i installed it
but is only seems to be working if i click on the display buttion
and only when the viewer is active will it work
cant it work by itself in the background
how to use gpu FaH software
Re: how to use gpu FaH software
I am using the Systray version in 32 bit Vista, you may be using some other version. When I put the cursor over the molecule in the Systray I see GPU - F@H: Working ( 3600/10000) If you see something with similar numbers it is working. If you use the Systray version and right click on the molecule, status, Log file you can see how fast it is thinking.
m using the same thing i see
F@H working (0/0)
F@H working (0/0)
Open the log file as suggested, and post the contents here so we can see what is going on, and help diagnose the problem. It would also help if you described your hardware, drivers, OS, etc.
pc specs intel q9300 @ 3.000GHz, 4GB DDR2 RAM @ 800MHz, 2.28 TB HDD (2x.5, 2x.64), palit hd 4850 @stock, ip35p mobo, WIN XP pro 32bit sp3, latest drivers available for all hardware
contents of log file below
--- Opening Log file [May 23 02:35:06 UTC]
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@home\Folding@home-gpu
[02:37:23] - Ask before connecting: No
[02:37:23] - User name: chin85u (Team 12772)
[02:37:23] - User ID: 2A254EFE2E990C04
[02:37:23] - Machine ID: 2
[02:37:23]
[02:37:23] Work directory not found. Creating...
[02:37:23] Could not open work queue, generating new queue...
[02:37:23] Initialization complete
[02:37:23] - Preparing to get new work unit...
[02:37:23] + Attempting to get work packet
[02:37:23] - Connecting to assignment server
[02:37:28] - Successful: assigned to (171.64.65.102).
[02:37:28] + News From Folding@Home: Welcome to Folding@Home
[02:37:28] Loaded queue successfully.
[02:37:38] + Closed connections
[02:37:38]
[02:37:38] + Processing work unit
[02:37:38] Core required: FahCore_11.exe
[02:37:38] Core not found.
[02:37:38] - Core is not present or corrupted.
[02:37:38] - Attempting to download new core...
[02:37:38] + Downloading new core: FahCore_11.exe
[02:37:44] + 10240 bytes downloaded
<snip>
[02:39:00] + 1091180 bytes downloaded
[02:39:00] Verifying core Core_11.fah...
[02:39:00] Signature is VALID
[02:39:00]
[02:39:00] Trying to unzip core FahCore_11.exe
[02:39:01] Decompressed FahCore_11.exe (3203072 bytes) successfully
[02:39:06] + Core successfully engaged
[02:39:11]
[02:39:11] + Processing work unit
[02:39:11] Core required: FahCore_11.exe
[02:39:11] Core found.
[02:39:11] Working on queue slot 01 [May 23 02:39:11 UTC]
[02:39:11] + Working ...
[02:39:11]
[02:39:11] *------------------------------*
[02:39:11] Folding@Home GPU Core - Beta
[02:39:11] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[02:39:11]
[02:39:11] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:39:11] Build host: amoeba
[02:39:11] Board Type: AMD
[02:39:11] Core :
[02:39:11] Preparing to commence simulation
[02:39:11] - Looking at optimizations...
[02:39:11] - Created dyn
[02:39:11] - Files status OK
[02:39:11] - Expanded 96629 -> 489152 (decompressed 506.2 percent)
[02:39:11] Called DecompressByteArray: compressed_data_size=96629 data_size=489152, decompressed_data_size=489152 diff=0
[02:39:11] - Digital signature verified
[02:39:11]
[02:39:11] Project: 5736 (Run 4, Clone 11, Gen 241)
[02:39:11]
[02:39:11] Assembly optimizations on if available.
[02:39:11] Entering M.D.
[02:39:17] Tpr hash work/wudata_01.tpr: 2357812867 3130456912 870561388 1419893916 788861382
[02:39:17] Working on Protein
[02:39:18] Client config found, loading data.
[02:39:18] Starting GUI Server
[02:41:28] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=12772...
[02:42:54] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=chin85u...
[02:48:15] Opening C:\Program Files\Folding@home\Folding@home-gpu\MyFolding.html...
[03:02:14] Opening http://foldingforum.org/...
[03:18:10] Opening C:\Program Files\Folding@home\Folding@home-gpu\MyFolding.html...
