CPU and GPU console on Vista
Crozz
Post by Crozz »
Hey guys!
I've a small problem.
On my computer, I run Vista and have two accounts. Both are admin accs.
When I install CPU and GPU through the console as install as service, then nothing happens. Everytime people uses my computer, I first start my acc and then F@H before someone else can use the computer and access the second acc.
Why doesn't it start auto? It works fine on our XP computer home, but probably because it only has one account without password.
Any ideas?
codysluder
Re: CPU and GPU console on Vista
Post by codysluder »
I don't know about the GPU client, but certainly a service running the CPU client starts before anyone logs in and keeps running while various accounts log in and out. Are you sure that you're not starting a client with a shortcut in startup or something like that?
Zagen30
Post by Zagen30 »
I believe that when a client is installed as a service there's no visible evidence on the desktop- it doesn't automatically open something in the taskbar or the system tray. If you use a monitoring client like FahMon and point that at the installation directory(ies), that should tell you whether they're running or not.
Check the box for View Processes from all users. Then check to see if any fah_cores are running.
Crozz
Post by Crozz »
I've checked and FaHMon says F@H isn't running and no process are running on my computer from F@H.
DanGe
Hardware configuration: 2018 Mac Mini / MacOS Catalina
3.2 GHz 6-Core Intel Core i7
Post by DanGe »
Open the Service manager (Start menu --> All Programs --> Administrative Tools --> Services OR Start Menu --> enter "services.msc") and check if there are entries that say "Folding@Home-CPU-[Machine ID]".
By the way, the GPU console does not work as a service on Vista. It says that on the Download page.
Windows Vista GPU Console client (note running as a service does not work in Vista).
Crozz
Post by Crozz »
Yes, I know that. I just wrote that to see if there was any way to fix it.
Maybe I should just create a .bat file and put it in autostart folder?
Crozz
Post by Crozz »
By the way guys. I'm starting to get troubales with Geforce 8800GT. When its 99% done with the WU, then suddenly it says "EUE Limited exceeded. Pausing 24 hours."
Why is this problem appearing? I've losed points because of this, and have didnät recieved any last days.
Shall I install a older client? Because I'm running the latest version.
DanGe
Post by DanGe »
Could you post your FAHlog here?
Crozz
Post by Crozz »
I got the CPU to work now, I was so stupid and forgot to "Run as administrator". Well, now CPU works :)
--- Opening Log file [June 15 11:45:10 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Users\Carl Sebastian Malm\Documents\Övrigt\FAH\GPU
Executable: C:\Users\Carl Sebastian Malm\Documents\Övrigt\FAH\GPU\Folding@home-Win32-GPU.exe
[11:45:10] Configuring Folding@Home...
[11:45:36] - Ask before connecting: No
[11:45:36] - User name: Crozz (Team 129657)
[11:45:36] - User ID: 47FE8D81329419B5
[11:45:36] - Machine ID: 2
[11:45:36]
[11:45:36] Work directory not found. Creating...
[11:45:36] Could not open work queue, generating new queue...
[11:45:36] - Preparing to get new work unit...
[11:45:36] + Attempting to get work packet
[11:45:36] - Connecting to assignment server
[11:45:37] - Successful: assigned to (171.67.108.11).
[11:45:37] + News From Folding@Home: Welcome to Folding@Home
[11:45:37] Loaded queue successfully.
[11:45:38] + Closed connections
[11:45:38]
[11:45:38] + Processing work unit
[11:45:39] Core required: FahCore_11.exe
[11:45:39] Core not found.
[11:45:39] - Core is not present or corrupted.
[11:45:39] - Attempting to download new core...
