Points going to wrong team
Hi, I started folding about 2 days ago. I go to check on my stats on my team pg 97103 and it says I am not there. So i look at my user stats in the folder app and it says I have 2372 pts but i am part of team 41239 on the fah website. I double checked my team number in the folder app and the number is 97103. What is going on?
P5-133XL
Machine #2:
Machine 3:
Re: Points going to wrong team
If you look at team 41239 the person "Dogface" with 2372 points last submitted a WU in 2005. Obviously, you picked a non-unique name. The most likely reason why you have no points for team 97103 is that you haven't yet finished even one WU for that team yet.
If you don't want to be part of team 41239 forever, then you really need to pick a different name (preferably a unique one) and reconfigure your client for it.
To check to see if you've returned a WU look in your FAHLOG.txt file and see if it has the words "Thank you for your contribution to Folding@Home". After you've sent a WU it will typically take 2-4 hours till you will show up in the stat system
ohhh ok, thank you very much. i could not find any answers anywhere
