[11:45:39] + Attempting to send results [June 23 11:45:39 UTC]
[11:45:39] - Reading file work/wuresults_01.dat from core
[11:45:39]   (Read 177000 bytes from disk)
[11:45:39] Connecting to http://171.64.65.102:8080/
[11:45:40] - Couldn't send HTTP request to server
[11:45:40] + Could not connect to Work Server (results)
[11:45:40]     (171.64.65.102:8080)
[11:45:40] + Retrying using alternative port
[11:45:40] Connecting to http://171.64.65.102:80/
[11:45:42] - Couldn't send HTTP request to server
[11:45:42] + Could not connect to Work Server (results)
[11:45:42]     (171.64.65.102:80)
[11:45:42] - Error: Could not transmit unit 01 (completed June 23) to work server.
[11:45:42] - 1 failed uploads of this unit.
[11:45:42]   Keeping unit 01 in queue.
[11:45:42] Trying to send all finished work units
[11:45:42] Project: 5744 (Run 2, Clone 85, Gen 177)
[11:45:42] - Read packet limit of 540015616... Set to 524286976.
[11:45:42] + Attempting to send results [June 23 11:45:42 UTC]
[11:45:42] - Reading file work/wuresults_01.dat from core
[11:45:42]   (Read 177000 bytes from disk)
[11:45:42] Connecting to http://171.64.65.102:8080/
[11:45:44] - Couldn't send HTTP request to server
[11:45:44] + Could not connect to Work Server (results)
[11:45:44]     (171.64.65.102:8080)
[11:45:44] + Retrying using alternative port
[11:45:44] Connecting to http://171.64.65.102:80/
[11:45:45] - Couldn't send HTTP request to server
[11:45:45] + Could not connect to Work Server (results)
[11:45:45]     (171.64.65.102:80)
[11:45:45] - Error: Could not transmit unit 01 (completed June 23) to work server.
[11:45:45] - 2 failed uploads of this unit.
[11:45:45] - Read packet limit of 540015616... Set to 524286976.
[11:45:45] + Attempting to send results [June 23 11:45:45 UTC]
[11:45:45] - Reading file work/wuresults_01.dat from core
[11:45:45]   (Read 177000 bytes from disk)
[11:45:45] Connecting to http://171.67.108.17:8080/
[11:45:47] - Couldn't send HTTP request to server
[11:45:47] + Could not connect to Work Server (results)
[11:45:47]     (171.67.108.17:8080)
[11:45:47] + Retrying using alternative port
[11:45:47] Connecting to http://171.67.108.17:80/
[11:45:52] - Couldn't send HTTP request to server
[11:45:52] + Could not connect to Work Server (results)
[11:45:52]     (171.67.108.17:80)
[11:45:52]   Could not transmit unit 01 to Collection server; keeping in queue.
[11:45:52] + Sent 0 of 1 completed units to the server
[11:45:52] - Preparing to get new work unit...
[11:45:52] + Attempting to get work packet
[11:45:52] - Will indicate memory of 4095 MB
[11:45:52] - Connecting to assignment server
[11:45:52] Connecting to http://assign-GPU.stanford.edu:8080/
[11:45:53] Posted data.
[11:45:53] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[11:45:53] + Couldn't get work instructions.
[11:45:53] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[11:46:11] + Attempting to get work packet
[11:46:11] - Will indicate memory of 4095 MB
[11:46:11] - Connecting to assignment server
[11:46:11] Connecting to http://assign-GPU.stanford.edu:8080/
[11:46:11] Posted data.
[11:46:11] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[11:46:11] + Couldn't get work instructions.
[11:46:11] - Attempt #2  to get work failed, and no other work to do.
[11:46:34] + Attempting to get work packet
[11:46:34] - Will indicate memory of 4095 MB
[11:46:34] - Connecting to assignment server
[11:46:34] Connecting to http://assign-GPU.stanford.edu:8080/
[11:46:35] Posted data.
