Project: 5738 (Run 4, Clone 114, Gen 86)
shiryunaga
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post by shiryunaga »
NANs detected on GPU :x
[10:08:10] + Closed connections
[10:08:15]
[10:08:15] + Processing work unit
[10:08:15] Core required: FahCore_11.exe
[10:08:15] Core found.
[10:08:15] Working on queue slot 02 [April 25 10:08:15 UTC]
[10:08:15] + Working ...
[10:08:15] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -checkpoint 30 -verbose -lifeline 13888 -version 623'
[10:08:15]
[10:08:15] *------------------------------*
[10:08:15] Folding@Home GPU Core - Beta
[10:08:15] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[10:08:15]
[10:08:15] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:08:15] Build host: amoeba
[10:08:15] Board Type: AMD
[10:08:15] Core      :
[10:08:15] Preparing to commence simulation
[10:08:15] - Looking at optimizations...
[10:08:15] - Created dyn
[10:08:15] - Files status OK
[10:08:15] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[10:08:15] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[10:08:15] - Digital signature verified
[10:08:15]
[10:08:15] Project: 5738 (Run 4, Clone 114, Gen 86)
[10:08:15]
[10:08:15] Assembly optimizations on if available.
[10:08:15] Entering M.D.
[10:08:21] Tpr hash work/wudata_02.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[10:08:22] Working on Protein
[10:08:23] Client config found, loading data.
[10:08:23] Starting GUI Server
[10:13:44] Completed 1%
[10:18:35] Completed 2%
[10:23:10] Completed 3%
[10:27:15] mdrun_gpu returned
[10:27:15] NANs detected on GPU
[10:27:15]
[10:27:15] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:27:17] CoreStatus = 7A (122)
[10:27:17] Sending work to server
[10:27:17] Project: 5738 (Run 4, Clone 114, Gen 86)
[10:27:17] - Error: Could not get length of results file work/wuresults_02.dat
[10:27:17] - Error: Could not read unit 02 file. Removing from queue.
[10:27:17] Trying to send all finished work units
[10:27:17] + No unsent completed units remaining.
[10:27:17] - Preparing to get new work unit...
[10:27:17] + Attempting to get work packet
[10:27:17] - Will indicate memory of 1022 MB
[10:27:17] - Connecting to assignment server
[10:27:17] Connecting to http://assign-GPU.stanford.edu:8080/
[10:27:19] Posted data.
[10:27:19] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[10:27:19] + News From Folding@Home: GPU folding beta
[10:27:19] Loaded queue successfully.
[10:27:19] Connecting to http://171.64.65.102:8080/
[10:27:21] Posted data.
[10:27:21] Initial: 0000; - Receiving payload (expected size: 97111)
[10:28:57] - Downloaded at ~0 kB/s
[10:28:57] - Averaged speed for that direction ~6 kB/s
[10:28:57] + Received work.
[10:28:57] Trying to send all finished work units
[10:28:57] + No unsent completed units remaining.
[10:28:57] + Closed connections
[10:29:02]
Folding@Home user since Feb 2009
Re: Project: 5738 (Run 4, Clone 114, Gen 86)
There's no data for this WU in the DB yet ...
shiryunaga
Update Report !!!
After that NAN, i get that WU again then this is the result
[10:29:02]
[10:29:02] + Processing work unit
[10:29:02] Core required: FahCore_11.exe
[10:29:02] Core found.
[10:29:02] Working on queue slot 03 [April 25 10:29:02 UTC]
[10:29:02] + Working ...
[10:29:02] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -verbose -lifeline 13888 -version 623'
[10:29:02]
[10:29:02] *------------------------------*
[10:29:02] Folding@Home GPU Core - Beta
[10:29:02] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[10:29:02]
[10:29:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:29:02] Build host: amoeba
[10:29:02] Board Type: AMD
[10:29:02] Core      :
[10:29:02] Preparing to commence simulation
[10:29:02] - Looking at optimizations...
