Beginner in need of advice
RETICENTFISH
Post by RETICENTFISH »
Hi guys,
OK 1st things 1st I am completely new to this but decided to join and start folding as it all goes to such a good cause. Anyway my question is this i would like to fold on the 2 home pc's I have and would like to know how to set it up so all points etc go to my rank and score the 2 pc's are not networked and at the moment I am running the client separately on both machines but under the same username. They are both single CPU machines (pretty old and archaic, but every bit helps I suppose). Im sure you will need lots more info than this if so I will supply as needed.
Thx
kiore
Re: Beginner in need of advice
Post by kiore »
RETICENTFISH wrote:Hi guys,
Thx
Welcome :D if they both are configed to exactly the same name and team number that is all that's needed, both will contribute to your account.
kiore.
addit for any other advice list you system specs plus the operating system and the client version you are using.
RETICENTFISH
cool thank you :)
