Project: 2665 (Run 1, Clone 184, Gen 122)
MoneyGuyBK
Post by MoneyGuyBK »
I noticed that both my SMP clients were frozen in place at 100%
Would someone check and see if the issue lies on my end or if the projects both have issues?
Also, it would be nice to see how much, if any, credit I received. Thanx in advance.
Here's the log from one, I am posting two different threads:
[15:15:02] Completed 247500 out of 250000 steps  (99 percent)
[15:15:02] Writing local files
[15:15:02] Completed 250000 out of 250000 steps  (100 percent)
[15:15:02] Writing final coordinates.
[15:15:02] Past main M.D. loop
[15:15:02] Will end MPI now
[15:15:02]
[15:15:02] Finished Work Unit:
[15:15:02] - Reading up to 21193200 from "work/wudata_00.arc": Read 21193200
[15:15:02] - Reading up to 530228 from "work/wudata_00.xtc": Read 530228
[15:15:02] goefile size: 0
[15:15:02] logfile size: 203307
[15:15:02] Leaving Run
[15:15:02] - Writing 21933107 bytes of core data to disk...
[15:15:02]   ... Done.
[15:15:02] - Failed to delete work/wudata_00.sas
[15:15:02] - Failed to delete work/wudata_00.goe
[15:15:02] Warning:  check for stray files
[15:15:02] - Shutting down core
[15:15:02]
[15:15:02] Folding@home Core Shutdown: FINISHED_UNIT
[15:15:02]
[15:17:22] CoreStatus = 1 (1)
[15:17:22] Sending work to server
[15:17:22] Project: 2665 (Run 1, Clone 184, Gen 122)
[15:17:22] + Attempting to send results [June 3 15:17:22 UTC]
[15:17:22] - Reading file work/wuresults_00.dat from core
[15:17:22]   (Read 21933107 bytes from disk)
[15:17:22] Connecting to http://171.64.65.64:8080/
[15:21:14] Posted data.
[15:21:15] Initial: 0000; - Uploaded at ~91 kB/s
[15:21:17] - Averaged speed for that direction ~179 kB/s
[15:21:17] + Results successfully sent
[15:21:17] Thank you for your contribution to Folding@Home.
[15:21:42] - Warning: Could not delete all work unit files (0): Core returned in
valid code
[15:21:42] Trying to send all finished work units
[15:21:42] + No unsent completed units remaining.
[15:21:42] - Preparing to get new work unit...
[15:21:42] + Attempting to get work packet
[15:21:42] - Will indicate memory of 1024 MB
[15:21:42] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 4
[15:21:42] - Connecting to assignment server
[15:21:42] Connecting to http://assign.stanford.edu:8080/
[15:21:42] Posted data.
[15:21:42] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[15:21:42] + News From Folding@Home: Welcome to Folding@Home
[15:21:42] Loaded queue successfully.
[15:21:42] Connecting to http://171.64.65.64:8080/
[15:21:45] Posted data.
[15:21:45] Initial: 0000; - Receiving payload (expected size: 2437661)
[15:21:47] - Downloaded at ~1190 kB/s
[15:21:47] - Averaged speed for that direction ~1715 kB/s
[15:21:47] + Received work.
[15:21:47] Trying to send all finished work units
[15:21:47] + No unsent completed units remaining.
[15:21:47] + Closed connections
[15:21:52]
[15:21:52] + Processing work unit
[15:21:52] Work type a1 not eligible for variable processors
[15:21:52] Core required: FahCore_a1.exe
[15:21:52] Core found.
[15:21:52] Using generic mpiexec calls
[15:21:52] Working on queue slot 01 [June 3 15:21:52 UTC]
[15:21:52] + Working ...
[15:21:52] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe
 -dir work/ -suffix 01 -cpu 90 -checkpoint 30 -verbose -lifeline 152688 -version
 623'
[15:21:52]
[15:21:52] *------------------------------*
[15:21:52] Folding@Home Gromacs SMP Core
[15:21:52] Version 1.74 (March 10, 2007)
[15:21:52]
[15:21:52] Preparing to commence simulation
[15:21:52] - Ensuring status. Please wait.
[15:22:09] - Looking at optimizations...
[15:22:09] - Working with standard loops on this execution.
[15:22:09] - Created dyn
[15:22:09] - Files status OK
[15:22:10] as improper.
[15:22:10] - Going to use standard loops.
[15:22:10] - Files status OK
[15:22:11] - Expanded 2437149 -> 1291282- Starting from initial work packet
[15:22:11]
[15:22:11] Project: 2653 (Run 2, Clone 87, Gen 111)
[15:22:11]
[15:22:11] 53 (Run 2, Clone 87, Gen 111)
[15:22:11]
[15:22:12] Entering M.D.
[15:22:18] Rejecting checkpoint
[15:22:19] Protein: Protein in POPC
[15:22:19] Writing local files
[15:22:20] Extra SSE boost OK.
[15:22:20] Writing local files
[15:22:20] Completed 0 out of 500000 steps  (0 percent)
[15:33:50] Writing local files
[15:33:50] Completed 5000 out of 500000 steps  (1 percent)
[15:45:40] Writing local files
[15:45:41] Completed 10000 out of 500000 steps  (2 percent)
Peace
T.E.A.M. “Together Everyone Accomplishes Miracles!”
OC, S. California ... God Bless All
susato
Re: Project: 2665 (Run 1, Clone 184, Gen 122)
Post by susato »
Yes, this was accepted for 1920 points.
Whenever the log says "Thank you for your contribution to Folding@Home" that indicates that the unit returned home OK.
MoneyGuyBK
Oh Thanx Susato ..... when I saw this """CoreStatus = 1 (1)""" instead of 64(100) I figured something went wrong.
Now the Q remains why the SMP had frozen in place at the finish line and I had to do a CtrlC and restart it to send :!:
Peace
