171.67.108.24: Server reports digital signature.....
JackOfAll
Post by JackOfAll »
Project: 2671 (Run 43, Clone 60, Gen 69)
11 failed uploads now.
[18:48:22] Trying to send all finished work units
[18:48:22] Project: 2671 (Run 43, Clone 60, Gen 69)
[18:48:22] + Attempting to send results [July 22 18:48:22 UTC]
[18:48:22] - Reading file work/wuresults_05.dat from core
[18:48:23]   (Read 48585190 bytes from disk)
[18:48:23] Connecting to http://171.67.108.24:8080/
[18:54:12] Posted data.
[18:54:12] Initial: 0000; - Uploaded at ~135 kB/s
[18:54:12] - Averaged speed for that direction ~137 kB/s
[18:54:12] - Server reports digital signature does not match.
[18:54:12]   (May be due to corruption during network transmission or a corrupted file.)
[18:54:12] - Error: Could not transmit unit 05 (completed July 21) to work server.
[18:54:12] - 10 failed uploads of this unit.
Index 5: ready for upload 1920.00 pts (176.773 pt/hr) 6.63 X min speed
  server: 171.67.108.24:8080; project: 2671
  Folding: run 43, clone 60, generation 69; benchmark 0; misc: 500, 200
  issue: Tue Jul 21 09:22:18 2009; begin: Tue Jul 21 09:22:33 2009
  end: Tue Jul 21 20:14:14 2009; due: Fri Jul 24 09:22:33 2009 (3 days)
  preferred: Fri Jul 24 09:22:33 2009 (3 days)
  core URL: http://www.stanford.edu/~pande/Linux/AMD64/Core_a2.fah (V2.07)
  core number: 0xa2; core name: GROCVS
  CPU: 16,0 AMD64; OS: 4,0 Linux
  smp cores: 4; cores to use: 4
  tag: P2671R43C60G69
  flops: 1062767810 (1062.767810 megaflops)
  memory: 2048 MB
  assignment info (le): Tue Jul 21 09:22:16 2009; BAA21CDF
  CS: 171.67.108.25; upload failures: 11; P limit: 524286976
  user: clivem; team: 35947; ID: FC8BBA106295B931; mach ID: 1
  work/wudata_05.dat file size: 4840726; WU type: Folding@Home
Folding on Linux - Fedora 11 x86_64 / nVidia 180.60 driver / CUDA 2.1
Re: 171.67.108.24: Server reports digital signature.....
Sneakernetting ? Data corruption during transfer ?
kasson
Pande Group Member
Post by kasson »
The message says it all. I'm afraid your upload didn't clear our checks. If it's repeated, it could be due to sneakernetting or other "unsupported" client-side changes. It could also occur if something strange is happening with your network connection.
After 11 failures, you can probably give up on that WU ever being returned . :(
JackOfAll
Post by JackOfAll »
Sneakernetting - no. Data corruption during transfer - I doubt it, not this many times. Network connection - I have 3 other folding machines behind the same router. No problems with them uploading WU's. IPAddress hasn't changed on this machine. It's been folding for 70 days without a reboot. Work units completed since on this machine - uploaded successfully. Nothing had changed between the original download of this WU and the failed initial upload. Anyway, not a problem. I'll just delete it from the queue and call it a day.
Just for the record, here is the complete log of the WU, from download to completion.
[08:22:16] + Attempting to get work packet
[08:22:16] - Will indicate memory of 2048 MB
[08:22:16] - Connecting to assignment server
[08:22:16] Connecting to http://assign.stanford.edu:8080/
[08:22:17] Posted data.
[08:22:17] Initial: 43AB; - Successful: assigned to (171.67.108.24).
[08:22:17] + News From Folding@Home: Welcome to Folding@Home
[08:22:17] Loaded queue successfully.
[08:22:17] Connecting to http://171.67.108.24:8080/
[08:22:23] Posted data.
[08:22:23] Initial: 0000; - Receiving payload (expected size: 4840726)
[08:22:33] - Downloaded at ~472 kB/s
[08:22:33] - Averaged speed for that direction ~504 kB/s
[08:22:33] + Received work.
[08:22:33] Trying to send all finished work units
[08:22:33] + No unsent completed units remaining.
[08:22:33] + Closed connections
[08:22:33]
[08:22:33] + Processing work unit
[08:22:33] Core required: FahCore_a2.exe
[08:22:33] Core found.
[08:22:33] Working on queue slot 05 [July 21 08:22:33 UTC]
[08:22:33] + Working ...
[08:22:33] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 14044 -version 624'
[08:22:33]
[08:22:33] *------------------------------*
[08:22:33] Folding@Home Gromacs SMP Core
[08:22:33] Version 2.07 (Sun Apr 19 14:51:09 PDT 2009)
[08:22:33]
[08:22:33] Preparing to commence simulation
[08:22:33] - Ensuring status. Please wait.
