Project: 5772 (Run 4, Clone 225, Gen 404)
harlam357
Post by harlam357 »
This one will just not run on my 9800GT 128sp. After this one failing ~15 times I finally got a different WU and the card is Folding happily again. :)
[18:31:00]
[18:31:00] *------------------------------*
[18:31:00] Folding@Home GPU Core - Beta
[18:31:00] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[18:31:00]
[18:31:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[18:31:00] Build host: amoeba
[18:31:00] Board Type: Nvidia
[18:31:00] Core      :
[18:31:00] Preparing to commence simulation
[18:31:00] - Looking at optimizations...
[18:31:00] - Created dyn
[18:31:00] - Files status OK
[18:31:00] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[18:31:00] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[18:31:00] - Digital signature verified
[18:31:00]
[18:31:00] Project: 5772 (Run 4, Clone 225, Gen 404)
[18:31:00]
[18:31:00] Assembly optimizations on if available.
[18:31:00] Entering M.D.
[18:31:07] Working on Protein
[18:31:07] Client config found, loading data.
[18:31:07] mdrun_gpu returned
[18:31:07] SHAKE violations on GPU
[18:31:07]
[18:31:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[18:31:10] CoreStatus = 7A (122)
[18:31:10] Sending work to server
[18:31:10] Project: 5772 (Run 4, Clone 225, Gen 404)
[18:31:10] - Read packet limit of 540015616... Set to 524286976.
[18:31:10] - Error: Could not get length of results file work/wuresults_01.dat
[18:31:10] - Error: Could not read unit 01 file. Removing from queue.
[18:31:10] Trying to send all finished work units
[18:31:10] + No unsent completed units remaining.
[18:31:10] - Preparing to get new work unit...
[18:31:10] + Attempting to get work packet
[18:31:10] - Will indicate memory of 4094 MB
[18:31:10] - Connecting to assignment server
[18:31:10] Connecting to http://assign-GPU.stanford.edu:8080/
[18:31:11] Posted data.
[18:31:11] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[18:31:11] + News From Folding@Home: Welcome to Folding@Home
[18:31:11] Loaded queue successfully.
[18:31:11] Connecting to http://171.67.108.11:8080/
[18:31:12] Posted data.
[18:31:12] Initial: 0000; - Receiving payload (expected size: 45965)
[18:31:13] - Downloaded at ~44 kB/s
[18:31:13] - Averaged speed for that direction ~67 kB/s
[18:31:13] + Received work.
[18:31:13] Trying to send all finished work units
[18:31:13] + No unsent completed units remaining.
[18:31:13] + Closed connections
[18:31:18]
[18:31:18] + Processing work unit
[18:31:18] Core required: FahCore_11.exe
[18:31:18] Core found.
[18:31:18] Working on queue slot 02 [May 21 18:31:18 UTC]
[18:31:18] + Working ...
[18:31:18] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 1644 -version 623'
[18:31:18]
[18:31:18] *------------------------------*
[18:31:18] Folding@Home GPU Core - Beta
[18:31:18] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[18:31:18]
[18:31:18] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[18:31:18] Build host: amoeba
[18:31:18] Board Type: Nvidia
[18:31:18] Core      :
[18:31:18] Preparing to commence simulation
[18:31:18] - Looking at optimizations...
[18:31:18] - Created dyn
[18:31:18] - Files status OK
[18:31:18] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[18:31:18] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[18:31:18] - Digital signature verified
[18:31:18]
[18:31:18] Project: 5772 (Run 4, Clone 225, Gen 404)
[18:31:18]
[18:31:18] Assembly optimizations on if available.
[18:31:18] Entering M.D.
[18:31:24] Working on Protein
[18:31:25] Client config found, loading data.
