No appropiate work server was available
Plazzman
Post by Plazzman »
Getting the following on all three of my nvidia gtcx 250 wine clients..
Connecting to http://assign-GPU.stanford.edu:8080/
Posted data.
Initial: 0000; No appropriate work server was available; will try again in a bit. Not sure which server to look for if it is down??
When I go to that address in browser acts like it wants to download something?
Thanks, Plazz
Re: No appropiate work server was available
Plazzman wrote:When I go to that address in browser acts like it wants to download something?
That's an expected behavior, and means that everything is fine (if you download the file and then open it, you'll seen a "OK").
If you can't get work something must be wrong with your client configuration (check the reported memory, your flags, ...) as all GPU work servers are operational and have work to distribute.
Plazzman
Post by Plazzman »
Thanks toTow!!!! My bad had to do a hard re boot (Power Off) to get it back working correctly..
Thanks Again.. Plazz
