I have the Zip (no installation) version of FahMon2.3.99.1.
I cannot locate the config file for my clients. The file name I think should be clientstab.txt.
Where can I find it? It is not in the FahMon folder, not in my documents, where is it?
FahMon 2.3.99.1 where is the config file clientstab.txt?
Re: FahMon 2.3.99.1 where is the config file clientstab.txt?
Fahmon questions are typically posted to and answered in the dedicated fahmon thread.
http://foldingforum.org/viewtopic.php?f=14&t=40
From the fahmon download page:
Just a guess, but one might assume you are upgrading a copy of fahmon already installed. And so that file already exists. No need to include that file in the zip if that file didn't didn't change in the latest version. Grab a copy of that file from another install of Fahmon.Choose the Zip file if you want to easily update an existing installation.
The config file would be in your %AppData%/FAHMon/config directory.
