14 attempts over the last 4+ hours and no work downloaded
[22:54:58] Completed 4950000 out of 5000000 steps  (99 percent)
[23:07:22] Writing local files
[23:07:22] Completed 5000000 out of 5000000 steps  (100 percent)
[23:07:22] Writing final coordinates.
[23:07:22] Past main M.D. loop
[23:07:22] Will end MPI now
[23:08:22]
[23:08:22] Finished Work Unit:
[23:08:22] - Reading up to 516624 from "work/wudata_01.arc": Read 516624
[23:08:22] - Reading up to 972236 from "work/wudata_01.xtc": Read 972236
[23:08:22] goefile size: 0
[23:08:22] logfile size: 140909
[23:08:22] Leaving Run
[23:08:23] - Writing 1830813 bytes of core data to disk...
[23:08:23]   ... Done.
[23:08:23] - Failed to delete work/wudata_01.sas
[23:08:23] - Failed to delete work/wudata_01.goe
[23:08:23] Warning:  check for stray files
[23:08:23] - Shutting down core
[23:10:23]
[23:10:23] Folding@home Core Shutdown: FINISHED_UNIT
[23:10:23]
[23:10:27] CoreStatus = 64 (100)
[23:10:27] Unit 1 finished with 76 percent of time to deadline remaining.
[23:10:27] Updated performance fraction: 0.780597
[23:10:27] Sending work to server
[23:10:27] Project: 3064 (Run 4, Clone 355, Gen 26)
[23:10:27] + Attempting to send results [May 25 23:10:27 UTC]
[23:10:27] - Reading file work/wuresults_01.dat from core
[23:10:27]   (Read 1830813 bytes from disk)
[23:10:27] Connecting to http://171.64.65.63:8080/
[23:10:32] Posted data.
[23:10:33] Initial: 0000; - Uploaded at ~298 kB/s
[23:10:33] - Averaged speed for that direction ~229 kB/s
[23:10:33] + Results successfully sent
[23:10:33] Thank you for your contribution to Folding@Home.
[23:10:33] + Number of Units Completed: 60
[23:10:37] - Warning: Could not delete all work unit files (1): Core returned in
valid code
[23:10:37] Trying to send all finished work units
[23:10:37] + No unsent completed units remaining.
[23:10:37] - Preparing to get new work unit...
[23:10:37] + Attempting to get work packet
[23:10:37] - Will indicate memory of 1024 MB
[23:10:37] - Connecting to assignment server
[23:10:37] Connecting to http://assign.stanford.edu:8080/
[23:10:37] Posted data.
[23:10:37] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:10:37] + Couldn't get work instructions.
[23:10:37] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[23:10:43] + Attempting to get work packet
[23:10:43] - Will indicate memory of 1024 MB
[23:10:43] - Connecting to assignment server
[23:10:43] Connecting to http://assign.stanford.edu:8080/
[23:10:43] Posted data.
[23:10:43] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:10:43] + Couldn't get work instructions.
[23:10:43] - Attempt #2  to get work failed, and no other work to do.
[23:11:03] + Attempting to get work packet
[23:11:03] - Will indicate memory of 1024 MB
[23:11:03] - Connecting to assignment server
[23:11:03] Connecting to http://assign.stanford.edu:8080/
[23:11:03] Posted data.
[23:11:03] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:11:03] + Couldn't get work instructions.
[23:11:03] - Attempt #3  to get work failed, and no other work to do.
[23:11:33] + Attempting to get work packet
[23:11:33] - Will indicate memory of 1024 MB
[23:11:33] - Connecting to assignment server
[23:11:33] Connecting to http://assign.stanford.edu:8080/
[23:11:33] Posted data.
[23:11:33] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:11:33] + Couldn't get work instructions.
[23:11:33] - Attempt #4  to get work failed, and no other work to do.
[23:12:19] + Attempting to get work packet
[23:12:19] - Will indicate memory of 1024 MB
[23:12:19] - Connecting to assignment server
[23:12:19] Connecting to http://assign.stanford.edu:8080/
[23:12:19] Posted data.