[11:45:39] + Downloading new core: FahCore_11.exe
[11:45:39] + 10240 bytes downloaded
[11:45:40] + 20480 bytes downloaded
[11:45:40] + 30720 bytes downloaded
[11:45:40] + 40960 bytes downloaded
[11:45:40] + 51200 bytes downloaded
[11:45:40] + 61440 bytes downloaded
[11:45:40] + 71680 bytes downloaded
[11:45:40] + 81920 bytes downloaded
[11:45:40] + 92160 bytes downloaded
[11:45:40] + 102400 bytes downloaded
[11:45:40] + 112640 bytes downloaded
[11:45:41] + 122880 bytes downloaded
[11:45:41] + 133120 bytes downloaded
[11:45:41] + 143360 bytes downloaded
[11:45:41] + 153600 bytes downloaded
[11:45:41] + 163840 bytes downloaded
[11:45:41] + 174080 bytes downloaded
[11:45:41] + 184320 bytes downloaded
[11:45:41] + 194560 bytes downloaded
[11:45:41] + 204800 bytes downloaded
[11:45:41] + 215040 bytes downloaded
[11:45:41] + 225280 bytes downloaded
[11:45:41] + 235520 bytes downloaded
[11:45:41] + 245760 bytes downloaded
[11:45:41] + 256000 bytes downloaded
[11:45:41] + 266240 bytes downloaded
[11:45:41] + 276480 bytes downloaded
[11:45:41] + 286720 bytes downloaded
[11:45:41] + 296960 bytes downloaded
[11:45:41] + 307200 bytes downloaded
[11:45:41] + 317440 bytes downloaded
[11:45:41] + 327680 bytes downloaded
[11:45:41] + 337920 bytes downloaded
[11:45:41] + 348160 bytes downloaded
[11:45:41] + 358400 bytes downloaded
[11:45:41] + 368640 bytes downloaded
[11:45:41] + 378880 bytes downloaded
[11:45:41] + 389120 bytes downloaded
[11:45:41] + 399360 bytes downloaded
[11:45:41] + 409600 bytes downloaded
[11:45:41] + 419840 bytes downloaded
[11:45:41] + 430080 bytes downloaded
[11:45:42] + 440320 bytes downloaded
[11:45:42] + 450560 bytes downloaded
[11:45:42] + 460800 bytes downloaded
[11:45:42] + 471040 bytes downloaded
[11:45:42] + 481280 bytes downloaded
[11:45:42] + 491520 bytes downloaded
[11:45:42] + 501760 bytes downloaded
[11:45:42] + 512000 bytes downloaded
[11:45:42] + 522240 bytes downloaded
[11:45:42] + 532480 bytes downloaded
[11:45:42] + 542720 bytes downloaded
[11:45:42] + 552960 bytes downloaded
[11:45:42] + 563200 bytes downloaded
[11:45:42] + 573440 bytes downloaded
[11:45:42] + 583680 bytes downloaded
[11:45:42] + 593920 bytes downloaded
[11:45:42] + 604160 bytes downloaded
[11:45:42] + 614400 bytes downloaded
[11:45:42] + 624640 bytes downloaded
[11:45:42] + 634880 bytes downloaded
[11:45:42] + 642475 bytes downloaded
[11:45:42] Verifying core Core_11.fah...
[11:45:42] Signature is VALID
[11:45:42]
[11:45:42] Trying to unzip core FahCore_11.exe
[11:45:42] Decompressed FahCore_11.exe (1843200 bytes) successfully
[11:45:47] + Core successfully engaged
[11:45:52]
[11:45:52] + Processing work unit
[11:45:52] Core required: FahCore_11.exe
[11:45:52] Core found.
[11:45:52] Working on queue slot 01 [June 15 11:45:52 UTC]
[11:45:52] + Working ...
[11:45:52]
[11:45:52] *------------------------------*
[11:45:52] Folding@Home GPU Core - Beta
[11:45:52] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[11:45:52]
[11:45:52] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:45:52] Build host: amoeba
[11:45:52] Board Type: Nvidia
[11:45:52] Core      :
[11:45:52] Preparing to commence simulation
[11:45:52] - Looking at optimizations...
[11:45:52] - Created dyn
[11:45:52] - Files status OK
[11:45:52] - Expanded 46710 -> 252912 (decompressed 541.4 percent)
[11:45:52] Called DecompressByteArray: compressed_data_size=46710 data_size=252912, decompressed_data_size=252912 diff=0
[11:45:52] - Digital signature verified
[11:45:52]
[11:45:52] Project: 5768 (Run 6, Clone 237, Gen 437)
[11:45:52]
[11:45:52] Assembly optimizations on if available.
[11:45:52] Entering M.D.
[11:45:59] Working on Protein
[11:46:00] Client config found, loading data.