[10:29:03] - Created dyn
[10:29:03] - Files status OK
[10:29:03] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[10:29:03] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[10:29:03] - Digital signature verified
[10:29:03]
[10:29:03] Project: 5738 (Run 4, Clone 114, Gen 86)
[10:29:03]
[10:29:03] Assembly optimizations on if available.
[10:29:03] Entering M.D.
[10:29:09] Tpr hash work/wudata_03.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[10:29:09] Working on Protein
[10:29:10] Client config found, loading data.
[10:29:10] Starting GUI Server
[10:33:46] Completed 1%
[10:38:14] Completed 2%
[10:42:58] Completed 3%
[10:47:40] Completed 4%
[10:52:03] Completed 5%
[10:56:29] Completed 6%
[11:01:17] Completed 7%
[11:05:23] Completed 8%
--- Opening Log file [April 25 11:07:35 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\shiryunaga\Application Data\Folding@home-gpu
Arguments: -verbosity 9
[11:07:35] - Ask before connecting: No
[11:07:35] - User name: shiryunaga (Team 153760)
[11:07:35] - User ID: 73178E15B3AB94B
[11:07:35] - Machine ID: 3
[11:07:35]
[11:07:35] Loaded queue successfully.
[11:07:35] Initialization complete
[11:07:35]
[11:07:35] + Processing work unit
[11:07:35] - Autosending finished units... [11:07:35]
[11:07:35] Trying to send all finished work units
[11:07:35] + No unsent completed units remaining.
[11:07:35] - Autosend completed
[11:07:35] Core required: FahCore_11.exe
[11:07:35] Core found.
[11:07:36] Working on queue slot 03 [April 25 11:07:36 UTC]
[11:07:36] + Working ...
[11:07:36] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -verbose -lifeline 648 -version 623'
[11:07:36]
[11:07:36] *------------------------------*
[11:07:36] Folding@Home GPU Core - Beta
[11:07:36] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[11:07:36]
[11:07:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:07:36] Build host: amoeba
[11:07:36] Board Type: AMD
[11:07:36] Core      :
[11:07:36] Preparing to commence simulation
[11:07:36] - Looking at optimizations...
[11:07:37] - Files status OK
[11:07:38] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[11:07:38] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[11:07:38] - Digital signature verified
[11:07:38]
[11:07:38] Project: 5738 (Run 4, Clone 114, Gen 86)
[11:07:38]
[11:07:39] Assembly optimizations on if available.
[11:07:39] Entering M.D.
[11:07:45] Will resume from checkpoint file
[11:07:45] Tpr hash work/wudata_03.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[11:07:58] Working on Protein
[11:07:59] Client config found, loading data.
[11:08:00] Starting GUI Server
[11:08:11] Resuming from checkpoint
[11:08:11] fcCheckPointResume: retreived and current tpr file hash:
[11:08:11]    0   1529259317   1529259317
[11:08:11]    1   4214223981   4214223981
[11:08:11]    2    865135675    865135675
[11:08:11]    3   3472622510   3472622510
[11:08:11]    4    847235170    847235170
[11:08:11] Verified work/wudata_03.log
[11:08:11] Verified work/wudata_03.edr
[11:08:11] Verified work/wudata_03.xtc
[11:08:11] Completed 8%
[11:12:26] Completed 9%
[11:16:40] Completed 10%
[11:21:10] Completed 11%
[11:25:33] Completed 12%
[11:30:04] Completed 13%
[11:34:03] Completed 14%
[11:38:10] Completed 15%
[11:42:21] Completed 16%
[11:46:43] Completed 17%
[11:50:48] Completed 18%
[11:54:50] Completed 19%
[11:58:50] Completed 20%
[12:02:54] Completed 21%
[12:06:58] Completed 22%
[12:11:05] Completed 23%
[12:15:11] Completed 24%
[12:19:16] Completed 25%
[12:23:29] Completed 26%
[12:27:50] Completed 27%
[12:31:59] Completed 28%
[12:36:18] Completed 29%
[12:40:27] Completed 30%
[12:44:37] Completed 31%
[12:48:55] Completed 32%
[12:53:16] Completed 33%
[12:57:33] Completed 34%
[13:01:57] Completed 35%
[13:06:15] Completed 36%
[13:10:44] Completed 37%
[13:15:08] Completed 38%
[13:19:35] Completed 39%
[13:24:19] Completed 40%
[13:24:45] ***** Got a SIGTERM signal (2)
[13:24:45] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [April 25 13:24:48 UTC]
[13:24:48] - Ask before connecting: No
[13:24:48] - User name: shiryunaga (Team 153760)
[13:24:48] - User ID: 73178E15B3AB94B
[13:24:48] - Machine ID: 3
[13:24:48]
[13:24:48] Loaded queue successfully.
