Project: 5765 (Run 7, Clone 238, Gen 289)
HendricksSA
Post by HendricksSA »
This one tried to run five times and then finally shut down for gpu NANs and going over the EUE limit. Just passing along FYI. All other WUs processing fine. I'm pretty new to folding so two questions. 1 - Should I bother posting these? 2 - I've looked without success. What the heck is a NAN?
[11:25:19] - Preparing to get new work unit...
[11:25:19] + Attempting to get work packet
[11:25:19] - Connecting to assignment server
[11:25:20] - Successful: assigned to (171.67.108.11).
[11:25:20] + News From Folding@Home: Welcome to Folding@Home
[11:25:20] Loaded queue successfully.
[11:25:20] + Closed connections
[11:25:20]
[11:25:20] + Processing work unit
[11:25:20] Core required: FahCore_11.exe
[11:25:20] Core found.
[11:25:20] Working on queue slot 03 [July 23 11:25:20 UTC]
[11:25:20] + Working ...
[11:25:21]
[11:25:21] *------------------------------*
[11:25:21] Folding@Home GPU Core - Beta
[11:25:21] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:25:21]
[11:25:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:25:21] Build host: amoeba
[11:25:21] Board Type: Nvidia
[11:25:21] Core      :
[11:25:21] Preparing to commence simulation
[11:25:21] - Looking at optimizations...
[11:25:21] - Created dyn
[11:25:21] - Files status OK
[11:25:21] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[11:25:21] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[11:25:21] - Digital signature verified
[11:25:21]
[11:25:21] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:25:21]
[11:25:21] Assembly optimizations on if available.
[11:25:21] Entering M.D.
[11:25:27] Working on Protein
[11:25:28] Client config found, loading data.
[11:25:28] mdrun_gpu returned
[11:25:28] NANs detected on GPU
[11:25:28]
[11:25:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:25:28] Starting GUI Server
[11:25:31] CoreStatus = 7A (122)
[11:25:31] Sending work to server
[11:25:31] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:25:31] - Read packet limit of 540015616... Set to 524286976.
[11:25:31] - Error: Could not get length of results file work/wuresults_03.dat
[11:25:31] - Error: Could not read unit 03 file. Removing from queue.
[11:25:31] - Preparing to get new work unit...
[11:25:31] + Attempting to get work packet
[11:25:31] - Connecting to assignment server
[11:25:31] - Successful: assigned to (171.67.108.11).
[11:25:31] + News From Folding@Home: Welcome to Folding@Home
[11:25:32] Loaded queue successfully.
[11:25:32] + Closed connections
[11:25:37]
[11:25:37] + Processing work unit
[11:25:37] Core required: FahCore_11.exe
[11:25:37] Core found.
[11:25:37] Working on queue slot 04 [July 23 11:25:37 UTC]
[11:25:37] + Working ...
[11:25:37]
[11:25:37] *------------------------------*
[11:25:37] Folding@Home GPU Core - Beta
[11:25:37] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:25:37]
[11:25:37] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:25:37] Build host: amoeba
[11:25:37] Board Type: Nvidia
[11:25:37] Core      :
[11:25:37] Preparing to commence simulation
[11:25:37] - Looking at optimizations...
[11:25:37] - Created dyn
[11:25:37] - Files status OK
[11:25:37] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[11:25:37] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[11:25:37] - Digital signature verified
[11:25:37]
[11:25:37] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:25:37]
[11:25:38] Assembly optimizations on if available.
[11:25:38] Entering M.D.
[11:25:44] Working on Protein
[11:25:45] Client config found, loading data.
[11:25:45] Starting GUI Server
[11:25:45] mdrun_gpu returned
[11:25:45] NANs detected on GPU
[11:25:45]
[11:25:45] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:25:48] CoreStatus = 7A (122)
[11:25:48] Sending work to server
[11:25:48] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:25:48] - Read packet limit of 540015616... Set to 524286976.
[11:25:48] - Error: Could not get length of results file work/wuresults_04.dat
[11:25:48] - Error: Could not read unit 04 file. Removing from queue.
[11:25:48] - Preparing to get new work unit...
[11:25:48] + Attempting to get work packet
[11:25:48] - Connecting to assignment server
[11:25:48] - Successful: assigned to (171.67.108.11).
