Server 171.64.122.70 assigning the same work unit
Teddy
Post by Teddy »
As you can see Server 171.64.122.70 assigning the same work unit to different PC's
First machine has a 8800GT
[01:01:38] Connecting to http://171.64.122.70:8080/
[01:01:39] Posted data.
[01:01:39] Initial: 0000; - Receiving payload (expected size: 69089)
[01:01:40] - Downloaded at ~67 kB/s
[01:01:40] - Averaged speed for that direction ~41 kB/s
[01:01:40] + Received work.
[01:01:40] Trying to send all finished work units
[01:01:40] + No unsent completed units remaining.
[01:01:40] + Closed connections
[01:01:40]
[01:01:40] + Processing work unit
[01:01:40] Core required: FahCore_14.exe
[01:01:40] Core found.
[01:01:40] Working on queue slot 02 [July 9 01:01:40 UTC]
[01:01:40] + Working ...
[01:01:40] - Calling '.\FahCore_14.exe -dir work/ -suffix 02 -priority 96 -checkpoint 3 -forceasm -verbose -lifeline 2472 -version 620'
[01:01:40]
[01:01:40] *------------------------------*
[01:01:40] Folding@Home GPU Core - Beta
[01:01:40] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[01:01:40]
[01:01:40] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:01:40] Build host: vspm46
[01:01:40] Board Type: Nvidia
[01:01:40] Core      :
[01:01:40] Preparing to commence simulation
[01:01:40] - Assembly optimizations manually forced on.
[01:01:40] - Not checking prior termination.
[01:01:40] - Expanded 68577 -> 357580 (decompressed 521.4 percent)
[01:01:40] Called DecompressByteArray: compressed_data_size=68577 data_size=357580, decompressed_data_size=357580 diff=0
[01:01:40] - Digital signature verified
[01:01:40]
[01:01:40] Project: 5905 (Run 7, Clone 788, Gen 9)
[01:01:40]
[01:01:40] Assembly optimizations on if available.
[01:01:40] Entering M.D.
[01:01:46] Tpr hash work/wudata_02.tpr:  1685994971 17079278 2184001687 1637963013 362036615
[01:01:46] Working on Protein
[01:01:47] Client config found, loading data.
[01:01:47] Starting GUI Server
[01:07:16] Completed 1%
& second machine has a 9800GTX+
[01:01:39] Initial: 40AB; - Successful: assigned to (171.64.122.70).
[01:01:39] + News From Folding@Home: Welcome to Folding@Home
[01:01:40] Loaded queue successfully.
[01:01:40] Connecting to http://171.64.122.70:8080/
[01:01:40] Posted data.
[01:01:40] Initial: 0000; - Receiving payload (expected size: 69089)
[01:01:41] - Downloaded at ~67 kB/s
[01:01:41] - Averaged speed for that direction ~62 kB/s
[01:01:41] + Received work.
[01:01:41] Trying to send all finished work units
[01:01:41] + No unsent completed units remaining.
[01:01:41] + Closed connections
[01:01:41]
[01:01:41] + Processing work unit
[01:01:41] Core required: FahCore_14.exe
[01:01:41] Core found.
[01:01:41] Working on queue slot 00 [July 9 01:01:41 UTC]
[01:01:41] + Working ...
[01:01:41] - Calling '.\FahCore_14.exe -dir work/ -suffix 00 -priority 96 -checkpoint 3 -forceasm -verbose -lifeline 3388 -version 620'
[01:01:41]
[01:01:41] *------------------------------*
[01:01:41] Folding@Home GPU Core - Beta
[01:01:41] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[01:01:41]
[01:01:41] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:01:41] Build host: vspm46
[01:01:41] Board Type: Nvidia
[01:01:41] Core      :
[01:01:41] Preparing to commence simulation
[01:01:41] - Assembly optimizations manually forced on.
[01:01:41] - Not checking prior termination.
[01:01:41] - Expanded 68577 -> 357580 (decompressed 521.4 percent)
[01:01:41] Called DecompressByteArray: compressed_data_size=68577 data_size=357580, decompressed_data_size=357580 diff=0
[01:01:41] - Digital signature verified
[01:01:41]
[01:01:41] Project: 5905 (Run 7, Clone 788, Gen 9)
[01:01:41]
[01:01:41] Assembly optimizations on if available.
[01:01:41] Entering M.D.
[01:01:47] Tpr hash work/wudata_00.tpr:  1685994971 17079278 2184001687 1637963013 362036615
[01:01:48] Working on Protein
[01:01:48] Client config found, loading data.
[01:01:49] Starting GUI Server
[01:06:08] Completed 1%
This is the NOT the first time this has happened either? Buggy AS code?
Teddy
Re: Server 171.64.122.70 assigning the same work unit
I had the same thing happen on another server yesterday ... it sometimes occurs when you simultaneously request two WUs.
It's a safety feature that prevent a single donor from depleting a server with to many requests from his clients (imagine someone with thousands of clients starting simultaneously).
You don't have to worry about this, you'll get credit for both WU.
Teddy
Post by Teddy »
Sorry about the cross post :(
Was not sure where to put the post?
Yes strange that this is a recurring problem, I would have thought once the AS decided to send out a work unit , it then doesn't decide to send the same work unit out again to somebody else in this case another PC in my farm, it must handle MANY simultaneous requests not just from my computers but from other users as well. Is this doubling up of sending out work a common problem coz this is the second time that I happened to notice this...?
Teddy :)