[18:31:25] mdrun_gpu returned
[18:31:25] SHAKE violations on GPU
[18:31:25]
[18:31:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[18:31:28] CoreStatus = 7A (122)
harlam357
Re: Project: 5772 (Run 4, Clone 225, Gen 404)
Post by harlam357 »
Just got this one again... this time on a GTX260-216. Same result. Appears to not be related to the GPU.
What's the database say mods?
The mod database is still down since last maintenance ... so it only says : Can't connect to the stats database ... Sorry, we can't help :(
Oldhat
Post by Oldhat »
Hi,
Just thought I would mention that I have the same WU and same result here as well.
Windows XP SP3 e8400 1024MB RAM XFX 8800GTX Driver 182.50
--- Opening Log file [June 11 20:28:06 UTC]
                       Folding@Home Client Version 6.20
[12:10:18] + Attempting to send results [June 13 12:10:18 UTC]
[12:10:20] + Results successfully sent
[12:10:20] Thank you for your contribution to Folding@Home.
[12:10:20] + Number of Units Completed: 2548
[12:10:24] - Preparing to get new work unit...
[12:10:24] + Attempting to get work packet
[12:10:24] - Connecting to assignment server
[12:10:25] - Successful: assigned to (171.67.108.11).
[12:10:25] + News From Folding@Home: Welcome to Folding@Home
[12:10:25] Loaded queue successfully.
[12:10:27] + Closed connections
[12:10:27]
[12:10:27] + Processing work unit
[12:10:27] Core required: FahCore_11.exe
[12:10:27] Core found.
[12:10:27] Working on queue slot 04 [June 13 12:10:27 UTC]
[12:10:27] + Working ...
[12:10:27]
[12:10:27] *------------------------------*
[12:10:27] Folding@Home GPU Core - Beta
[12:10:27] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[12:10:27]
[12:10:27] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:10:27] Build host: amoeba
[12:10:27] Board Type: Nvidia
[12:10:27] Core      :
[12:10:27] Preparing to commence simulation
[12:10:27] - Looking at optimizations...
[12:10:27] - Created dyn
[12:10:27] - Files status OK
[12:10:27] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[12:10:27] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[12:10:27] - Digital signature verified
[12:10:27]
[12:10:27] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:10:27]
[12:10:27] Assembly optimizations on if available.
[12:10:27] Entering M.D.
[12:10:34] Working on Protein
[12:10:34] Client config found, loading data.
[12:10:34] mdrun_gpu returned
[12:10:34] SHAKE violations on GPU
[12:10:34]
[12:10:34] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:10:37] CoreStatus = 7A (122)
[12:10:37] Sending work to server
[12:10:37] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:10:37] - Read packet limit of 540015616... Set to 524286976.
[12:10:37] - Error: Could not get length of results file work/wuresults_04.dat
[12:10:37] - Error: Could not read unit 04 file. Removing from queue.
[12:10:37] - Preparing to get new work unit...
[12:10:37] + Attempting to get work packet
[12:10:37] - Connecting to assignment server
[12:10:38] - Successful: assigned to (171.67.108.11).
[12:10:38] + News From Folding@Home: Welcome to Folding@Home
[12:10:38] Loaded queue successfully.
[12:10:39] + Closed connections
[12:10:44]
[12:10:44] + Processing work unit
[12:10:44] Core required: FahCore_11.exe
[12:10:44] Core found.
[12:10:44] Working on queue slot 05 [June 13 12:10:44 UTC]
[12:10:44] + Working ...
[12:10:44]
[12:10:44] *------------------------------*
[12:10:44] Folding@Home GPU Core - Beta
[12:10:44] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[12:10:44]
[12:10:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:10:44] Build host: amoeba
[12:10:44] Board Type: Nvidia
[12:10:44] Core      :
[12:10:44] Preparing to commence simulation
[12:10:44] - Looking at optimizations...
[12:10:44] - Created dyn
[12:10:44] - Files status OK
[12:10:44] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[12:10:44] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[12:10:44] - Digital signature verified
[12:10:44]
[12:10:44] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:10:44]
[12:10:44] Assembly optimizations on if available.