[11:25:48] + News From Folding@Home: Welcome to Folding@Home
[11:25:48] Loaded queue successfully.
[11:25:49] + Closed connections
[11:25:54]
[11:25:54] + Processing work unit
[11:25:54] Core required: FahCore_11.exe
[11:25:54] Core found.
[11:25:54] Working on queue slot 05 [July 23 11:25:54 UTC]
[11:25:54] + Working ...
[11:25:54]
[11:25:54] *------------------------------*
[11:25:54] Folding@Home GPU Core - Beta
[11:25:54] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:25:54]
[11:25:54] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:25:54] Build host: amoeba
[11:25:54] Board Type: Nvidia
[11:25:54] Core      :
[11:25:54] Preparing to commence simulation
[11:25:54] - Looking at optimizations...
[11:25:54] - Created dyn
[11:25:54] - Files status OK
[11:25:55] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[11:25:55] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[11:25:55] - Digital signature verified
[11:25:55]
[11:25:55] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:25:55]
[11:25:55] Assembly optimizations on if available.
[11:25:55] Entering M.D.
[11:26:02] Working on Protein
[11:26:03] Client config found, loading data.
[11:26:03] Starting GUI Server
[11:26:03] mdrun_gpu returned
[11:26:03] NANs detected on GPU
[11:26:03]
[11:26:03] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:26:06] CoreStatus = 7A (122)
[11:26:06] Sending work to server
[11:26:06] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:26:06] - Read packet limit of 540015616... Set to 524286976.
[11:26:06] - Error: Could not get length of results file work/wuresults_05.dat
[11:26:06] - Error: Could not read unit 05 file. Removing from queue.
[11:26:06] - Preparing to get new work unit...
[11:26:06] + Attempting to get work packet
[11:26:06] - Connecting to assignment server
[11:26:07] - Successful: assigned to (171.67.108.11).
[11:26:07] + News From Folding@Home: Welcome to Folding@Home
[11:26:07] Loaded queue successfully.
[11:26:08] + Closed connections
[11:26:13]
[11:26:13] + Processing work unit
[11:26:13] Core required: FahCore_11.exe
[11:26:13] Core found.
[11:26:13] Working on queue slot 06 [July 23 11:26:13 UTC]
[11:26:13] + Working ...
[11:26:13]
[11:26:13] *------------------------------*
[11:26:13] Folding@Home GPU Core - Beta
[11:26:13] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:26:13]
[11:26:13] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:26:13] Build host: amoeba
[11:26:13] Board Type: Nvidia
[11:26:13] Core      :
[11:26:13] Preparing to commence simulation
[11:26:13] - Looking at optimizations...
[11:26:13] - Created dyn
[11:26:13] - Files status OK
[11:26:13] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[11:26:13] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[11:26:13] - Digital signature verified
[11:26:13]
[11:26:13] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:26:13]
[11:26:13] Assembly optimizations on if available.
[11:26:13] Entering M.D.
[11:26:19] Working on Protein
[11:26:20] Client config found, loading data.
[11:26:20] Starting GUI Server
[11:26:20] mdrun_gpu returned
[11:26:20] NANs detected on GPU
[11:26:20]
[11:26:20] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:26:23] CoreStatus = 7A (122)
[11:26:23] Sending work to server
[11:26:23] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:26:23] - Read packet limit of 540015616... Set to 524286976.
[11:26:23] - Error: Could not get length of results file work/wuresults_06.dat
[11:26:23] - Error: Could not read unit 06 file. Removing from queue.
[11:26:23] - Preparing to get new work unit...
[11:26:23] + Attempting to get work packet
[11:26:23] - Connecting to assignment server
[11:26:24] - Successful: assigned to (171.67.108.11).
[11:26:24] + News From Folding@Home: Welcome to Folding@Home
[11:26:24] Loaded queue successfully.
[11:26:24] + Closed connections
[11:26:29]
[11:26:29] + Processing work unit
[11:26:29] Core required: FahCore_11.exe
[11:26:29] Core found.
[11:26:29] Working on queue slot 07 [July 23 11:26:29 UTC]
[11:26:29] + Working ...