[11:46:00] Starting GUI Server
[11:46:55] Completed 1%
[11:47:49] Completed 2%
[11:48:42] Completed 3%
[11:49:36] Completed 4%
[11:50:29] Completed 5%
[11:51:24] Completed 6%
[11:52:18] Completed 7%
[11:53:11] Completed 8%
[11:54:04] Completed 9%
[11:54:57] Completed 10%
[11:55:50] Completed 11%
[11:56:44] Completed 12%
[11:57:37] Completed 13%
[11:58:30] Completed 14%
[11:59:24] Completed 15%
[12:00:17] Completed 16%
[12:01:10] Completed 17%
[12:02:05] Completed 18%
[12:03:00] Completed 19%
[12:03:54] Completed 20%
[12:04:49] Completed 21%
[12:05:44] Completed 22%
[12:06:39] Completed 23%
[12:07:34] Completed 24%
[12:08:29] Completed 25%
[12:09:24] Completed 26%
[12:10:19] Completed 27%
[12:11:13] Completed 28%
[12:12:07] Completed 29%
[12:13:00] Completed 30%
[12:13:53] Completed 31%
[12:14:47] Completed 32%
[12:15:40] Completed 33%
[12:16:33] Completed 34%
[12:17:26] Completed 35%
[12:18:19] Completed 36%
[12:19:12] Completed 37%
[12:20:06] Completed 38%
[12:20:59] Completed 39%
[12:21:52] Completed 40%
[12:22:45] Completed 41%
[12:23:38] Completed 42%
[12:24:32] Completed 43%
[12:25:25] Completed 44%
[12:26:18] Completed 45%
[12:27:11] Completed 46%
[12:28:04] Completed 47%
[12:28:57] Completed 48%
[12:29:51] Completed 49%
[12:30:44] Completed 50%
[12:31:37] Completed 51%
[12:32:30] Completed 52%
[12:33:23] Completed 53%
[12:34:16] Completed 54%
[12:35:10] Completed 55%
[12:36:03] Completed 56%
[12:36:56] Completed 57%
[12:37:49] Completed 58%
[12:38:43] Completed 59%
[12:39:36] Completed 60%
[12:40:29] Completed 61%
[12:41:22] Completed 62%
[12:42:15] Completed 63%
[12:43:08] Completed 64%
[12:44:01] Completed 65%
[12:44:55] Completed 66%
[12:45:48] Completed 67%
[12:46:41] Completed 68%
[12:47:34] Completed 69%
[12:48:27] Completed 70%
[12:49:20] Completed 71%
[12:50:13] Completed 72%
[12:51:07] Completed 73%
[12:52:00] Completed 74%
[12:52:53] Completed 75%
[12:53:46] Completed 76%
[12:54:39] Completed 77%
[12:55:32] Completed 78%
[12:56:26] Completed 79%
[12:57:19] Completed 80%
[12:58:12] Completed 81%
[12:59:05] Completed 82%
[12:59:58] Completed 83%
[13:00:51] Completed 84%
[13:01:44] Completed 85%
[13:02:37] Completed 86%
[13:03:31] Completed 87%
[13:04:24] Completed 88%
[13:05:17] Completed 89%
[13:06:10] Completed 90%
[13:07:03] Completed 91%
[13:07:56] Completed 92%
[13:08:49] Completed 93%
[13:09:43] Completed 94%
[13:10:36] Completed 95%
[13:11:29] Completed 96%
[13:12:22] Completed 97%
[13:13:15] Completed 98%
[13:14:08] Completed 99%
[13:15:01] Completed 100%
[13:15:02] Successful run
[13:15:02] DynamicWrapper: Finished Work Unit: sleep=10000
[13:15:12] Reserved 75960 bytes for xtc file; Cosm status=0
[13:15:12] Allocated 75960 bytes for xtc file
[13:15:12] - Reading up to 75960 from "work/wudata_01.xtc": Read 75960
[13:15:12] Read 75960 bytes from xtc file; available packet space=786354504
[13:15:12] xtc file hash check passed.
[13:15:12] Reserved 15168 15168 786354504 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[13:15:12] Allocated 15168 bytes for arc file
[13:15:12] - Reading up to 15168 from "work/wudata_01.trr": Read 15168
[13:15:12] Read 15168 bytes from arc file; available packet space=786339336
[13:15:12] trr file hash check passed.
[13:15:12] Allocated 560 bytes for edr file
[13:15:12] Read bedfile
[13:15:12] edr file hash check passed.
[13:15:12] Allocated 17264 bytes for logfile
[13:15:12] Read logfile
[13:15:12] GuardedRun: success in DynamicWrapper
[13:15:12] GuardedRun: done
[13:15:12] Run: GuardedRun completed.
[13:15:13] - Writing 109464 bytes of core data to disk...