[11:46:35] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[11:46:35] + Couldn't get work instructions.
[11:46:35] - Attempt #3  to get work failed, and no other work to do.
[11:47:06] + Attempting to get work packet
[11:47:06] - Will indicate memory of 4095 MB
[11:47:06] - Connecting to assignment server
[11:47:06] Connecting to http://assign-GPU.stanford.edu:8080/
[11:47:07] Posted data.
[11:47:07] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[11:47:07] + Couldn't get work instructions.
[11:47:07] - Attempt #4  to get work failed, and no other work to do.
[11:47:57] + Attempting to get work packet
[11:47:57] - Will indicate memory of 4095 MB
[11:47:57] - Connecting to assignment server
[11:47:57] Connecting to http://assign-GPU.stanford.edu:8080/
[11:47:58] Posted data.
[11:47:58] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[11:47:58] + Couldn't get work instructions.
[11:47:58] - Attempt #5  to get work failed, and no other work to do.
[11:49:30] + Attempting to get work packet
[11:49:30] - Will indicate memory of 4095 MB
[11:49:30] - Connecting to assignment server
[11:49:30] Connecting to http://assign-GPU.stanford.edu:8080/
[11:49:30] - Could not CosmHTTPOpen
[11:49:30] + Could not connect to Assignment Server
[11:49:30] Connecting to http://assign-GPU.stanford.edu:80/
[11:49:30] + Could not connect to Assignment Server 2
[11:49:30] + Couldn't get work instructions.
[11:49:30] - Attempt #6  to get work failed, and no other work to do.
[11:52:16] + Attempting to get work packet
[11:52:16] - Will indicate memory of 4095 MB
[11:52:16] - Connecting to assignment server
[11:52:16] Connecting to http://assign-GPU.stanford.edu:8080/
[11:52:16] - Could not CosmHTTPOpen
[11:52:16] + Could not connect to Assignment Server
[11:52:16] Connecting to http://assign-GPU.stanford.edu:80/
[11:52:16] + Could not connect to Assignment Server 2
[11:52:16] + Couldn't get work instructions.
[11:52:16] - Attempt #7  to get work failed, and no other work to do.
[11:57:39] + Attempting to get work packet
[11:57:39] - Will indicate memory of 4095 MB
[11:57:39] - Connecting to assignment server
[11:57:39] Connecting to http://assign-GPU.stanford.edu:8080/
[11:57:40] Posted data.
[11:57:40] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[11:57:40] + Couldn't get work instructions.
[11:57:40] - Attempt #8  to get work failed, and no other work to do.
[12:08:34] + Attempting to get work packet
[12:08:34] - Will indicate memory of 4095 MB
[12:08:34] - Connecting to assignment server
[12:08:34] Connecting to http://assign-GPU.stanford.edu:8080/
[12:08:35] Posted data.
[12:08:35] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[12:08:35] + Couldn't get work instructions.
[12:08:35] - Attempt #9  to get work failed, and no other work to do.
--- Opening Log file [June 23 13:06:40 UTC]
                          http://folding.stanford.edu
Launch directory: F:\GPU FaH\console
Executable: F:\GPU FaH\console\Folding@home-Win32-GPU.exe
Arguments: -gpu 0 -verbosity 9
[13:06:40] - Ask before connecting: No
[13:06:40] - User name:
[13:06:40] - User ID:
[13:06:40] - Machine ID: 3
[13:06:40]
[13:06:40] Loaded queue successfully.
[13:06:40] - Preparing to get new work unit...
[13:06:40] + Attempting to get work packet
[13:06:40] - Autosending finished units... [13:06:40]3:06:40 UTC]
[13:06:40] - Will indicate memory of 4095 MB
[13:06:40] Trying to send all finished work units
[13:06:40] - Detect CPU.[13:06:40] Project: 5744 (Run 2, Clone 85, Gen 177)
 Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 10
[13:06:40] - Read packet limit of 540015616... [13:06:40] - Connecting to assignment server
[13:06:40] Connecting to http://assign-GPU.stanford.edu:8080/
Set to 524286976.