[11:26:31]
[11:26:31] *------------------------------*
[11:26:31] Folding@Home GPU Core - Beta
[11:26:31] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:26:31]
[11:26:31] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:26:31] Build host: amoeba
[11:26:31] Board Type: Nvidia
[11:26:31] Core      :
[11:26:31] Preparing to commence simulation
[11:26:31] - Looking at optimizations...
[11:26:31] - Created dyn
[11:26:31] - Files status OK
[11:26:31] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[11:26:31] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[11:26:31] - Digital signature verified
[11:26:31]
[11:26:31] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:26:31]
[11:26:31] Assembly optimizations on if available.
[11:26:31] Entering M.D.
[11:26:37] Working on Protein
[11:26:38] Client config found, loading data.
[11:26:38] mdrun_gpu returned
[11:26:38] NANs detected on GPU
[11:26:38]
[11:26:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:26:42] CoreStatus = 7A (122)
[11:26:42] Sending work to server
[11:26:42] Project: 5765 (Run 7, Clone 238, Gen 289)
[11:26:42] - Read packet limit of 540015616... Set to 524286976.
[11:26:42] - Error: Could not get length of results file work/wuresults_07.dat
[11:26:42] - Error: Could not read unit 07 file. Removing from queue.
[11:26:42] EUE limit exceeded. Pausing 24 hours.
Re: Project: 5765 (Run 7, Clone 238, Gen 289)
NaN means Not a Number ... in programming world, you get this error in mathematic operations when a result is expected to be a number (binary number) and it's not, because of calculation error or hardware bug (this "not a number" can be a value out of range in the type of data used for result ... or a CPU exception). Complete definition : http://en.wikipedia.org/wiki/NaN
In FAH, it has two causes : simulation instability or hardware (or anything related) instability (because of overclocking or bad hardware).
HendricksSA wrote:Should I bother posting these?
Yes.
We do monitor these reports carefully and it's the only way that I know to determine which WUs are structurally bad and which ones may have had a problem on a single machine but work correctly on another machine.
Christopher N. Lewis
Post by Christopher N. Lewis »
Ah, right. Should we post all EUEs or just NaNs? I seem to get mostly guarded run errors soon after a WU starts (of the errors I get, most WUs run fine).
Folding for my father
Christopher N. Lewis wrote:Ah, right. Should we post all EUEs or just NaNs? I seem to get mostly guarded run errors soon after a WU starts (of the errors I get, most WUs run fine).
Depends on which client and work units, and even the EUE message. Or if the client or work units are in beta testing, and whether a few natural EUEs are expected or not.
An occasional NaN, yes. Repeated NaNs, no, because your hardware caused the problem. And the fah wiki suggests how and when to report EUEs, although the entry is not 100% definitive. http://fahwiki.net/index.php/Early_Unit ... rting_EUEs
Thanks for the Wiki link - useful
HendricksSA
It's back. No sooner do I get free of Project 5765 than the same WU comes back to haunt me 16 hours later. Same problem with GPU NANs and EUEs. Just passing FYI. Details follow. Thanks for the good info above from all you experts!
[04:10:03] - Preparing to get new work unit...
[04:10:03] + Attempting to get work packet
[04:10:03] - Connecting to assignment server
[04:10:07] - Successful: assigned to (171.67.108.11).
[04:10:07] + News From Folding@Home: Welcome to Folding@Home
[04:10:07] Loaded queue successfully.
[04:10:11] + Closed connections
[04:10:11]
[04:10:11] + Processing work unit
[04:10:11] Core required: FahCore_11.exe
[04:10:11] Core found.
[04:10:11] Working on queue slot 09 [July 24 04:10:11 UTC]
[04:10:11] + Working ...
[04:10:11]
[04:10:11] *------------------------------*
[04:10:11] Folding@Home GPU Core - Beta
[04:10:11] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[04:10:11]
[04:10:11] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:10:11] Build host: amoeba
[04:10:11] Board Type: Nvidia
[04:10:11] Core      :
[04:10:11] Preparing to commence simulation
[04:10:11] - Looking at optimizations...