[13:15:13] Done: 108952 -> 96715 (compressed to 88.7 percent)
[13:15:13]   ... Done.
[13:15:13] - Shutting down core
[13:15:13]
[13:15:13] Folding@home Core Shutdown: FINISHED_UNIT
[13:15:17] CoreStatus = 64 (100)
[13:15:17] Sending work to server
[13:15:17] Project: 5768 (Run 6, Clone 237, Gen 437)
[13:15:17] + Attempting to send results [June 15 13:15:17 UTC]
[13:15:19] + Results successfully sent
[13:15:19] Thank you for your contribution to Folding@Home.
[13:15:19] + Starting local stats count at 1
[13:15:23] - Preparing to get new work unit...
[13:15:23] + Attempting to get work packet
[13:15:23] - Connecting to assignment server
[13:15:24] - Successful: assigned to (171.67.108.11).
[13:15:24] + News From Folding@Home: Welcome to Folding@Home
[13:15:25] Loaded queue successfully.
[13:15:26] + Closed connections
[13:15:26]
[13:15:26] + Processing work unit
[13:15:26] Core required: FahCore_11.exe
[13:15:26] Core found.
[13:15:26] Working on queue slot 02 [June 15 13:15:26 UTC]
[13:15:26] + Working ...
[13:15:26]
[13:15:26] *------------------------------*
[13:15:26] Folding@Home GPU Core - Beta
[13:15:26] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:15:26]
[13:15:26] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:15:26] Build host: amoeba
[13:15:26] Board Type: Nvidia
[13:15:26] Core      :
[13:15:26] Preparing to commence simulation
[13:15:26] - Looking at optimizations...
[13:15:26] - Created dyn
[13:15:26] - Files status OK
[13:15:26] - Expanded 46706 -> 252912 (decompressed 541.4 percent)
[13:15:26] Called DecompressByteArray: compressed_data_size=46706 data_size=252912, decompressed_data_size=252912 diff=0
[13:15:26] - Digital signature verified
[13:15:26]
[13:15:26] Project: 5765 (Run 2, Clone 176, Gen 506)
[13:15:26]
[13:15:26] Assembly optimizations on if available.
[13:15:26] Entering M.D.
[13:15:32] mdrun_gpu returned
[13:15:32] Going to send back what have done -- stepsTotalG=0
[13:15:32] Work fraction=0.0000 steps=0.
[13:15:36] logfile size=0 infoLength=0 edr=0 trr=25
[13:15:36] - Writing 637 bytes of core data to disk...
[13:15:36] Done: 125 -> 124 (compressed to 99.2 percent)
[13:15:36]   ... Done.
[13:15:37]
[13:15:37] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:15:41] CoreStatus = 7A (122)
[13:15:41] Sending work to server
[13:15:41] Project: 5765 (Run 2, Clone 176, Gen 506)
[13:15:41] + Attempting to send results [June 15 13:15:41 UTC]
[13:15:41] + Results successfully sent
[13:15:41] Thank you for your contribution to Folding@Home.
[13:15:45] - Preparing to get new work unit...
[13:15:45] + Attempting to get work packet
[13:15:45] - Connecting to assignment server
[13:15:46] - Successful: assigned to (171.67.108.11).
[13:15:46] + News From Folding@Home: Welcome to Folding@Home
[13:15:46] Loaded queue successfully.
[13:15:48] + Closed connections
[13:15:53]
[13:15:53] + Processing work unit
[13:15:53] Core required: FahCore_11.exe
[13:15:53] Core found.
[13:15:53] Working on queue slot 03 [June 15 13:15:53 UTC]
[13:15:53] + Working ...
[13:15:53]
[13:15:53] *------------------------------*
[13:15:53] Folding@Home GPU Core - Beta
[13:15:53] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:15:53]
[13:15:53] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:15:53] Build host: amoeba
[13:15:53] Board Type: Nvidia
[13:15:53] Core      :
[13:15:53] Preparing to commence simulation
[13:15:53] - Looking at optimizations...
[13:15:53] - Created dyn
[13:15:53] - Files status OK
[13:15:53] - Expanded 46757 -> 252912 (decompressed 540.9 percent)
[13:15:53] Called DecompressByteArray: compressed_data_size=46757 data_size=252912, decompressed_data_size=252912 diff=0
[13:15:53] - Digital signature verified
[13:15:53]
[13:15:53] Project: 5768 (Run 4, Clone 122, Gen 586)
[13:15:53]
[13:15:53] Assembly optimizations on if available.