[13:24:48] Initialization complete
[13:24:48]
[13:24:48] + Processing work unit
[13:24:48] - Autosending finished units... [April 25 13:24:48 UTC]
[13:24:48] Trying to send all finished work units
[13:24:48] + No unsent completed units remaining.
[13:24:48] - Autosend completed
[13:24:48] Core required: FahCore_11.exe
[13:24:48] Core found.
[13:24:48] Working on queue slot 03 [April 25 13:24:48 UTC]
[13:24:48] + Working ...
[13:24:48] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -verbose -lifeline 3136 -version 623'
[13:24:48]
[13:24:48] *------------------------------*
[13:24:48] Folding@Home GPU Core - Beta
[13:24:48] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[13:24:48]
[13:24:48] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:24:48] Build host: amoeba
[13:24:48] Board Type: AMD
[13:24:48] Core      :
[13:24:48] Preparing to commence simulation
[13:24:48] - Looking at optimizations...
[13:24:48] - Files status OK
[13:24:49] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[13:24:49] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[13:24:49] - Digital signature verified
[13:24:49]
[13:24:49] Project: 5738 (Run 4, Clone 114, Gen 86)
[13:24:49]
[13:24:49] Assembly optimizations on if available.
[13:24:49] Entering M.D.
[13:24:55] Will resume from checkpoint file
[13:24:55] Tpr hash work/wudata_03.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[13:24:55] Working on Protein
[13:24:56] Client config found, loading data.
[13:24:56] Starting GUI Server
[13:25:08] Resuming from checkpoint
[13:25:08] fcCheckPointResume: retreived and current tpr file hash:
[13:25:08]    0   1529259317   1529259317
[13:25:08]    1   4214223981   4214223981
[13:25:08]    2    865135675    865135675
[13:25:08]    3   3472622510   3472622510
[13:25:08]    4    847235170    847235170
[13:25:08] Verified work/wudata_03.log
[13:25:08] Verified work/wudata_03.edr
[13:25:08] Verified work/wudata_03.xtc
[13:25:08] Completed 39%
[13:29:25] Completed 40%
[13:31:55] ***** Got a SIGTERM signal (2)
[13:31:55] Killing all core threads
--- Opening Log file [April 25 13:31:58 UTC]
[13:31:58] - Ask before connecting: No
[13:31:58] - User name: shiryunaga (Team 153760)
[13:31:58] - User ID: 73178E15B3AB94B
[13:31:58] - Machine ID: 3
[13:31:58]
[13:31:58] Loaded queue successfully.
[13:31:58] Initialization complete
[13:31:58]
[13:31:58] + Processing work unit
[13:31:58] - Autosending finished units... [April 25 13:31:58 UTC]
[13:31:58] Core required: FahCore_11.exe
[13:31:58] Core found.
[13:31:58] Trying to send all finished work units
[13:31:58] + No unsent completed units remaining.