[04:10:11] - Created dyn
[04:10:11] - Files status OK
[04:10:11] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[04:10:11] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[04:10:11] - Digital signature verified
[04:10:11]
[04:10:11] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:10:11]
[04:10:12] Assembly optimizations on if available.
[04:10:12] Entering M.D.
[04:10:18] Working on Protein
[04:10:19] Client config found, loading data.
[04:10:19] mdrun_gpu returned
[04:10:19] NANs detected on GPU
[04:10:19]
[04:10:19] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:10:21] CoreStatus = 7A (122)
[04:10:21] Sending work to server
[04:10:21] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:10:21] - Read packet limit of 540015616... Set to 524286976.
[04:10:21] - Error: Could not get length of results file work/wuresults_09.dat
[04:10:21] - Error: Could not read unit 09 file. Removing from queue.
[04:10:21] - Preparing to get new work unit...
[04:10:21] + Attempting to get work packet
[04:10:21] - Connecting to assignment server
[04:10:22] - Successful: assigned to (171.67.108.11).
[04:10:22] + News From Folding@Home: Welcome to Folding@Home
[04:10:22] Loaded queue successfully.
[04:10:24] + Closed connections
[04:10:29]
[04:10:29] + Processing work unit
[04:10:29] Core required: FahCore_11.exe
[04:10:29] Core found.
[04:10:29] Working on queue slot 00 [July 24 04:10:29 UTC]
[04:10:29] + Working ...
[04:10:29]
[04:10:29] *------------------------------*
[04:10:29] Folding@Home GPU Core - Beta
[04:10:29] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[04:10:29]
[04:10:29] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:10:29] Build host: amoeba
[04:10:29] Board Type: Nvidia
[04:10:29] Core      :
[04:10:29] Preparing to commence simulation
[04:10:29] - Looking at optimizations...
[04:10:29] - Created dyn
[04:10:29] - Files status OK
[04:10:29] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[04:10:29] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[04:10:29] - Digital signature verified
[04:10:29]
[04:10:29] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:10:29]
[04:10:29] Assembly optimizations on if available.
[04:10:29] Entering M.D.
[04:10:36] Working on Protein
[04:10:37] Client config found, loading data.
[04:10:37] mdrun_gpu returned
[04:10:37] NANs detected on GPU
[04:10:37]
[04:10:37] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:10:39] CoreStatus = 7A (122)
[04:10:39] Sending work to server
[04:10:39] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:10:39] - Read packet limit of 540015616... Set to 524286976.
[04:10:39] - Error: Could not get length of results file work/wuresults_00.dat
[04:10:39] - Error: Could not read unit 00 file. Removing from queue.
[04:10:39] - Preparing to get new work unit...
[04:10:39] + Attempting to get work packet
[04:10:39] - Connecting to assignment server
[04:10:40] - Successful: assigned to (171.67.108.11).
[04:10:40] + News From Folding@Home: Welcome to Folding@Home
[04:10:40] Loaded queue successfully.
[04:10:41] + Closed connections
[04:10:46]
[04:10:46] + Processing work unit
[04:10:46] Core required: FahCore_11.exe
[04:10:46] Core found.
[04:10:46] Working on queue slot 01 [July 24 04:10:46 UTC]
[04:10:46] + Working ...
[04:10:46]
[04:10:46] *------------------------------*
[04:10:46] Folding@Home GPU Core - Beta
[04:10:46] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[04:10:46]
[04:10:46] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:10:46] Build host: amoeba
[04:10:46] Board Type: Nvidia
[04:10:46] Core      :
[04:10:46] Preparing to commence simulation
[04:10:46] - Looking at optimizations...
[04:10:46] - Created dyn
[04:10:46] - Files status OK
[04:10:46] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[04:10:46] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[04:10:46] - Digital signature verified
[04:10:46]
[04:10:46] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:10:46]
[04:10:47] Assembly optimizations on if available.
[04:10:47] Entering M.D.
[04:10:53] Working on Protein
[04:10:54] Client config found, loading data.
[04:10:54] Starting GUI Server
[04:10:54] mdrun_gpu returned
[04:10:54] NANs detected on GPU
[04:10:54]
[04:10:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:10:58] CoreStatus = 7A (122)
[04:10:58] Sending work to server
[04:10:58] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:10:58] - Read packet limit of 540015616... Set to 524286976.
