171.64.65.102 can't get work
- Hardware configuration: 2 x X5550 Xeons - SuperMicro MBD-X8DAi-O
Server 2008 R2 x64 - 12GB Crucial DDR3 ECC Ram
PCP&C 910 Silencer - 1 x HIS 4850 ICEQ Turbo Edition
6 x E5530 Xeons (3 Systems) - SUPERMICRO MBD-X8DTL-i-O
Server 2008 RS x64 - 8GB DDR3 GSkill Non-ECC Ram
Seasonic 80+ Bronze 380w PSU
2 x E5504 - SUPERMICRO MBD-X8DTL-i-O
Server 2008 R2 x64 - 6GB DDR3 GSkill Non-ECC Ram
2.3 TB Raid 5 Array - Corsair 520 Power Supply
E5504 - EVGA X58 ATX Motherboard
Windows 7 x64 - 6GB DDR3 GSkill Non-ECC Ram
Seasonic 300 Power Supply
Intel X5550 CPU - EVGA X58 Micro ATX Motherboard
Windows 7 x64 - 3GB Corsair DDR3-1600
Corsair 550 Power Supply - ATI 4350
Dell Vostro 1500 Laptop - Intel T9300 C2D CPU
Windows 7 x64 - 4 GB DDR2-6400 - nVidia 8400m GS
Xeon 3075 C2D - Intel P35 Motherboard - 4GB DDR2 Non-ECC Ram
Server 2008 R2 x64- Seasonic 300 Power Supply - Location: Columbia, Tennessee
171.64.65.102 - In Reject +1 hour
Server: 171.64.65.102
Status: Reject
Looks like it went down at: Sun May 17 20:35:20 PDT 2009
This is affecting ATI gpu2 clients.
Status: Reject
Re: 171.64.65.102 - In Reject +1 hour
Somebody at Stanford must have been up late. It looks like this was fixed about 23:20:20 PDT
The issue did appear fixed as of this morning but I am having issues again with the client
Cannot receive work.
Intel Q9450 | 8GB Corsair XMS2 | 4870 1GB | Logitech G-15/G-9 | Windows 7 Ultimate x64
AMD 4400+ | 2GB Corsair XMS | 8800 GTS 512 | Logitech Edge | Windows 7 Ultimate x32
Please post FAHlog showing which servers it has tried during what times.Sazar wrote:Cannot receive work.
- Hardware configuration: 4p/4 MC ES @ 3.0GHz/32GB
4p/4x6128 @ 2.47GHz/32GB
2p/2 IL ES @ 2.7GHz/16GB
1p/8150/8GB
1p/1090T/4GB - Location: neither here nor there
Here's part of mine, it's the only part that shows a server.
[11:12:33] + Couldn't get work instructions.
[11:12:33] - Attempt #7 to get work failed, and no other work to do.
Waiting before retry.
[11:18:03] + Attempting to get work packet
[11:18:03] - Connecting to assignment server
[11:18:04] - Successful: assigned to (171.64.65.103).
[11:18:04] + News From Folding@Home: Welcome to Folding@Home
[11:18:04] Loaded queue successfully.
[11:18:04] + Could not connect to Work Server
[11:18:04] - Attempt #8 to get work failed, and no other work to do.
[11:28:56] + Attempting to get work packet
iustus quia...
But that's no the right server ... see viewtopic.php?f=18&t=10011 for issues with 103.
- Hardware configuration: HD 3870 / HD 3870x2 / HD 4870 / E8400 / Q9550 / AMD 4800+ x2 939
I've got 5 clients in this state. I don't think it's fixed yet.
[18:28:20] + Attempting to send results [May 19 18:28:20 UTC]
[18:28:20] - Reading file work/wuresults_02.dat from core
[18:28:20] (Read 238737 bytes from disk)
[18:28:20] Connecting to http://171.64.65.103:8080/
[18:28:25] Posted data.