[13:31:58] - Autosend completed
[13:31:58] Working on queue slot 03 [April 25 13:31:58 UTC]
[13:31:58] + Working ...
[13:31:58] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -verbose -lifeline 2192 -version 623'
[13:31:58]
[13:31:58] *------------------------------*
[13:31:58] Folding@Home GPU Core - Beta
[13:31:58] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[13:31:58]
[13:31:58] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:31:58] Build host: amoeba
[13:31:58] Board Type: AMD
[13:31:58] Core      :
[13:31:58] Preparing to commence simulation
[13:31:58] - Looking at optimizations...
[13:31:58] - Files status OK
[13:31:58] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[13:31:58] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[13:31:58] - Digital signature verified
[13:31:58]
[13:31:58] Project: 5738 (Run 4, Clone 114, Gen 86)
[13:31:58]
[13:31:58] Assembly optimizations on if available.
[13:31:58] Entering M.D.
[13:32:04] Will resume from checkpoint file
[13:32:04] Tpr hash work/wudata_03.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[13:32:04] Working on Protein
[13:32:05] Client config found, loading data.
[13:32:05] Starting GUI Server
[13:32:15] Resuming from checkpoint
[13:32:15] fcCheckPointResume: retreived and current tpr file hash:
[13:32:15]    0   1529259317   1529259317
[13:32:15]    1   4214223981   4214223981
[13:32:15]    2    865135675    865135675
[13:32:15]    3   3472622510   3472622510
[13:32:15]    4    847235170    847235170
[13:32:15] Verified work/wudata_03.log
[13:32:15] Verified work/wudata_03.edr
[13:32:15] Verified work/wudata_03.xtc
[13:32:15] Completed 40%
[13:36:38] Completed 41%
[13:40:59] Completed 42%
[13:45:13] Completed 43%
[14:24:21] ***** Got a SIGTERM signal (2)
[14:24:21] Killing all core threads
--- Opening Log file [April 25 14:24:24 UTC]
[14:24:24] - Ask before connecting: No
[14:24:24] - User name: shiryunaga (Team 153760)
[14:24:24] - User ID: 73178E15B3AB94B
[14:24:24] - Machine ID: 3
[14:24:24]
[14:24:24] Loaded queue successfully.
[14:24:24] Initialization complete
[14:24:24]
[14:24:24] + Processing work unit
[14:24:24] Core required: FahCore_11.exe
[14:24:24] - Autosending finished units... [April 25 14:24:24 UTC]
[14:24:24] Trying to send all finished work units
[14:24:24] + No unsent completed units remaining.
[14:24:24] - Autosend completed
[14:24:24] Core found.
[14:24:24] Working on queue slot 03 [April 25 14:24:24 UTC]
[14:24:24] + Working ...
[14:24:24] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -verbose -lifeline 3272 -version 623'
[14:24:24]
[14:24:24] *------------------------------*
[14:24:24] Folding@Home GPU Core - Beta
[14:24:24] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[14:24:24]
[14:24:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:24:24] Build host: amoeba
[14:24:24] Board Type: AMD
[14:24:24] Core      :
[14:24:24] Preparing to commence simulation
[14:24:24] - Looking at optimizations...
[14:24:24] - Files status OK
[14:24:24] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[14:24:24] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[14:24:24] - Digital signature verified
[14:24:24]
[14:24:24] Project: 5738 (Run 4, Clone 114, Gen 86)
[14:24:24]
[14:24:24] Assembly optimizations on if available.
[14:24:24] Entering M.D.
[14:24:30] Will resume from checkpoint file
[14:24:30] Tpr hash work/wudata_03.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[14:24:31] Working on Protein
[14:24:31] Client config found, loading data.