[08:22:34] Called DecompressByteArray: compressed_data_size=4840214 data_size=24005045, decompressed_data_size=24005045 diff=0
[08:22:34] - Digital signature verified
[08:22:34]
[08:22:34] Project: 2671 (Run 43, Clone 60, Gen 69)
[08:22:34]
[08:22:34] Assembly optimizations on if available.
[08:22:34] Entering M.D.
[08:22:44] Run 43, Clone 60, Gen 69)
[08:22:44]
[08:22:44] Entering M.D.
[08:22:52] Completed 0 out of 250000 steps  (0%)
[08:29:36] Completed 2500 out of 250000 steps  (1%)
[08:33:53] - Autosending finished units... [July 21 08:33:53 UTC]
[08:33:53] Trying to send all finished work units
[08:33:53] + No unsent completed units remaining.
[08:33:53] - Autosend completed
[08:36:24] Completed 5000 out of 250000 steps  (2%)
[08:43:09] Completed 7500 out of 250000 steps  (3%)
[08:49:51] Completed 10000 out of 250000 steps  (4%)
[08:56:42] Completed 12500 out of 250000 steps  (5%)
[09:03:31] Completed 15000 out of 250000 steps  (6%)
[09:10:15] Completed 17500 out of 250000 steps  (7%)
[09:16:43] Completed 20000 out of 250000 steps  (8%)
[09:22:52] Completed 22500 out of 250000 steps  (9%)
[09:28:57] Completed 25000 out of 250000 steps  (10%)
[09:35:01] Completed 27500 out of 250000 steps  (11%)
[09:41:07] Completed 30000 out of 250000 steps  (12%)
[09:47:12] Completed 32500 out of 250000 steps  (13%)
[09:53:19] Completed 35000 out of 250000 steps  (14%)
[09:59:27] Completed 37500 out of 250000 steps  (15%)
[10:05:30] Completed 40000 out of 250000 steps  (16%)
[10:11:36] Completed 42500 out of 250000 steps  (17%)
[10:17:40] Completed 45000 out of 250000 steps  (18%)
[10:23:49] Completed 47500 out of 250000 steps  (19%)
[10:29:56] Completed 50000 out of 250000 steps  (20%)
[10:36:04] Completed 52500 out of 250000 steps  (21%)
[10:42:09] Completed 55000 out of 250000 steps  (22%)
[10:48:12] Completed 57500 out of 250000 steps  (23%)
[10:54:20] Completed 60000 out of 250000 steps  (24%)
[11:00:29] Completed 62500 out of 250000 steps  (25%)
[11:06:37] Completed 65000 out of 250000 steps  (26%)
[11:12:41] Completed 67500 out of 250000 steps  (27%)
[11:18:50] Completed 70000 out of 250000 steps  (28%)
[11:24:58] Completed 72500 out of 250000 steps  (29%)
[11:31:04] Completed 75000 out of 250000 steps  (30%)
[11:37:09] Completed 77500 out of 250000 steps  (31%)
[11:43:17] Completed 80000 out of 250000 steps  (32%)
[11:49:24] Completed 82500 out of 250000 steps  (33%)
[11:55:33] Completed 85000 out of 250000 steps  (34%)
[12:01:38] Completed 87500 out of 250000 steps  (35%)
[12:07:42] Completed 90000 out of 250000 steps  (36%)
[12:13:46] Completed 92500 out of 250000 steps  (37%)
[12:19:50] Completed 95000 out of 250000 steps  (38%)
[12:25:59] Completed 97500 out of 250000 steps  (39%)
[12:32:03] Completed 100000 out of 250000 steps  (40%)
[12:38:05] Completed 102500 out of 250000 steps  (41%)
[12:44:11] Completed 105000 out of 250000 steps  (42%)
[12:50:10] Completed 107500 out of 250000 steps  (43%)
[12:56:15] Completed 110000 out of 250000 steps  (44%)
[13:02:21] Completed 112500 out of 250000 steps  (45%)
[13:08:21] Completed 115000 out of 250000 steps  (46%)
[13:14:24] Completed 117500 out of 250000 steps  (47%)
[13:20:30] Completed 120000 out of 250000 steps  (48%)
[13:26:28] Completed 122500 out of 250000 steps  (49%)
[13:32:30] Completed 125000 out of 250000 steps  (50%)
[13:38:36] Completed 127500 out of 250000 steps  (51%)
[13:44:41] Completed 130000 out of 250000 steps  (52%)
[13:50:48] Completed 132500 out of 250000 steps  (53%)
[13:56:55] Completed 135000 out of 250000 steps  (54%)
[14:03:02] Completed 137500 out of 250000 steps  (55%)
[14:09:09] Completed 140000 out of 250000 steps  (56%)
[14:15:16] Completed 142500 out of 250000 steps  (57%)
[14:21:22] Completed 145000 out of 250000 steps  (58%)
[14:27:29] Completed 147500 out of 250000 steps  (59%)
[14:33:34] Completed 150000 out of 250000 steps  (60%)
[14:33:53] - Autosending finished units... [July 21 14:33:53 UTC]
[14:33:53] Trying to send all finished work units
[14:33:53] + No unsent completed units remaining.
