Queue Info
kjplzak
Queue Info
Post by kjplzak »
My computer is new to F@H. I was observing some of the options available with the icon in the lower left tray. Under "Status", there is a subheading called "Queue Info". The queue slot is set to 0. Is this appropriate? Is there any other information that I need to know to make things work better?
Thank you,
Kevin - Astronomer :)
Re: Queue Info
There are 10 queue slots, from 0 to 9 ... first WU uses slot 0, the next one will use slot 1, etc ... After slot 9, it will go back to slot 0 and it continues like this.
These queue slots are used to keep WU on hold if you can't send results back because some servers are down.