[23:12:19] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:12:19] + Couldn't get work instructions.
[23:12:19] - Attempt #5  to get work failed, and no other work to do.
[23:13:54] + Attempting to get work packet
[23:13:54] - Will indicate memory of 1024 MB
[23:13:54] - Connecting to assignment server
[23:13:54] Connecting to http://assign.stanford.edu:8080/
[23:13:54] Posted data.
[23:13:54] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:13:54] + Couldn't get work instructions.
[23:13:54] - Attempt #6  to get work failed, and no other work to do.
[23:16:48] + Attempting to get work packet
[23:16:48] - Will indicate memory of 1024 MB
[23:16:48] - Connecting to assignment server
[23:16:48] Connecting to http://assign.stanford.edu:8080/
[23:16:48] Posted data.
[23:16:48] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:16:48] + Couldn't get work instructions.
[23:16:48] - Attempt #7  to get work failed, and no other work to do.
[23:22:22] + Attempting to get work packet
[23:22:22] - Will indicate memory of 1024 MB
[23:22:22] - Connecting to assignment server
[23:22:22] Connecting to http://assign.stanford.edu:8080/
[23:22:22] Posted data.
[23:22:22] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:22:22] + Couldn't get work instructions.
[23:22:22] - Attempt #8  to get work failed, and no other work to do.
[23:33:11] + Attempting to get work packet
[23:33:11] - Will indicate memory of 1024 MB
[23:33:11] - Connecting to assignment server
[23:33:11] Connecting to http://assign.stanford.edu:8080/
[23:33:11] Posted data.
[23:33:11] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:33:11] + Couldn't get work instructions.
[23:33:11] - Attempt #9  to get work failed, and no other work to do.
[23:54:31] + Attempting to get work packet
[23:54:31] - Will indicate memory of 1024 MB
[23:54:31] - Connecting to assignment server
[23:54:31] Connecting to http://assign.stanford.edu:8080/
[23:54:32] Posted data.
[23:54:32] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[23:54:32] + Couldn't get work instructions.
[23:54:32] - Attempt #10  to get work failed, and no other work to do.
[00:37:14] + Attempting to get work packet
[00:37:14] - Will indicate memory of 1024 MB
[00:37:14] - Connecting to assignment server
[00:37:14] Connecting to http://assign.stanford.edu:8080/
[00:37:14] Posted data.
[00:37:14] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[00:37:14] + Couldn't get work instructions.
[00:37:14] - Attempt #11  to get work failed, and no other work to do.
[01:25:28] + Attempting to get work packet
[01:25:28] - Will indicate memory of 1024 MB
[01:25:28] - Connecting to assignment server
[01:25:28] Connecting to http://assign.stanford.edu:8080/
[01:25:28] Posted data.
[01:25:28] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[01:25:28] + Couldn't get work instructions.
[01:25:28] - Attempt #12  to get work failed, and no other work to do.
[02:13:38] + Attempting to get work packet
[02:13:38] - Will indicate memory of 1024 MB
[02:13:38] - Connecting to assignment server
[02:13:38] Connecting to http://assign.stanford.edu:8080/
[02:13:38] Posted data.
[02:13:38] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[02:13:38] + Couldn't get work instructions.
[02:13:38] - Attempt #13  to get work failed, and no other work to do.
[02:40:22] - Autosending finished units... [May 26 02:40:22 UTC]
[02:40:22] Trying to send all finished work units
[02:40:22] + No unsent completed units remaining.
[02:40:22] - Autosend completed
[03:01:52] + Attempting to get work packet
[03:01:52] - Will indicate memory of 1024 MB
[03:01:52] - Connecting to assignment server
[03:01:52] Connecting to http://assign.stanford.edu:8080/
[03:01:52] Posted data.
[03:01:52] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[03:01:52] + Couldn't get work instructions.
[03:01:52] - Attempt #14  to get work failed, and no other work to do.
Waiting before retry.Peace
 keep up the good work guys
