ATI GPU: No appropriate work server was available
bapriebe
Hardware configuration: HP xw4600 workstation (4GB)+Q9650+Sapphire Vapor-X HD4890,
HP Z600 workstation (4GB)+2xXEON E5540+Sapphire HD5770,
HP ML350 server (4GB)+2xXEON E5520+Diamond HD3850
Post by bapriebe »
[13:02:07] Connecting to http://assign-GPU.stanford.edu:8080/
[13:02:07] Posted data.
[13:02:07] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:02:07] + Couldn't get work instructions.
[13:02:07] - Attempt #9  to get work failed, and no other work to do.  Waiting before retry.
171.64.65.102 is shown in REJECT mode.
171.64.65.103 is shown in ACCEPTING mode with WU's available. Yet I'm not getting any...
Re: ATI GPU: No appropriate work server was available
On next update, Server Status shows both server working ... but yes, 103 is low on work :(
bapriebe
Post by bapriebe »
It might be low but it wasn't completely out. Why would it refuse to assign to it ,low or not?
bapriebe wrote:It might be low but it wasn't completely out. Why would it refuse to assign to it ,low or not?
There is a threshold that it doesn't go below. I can only guess, but I suspect it has to do with the coordination if information between the Assignment Server and the various Work Servers and whatever associated timing issues might exist.
It takes about 7 minutes to generate the data we see on serverstat.html and it is posted about every 10 minutes. As completed WUs are returned, new WUs are generated, so the number changes frequently between the updates that we can see.
bapriebe
Post by bapriebe »
Are 171.64.65.102 and 171.64.65.103 the only ATI GPU work servers? We're back in the same boat we were earlier with 102 in REJECT and 103 critically low on work. One GPU here idled for 1.5hrs and another about to be...
EvilAlchemist
Hardware configuration: 2 x X5550 Xeons - SuperMicro MBD-X8DAi-O
Server 2008 R2 x64 - 12GB Crucial DDR3 ECC Ram
PCP&C 910 Silencer - 1 x HIS 4850 ICEQ Turbo Edition
6 x E5530 Xeons (3 Systems) - SUPERMICRO MBD-X8DTL-i-O
Server 2008 RS x64 - 8GB DDR3 GSkill Non-ECC Ram
Seasonic 80+ Bronze 380w PSU
2 x E5504 - SUPERMICRO MBD-X8DTL-i-O
Server 2008 R2 x64 - 6GB DDR3 GSkill Non-ECC Ram
2.3 TB Raid 5 Array - Corsair 520 Power Supply
E5504 - EVGA X58 ATX Motherboard
Windows 7 x64 - 6GB DDR3 GSkill Non-ECC Ram
Seasonic 300 Power Supply
Intel X5550 CPU - EVGA X58 Micro ATX Motherboard
Windows 7 x64 - 3GB Corsair DDR3-1600
Corsair 550 Power Supply - ATI 4350
Dell Vostro 1500 Laptop - Intel T9300 C2D CPU
Windows 7 x64 - 4 GB DDR2-6400 - nVidia 8400m GS
Xeon 3075 C2D - Intel P35 Motherboard - 4GB DDR2 Non-ECC Ram
Server 2008 R2 x64- Seasonic 300 Power Supply
Post by EvilAlchemist »
It seems I am having this issue as well.
[20:23:35] + Attempting to send results [June 19 20:23:35 UTC]
[20:23:35] - Reading file work/wuresults_09.dat from core
[20:23:35]   (Read 177313 bytes from disk)
[20:23:35] Connecting to http://171.67.108.17:8080/
[20:23:35] - Couldn't send HTTP request to server
[20:23:35]   (Got status 503)
[20:23:35] + Could not connect to Work Server (results)
[20:23:35]     (171.67.108.17:8080)
[20:23:35] + Retrying using alternative port
[20:23:35] Connecting to http://171.67.108.17:80/
[20:23:35]     (171.67.108.17:80)
[20:23:35]   Could not transmit unit 09 to Collection server; keeping in queue.
[20:23:35] + Sent 0 of 1 completed units to the server
[20:23:35] - Autosend completed
[20:49:00] + Attempting to get work packet
[20:49:00] - Will indicate memory of 4027 MB
[20:49:00] - Connecting to assignment server
[20:49:00] Connecting to http://assign-GPU.stanford.edu:8080/
[20:49:00] Posted data.
[20:49:00] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[20:49:00] + Couldn't get work instructions.
[20:49:00] - Attempt #11  to get work failed, and no other work to do.
[21:37:14] + Attempting to get work packet
[21:37:14] - Will indicate memory of 4027 MB
[21:37:14] - Connecting to assignment server
[21:37:14] Connecting to http://assign-GPU.stanford.edu:8080/
[21:37:14] Posted data.
[21:37:14] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[21:37:14] + Couldn't get work instructions.
[21:37:14] - Attempt #12  to get work failed, and no other work to do.
bapriebe
Post by bapriebe »
EvilAlchemist wrote:It seems I am having this issue as well.
102 just dispensed a WU here...
bapriebe wrote:Are 171.64.65.102 and 171.64.65.103 the only ATI GPU work servers?
Yes :(