[04:10:58] - Error: Could not get length of results file work/wuresults_01.dat
[04:10:58] - Error: Could not read unit 01 file. Removing from queue.
[04:10:58] - Preparing to get new work unit...
[04:10:58] + Attempting to get work packet
[04:10:58] - Connecting to assignment server
[04:10:58] - Successful: assigned to (171.67.108.11).
[04:10:58] + News From Folding@Home: Welcome to Folding@Home
[04:10:58] Loaded queue successfully.
[04:11:00] + Closed connections
[04:11:05]
[04:11:05] + Processing work unit
[04:11:05] Core required: FahCore_11.exe
[04:11:05] Core found.
[04:11:05] Working on queue slot 02 [July 24 04:11:05 UTC]
[04:11:05] + Working ...
[04:11:05]
[04:11:05] *------------------------------*
[04:11:05] Folding@Home GPU Core - Beta
[04:11:05] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[04:11:05]
[04:11:05] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:11:05] Build host: amoeba
[04:11:05] Board Type: Nvidia
[04:11:05] Core      :
[04:11:05] Preparing to commence simulation
[04:11:05] - Looking at optimizations...
[04:11:05] - Created dyn
[04:11:05] - Files status OK
[04:11:05] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[04:11:05] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[04:11:05] - Digital signature verified
[04:11:05]
[04:11:05] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:11:05]
[04:11:05] Assembly optimizations on if available.
[04:11:05] Entering M.D.
[04:11:11] Working on Protein
[04:11:12] Client config found, loading data.
[04:11:12] Starting GUI Server
[04:11:12] mdrun_gpu returned
[04:11:12] NANs detected on GPU
[04:11:12]
[04:11:12] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:11:15] CoreStatus = 7A (122)
[04:11:15] Sending work to server
[04:11:15] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:11:15] - Read packet limit of 540015616... Set to 524286976.
[04:11:15] - Error: Could not get length of results file work/wuresults_02.dat
[04:11:15] - Error: Could not read unit 02 file. Removing from queue.
[04:11:15] - Preparing to get new work unit...
[04:11:15] + Attempting to get work packet
[04:11:15] - Connecting to assignment server
[04:11:18] - Successful: assigned to (171.67.108.11).
[04:11:18] + News From Folding@Home: Welcome to Folding@Home
[04:11:18] Loaded queue successfully.
[04:11:21] + Closed connections
[04:11:26]
[04:11:26] + Processing work unit
[04:11:26] Core required: FahCore_11.exe
[04:11:26] Core found.
[04:11:26] Working on queue slot 03 [July 24 04:11:26 UTC]
[04:11:26] + Working ...
[04:11:26]
[04:11:26] *------------------------------*
[04:11:26] Folding@Home GPU Core - Beta
[04:11:26] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[04:11:26]
[04:11:26] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:11:26] Build host: amoeba
[04:11:26] Board Type: Nvidia
[04:11:26] Core      :
[04:11:26] Preparing to commence simulation
[04:11:26] - Looking at optimizations...
[04:11:26] - Created dyn
[04:11:26] - Files status OK
[04:11:26] - Expanded 46759 -> 252912 (decompressed 540.8 percent)
[04:11:26] Called DecompressByteArray: compressed_data_size=46759 data_size=252912, decompressed_data_size=252912 diff=0
[04:11:26] - Digital signature verified
[04:11:26]
[04:11:26] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:11:26]
[04:11:27] Assembly optimizations on if available.
[04:11:27] Entering M.D.
[04:11:33] Working on Protein
[04:11:34] Client config found, loading data.
[04:11:34] mdrun_gpu returned
[04:11:34] NANs detected on GPU
[04:11:34]
[04:11:34] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:11:38] CoreStatus = 7A (122)
[04:11:38] Sending work to server
[04:11:38] Project: 5765 (Run 7, Clone 238, Gen 289)
[04:11:38] - Read packet limit of 540015616... Set to 524286976.
[04:11:38] - Error: Could not get length of results file work/wuresults_03.dat
[04:11:38] - Error: Could not read unit 03 file. Removing from queue.
[04:11:38] EUE limit exceeded. Pausing 24 hours.