[18:28:25] Initial: 0000; - Uploaded at ~46 kB/s
[18:28:25] - Averaged speed for that direction ~41 kB/s
[18:28:25] + Results successfully sent
[18:28:25] Thank you for your contribution to Folding@Home.
[18:28:25] + Number of Units Completed: 331
[18:28:29] Trying to send all finished work units
[18:28:29] + No unsent completed units remaining.
[18:28:29] - Preparing to get new work unit...
[18:28:29] + Attempting to get work packet
[18:28:29] - Will indicate memory of 3070 MB
[18:28:29] - Connecting to assignment server
[18:28:29] Connecting to http://assign-GPU.stanford.edu:8080/
[18:28:30] Posted data.
[18:28:30] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:28:30] + Couldn't get work instructions.
[18:28:30] - Attempt #1 to get work failed, and no other work to do.
[18:28:39] + Attempting to get work packet
[18:28:39] - Will indicate memory of 3070 MB
[18:28:39] - Connecting to assignment server
[18:28:39] Connecting to http://assign-GPU.stanford.edu:8080/
[18:28:40] Posted data.
[18:28:40] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:28:40] + Couldn't get work instructions.
[18:28:40] - Attempt #2 to get work failed, and no other work to do.
[18:28:55] + Attempting to get work packet
[18:28:55] - Will indicate memory of 3070 MB
[18:28:55] - Connecting to assignment server
[18:28:55] Connecting to http://assign-GPU.stanford.edu:8080/
[18:28:56] Posted data.
[18:28:56] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:28:56] + Couldn't get work instructions.
[18:28:56] - Attempt #3 to get work failed, and no other work to do.
[18:29:18] + Attempting to get work packet
[18:29:18] - Will indicate memory of 3070 MB
[18:29:18] - Connecting to assignment server
[18:29:18] Connecting to http://assign-GPU.stanford.edu:8080/
[18:29:19] Posted data.
[18:29:19] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:29:19] + Couldn't get work instructions.
[18:29:19] - Attempt #4 to get work failed, and no other work to do.
[18:30:06] + Attempting to get work packet
[18:30:06] - Will indicate memory of 3070 MB
[18:30:06] - Connecting to assignment server
[18:30:06] Connecting to http://assign-GPU.stanford.edu:8080/
[18:30:07] Posted data.
[18:30:07] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:30:07] + Couldn't get work instructions.
[18:30:07] - Attempt #5 to get work failed, and no other work to do.
[18:31:35] + Attempting to get work packet
[18:31:35] - Will indicate memory of 3070 MB
[18:31:35] - Connecting to assignment server
[18:31:35] Connecting to http://assign-GPU.stanford.edu:8080/
[18:31:35] Posted data.
[18:31:35] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:31:35] + Couldn't get work instructions.
[18:31:35] - Attempt #6 to get work failed, and no other work to do.
[18:34:29] + Attempting to get work packet
[18:34:29] - Will indicate memory of 3070 MB
[18:34:29] - Connecting to assignment server
[18:34:29] Connecting to http://assign-GPU.stanford.edu:8080/
[18:34:30] Posted data.
[18:34:30] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:34:30] + Couldn't get work instructions.
[18:34:30] - Attempt #7 to get work failed, and no other work to do.
[18:40:03] + Attempting to get work packet
[18:40:03] - Will indicate memory of 3070 MB
[18:40:03] - Connecting to assignment server
[18:40:03] Connecting to http://assign-GPU.stanford.edu:8080/
[18:40:03] Posted data.
[18:40:03] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[18:40:03] + News From Folding@Home: Welcome to Folding@Home
[18:40:03] Loaded queue successfully.
[18:40:03] Connecting to http://171.64.65.103:8080/
[18:40:04] Posted data.
[18:40:04] Initial: 0000; + Could not connect to Work Server
[18:40:04] - Attempt #8 to get work failed, and no other work to do.
[18:50:47] + Attempting to get work packet
[18:50:47] - Will indicate memory of 3070 MB
[18:50:47] - Connecting to assignment server
[18:50:47] Connecting to http://assign-GPU.stanford.edu:8080/
[18:50:48] Posted data.