[14:24:31] Starting GUI Server
[14:24:40] Resuming from checkpoint
[14:24:40] fcCheckPointResume: retreived and current tpr file hash:
[14:24:40]    0   1529259317   1529259317
[14:24:40]    1   4214223981   4214223981
[14:24:40]    2    865135675    865135675
[14:24:40]    3   3472622510   3472622510
[14:24:40]    4    847235170    847235170
[14:24:40] Verified work/wudata_03.log
[14:24:40] Verified work/wudata_03.edr
[14:24:40] Verified work/wudata_03.xtc
[14:24:40] Completed 43%
[14:28:54] Completed 44%
[14:33:10] Completed 45%
[14:37:21] Completed 46%
[14:40:10] ***** Got a SIGTERM signal (2)
[14:40:10] Killing all core threads
--- Opening Log file [April 25 14:40:14 UTC]
[14:40:14] - Ask before connecting: No
[14:40:14] - User name: shiryunaga (Team 153760)
[14:40:14] - User ID: 73178E15B3AB94B
[14:40:14] - Machine ID: 3
[14:40:14]
[14:40:14] Loaded queue successfully.
[14:40:14] Initialization complete
[14:40:14]
[14:40:14] + Processing work unit
[14:40:14] - Autosending finished units... [April 25 14:40:14 UTC]
[14:40:14] Trying to send all finished work units
[14:40:14] + No unsent completed units remaining.
[14:40:14] - Autosend completed
[14:40:14] Core required: FahCore_11.exe
[14:40:14] Core found.
[14:40:14] Working on queue slot 03 [April 25 14:40:14 UTC]
[14:40:14] + Working ...
[14:40:14] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -verbose -lifeline 516 -version 623'
[14:40:15]
[14:40:15] *------------------------------*
[14:40:15] Folding@Home GPU Core - Beta
[14:40:15] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[14:40:15]
[14:40:15] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:40:15] Build host: amoeba
[14:40:15] Board Type: AMD
[14:40:15] Core      :
[14:40:15] Preparing to commence simulation
[14:40:15] - Looking at optimizations...
[14:40:15] - Files status OK
[14:40:15] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[14:40:15] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[14:40:15] - Digital signature verified
[14:40:15]
[14:40:15] Project: 5738 (Run 4, Clone 114, Gen 86)
[14:40:15]
[14:40:15] Assembly optimizations on if available.
[14:40:15] Entering M.D.
[14:40:21] Will resume from checkpoint file
[14:40:21] Tpr hash work/wudata_03.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[14:40:21] Working on Protein
[14:40:22] Client config found, loading data.
[14:40:22] Starting GUI Server
[14:40:32] Resuming from checkpoint
[14:40:32] fcCheckPointResume: retreived and current tpr file hash:
[14:40:32]    0   1529259317   1529259317
[14:40:32]    1   4214223981   4214223981
[14:40:32]    2    865135675    865135675
[14:40:32]    3   3472622510   3472622510
[14:40:32]    4    847235170    847235170
[14:40:32] Verified work/wudata_03.log
[14:40:32] Verified work/wudata_03.edr
[14:40:32] Verified work/wudata_03.xtc
[14:40:32] Completed 46%
[14:44:33] ***** Got a SIGTERM signal (2)
[14:44:33] Killing all core threads
--- Opening Log file [April 25 14:44:35 UTC]
[14:44:35] - Ask before connecting: No
[14:44:35] - User name: shiryunaga (Team 153760)
[14:44:35] - User ID: 73178E15B3AB94B
[14:44:35] - Machine ID: 3
[14:44:35]
[14:44:35] Loaded queue successfully.
[14:44:35] Initialization complete
[14:44:35]
[14:44:35] + Processing work unit
[14:44:35] - Autosending finished units... [April 25 14:44:35 UTC]
[14:44:35] Trying to send all finished work units
[14:44:35] + No unsent completed units remaining.
[14:44:35] - Autosend completed
[14:44:35] Core required: FahCore_11.exe
[14:44:35] Core found.
[14:44:35] Working on queue slot 03 [April 25 14:44:35 UTC]
[14:44:35] + Working ...
