Project: 2483 (Run 63, Clone 33, Gen 7) - no credit
goodyca
Post by goodyca »
I was able to successfully upload the subject WU on April 19th at 10:39:05 UTC, but have not received any credit for the unit. Would someone please check the status of this WU for me?
[22:24:51] Connecting to http://assign.stanford.edu:8080/
[22:24:51] Posted data.
[22:24:51] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[22:24:51] + News From Folding@Home: Welcome to Folding@Home
[22:24:51] Loaded queue successfully.
[22:24:51] Connecting to http://171.65.103.162:8080/
[22:25:00] Posted data.
[22:25:00] Initial: 0000; - Receiving payload (expected size: 2969161)
[22:25:18] - Downloaded at ~161 kB/s
[22:25:18] - Averaged speed for that direction ~144 kB/s
[22:25:18] + Received work.
[22:25:18] Trying to send all finished work units
[22:25:18] + No unsent completed units remaining.
[22:25:18] + Closed connections
[22:25:18]
[22:25:18] + Processing work unit
[22:25:18] Core required: FahCore_78.exe
[22:25:18] Core found.
[22:25:18] Working on Unit 04 [April 15 22:25:18]
[22:25:18] + Working ...
[22:25:18] - Calling './FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 16059 -version 602'
[22:25:18]
[22:25:18] *------------------------------*
[22:25:18] Folding@Home Gromacs Core
[22:25:18] Version 1.90 (March 8, 2006)
[22:25:18]
[22:25:18] Preparing to commence simulation
[22:25:18] - Looking at optimizations...
[22:25:18] - Created dyn
[22:25:18] - Files status OK
[22:25:19] - Expanded 2968649 -> 15078465 (decompressed 507.9 percent)
[22:25:19] - Starting from initial work packet
[22:25:19]
[22:25:19] Project: 2483 (Run 63, Clone 33, Gen 7)
[22:25:19]
[22:25:19] Assembly optimizations on if available.
[22:25:19] Entering M.D.
[22:25:26] Protein: system
[22:25:26]
[22:25:26] Writing local files
[22:25:27] Extra SSE boost OK.
[22:25:28] Writing local files
[22:25:28] Completed 0 out of 250000 steps  (0%)
[22:40:28] Timered checkpoint triggered.
[22:55:29] Timered checkpoint triggered.
[23:10:30] Timered checkpoint triggered.
[23:15:38] Writing local files
[23:15:38] Completed 2500 out of 250000 steps  (1%)
[09:47:09] Completed 247500 out of 250000 steps  (99%)
[10:02:10] Timered checkpoint triggered.
[10:17:12] Timered checkpoint triggered.
[10:32:12] Timered checkpoint triggered.
[10:37:15] Writing local files
[10:37:16] Completed 250000 out of 250000 steps  (100%)
[10:37:16] Writing final coordinates.
[10:37:16] Past main M.D. loop
[10:38:16]
[10:38:16] Finished Work Unit:
[10:38:16] - Reading up to 2296656 from "work/wudata_04.arc": Read 2296656
[10:38:16] - Reading up to 98788 from "work/wudata_04.xtc": Read 98788
[10:38:16] goefile size: 0
[10:38:16] logfile size: 41584
[10:38:16] Leaving Run
[10:38:18] - Writing 2455860 bytes of core data to disk...
[10:38:18]   ... Done.
[10:38:18] - Shutting down core
[10:38:18]
[10:38:18] Folding@home Core Shutdown: FINISHED_UNIT
[10:38:19] CoreStatus = 64 (100)
[10:38:19] Unit 4 finished with 96 percent of time to deadline remaining.
[10:38:19] Updated performance fraction: 0.962321
[10:38:19] Sending work to server
[10:38:19] - Read packet limit of 540015616... Set to 524286976.
[10:38:19] + Attempting to send results
[10:38:19] - Reading file work/wuresults_04.dat from core
[10:38:19]   (Read 2455860 bytes from disk)
[10:38:19] Connecting to http://171.65.103.162:8080/
[10:39:05] Posted data.
[10:39:05] Initial: 0000; - Uploaded at ~52 kB/s
[10:39:05] - Averaged speed for that direction ~48 kB/s
[10:39:05] + Results successfully sent
[10:39:05] Thank you for your contribution to Folding@Home.
[10:39:05] + Number of Units Completed: 1362
Re: Project: 2483 (Run 63, Clone 33, Gen 7) - no credit
There's no data for this WU in the DB :(
goodyca
171.65.103.162 - wu not in db
Post by goodyca »
Per toTOW: "There's no data for this WU in the DB" in message http://foldingforum.org/viewtopic.php?f=19&t=9611#
Is this another glitch from the recent problems with the subject server ?
# Linux Console Edition #######################################################
                       Folding@Home Client Version 6.02
                          http://folding.stanford.edu
Launch directory: /home/craig/folding/1
Executable: ./fah6
Arguments: -advmethods -verbosity 9
[22:25:18]
[22:25:18]
[22:25:18]
[22:25:19]
[22:25:19]
[22:25:26]
[10:38:16]
[10:38:18]
It means that we can't tell what happened to your WU with the tools we have. Only the person in charge of the project/server can tell (if he has some spare time to check the server logs).
See my reply here: viewtopic.php?f=19&t=9644