[18:50:48] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:50:48] + Couldn't get work instructions.
[18:50:48] - Attempt #9 to get work failed, and no other work to do.
[19:12:20] + Attempting to get work packet
[19:12:20] - Will indicate memory of 3070 MB
[19:12:20] - Connecting to assignment server
[19:12:20] Connecting to http://assign-GPU.stanford.edu:8080/
[19:12:21] Posted data.
[19:12:21] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:12:21] + Couldn't get work instructions.
[19:12:21] - Attempt #10 to get work failed, and no other work to do.
[19:55:06] + Attempting to get work packet
[19:55:06] - Will indicate memory of 3070 MB
[19:55:06] - Connecting to assignment server
[19:55:06] Connecting to http://assign-GPU.stanford.edu:8080/
[19:55:06] Posted data.
[19:55:06] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:55:06] + Couldn't get work instructions.
[19:55:06] - Attempt #11 to get work failed, and no other work to do.
[20:43:09] + Attempting to get work packet
[20:43:09] - Will indicate memory of 3070 MB
[20:43:09] - Connecting to assignment server
[20:43:09] Connecting to http://assign-GPU.stanford.edu:8080/
[20:43:10] Posted data.
[20:43:10] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[20:43:10] + News From Folding@Home: Welcome to Folding@Home
[20:43:10] Loaded queue successfully.
[20:43:10] Connecting to http://171.64.65.103:8080/
[20:43:11] Posted data.
[20:43:11] Initial: 0000; + Could not connect to Work Server
[20:43:11] - Attempt #12 to get work failed, and no other work to do.
[21:31:20] + Attempting to get work packet
[21:31:20] - Will indicate memory of 3070 MB
[21:31:20] - Connecting to assignment server
[21:31:20] Connecting to http://assign-GPU.stanford.edu:8080/
[21:31:21] Posted data.
[21:31:21] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[21:31:21] + News From Folding@Home: Welcome to Folding@Home
[21:31:21] Loaded queue successfully.
[21:31:21] Connecting to http://171.64.65.103:8080/
[21:31:21] Initial: 0000; + Could not connect to Work Server
[21:31:21] - Attempt #13 to get work failed, and no other work to do.
[21:37:54] - Autosending finished units... [May 19 21:37:54 UTC]
[21:37:54] Trying to send all finished work units
[21:37:54] + No unsent completed units remaining.
[21:37:54] - Autosend completed
1p/8150/8GB
Yes, but if you look at the time stamp of my post and his, he posted 2 minutes before me so I was already in this post reading, copying/pasteing and typing before he posted. Besides that was the only server that showed up in the log and hoped it would make a contrabution to the thread.toTOW wrote:But that's no the right server ... see viewtopic.php?f=18&t=10011 for issues with 103.
But thanks for the link anyway.
PS. I'm still not receiving email notification to post's being answered.
iustus quia...
Either you have one of the ISPs which has adopted a filtering program that is blocking email from the forum or you have a spam filter that needs to be configured so that the forum is on your white-list. See viewtopic.php?f=27&t=8996orion wrote:PS. I'm still not receiving email notification to post's being answered.
1p/8150/8GB
Yep, saw and posted in there.codysluder wrote:Either you have one of the ISPs which has adopted a filtering program that is blocking email from the forum or you have a spam filter that needs to be configured so that the forum is on your white-list. See viewtopic.php?f=27&t=8996orion wrote:PS. I'm still not receiving email notification to post's being answered.
O well, it does make me come back and check things out more often
iustus quia...
- Hardware configuration: 3 - Supermicro H8QGi-F AMD MC 6174=144 cores 2.5Ghz, 96GB G.Skill DDR3 1333Mhz Ubuntu 10.10
In Reject mode
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Well she is down again along with 171.67.108.17
[12:22:58] - Couldn't send HTTP request to server
[12:22:58] + Could not connect to Work Server (results)
[12:22:58] (171.64.65.102:80)
[12:22:58] - Error: Could not transmit unit 00 (completed June 23) to work server.