[03:18:49] CoreStatus = 62 (98)
[03:18:49] + Restarting core (settings changed)
[03:18:49]
[03:18:49] + Processing work unit
[03:18:49] Core required: FahCore_11.exe
[03:18:49] Core found.
[03:18:49] Working on queue slot 01 [May 23 03:18:49 UTC]
[03:18:49] + Working ...
[03:18:49]
[03:18:49] *------------------------------*
[03:18:49] Folding@Home GPU Core - Beta
[03:18:49] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[03:18:49]
[03:18:49] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[03:18:49] Build host: amoeba
[03:18:49] Board Type: AMD
[03:18:49] Core :
[03:18:49] Preparing to commence simulation
[03:18:49] - Ensuring status. Please wait.
[03:18:59] - Looking at optimizations...
[03:18:59] - Not checking prior termination.
[03:18:59] - Expanded 96629 -> 489152 (decompressed 506.2 percent)
[03:18:59] Called DecompressByteArray: compressed_data_size=96629 data_size=489152, decompressed_data_size=489152 diff=0
[03:18:59] - Digital signature verified
[03:18:59]
[03:18:59] Project: 5736 (Run 4, Clone 11, Gen 241)
[03:18:59]
[03:18:59] Assembly optimizations on if available.
[03:18:59] Entering M.D.
[03:19:05] Will resume from checkpoint file
[03:19:05] Tpr hash work/wudata_01.tpr: 2357812867 3130456912 870561388 1419893916 788861382
[03:19:05] Working on Protein
[03:19:08] Client config found, loading data.
[03:19:08] Starting GUI Server
[03:19:14] Resuming from checkpoint
[03:19:14] fcCheckPointResume: retreived and current tpr file hash:
[03:19:14] 0 2357812867 2357812867
[03:19:14] 1 3130456912 3130456912
[03:19:14] 2 870561388 870561388
[03:19:14] 3 1419893916 1419893916
[03:19:14] 4 788861382 788861382
[03:19:14] Verified work/wudata_01.log
[03:19:14] Verified work/wudata_01.edr
[03:19:14] Verified work/wudata_01.xtc
[03:20:24] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=chin85u...
[03:22:47] CoreStatus = 62 (98)
[03:22:47] + Restarting core (settings changed)
[03:22:47]
[03:22:47] + Processing work unit
[03:22:47] Core required: FahCore_11.exe
[03:22:47] Core found.
[03:22:47] Working on queue slot 01 [May 23 03:22:47 UTC]
[03:22:47] + Working ...
[03:22:47]
[03:22:47] *------------------------------*
[03:22:47] Folding@Home GPU Core - Beta
[03:22:47] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[03:22:47]
[03:22:47] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[03:22:47] Build host: amoeba
[03:22:47] Board Type: AMD
[03:22:47] Core :
[03:22:47] Preparing to commence simulation
[03:22:47] - Ensuring status. Please wait.
[03:22:57] - Looking at optimizations...
[03:22:57] - Not checking prior termination.
[03:22:57] - Expanded 96629 -> 489152 (decompressed 506.2 percent)
[03:22:57] Called DecompressByteArray: compressed_data_size=96629 data_size=489152, decompressed_data_size=489152 diff=0
[03:22:57] - Digital signature verified
[03:22:57]
[03:22:57] Project: 5736 (Run 4, Clone 11, Gen 241)
[03:22:57]
[03:22:57] Assembly optimizations on if available.
[03:22:57] Entering M.D.
[03:23:03] Will resume from checkpoint file
[03:23:03] Tpr hash work/wudata_01.tpr: 2357812867 3130456912 870561388 1419893916 788861382
[03:23:03] Working on Protein
[03:23:05] Client config found, loading data.
[03:23:05] Starting GUI Server
Folding@Home Client Shutdown.
Welcome to the folding forum, chin85u.chin85u wrote:pc specs intel q9300 @ 3.000GHz, 4GB DDR2 RAM @ 800MHz, 2.28 TB HDD (2x.5, 2x.64), palit hd 4850 @stock, ip35p mobo, WIN XP pro 32bit sp3, latest drivers available for all hardware
Specifically what version of the ATI drivers do you have? "Latest drivers" can be rather vague. Were these drivers updated from a previous version? If so, did you use something like DriverCleaner?
Have you set any Environment Variables?
The ATI code is in the midst of some pretty rapid changes, which is why the client is called beta, so it's not quite as simple as it should be.