[14:44:35] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -verbose -lifeline 3544 -version 623'
[14:44:35]
[14:44:35] *------------------------------*
[14:44:35] Folding@Home GPU Core - Beta
[14:44:35] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[14:44:35]
[14:44:35] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:44:35] Build host: amoeba
[14:44:35] Board Type: AMD
[14:44:35] Core      :
[14:44:35] Preparing to commence simulation
[14:44:35] - Looking at optimizations...
[14:44:35] - Files status OK
[14:44:35] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[14:44:35] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[14:44:35] - Digital signature verified
[14:44:35]
[14:44:35] Project: 5738 (Run 4, Clone 114, Gen 86)
[14:44:35]
[14:44:35] Assembly optimizations on if available.
[14:44:35] Entering M.D.
[14:44:41] Will resume from checkpoint file
[14:44:41] Tpr hash work/wudata_03.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[14:44:42] Working on Protein
[14:44:42] Client config found, loading data.
[14:44:42] Starting GUI Server
[14:44:52] Resuming from checkpoint
[14:44:52] fcCheckPointResume: retreived and current tpr file hash:
[14:44:52]    0   1529259317   1529259317
[14:44:52]    1   4214223981   4214223981
[14:44:52]    2    865135675    865135675
[14:44:52]    3   3472622510   3472622510
[14:44:52]    4    847235170    847235170
[14:44:52] Verified work/wudata_03.log
[14:44:52] Verified work/wudata_03.edr
[14:44:52] Verified work/wudata_03.xtc
[14:44:52] Completed 46%
[14:49:16] Completed 47%
[14:53:27] Completed 48%
[14:57:49] Completed 49%
[15:02:14] ***** Got a SIGTERM signal (2)
[15:02:14] Killing all core threads
--- Opening Log file [April 25 15:02:16 UTC]
[15:02:16] - Ask before connecting: No
[15:02:16] - User name: shiryunaga (Team 153760)
[15:02:16] - User ID: 73178E15B3AB94B
[15:02:16] - Machine ID: 3
[15:02:16]
[15:02:16] Loaded queue successfully.
[15:02:16] Initialization complete
[15:02:16]
[15:02:16] + Processing work unit
[15:02:16] - Autosending finished units... [April 25 15:02:16 UTC]
[15:02:16] Trying to send all finished work units
[15:02:16] + No unsent completed units remaining.
[15:02:16] - Autosend completed
[15:02:16] Core required: FahCore_11.exe
[15:02:16] Core found.
[15:02:16] Working on queue slot 03 [April 25 15:02:16 UTC]
[15:02:16] + Working ...
[15:02:16] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -verbose -lifeline 628 -version 623'
[15:02:16]
[15:02:16] *------------------------------*
[15:02:16] Folding@Home GPU Core - Beta
[15:02:16] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[15:02:16]
[15:02:16] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:02:16] Build host: amoeba
[15:02:16] Board Type: AMD
[15:02:16] Core      :
[15:02:16] Preparing to commence simulation
[15:02:16] - Looking at optimizations...
[15:02:16] - Files status OK
[15:02:16] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[15:02:16] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[15:02:16] - Digital signature verified
[15:02:16]
[15:02:16] Project: 5738 (Run 4, Clone 114, Gen 86)
[15:02:16]
[15:02:16] Assembly optimizations on if available.
[15:02:16] Entering M.D.
[15:02:22] Will resume from checkpoint file
[15:02:22] Tpr hash work/wudata_03.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[15:02:22] Working on Protein
[15:02:23] Client config found, loading data.
