Note: Please read the license agreement (SMP1.exe -license). Further
use of this software requires that you have read and accepted this agreement.
8 cores detected
If you see this twice, MPI is working
--- Opening Log file [May 26 21:39:03 UTC]
Folding@Home Client Version 6.23 Beta R1
http://folding.stanford.edu
Launch directory: C:\SMP1
Executable: C:\SMP1\SMP1.exe
[21:39:03] - Ask before connecting: No
[21:39:03] - User name: MoneyGuyBK (Team 80856)
[21:39:03] - User ID: ***7BA4
[21:39:03] - Machine ID: 3
[21:39:03]
[21:39:04] Loaded queue successfully.
[21:39:04]
[21:39:04] - Autosending finished units... [May 26 21:39:04 UTC]
[21:39:04] + Processing work unit
[21:39:04] Trying to send all finished work units
[21:39:04] Work type a1 not eligible for variable processors
[21:39:04] + No unsent completed units remaining.
[21:39:04] Core required: FahCore_a1.exe
[21:39:04] - Autosend completed
[21:39:04] Core found.
[21:39:04] Using generic mpiexec calls
[21:39:04] Working on queue slot 09 [May 26 21:39:04 UTC]
[21:39:04] + Working ...
[21:39:04] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe
-dir work/ -suffix 09 -cpu 90 -checkpoint 30 -verbose -lifeline 7756 -version 6
23'
[21:39:04]
[21:39:04] *------------------------------*
[21:39:04] Folding@Home Gromacs SMP Core
[21:39:04] Version 1.74 (March 10, 2007)
[21:39:04]
[21:39:04] Preparing to commence simulation
[21:39:04] - Ensuring status. Please wait.
[21:39:21] - Looking at optimizations...
[21:39:21] - Working with standard loops on this execution.
[21:39:21] - Previous termination of core was improper.
[21:39:21] - Going to use standard loops.
[21:39:21] - Files status OK
[21:39:22] - Expanded 609185 -> 3260933 (decompressed 535.2 percent)
[21:39:22]
[21:39:22] Project: 3064 (Run 5, Clone 267, Gen 25)
[21:39:22]
[21:39:22] Entering M.D.
[21:39:44] Protein: p3064_lambda5_2003
[21:39:44] Writing local files
[21:39:44] Completed 3200000 out of 5000000 steps (64 percent)
[21:39:44] Extra SSE boost OK.
[21:39:44]
[21:53:48] Writing local files
[21:53:48] Completed 3250000 out of 5000000 steps (65 percent)
[22:07:46] Writing local files
SNIP
[00:40:25] Writing local files
[00:40:25] Completed 3850000 out of 5000000 steps (77 percent)
[00:52:29] Writing local files
[00:52:29] Completed 3900000 out of 5000000 steps (78 percent)
[01:04:42] Writing local files
[01:04:42] Completed 3950000 out of 5000000 steps (79 percent)
[01:17:33] Writing local files
[01:17:33] Completed 4000000 out of 5000000 steps (80 percent)
[01:25:01] Gromacs cannot continue further.
[01:25:01] Going to send back what have done.
[01:25:01] logfile size: 116380
[01:25:01] - Writing 116916 bytes of core data to disk...
[01:25:01] ... Done.
[01:25:01] - Failed to delete work/wudata_09.sas
[01:25:01] - Failed to delete work/wudata_09.goe
[01:25:01] Warning: check for stray files
[01:25:01]
[01:25:01] Folding@home Core Shutdown: EARLY_UNIT_END
[01:25:01]
[01:25:04] CoreStatus = 7B (123)
[01:25:04] Sending work to server
[01:25:04] Project: 3064 (Run 5, Clone 267, Gen 25)
[01:25:04] + Attempting to send results [May 27 01:25:04 UTC]
[01:25:04] - Reading file work/wuresults_09.dat from core
[01:25:04] (Read 116916 bytes from disk)
[01:25:04] Connecting to http://171.64.65.63:8080/
[01:25:05] Posted data.
[01:25:05] Initial: 0000; - Uploaded at ~115 kB/s
[01:25:05] - Averaged speed for that direction ~210 kB/s
[01:25:05] + Results successfully sent
[01:25:05] Thank you for your contribution to Folding@Home.
[01:25:09] - Warning: Could not delete all work unit files (9): Core returned in
valid code
[01:25:09] Trying to send all finished work units
[01:25:09] + No unsent completed units remaining.
[01:25:09] - Preparing to get new work unit...
[01:25:09] + Attempting to get work packet
[01:25:09] - Will indicate memory of 1024 MB
[01:25:09] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 4
[01:25:09] - Connecting to assignment server
[01:25:09] Connecting to http://assign.stanford.edu:8080/
[01:25:10] Posted data.
[01:25:10] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[01:25:10] + News From Folding@Home: Welcome to Folding@Home
[01:25:10] Loaded queue successfully.
[01:25:10] Connecting to http://171.64.65.63:8080/
[01:25:12] Posted data.
[01:25:12] Initial: 0000; - Receiving payload (expected size: 1653622)
[01:25:13] - Downloaded at ~1614 kB/s
[01:25:13] - Averaged speed for that direction ~1339 kB/s
[01:25:13] + Received work.
[01:25:13] Trying to send all finished work units
[01:25:13] + No unsent completed units remaining.
[01:25:13] + Closed connections
[01:25:18]
[01:25:18] + Processing work unit
[01:25:18] Work type a1 not eligible for variable processors
[01:25:18] Core required: FahCore_a1.exe
[01:25:18] Core found.
[01:25:18] Using generic mpiexec calls
[01:25:18] Working on queue slot 00 [May 27 01:25:18 UTC]
[01:25:18] + Working ...
[01:25:18] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe
-dir work/ -suffix 00 -cpu 90 -checkpoint 30 -verbose -lifeline 7756 -version 6
23'
[01:25:18]
[01:25:18] *------------------------------*
[01:25:18] Folding@Home Gromacs SMP Core
[01:25:18] Version 1.74 (March 10, 2007)
[01:25:18]
[01:25:18] Preparing to commence simulation
[01:25:18] - Ensuring status. Please wait.
[01:25:19] - Starting from initial work packet
[01:25:19]
[01:25:19] Project: 3065 (Run 3, Clone 413, Gen 17)
[01:25:19]
[01:25:19] Assembly optimizations on if available.
[01:25:19] Entering M.D.
[01:25:36] percent)
[01:25:36] - Starting from initial work packet
[01:25:36]
[01:25:36] Project: 3065 (Run 3, Clone 413, Gen 17)
[01:25:36]
[01:25:37] Entering M.D.
[01:25:43] Rejecting checkpoint
[01:25:44] files
[01:25:44] Extra SSE boost OK.
[01:25:44] a5_99sb_bigExtra SSE boost OK.
[01:25:44]
[01:25:44] Writing local files
[01:25:44] Completed 0 out of 2500000 steps (0 percent)
[01:42:47] Writing local files
[01:42:47] Completed 25000 out of 2500000 steps (1 percent)
[01:58:26] Writing local filesPeace