[13:15:53] Entering M.D.
[13:15:59] mdrun_gpu returned
[13:15:59] Going to send back what have done -- stepsTotalG=0
[13:15:59] Work fraction=0.0000 steps=0.
[13:16:03] logfile size=0 infoLength=0 edr=0 trr=25
[13:16:03] - Writing 637 bytes of core data to disk...
[13:16:03] Done: 125 -> 124 (compressed to 99.2 percent)
[13:16:03]   ... Done.
[13:16:04]
[13:16:04] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:16:07] CoreStatus = 7A (122)
[13:16:07] Sending work to server
[13:16:07] Project: 5768 (Run 4, Clone 122, Gen 586)
[13:16:07] + Attempting to send results [June 15 13:16:07 UTC]
[13:16:08] + Results successfully sent
[13:16:08] Thank you for your contribution to Folding@Home.
[13:16:12] - Preparing to get new work unit...
[13:16:12] + Attempting to get work packet
[13:16:12] - Connecting to assignment server
[13:16:13] - Successful: assigned to (171.67.108.11).
[13:16:13] + News From Folding@Home: Welcome to Folding@Home
[13:16:13] Loaded queue successfully.
[13:16:15] + Closed connections
[13:16:20]
[13:16:20] + Processing work unit
[13:16:20] Core required: FahCore_11.exe
[13:16:20] Core found.
[13:16:20] Working on queue slot 04 [June 15 13:16:20 UTC]
[13:16:20] + Working ...
[13:16:20]
[13:16:20] *------------------------------*
[13:16:20] Folding@Home GPU Core - Beta
[13:16:20] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:16:20]
[13:16:20] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:16:20] Build host: amoeba
[13:16:20] Board Type: Nvidia
[13:16:20] Core      :
[13:16:20] Preparing to commence simulation
[13:16:20] - Looking at optimizations...
[13:16:20] - Created dyn
[13:16:20] - Files status OK
[13:16:20] - Expanded 96465 -> 489240 (decompressed 507.1 percent)
[13:16:20] Called DecompressByteArray: compressed_data_size=96465 data_size=489240, decompressed_data_size=489240 diff=0
[13:16:20] - Digital signature verified
[13:16:20]
[13:16:20] Project: 5753 (Run 11, Clone 19, Gen 373)
[13:16:20]
[13:16:20] Assembly optimizations on if available.
[13:16:20] Entering M.D.
[13:16:27] mdrun_gpu returned
[13:16:27] Going to send back what have done -- stepsTotalG=0
[13:16:27] Work fraction=0.0000 steps=0.
[13:16:31] logfile size=0 infoLength=0 edr=0 trr=25
[13:16:31] - Writing 637 bytes of core data to disk...
[13:16:31] Done: 125 -> 124 (compressed to 99.2 percent)
[13:16:31]   ... Done.
[13:16:31]
[13:16:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:16:34] CoreStatus = 7A (122)
[13:16:34] Sending work to server
[13:16:34] Project: 5753 (Run 11, Clone 19, Gen 373)
[13:16:34] + Attempting to send results [June 15 13:16:34 UTC]
[13:16:35] + Results successfully sent
[13:16:35] Thank you for your contribution to Folding@Home.
[13:16:39] - Preparing to get new work unit...
[13:16:39] + Attempting to get work packet
[13:16:39] - Connecting to assignment server
[13:16:40] - Successful: assigned to (171.67.108.11).
[13:16:40] + News From Folding@Home: Welcome to Folding@Home
[13:16:40] Loaded queue successfully.
[13:16:42] + Closed connections
[13:16:47]
[13:16:47] + Processing work unit
[13:16:47] Core required: FahCore_11.exe
[13:16:47] Core found.
[13:16:47] Working on queue slot 05 [June 15 13:16:47 UTC]
[13:16:47] + Working ...
[13:16:47]
[13:16:47] *------------------------------*
[13:16:47] Folding@Home GPU Core - Beta
[13:16:47] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:16:47]
[13:16:47] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:16:47] Build host: amoeba
[13:16:47] Board Type: Nvidia
[13:16:47] Core      :
[13:16:47] Preparing to commence simulation
[13:16:47] - Looking at optimizations...