[12:22:58] - 2 failed uploads of this unit.
[12:22:58] + Attempting to send results [June 23 12:22:58 UTC]
[12:22:58] - Reading file work/wuresults_00.dat from core
[12:22:58] (Read 176693 bytes from disk)
[12:22:58] Connecting to http://171.67.108.17:8080/
[12:22:58] (Got status 503)
[12:22:58] (171.67.108.17:8080)
[12:22:58] + Retrying using alternative port
[12:22:58] Connecting to http://171.67.108.17:80/
[12:22:58] (171.67.108.17:80)
[12:22:58] Could not transmit unit 00 to Collection server; keeping in queue.
[12:22:58] Project: 5745 (Run 1, Clone 87, Gen 152)
Yup...can't get work on this one or 171.64.65.64 (SMP)
New problem new thread....can't get work
checking communications with it and I get an ok
[22:29:10] Posted data.
[22:29:10] Initial: 0000; + Could not connect to Work Server
[22:29:10] - Attempt #8 to get work failed, and no other work to do.
[22:39:57] + Attempting to get work packet
[22:39:57] - Will indicate memory of 2046 MB
[22:39:57] - Connecting to assignment server
[22:39:57] Connecting to http://assign-GPU.stanford.edu:8080/
[22:39:58] Posted data.
[22:39:58] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[22:39:58] + News From Folding@Home: Welcome to Folding@Home
[22:39:58] Loaded queue successfully.
[22:39:58] Connecting to http://171.64.65.102:8080/
[22:39:59] Posted data.
[22:39:59] Initial: 0000; + Could not connect to Work Server
[22:39:59] - Attempt #9 to get work failed, and no other work to do.
[23:01:28] + Attempting to get work packet
[23:01:28] - Will indicate memory of 2046 MB
[23:01:28] - Connecting to assignment server
[23:01:28] Connecting to http://assign-GPU.stanford.edu:8080/
[23:01:29] Posted data.
[23:01:29] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[23:01:29] + News From Folding@Home: Welcome to Folding@Home
[23:01:29] Loaded queue successfully.
[23:01:29] Connecting to http://171.64.65.102:8080/
[23:01:30] Posted data.
[23:01:30] Initial: 0000; + Could not connect to Work Server
[23:01:30] - Attempt #10 to get work failed, and no other work to do.
Re: 171.64.65.102 can't get work
can't get work
[01:22:19] - Successful: assigned to (171.64.65.102).
[01:22:19] + News From Folding@Home: Welcome to Folding@Home
[01:22:19] Loaded queue successfully.
[01:22:19] + Could not connect to Work Server
[01:22:19] - Attempt #5 to get work failed, and no other work to do.
[01:23:51] + Attempting to get work packet
[01:23:51] - Connecting to assignment server
[01:23:51] + No appropriate work server was available; will try again in a bit.
[01:23:51] + Couldn't get work instructions.
[01:23:51] - Attempt #6 to get work failed, and no other work to do.
[01:26:32] + Attempting to get work packet
[01:26:32] - Connecting to assignment server
[01:26:32] + No appropriate work server was available; will try again in a bit.
[01:26:32] + Couldn't get work instructions.
[01:26:32] - Attempt #7 to get work failed, and no other work to do.
[01:32:03] + Attempting to get work packet
[01:32:03] - Connecting to assignment server
[01:32:04] + No appropriate work server was available; will try again in a bit.
[01:32:04] + Couldn't get work instructions.
[01:32:04] - Attempt #8 to get work failed, and no other work to do.
[01:42:50] + Attempting to get work packet
[01:42:50] - Connecting to assignment server
[01:42:50] + No appropriate work server was available; will try again in a bit.
[01:42:50] + Couldn't get work instructions.
[01:42:50] - Attempt #9 to get work failed, and no other work to do.
