1. What does "goefile: size 0" mean, and is does it reflect a cause--or result--of the problem?
2. I believe most--if not all--my WUs last summer were eventually recorded. Is the log entry below consistent with that happening again?
Thanks in advance for the help.
Slot 09 Empty/Deleted
Project: 4461 (Run 640, Clone 0, Gen 25), Core: 78
Work server: 171.67.108.13:8080
Collection server: 171.67.108.17
Download date: May 29 06:05:41
Finished date: May 31 10:51:38Code: Select all
--- Opening Log file [May 30 22:25:25]
# Windows Graphical Edition ###################################################
Folding@Home Client Version 5.03
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
[22:25:25] - Ask before connecting: No
[22:25:25] - User name: DrBB1 (Team 0324498)
[22:25:25] - User ID: 41257AD02312174
[22:25:25] - Machine ID: 1
[22:25:25]
[22:25:25] Loaded queue successfully.
[22:25:28] Initialization complete
[22:25:28] + Benchmarking ...
[22:25:40]
[22:25:40] + Processing work unit
[22:25:40] Core required: FahCore_78.exe
[22:25:40] Core found.
[22:25:40] Working on Unit 05 [May 30 22:25:40]
[22:25:40] + Working ...
[22:25:58]
[22:25:58] *------------------------------*
[22:25:58] Folding@Home Gromacs Core
[22:25:58] Version 1.90 (March 8, 2006)
[22:25:58]
[22:25:58] Preparing to commence simulation
[22:25:58] - Looking at optimizations...
[22:25:58] - Files status OK
[22:26:00] - Expanded 237763 -> 1167721 (decompressed 491.1 percent)
[22:26:01]
[22:26:01] Project: 4441 (Run 291, Clone 4, Gen 20)
[22:26:01]
[22:26:03] Assembly optimizations on if available.
[22:26:03] Entering M.D.
[22:26:26] (Starting from checkpoint)
[22:26:26] Protein: p4441_Seq42_Amber03
[22:26:26]
[22:26:26] Writing local files
[22:28:38] Completed 1211312 out of 1500000 steps (81)
[22:28:38] Extra 3DNow boost OK.
[22:58:09] Writing local files
[22:58:09] Completed 1215000 out of 1500000 steps (81)
[23:07:46] + Screensaver: engaging
[23:36:08] + Screensaver: no longer idle, ending
[02:02:22] + Screensaver: engaging
[02:07:10] Writing local files
[02:07:11] Completed 1230000 out of 1500000 steps (82)
[03:12:44] Writing local files
[03:12:44] Completed 1245000 out of 1500000 steps (83)
[04:19:24] Writing local files
[04:19:24] Completed 1260000 out of 1500000 steps (84)
[04:25:40] + Working...
[05:29:11] Writing local files
[05:29:11] Completed 1275000 out of 1500000 steps (85)
[08:03:52] Writing local files
[08:03:52] Completed 1290000 out of 1500000 steps (86)
[10:23:21] Writing local files
[10:23:21] Completed 1305000 out of 1500000 steps (87)
[10:25:40] + Working...
[11:32:33] Writing local files
[11:32:33] Completed 1320000 out of 1500000 steps (88)
[12:41:32] Writing local files
[12:41:33] Completed 1335000 out of 1500000 steps (89)
[13:50:32] Writing local files
[13:50:32] Completed 1350000 out of 1500000 steps (90)
[14:59:36] Writing local files
[14:59:36] Completed 1365000 out of 1500000 steps (91)
[16:08:41] Writing local files
[16:08:41] Completed 1380000 out of 1500000 steps (92)
[16:25:40] + Working...
[17:17:42] Writing local files
[17:17:42] Completed 1395000 out of 1500000 steps (93)
[18:26:45] Writing local files
[18:26:45] Completed 1410000 out of 1500000 steps (94)
[19:35:38] Writing local files
[19:35:38] Completed 1425000 out of 1500000 steps (95)
[20:44:24] Writing local files
[20:44:24] Completed 1440000 out of 1500000 steps (96)
[21:53:21] Writing local files
[21:53:21] Completed 1455000 out of 1500000 steps (97)
[22:25:40] + Working...
[23:02:17] Writing local files
[23:02:17] Completed 1470000 out of 1500000 steps (98)
[00:11:16] Writing local files
[00:11:16] Completed 1485000 out of 1500000 steps (99)
[01:20:15] Writing local files
[01:20:15] Completed 1500000 out of 1500000 steps (100)
[01:20:15] Writing final coordinates.
[01:20:16] Past main M.D. loop
[01:21:16]
[01:21:16] Finished Work Unit:
[01:21:16] - Reading up to 188856 from "work/wudata_05.arc": Read 188856
[01:21:16] - Reading up to 17868 from "work/wudata_05.xtc": Read 17868
[01:21:16] goefile size: 0
[01:21:16] logfile size: 26067
[01:21:16] Leaving Run
[01:21:16] - Writing 239795 bytes of core data to disk...
[01:21:17] Done: 239283 -> 209570 (compressed to 87.5 percent)
[01:21:17] ... Done.
[01:21:17] - Shutting down core
[01:21:17]
[01:21:17] Folding@home Core Shutdown: FINISHED_UNIT
[01:21:20] CoreStatus = 64 (100)
[01:21:20] Sending work to server
[01:21:20] + Attempting to send results
[01:21:23] + Results successfully sent
[01:21:23] Thank you for your contribution to Folding@Home.
[01:21:23] + Number of Units Completed: 190
