server
[07:18:11] Connecting to http://assign.stanford.edu:8080/
[07:18:11] Initial: 40AB; - Successful: assigned to (171.64.65.56).
[07:18:11] + News From Folding@Home: Welcome to Folding@Home
[07:18:11] Loaded queue successfully.
[07:18:11] Connecting to http://171.64.65.56:8080/
[07:18:17] Posted data.
[07:18:17] Initial: 0000; - Receiving payload (expected size: 4835156)
[07:18:24] - Downloaded at ~674 kB/s
[07:18:24] - Averaged speed for that direction ~613 kB/s
[07:18:24] + Received work.
[07:18:24] Trying to send all finished work units
[07:18:24] Project: 2681 (Run 0, Clone 4, Gen 18)
[07:18:24] + Attempting to send results [July 27 07:18:24 UTC]
[07:18:24] - Reading file work/wuresults_07.dat from core
[07:18:24] (Read 95932426 bytes from disk)
[07:18:24] Connecting to http://171.67.108.22:8080/
[07:21:25] - Couldn't send HTTP request to server
[07:21:25] (Got status 504)
[07:21:25] + Could not connect to Work Server (results)
[07:21:25] (171.67.108.22:8080)
[07:21:25] + Retrying using alternative port
[07:21:25] Connecting to http://171.67.108.22:80/
[07:24:26] - Couldn't send HTTP request to server
[07:24:26] (Got status 504)
[07:24:26] + Could not connect to Work Server (results)
[07:24:26] (171.67.108.22:80)
[07:24:26] - Error: Could not transmit unit 07 (completed July 27) to work server.
[07:24:26] - 3 failed uploads of this unit.
[07:24:26] + Attempting to send results [July 27 07:24:26 UTC]
[07:24:26] - Reading file work/wuresults_07.dat from core
[07:24:26] (Read 95932426 bytes from disk)
[07:24:26] Connecting to http://171.67.108.25:8080/
[07:24:27] - Couldn't send HTTP request to server
[07:24:27] (Got status 503)
[07:24:27] + Could not connect to Work Server (results)
[07:24:27] (171.67.108.25:8080)
[07:24:27] + Retrying using alternative port
[07:24:27] Connecting to http://171.67.108.25:80/
[07:25:20] Posted data.
[07:25:20] Initial: 0000; - Server does not have record of this unit. Will try again later.
[07:25:20] Could not transmit unit 07 to Collection server; keeping in queue.
[07:25:20] + Sent 0 of 1 completed units to the server
[07:25:20] + Closed connections
[07:25:20]
[07:25:20] + Processing work unit
[07:25:20] Core required: FahCore_a2.exe
[07:25:20] Core found.
[07:25:20] Working on queue slot 08 [July 27 07:25:20 UTC]
[07:25:20] + Working ...
[07:25:20] - Calling './mpiexec -np 8 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -nice 19 -suffix 08 -nocpulock -checkpoint
30 -verbose -lifeline 12712 -version 624'
[07:25:20]
[07:25:20] *------------------------------*
[07:25:20] Folding@Home Gromacs SMP Core
[07:25:20] Version 2.08 (Mon May 18 14:47:42 PDT 2009)
[07:25:20]
[07:25:20] Preparing to commence simulation
[07:25:20] - Ensuring status. Please wait.
[07:25:21] Called DecompressByteArray: compressed_data_size=4834644 data_size=23977801, decompressed_data_size=23977801
diff=0
[07:25:21] - Digital signature verified
[07:25:21]
[07:25:21] Project: 2669 (Run 7, Clone 80, Gen 156)
*****other wu's were completed and uploaded during this time***************
[18:07:17] Completed 107500 out of 250000 steps (43%)
[18:08:14] - Autosending finished units... [July 27 18:08:14 UTC]
[18:08:14] Trying to send all finished work units
[18:08:14] Project: 2681 (Run 0, Clone 4, Gen 18)
[18:08:14] + Attempting to send results [July 27 18:08:14 UTC]
[18:08:14] - Reading file work/wuresults_07.dat from core
[18:08:14] (Read 95932426 bytes from disk)
[18:08:14] Connecting to http://171.67.108.22:8080/
[18:09:15] Posted data.
[18:09:15] Initial: 0000; - Uploaded at ~1535 kB/s
[18:09:15] - Averaged speed for that direction ~1676 kB/s
[18:09:15] + Results successfully sent
[18:09:15] Thank you for your contribution to Folding@Home.
[18:09:15] + Number of Units Completed: 9
[18:09:45] Completed 110000 out of 250000 steps (44%)
[18:10:52] + Sent 1 of 1 completed units to the server
[18:10:52] - Autosend completed
[18:12:13] Completed 112500 out of 250000 steps (45%)
Unable to upload Project: 2681 (Run 0, Clone 4, Gen 18)
Re: Unable to upload Project: 2681 (Run 0, Clone 4, Gen 18)
See viewtopic.php?f=18&t=10832
