First one:
[11:22:37] + No unsent completed units remaining.
[11:22:37] - Preparing to get new work unit...
[11:22:37] + Attempting to get work packet
[11:22:37] - Will indicate memory of 2046 MB
[11:22:37] - Connecting to assignment server
[11:22:37] Connecting to http://assign.stanford.edu:8080/
[11:22:37] Posted data.
[11:22:37] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[11:22:37] + News From Folding@Home: Welcome to Folding@Home
[11:22:37] Loaded queue successfully.
[11:22:37] Connecting to http://171.64.65.63:8080/
[11:22:38] Posted data.
[11:22:38] Initial: 0000; - Receiving payload (expected size: 609129)
[11:22:39] - Downloaded at ~594 kB/s
[11:22:39] - Averaged speed for that direction ~491 kB/s
[11:22:39] + Received work.
[11:22:39] Trying to send all finished work units
[11:22:39] + No unsent completed units remaining.
[11:22:39] + Closed connections
[11:22:39]
[11:22:39] + Processing work unit
[11:22:39] Work type a1 not eligible for variable processors
[11:22:39] Core required: FahCore_a1.exe
[11:22:39] Core found.
[11:22:39] Using generic mpiexec calls
[11:22:39] Working on queue slot 09 [May 20 11:22:39 UTC]
[11:22:39] + Working ...
[11:22:39] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 09 -checkpoint 15 -verbose -lifeline 4924 -version 623'
[11:22:40]
[11:22:40] *------------------------------*
[11:22:40] Folding@Home Gromacs SMP Core
[11:22:40] Version 1.74 (March 10, 2007)
[11:22:40]
[11:22:40] Preparing to commence simulation
[11:22:40] - Ensuring status. Please wait- Created dyn
[11:22:40] - Files status OK
[11:22:40] - Expanded 608617 -> 3266341 (decompressed 536.6 percent)
[11:22:40] - Starting from initial work packet
[11:22:40]
[11:22:40] Project: 3064 (Run 1, Clone 435, Gen 14)Code: Select all
[07:39:00] Folding@home Core Shutdown: FINISHED_UNIT
[07:39:00]
[07:39:03] CoreStatus = 64 (100)
[07:39:03] Unit 9 finished with 21 percent of time to deadline remaining.
[07:39:03] Updated performance fraction: 0.446877
[07:39:03] Sending work to server
[07:39:03] Project: 3064 (Run 1, Clone 435, Gen 14)
[07:39:03] + Attempting to send results [May 23 07:39:03 UTC]
[07:39:03] - Reading file work/wuresults_09.dat from core
[07:39:03] (Read 1832082 bytes from disk)
[07:39:03] Connecting to http://171.64.65.63:8080/
[07:39:04] Posted data.
[07:39:04] Initial: 0000; - Uploaded at ~895 kB/s
[07:39:05] - Averaged speed for that direction ~652 kB/s
[07:39:05] + Results successfully sent
[07:39:05] Thank you for your contribution to Folding@Home.
[07:39:05] + Number of Units Completed: 78
[07:39:09] - Warning: Could not delete all work unit files (9): Core returned invalid code
[07:39:09] Trying to send all finished work units
[07:39:09] + No unsent completed units remaining.
[07:39:09] - Preparing to get new work unit...
[07:39:09] + Attempting to get work packet
[07:39:09] - Will indicate memory of 2046 MB
[07:39:09] - Connecting to assignment server
[07:39:09] Connecting to http://assign.stanford.edu:8080/
[07:39:09] Posted data.
[07:39:09] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[07:39:09] + News From Folding@Home: Welcome to Folding@Home
[07:39:09] Loaded queue successfully.
[07:39:09] Connecting to http://171.64.65.63:8080/
[07:39:10] Posted data.
[07:39:10] Initial: 0000; - Receiving payload (expected size: 608217)
[07:39:11] - Downloaded at ~593 kB/s
[07:39:11] - Averaged speed for that direction ~512 kB/s
[07:39:11] + Received work.
[07:39:11] Trying to send all finished work units
[07:39:11] + No unsent completed units remaining.
[07:39:11] + Closed connections
[07:39:11]
[07:39:11] + Processing work unit
[07:39:11] Work type a1 not eligible for variable processors
[07:39:11] Core required: FahCore_a1.exe
[07:39:11] Core found.
[07:39:11] Using generic mpiexec calls
[07:39:11] Working on queue slot 00 [May 23 07:39:11 UTC]
[07:39:11] + Working ...
[07:39:11] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 4924 -version 623'
[07:39:12]
[07:39:12] *------------------------------*
[07:39:12] Folding@Home Gromacs SMP Core
[07:39:12] Version 1.74 (March 10, 2007)
[07:39:12]
[07:39:12] Preparing to commence simulation
[07:39:12] - Ensuring status. Please wait- Created dyn
[07:39:12] - Files status OK
[07:39:12] - Expanded 607705 -> 3255941 (decompressed 535.7 percent)
[07:39:12] - Starting from initial work packet
[07:39:12]
[07:39:12] Project: 3064 (Run 0, Clone 224, Gen 36)