[12:10:44] Entering M.D.
[12:10:51] Working on Protein
[12:10:51] Client config found, loading data.
[12:10:51] Starting GUI Server
[12:10:51] mdrun_gpu returned
[12:10:51] SHAKE violations on GPU
[12:10:51]
[12:10:51] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:10:54] CoreStatus = 7A (122)
[12:10:54] Sending work to server
[12:10:54] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:10:54] - Read packet limit of 540015616... Set to 524286976.
[12:10:54] - Error: Could not get length of results file work/wuresults_05.dat
[12:10:54] - Error: Could not read unit 05 file. Removing from queue.
[12:10:54] - Preparing to get new work unit...
[12:10:54] + Attempting to get work packet
[12:10:54] - Connecting to assignment server
[12:10:55] - Successful: assigned to (171.67.108.11).
[12:10:55] + News From Folding@Home: Welcome to Folding@Home
[12:10:55] Loaded queue successfully.
[12:10:57] + Closed connections
[12:11:02]
[12:11:02] + Processing work unit
[12:11:02] Core required: FahCore_11.exe
[12:11:02] Core found.
[12:11:02] Working on queue slot 06 [June 13 12:11:02 UTC]
[12:11:02] + Working ...
[12:11:02]
[12:11:02] *------------------------------*
[12:11:02] Folding@Home GPU Core - Beta
[12:11:02] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[12:11:02]
[12:11:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:11:02] Build host: amoeba
[12:11:02] Board Type: Nvidia
[12:11:02] Core      :
[12:11:02] Preparing to commence simulation
[12:11:02] - Looking at optimizations...
[12:11:02] - Created dyn
[12:11:02] - Files status OK
[12:11:02] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[12:11:02] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[12:11:02] - Digital signature verified
[12:11:02]
[12:11:02] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:11:02]
[12:11:02] Assembly optimizations on if available.
[12:11:02] Entering M.D.
[12:11:08] Working on Protein
[12:11:09] Client config found, loading data.
[12:11:09] mdrun_gpu returned
[12:11:09] SHAKE violations on GPU
[12:11:09]
[12:11:09] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:11:12] CoreStatus = 7A (122)
[12:11:12] Sending work to server
[12:11:12] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:11:12] - Read packet limit of 540015616... Set to 524286976.
[12:11:12] - Error: Could not get length of results file work/wuresults_06.dat
[12:11:12] - Error: Could not read unit 06 file. Removing from queue.
[12:11:12] - Preparing to get new work unit...
[12:11:12] + Attempting to get work packet
[12:11:12] - Connecting to assignment server
[12:11:12] - Successful: assigned to (171.67.108.11).
[12:11:12] + News From Folding@Home: Welcome to Folding@Home
[12:11:13] Loaded queue successfully.
[12:11:14] + Closed connections
[12:11:19]
[12:11:19] + Processing work unit
[12:11:19] Core required: FahCore_11.exe
[12:11:19] Core found.
[12:11:19] Working on queue slot 07 [June 13 12:11:19 UTC]
[12:11:19] + Working ...
[12:11:19]
[12:11:19] *------------------------------*
[12:11:19] Folding@Home GPU Core - Beta
[12:11:19] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[12:11:19]
[12:11:19] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:11:19] Build host: amoeba
[12:11:19] Board Type: Nvidia
[12:11:19] Core      :
[12:11:19] Preparing to commence simulation
[12:11:19] - Looking at optimizations...
[12:11:19] - Created dyn
[12:11:19] - Files status OK
[12:11:19] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[12:11:19] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[12:11:19] - Digital signature verified
[12:11:19]
[12:11:19] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:11:19]
[12:11:19] Assembly optimizations on if available.
[12:11:19] Entering M.D.
[12:11:26] Working on Protein
[12:11:26] Client config found, loading data.