[13:16:47] - Created dyn
[13:16:47] - Files status OK
[13:16:47] - Expanded 45314 -> 251112 (decompressed 554.1 percent)
[13:16:47] Called DecompressByteArray: compressed_data_size=45314 data_size=251112, decompressed_data_size=251112 diff=0
[13:16:47] - Digital signature verified
[13:16:47]
[13:16:47] Project: 5769 (Run 3, Clone 127, Gen 513)
[13:16:47]
[13:16:47] Assembly optimizations on if available.
[13:16:47] Entering M.D.
[13:16:53] mdrun_gpu returned
[13:16:53] Going to send back what have done -- stepsTotalG=0
[13:16:53] Work fraction=0.0000 steps=0.
[13:16:57] logfile size=0 infoLength=0 edr=0 trr=25
[13:16:57] - Writing 637 bytes of core data to disk...
[13:16:57] Done: 125 -> 124 (compressed to 99.2 percent)
[13:16:57]   ... Done.
[13:16:58]
[13:16:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:17:01] CoreStatus = 7A (122)
[13:17:01] Sending work to server
[13:17:01] Project: 5769 (Run 3, Clone 127, Gen 513)
[13:17:01] + Attempting to send results [June 15 13:17:01 UTC]
[13:17:02] + Results successfully sent
[13:17:02] Thank you for your contribution to Folding@Home.
[13:17:06] - Preparing to get new work unit...
[13:17:06] + Attempting to get work packet
[13:17:06] - Connecting to assignment server
[13:17:07] - Successful: assigned to (171.67.108.11).
[13:17:07] + News From Folding@Home: Welcome to Folding@Home
[13:17:07] Loaded queue successfully.
[13:17:09] + Closed connections
[13:17:14]
[13:17:14] + Processing work unit
[13:17:14] Core required: FahCore_11.exe
[13:17:14] Core found.
[13:17:14] Working on queue slot 06 [June 15 13:17:14 UTC]
[13:17:14] + Working ...
[13:17:14]
[13:17:14] *------------------------------*
[13:17:14] Folding@Home GPU Core - Beta
[13:17:14] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:17:14]
[13:17:14] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:17:14] Build host: amoeba
[13:17:14] Board Type: Nvidia
[13:17:14] Core      :
[13:17:14] Preparing to commence simulation
[13:17:14] - Looking at optimizations...
[13:17:14] - Created dyn
[13:17:14] - Files status OK
[13:17:14] - Expanded 98669 -> 492276 (decompressed 498.9 percent)
[13:17:14] Called DecompressByteArray: compressed_data_size=98669 data_size=492276, decompressed_data_size=492276 diff=0
[13:17:14] - Digital signature verified
[13:17:14]
[13:17:14] Project: 5750 (Run 2, Clone 94, Gen 311)
[13:17:14]
[13:17:14] Assembly optimizations on if available.
[13:17:14] Entering M.D.
[13:17:21] mdrun_gpu returned
[13:17:21] Going to send back what have done -- stepsTotalG=0
[13:17:21] Work fraction=0.0000 steps=0.
[13:17:25] logfile size=0 infoLength=0 edr=0 trr=25
[13:17:25] - Writing 637 bytes of core data to disk...
[13:17:25] Done: 125 -> 124 (compressed to 99.2 percent)
[13:17:25]   ... Done.
[13:17:25]
[13:17:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:17:28] CoreStatus = 7A (122)
[13:17:28] Sending work to server
[13:17:28] Project: 5750 (Run 2, Clone 94, Gen 311)
[13:17:28] + Attempting to send results [June 15 13:17:28 UTC]
[13:17:29] + Results successfully sent
[13:17:29] Thank you for your contribution to Folding@Home.
[13:17:33] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
This is my fahlog file.
Well ... I'm sorry to say that it's not working ... :(
Crozz
Post by Crozz »
Hmm, why do this suddenly happen? Is there anything I can do or shall I get my money back? It's almost a year old.
Have you tried the NV memory tester? Won't test the GPU, but if the GPU memory is a problem, you will know for sure if it needs to be RMAd.
Crozz
Post by Crozz »
7im wrote:Have you tried the NV memory tester? Won't test the GPU, but if the GPU memory is a problem, you will know for sure if it needs to be RMAd.
No I havent, can you link it? It has something to do with F@H because GTA IV works fine for my brother when he plays.
RMAd, never heard of :oops:
kiore
Post by kiore »
Return Merchandise Authorisation, basically send it back to the manufacturer for a replacement because it's faulty in some way :D
kiore.
