1. heating is a hardware problem, CPUs, GPUs, and other chipsets are designed throughout the industry to run at maximum speed, if Nvidia's GPUs can't, then it's a hardware problem.
2. Donors should have the obvious right to choose which WUs they are folding. Especially when these problems emerge. This right to choose is good for everyone, and indeed for the science to go on as swiftly as possible. If Stanford finds out that some projects are getting behind, they can simply increase their point value, so as to achieve the right balance. Surely this must be easy to implement!
It is really simple guys. The further question of: «is there a bug in the client, drivers or WU?» is an interesting and important one, and it will certainly be addressed in due time. But right now the important thing is to give donors the ability to choose their WUs and it would also be nice if people here accepted the general premise that CPUs and GPUs are intended to work correctly no matter what kind of software you throw at them. We are really entering a dangerous path for the industry if we allow software developers to be criticized by badly designed hardware.
Good luck to you all!