[12:11:26] mdrun_gpu returned
[12:11:26] SHAKE violations on GPU
[12:11:26]
[12:11:26] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:11:29] CoreStatus = 7A (122)
[12:11:29] Sending work to server
[12:11:29] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:11:29] - Read packet limit of 540015616... Set to 524286976.
[12:11:29] - Error: Could not get length of results file work/wuresults_07.dat
[12:11:29] - Error: Could not read unit 07 file. Removing from queue.
[12:11:29] - Preparing to get new work unit...
[12:11:29] + Attempting to get work packet
[12:11:29] - Connecting to assignment server
[12:11:30] - Successful: assigned to (171.67.108.11).
[12:11:30] + News From Folding@Home: Welcome to Folding@Home
[12:11:30] Loaded queue successfully.
[12:11:31] + Closed connections
[12:11:36]
[12:11:36] + Processing work unit
[12:11:36] Core required: FahCore_11.exe
[12:11:36] Core found.
[12:11:36] Working on queue slot 08 [June 13 12:11:36 UTC]
[12:11:36] + Working ...
[12:11:36]
[12:11:36] *------------------------------*
[12:11:36] Folding@Home GPU Core - Beta
[12:11:36] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[12:11:36]
[12:11:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:11:36] Build host: amoeba
[12:11:36] Board Type: Nvidia
[12:11:36] Core      :
[12:11:36] Preparing to commence simulation
[12:11:36] - Looking at optimizations...
[12:11:36] - Created dyn
[12:11:36] - Files status OK
[12:11:36] - Expanded 45453 -> 251112 (decompressed 552.4 percent)
[12:11:36] Called DecompressByteArray: compressed_data_size=45453 data_size=251112, decompressed_data_size=251112 diff=0
[12:11:36] - Digital signature verified
[12:11:36]
[12:11:36] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:11:36]
[12:11:36] Assembly optimizations on if available.
[12:11:36] Entering M.D.
[12:11:43] Working on Protein
[12:11:43] Client config found, loading data.
[12:11:43] Starting GUI Server
[12:11:43] mdrun_gpu returned
[12:11:43] SHAKE violations on GPU
[12:11:43]
[12:11:43] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:11:47] CoreStatus = 7A (122)
[12:11:47] Sending work to server
[12:11:47] Project: 5772 (Run 4, Clone 225, Gen 404)
[12:11:47] - Read packet limit of 540015616... Set to 524286976.
[12:11:47] - Error: Could not get length of results file work/wuresults_08.dat
[12:11:47] - Error: Could not read unit 08 file. Removing from queue.
[12:11:47] EUE limit exceeded. Pausing 24 hours.
[14:28:51] + Working...
[20:28:51] + Working...
Cheers
selfwilly
Post by selfwilly »
Yah, I just got the same thing..any news on this?
[11:17:45]
[11:17:45] Assembly optimizations on if available.
[11:17:45] Entering M.D.
[11:17:51] Working on Protein
[11:17:52] Client config found, loading data.
[11:17:52] mdrun_gpu returned
[11:17:52] SHAKE violations on GPU
[11:17:52]
[11:17:52] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:17:52] Starting GUI Server
[11:17:55] CoreStatus = 7A (122)
[11:17:55] Sending work to server
[11:17:55] Project: 5772 (Run 4, Clone 225, Gen 404)
[11:17:55] - Error: Could not get length of results file work/wuresults_03.dat
[11:17:55] - Error: Could not read unit 03 file. Removing from queue.
[11:17:55] - Preparing to get new work unit...
[11:17:55] + Attempting to get work packet
[11:17:55] - Connecting to assignment server
[11:17:56] - Successful: assigned to (171.67.108.11).
[11:17:56] + News From Folding@Home: Welcome to Folding@Home
[11:17:56] Loaded queue successfully.
[11:17:57] + Closed connections
This one is very likely a bad WU with so many similar reports.