[15:02:23] Starting GUI Server
[15:02:32] Resuming from checkpoint
[15:02:32] fcCheckPointResume: retreived and current tpr file hash:
[15:02:32]    0   1529259317   1529259317
[15:02:32]    1   4214223981   4214223981
[15:02:32]    2    865135675    865135675
[15:02:32]    3   3472622510   3472622510
[15:02:32]    4    847235170    847235170
[15:02:32] Verified work/wudata_03.log
[15:02:32] Verified work/wudata_03.edr
[15:02:32] Verified work/wudata_03.xtc
[15:02:32] Completed 49%
[15:06:42] Completed 50%
[15:19:57] ***** Got a SIGTERM signal (2)
[15:19:57] Killing all core threads
--- Opening Log file [April 25 15:20:00 UTC]
[15:20:00] - Ask before connecting: No
[15:20:00] - User name: shiryunaga (Team 153760)
[15:20:00] - User ID: 73178E15B3AB94B
[15:20:00] - Machine ID: 3
[15:20:00]
[15:20:00] Loaded queue successfully.
[15:20:00] Initialization complete
[15:20:00]
[15:20:00] + Processing work unit
[15:20:00] - Autosending finished units... [April 25 15:20:00 UTC]
[15:20:00] Trying to send all finished work units
[15:20:00] + No unsent completed units remaining.
[15:20:00] - Autosend completed
[15:20:00] Core required: FahCore_11.exe
[15:20:00] Core found.
[15:20:00] Working on queue slot 03 [April 25 15:20:00 UTC]
[15:20:00] + Working ...
[15:20:00] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 30 -verbose -lifeline 3404 -version 623'
[15:20:00]
[15:20:00] *------------------------------*
[15:20:00] Folding@Home GPU Core - Beta
[15:20:00] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[15:20:00]
[15:20:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:20:00] Build host: amoeba
[15:20:00] Board Type: AMD
[15:20:00] Core      :
[15:20:00] Preparing to commence simulation
[15:20:00] - Looking at optimizations...
[15:20:00] - Files status OK
[15:20:00] - Expanded 96599 -> 489152 (decompressed 506.3 percent)
[15:20:00] Called DecompressByteArray: compressed_data_size=96599 data_size=489152, decompressed_data_size=489152 diff=0
[15:20:00] - Digital signature verified
[15:20:00]
[15:20:00] Project: 5738 (Run 4, Clone 114, Gen 86)
[15:20:00]
[15:20:00] Assembly optimizations on if available.
[15:20:00] Entering M.D.
[15:20:06] Will resume from checkpoint file
[15:20:06] Tpr hash work/wudata_03.tpr:  1529259317 4214223981 865135675 3472622510 847235170
[15:20:06] Working on Protein
[15:20:07] Client config found, loading data.
[15:20:07] Starting GUI Server
[15:20:16] Resuming from checkpoint
[15:20:16] fcCheckPointResume: retreived and current tpr file hash:
[15:20:16]    0   1529259317   1529259317
[15:20:16]    1   4214223981   4214223981
[15:20:16]    2    865135675    865135675
[15:20:16]    3   3472622510   3472622510
[15:20:16]    4    847235170    847235170
[15:20:16] Verified work/wudata_03.log
[15:20:16] Verified work/wudata_03.edr
[15:20:16] Verified work/wudata_03.xtc
[15:20:16] Completed 50%
[15:24:31] Completed 51%
[15:28:38] ng GuardedRun
[15:28:38] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[15:28:38] Going to send back what have done -- stepsTotalG=10000000
[15:28:38] Work fraction=0.0000 steps=10000000.
[15:28:42] logfile size=29813 infoLength=29813 edr=0 trr=23
[15:28:42] - Writing 30349 bytes of core data to disk...
[15:28:42] Done: 29837 -> 6302 (compressed to 21.1 percent)
[15:28:42]   ... Done.
[15:28:42]
[15:28:42] Folding@home Core Shutdown: EARLY_UNIT_END
[15:34:25] ***** Got a SIGTERM signal (2)
[15:34:25] Killing all core threads
Do you have a good reason to restart the client so often ?
shiryunaga
VPU Recover
You should look at the thread about VPU Recover in the ATI specific forum : viewforum.php?f=51