[13:06:40] + Attempting to send results [June 23 13:06:40 UTC]
[13:06:40] - Reading file work/wuresults_01.dat from core
[13:06:40]   (Read 177000 bytes from disk)
[13:06:40] Connecting to http://171.64.65.102:8080/
[13:06:41] Posted data.
[13:06:41] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:06:41] + Couldn't get work instructions.
[13:06:41] - Attempt #1  to get work failed, and no other work to do.
[13:06:42] - Couldn't send HTTP request to server
[13:06:42] + Could not connect to Work Server (results)
[13:06:42]     (171.64.65.102:8080)
[13:06:42] + Retrying using alternative port
[13:06:42] Connecting to http://171.64.65.102:80/
[13:06:43] - Couldn't send HTTP request to server
[13:06:43] + Could not connect to Work Server (results)
[13:06:43]     (171.64.65.102:80)
[13:06:43] - Error: Could not transmit unit 01 (completed June 23) to work server.
[13:06:43] - 3 failed uploads of this unit.
[13:06:43] - Read packet limit of 540015616... Set to 524286976.
[13:06:43] + Attempting to send results [June 23 13:06:43 UTC]
[13:06:43] - Reading file work/wuresults_01.dat from core
[13:06:43]   (Read 177000 bytes from disk)
[13:06:43] Connecting to http://171.67.108.17:8080/
[13:06:44] - Couldn't send HTTP request to server
[13:06:44] + Could not connect to Work Server (results)
[13:06:44]     (171.67.108.17:8080)
[13:06:44] + Retrying using alternative port
[13:06:44] Connecting to http://171.67.108.17:80/
[13:06:46] - Couldn't send HTTP request to server
[13:06:46] + Could not connect to Work Server (results)
[13:06:46]     (171.67.108.17:80)
[13:06:46]   Could not transmit unit 01 to Collection server; keeping in queue.
[13:06:46] + Sent 0 of 1 completed units to the server
[13:06:46] - Autosend completed
[13:06:56] + Attempting to get work packet
[13:06:56] - Will indicate memory of 4095 MB
[13:06:56] - Connecting to assignment server
[13:06:56] Connecting to http://assign-GPU.stanford.edu:8080/
[13:06:57] Posted data.
[13:06:57] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:06:57] + Couldn't get work instructions.
[13:06:57] - Attempt #2  to get work failed, and no other work to do.
[13:07:19] + Attempting to get work packet
[13:07:19] - Will indicate memory of 4095 MB
[13:07:19] - Connecting to assignment server
[13:07:19] Connecting to http://assign-GPU.stanford.edu:8080/
[13:07:19] Posted data.
[13:07:19] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:07:19] + Couldn't get work instructions.
[13:07:19] - Attempt #3  to get work failed, and no other work to do.
[13:07:46] + Attempting to get work packet
[13:07:46] - Will indicate memory of 4095 MB
[13:07:46] - Connecting to assignment server
[13:07:46] Connecting to http://assign-GPU.stanford.edu:8080/
[13:07:47] Posted data.
[13:07:47] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:07:47] + Couldn't get work instructions.
[13:07:47] - Attempt #4  to get work failed, and no other work to do.
[13:08:38] + Attempting to get work packet
[13:08:38] - Will indicate memory of 4095 MB
[13:08:38] - Connecting to assignment server
[13:08:38] Connecting to http://assign-GPU.stanford.edu:8080/
[13:08:39] Posted data.
[13:08:39] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:08:39] + Couldn't get work instructions.
[13:08:39] - Attempt #5  to get work failed, and no other work to do.
Failed to Connect
The connection was refused when attempting to contact 171.64.65.102:8080.