[14:33:53] - Autosend completed
[14:39:36] Completed 152500 out of 250000 steps  (61%)
[14:45:39] Completed 155000 out of 250000 steps  (62%)
[14:51:46] Completed 157500 out of 250000 steps  (63%)
[14:57:51] Completed 160000 out of 250000 steps  (64%)
[15:03:57] Completed 162500 out of 250000 steps  (65%)
[15:09:59] Completed 165000 out of 250000 steps  (66%)
[15:16:06] Completed 167500 out of 250000 steps  (67%)
[15:22:12] Completed 170000 out of 250000 steps  (68%)
[15:28:19] Completed 172500 out of 250000 steps  (69%)
[15:34:17] Completed 175000 out of 250000 steps  (70%)
[15:40:20] Completed 177500 out of 250000 steps  (71%)
[15:46:31] Completed 180000 out of 250000 steps  (72%)
[15:52:33] Completed 182500 out of 250000 steps  (73%)
[15:59:15] Completed 185000 out of 250000 steps  (74%)
[16:06:52] Completed 187500 out of 250000 steps  (75%)
[16:14:23] Completed 190000 out of 250000 steps  (76%)
[16:22:02] Completed 192500 out of 250000 steps  (77%)
[16:29:37] Completed 195000 out of 250000 steps  (78%)
[16:37:12] Completed 197500 out of 250000 steps  (79%)
[16:44:48] Completed 200000 out of 250000 steps  (80%)
[16:52:25] Completed 202500 out of 250000 steps  (81%)
[17:00:01] Completed 205000 out of 250000 steps  (82%)
[17:07:24] Completed 207500 out of 250000 steps  (83%)
[17:15:05] Completed 210000 out of 250000 steps  (84%)
[17:22:43] Completed 212500 out of 250000 steps  (85%)
[17:30:22] Completed 215000 out of 250000 steps  (86%)
[17:37:58] Completed 217500 out of 250000 steps  (87%)
[17:45:38] Completed 220000 out of 250000 steps  (88%)
[17:53:13] Completed 222500 out of 250000 steps  (89%)
[18:00:47] Completed 225000 out of 250000 steps  (90%)
[18:08:25] Completed 227500 out of 250000 steps  (91%)
[18:16:04] Completed 230000 out of 250000 steps  (92%)
[18:22:58] Completed 232500 out of 250000 steps  (93%)
[18:29:46] Completed 235000 out of 250000 steps  (94%)
[18:36:38] Completed 237500 out of 250000 steps  (95%)
[18:43:22] Completed 240000 out of 250000 steps  (96%)
[18:50:10] Completed 242500 out of 250000 steps  (97%)
[18:56:59] Completed 245000 out of 250000 steps  (98%)
[19:03:48] Completed 247500 out of 250000 steps  (99%)
[19:10:38] Completed 250000 out of 250000 steps  (100%)
[19:10:39] DynamicWrapper: Finished Work Unit: sleep=10000
[19:10:49]
[19:10:49] Finished Work Unit:
[19:10:49] - Reading up to 21152736 from "work/wudata_05.trr": Read 21152736
[19:10:49] trr file hash check passed.
[19:10:49] - Reading up to 27105440 from "work/wudata_05.xtc": Read 27105440
[19:10:49] xtc file hash check passed.
[19:10:49] edr file hash check passed.
[19:10:49] logfile size: 181918
[19:10:49] Leaving Run
[19:10:54] - Writing 48585190 bytes of core data to disk...
[19:10:54]   ... Done.
[19:10:59] - Shutting down core
[19:10:59]
[19:10:59] Folding@home Core Shutdown: FINISHED_UNIT
[19:14:14] CoreStatus = 64 (100)
[19:14:14] Unit 5 finished with 85 percent of time to deadline remaining.
[19:14:14] Updated performance fraction: 0.846548
[19:14:14] Sending work to server
[19:14:14] Project: 2671 (Run 43, Clone 60, Gen 69)
[19:14:14] + Attempting to send results [July 21 19:14:14 UTC]
[19:14:14] - Reading file work/wuresults_05.dat from core
[19:14:14]   (Read 48585190 bytes from disk)
[19:14:14] Connecting to http://171.67.108.24:8080/
[19:19:56] Posted data.
[19:19:57] Initial: 0000; - Uploaded at ~138 kB/s
[19:19:57] - Averaged speed for that direction ~129 kB/s
[19:19:57] - Server reports digital signature does not match.
[19:19:57]   (May be due to corruption during network transmission or a corrupted file.)
[19:19:57] - Error: Could not transmit unit 05 (completed July 21) to work server.
[19:19:57] - 1 failed uploads of this unit.
kasson
Pande Group Member
Post by kasson »
Sorry--sounds like the machine is otherwise clean. I'd guess that maybe one of the data files got corrupted.
JackOfAll
Post by JackOfAll »
No problem. Thanks for looking.
