Project: 2665 (Run 0, Clone 451, Gen 105)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE also on Big Red.
[15:09:36] + Closed connections
[15:09:36]
[15:09:36] + Processing work unit
[15:09:36] Work type a1 not eligible for variable processors
[15:09:36] Core required: FahCore_a1.exe
[15:09:36] Core found.
[15:09:36] Using generic mpiexec calls
[15:09:36] Working on queue slot 03 [April 16 15:09:36 UTC]
[15:09:36] + Working ...
[15:09:36] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 3684 -version 623'
[15:09:36]
[15:09:36] *------------------------------*
[15:09:36] Folding@Home Gromacs SMP Core
[15:09:36] Version 1.74 (March 10, 2007)
[15:09:36]
[15:09:36] Preparing to commence simulation
[15:09:36] - Looking at optimizations...
[15:09:37] .
[15:09:41] - Starting from initial work packet
[15:09:41]
[15:09:41] Project: 2665 (Run 0, Clone 451, Gen 105)
[15:09:41]
[15:09:42] Assembly optimizations on if available.
[15:09:42] Entering M.D.
[15:10:04] l work pa- Starting from initial work packet
[15:10:04]
[15:10:04] Project: 2665 (Run 0, Clone 451, Gen 105)
[15:10:04]
[15:10:05] Entering M.D.
[15:10:11] Rejecting checkpoint
[15:10:13] Protein: HGG in water
[15:10:13] Writing local files
[15:10:21] Extra SSE boost OK.
[15:10:22] Writing local files
[15:10:22] Completed 0 out of 250000 steps  (0 percent)
[15:25:23] Timered checkpoint triggered.
[15:25:51] Writing local files
[15:25:51] Completed 2500 out of 250000 steps  (1 percent)
           {snip}
[20:04:01] Timered checkpoint triggered.
[20:04:27] Writing local files
[20:04:27] Completed 47500 out of 250000 steps  (19 percent)
[20:19:00] Warning:  long 1-4 interactions
[20:19:01] Quit 101 - NaN detected: (ener[20])
[20:19:01]
[20:19:01] Simulation instability has been encountered. The run has entered a
[20:19:01]   state from which no further progress can be made.
[20:19:01] This may be the correct result of the simulation, however if you
[20:19:01]   often see other project units terminating early like this
[20:19:01]   too, you may wish to check the stability of your computer (issues
[20:19:01]   such as high temperature, overclocking, etc.).
[20:19:01] Going to send back what have done.
[20:19:01] logfile size: 44967
[20:19:01] - Writing 45517 bytes of core data to disk...
[20:19:01]   ... Done.
[20:21:01]
[20:21:01] Folding@home Core Shutdown: EARLY_UNIT_END
[20:21:01]
[20:21:04] CoreStatus = 7B (123)
[20:21:04] Sending work to server
[20:21:04] Project: 2665 (Run 0, Clone 451, Gen 105)
[20:21:04] + Attempting to send results [April 16 20:21:04 UTC]
[20:21:04] - Reading file work/wuresults_03.dat from core
[20:21:04]   (Read 45517 bytes from disk)
[20:21:04] Connecting to http://171.64.65.64:8080/
[20:21:04] Posted data.
[20:21:05] Initial: 0000; - Uploaded at ~45 kB/s
[20:21:05] - Averaged speed for that direction ~167 kB/s
[20:21:05] + Results successfully sent
[20:21:05] Thank you for your contribution to Folding@Home.
Re: Project: 2665 (Run 0, Clone 451, Gen 105)
Your WU (P2665 R0 C451 G105) was added to the stats database on 2009-04-16 14:14:31 for 382.9 points of credit.
Another donor completed it successfully.
anko1
Post by anko1 »
Thanks for checking on my WUs, toTOW.
