Project: 3861 (Run 171, Clone 16, Gen 12)
Pjotr
Post by Pjotr »
I seem to have a problem with Project: 3861 (Run 171, Clone 16, Gen 12), it was allready 60% done when I tried to reconfigure FAH (thought I had to do so to get the bonus WU's according to config FAQ)
I paused the project and shut down FAH before starting the reconfig, on startup however the project started all over again :cry:
Anything I (or any of you) can do about this or did I just waste quite some time and a couple of points?
p.s. don't understand a thing about the qfix thingy but i can send the FAH log files if needed (it seems to have the old one stored in C:\Documents and Settings\*Username*\Application Data\Folding@home-x86 and the one it's working on now in just C:\Documents and Settings\*Username*. Is it possible to start the file from app data instead of the current location?
They both still have the same project code strangely.
-update: fixed it by copying the files to C:\Program Files\Folding@home\Folding@home-x86 and start FAH from there (I accedentically ran accross it when I started FAH from that folder, saw it made the same files as stored in app data and Docs & Sets
Re: Project: 3861 (Run 171, Clone 16, Gen 12)
Log file please ?
As a general rule : don't pause client before shutting it down or it will very likely trash WU.
Also, your files seems to be pretty messed ... you should uninstall the client, remove all files and folders related to FAH, and start a fresh install following the official installation guides.
Pjotr
Post by Pjotr »
ah well it's fixed anyway, I'll just reinstall after current WU
