Project: 4620 (Run 1, Clone 4, Gen 67) -- EUE
whynot
Post by whynot »
I've searched this forum: found runs 3 and 6. And now another one
[20:36:49] + Results successfully sent
[20:36:49] Thank you for your contribution to Folding@Home.
[20:36:49] + Number of Units Completed: 138
[20:36:50] Trying to send all finished work units
[20:36:50] + No unsent completed units remaining.
[20:36:50] - Preparing to get new work unit...
[20:36:50] + Attempting to get work packet
[20:36:50] - Will indicate memory of 504 MB
[20:36:50] - Connecting to assignment server
[20:36:50] Connecting to http://assign.stanford.edu:8080/
[20:36:52] Posted data.
[20:36:52] Initial: E6A9; - Successful: assigned to (169.230.26.30).
[20:36:52] + News From Folding@Home: Welcome to Folding@Home
[20:36:52] Loaded queue successfully.
[20:36:52] Connecting to http://169.230.26.30:8080/
[20:36:55] Posted data.
[20:36:55] Initial: 0000; - Receiving payload (expected size: 16285)
[20:36:57] - Downloaded at ~7 kB/s
[20:36:57] - Averaged speed for that direction ~14 kB/s
[20:36:57] + Received work.
[20:36:57] Trying to send all finished work units
[20:36:57] + No unsent completed units remaining.
[20:36:57] + Closed connections
[20:36:57]
[20:36:57] + Processing work unit
[20:36:57] Core required: FahCore_82.exe
[20:36:57] Core found.
[20:36:57] Working on Unit 01 [April 16 20:36:57]
[20:36:57] + Working ...
[20:36:57] - Calling './FahCore_82.exe -dir work/ -suffix 01 -priority 96 -ch
eckpoint 15 -verbose -lifeline 2802 -version 602'
[20:36:57]
[20:36:57] *------------------------------*
[20:36:57] Folding@Home PMD Core
[20:36:57] Version 1.03 (September 7, 2005)
[20:36:57]
[20:36:57] Preparing to commence simulation
[20:36:57] - Looking at optimizations...
[20:36:57] - Created dyn
[20:36:57] - Files status OK
[20:36:57] - Expanded 15773 -> 106504 (decompressed 675.2 percent)
[20:36:57]
[20:36:57] Project: 4620 (Run 1, Clone 4, Gen 67)
[20:36:57]
[20:36:57] Assembly optimizations on if available.
[20:36:57] Entering M.D.
[20:37:03] Going to send back what have done.
[20:37:03] logfile size: 5649
[20:37:03] - Writing 6169 bytes of core data to disk...
[20:37:03]   ... Done.
[20:37:04]
[20:37:04] Folding@home Core Shutdown: EARLY_UNIT_END
[20:37:04] CoreStatus = 72 (114)
[20:37:04] Sending work to server
[20:37:04] - Read packet limit of 540015616... Set to 524286976.
[20:37:04] + Attempting to send results
[20:37:04] - Reading file work/wuresults_01.dat from core
[20:37:04]   (Read 6169 bytes from disk)
[20:37:04] Connecting to http://169.230.26.30:8080/
[20:37:06] Posted data.
[20:37:06] Initial: 0000; - Uploaded at ~3 kB/s
[20:37:06] - Averaged speed for that direction ~5 kB/s
[20:37:06] + Results successfully sent
[20:37:06] Thank you for your contribution to Folding@Home.
[20:37:06] Trying to send all finished work units
[20:37:06] + No unsent completed units remaining.
[20:37:06] - Preparing to get new work unit...
[20:37:06] + Attempting to get work packet
[20:37:06] - Will indicate memory of 504 MB
[20:37:06] - Connecting to assignment server
[20:37:06] Connecting to http://assign.stanford.edu:8080/
[20:37:08] Posted data.
[20:37:08] Initial: E6A9; - Successful: assigned to (169.230.26.30).
[20:37:08] + News From Folding@Home: Welcome to Folding@Home
[20:37:08] Loaded queue successfully.
[20:37:08] Connecting to http://169.230.26.30:8080/
[20:37:10] Posted data.
[20:37:10] Initial: 0000; - Receiving payload (expected size: 13731)
[20:37:12] - Downloaded at ~6 kB/s
[20:37:12] - Averaged speed for that direction ~13 kB/s
[20:37:12] + Received work.
[20:37:12] Trying to send all finished work units
[20:37:12] + No unsent completed units remaining.
[20:37:12] + Closed connections
[20:37:17]
[20:37:17] + Processing work unit
[20:37:17] Core required: FahCore_82.exe
[20:37:17] Core found.
[20:37:17] Working on Unit 02 [April 16 20:37:17]
[20:37:17] + Working ...
[20:37:17] - Calling './FahCore_82.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 2802 -version 602'
[20:37:17]
[20:37:17] *------------------------------*
[20:37:17] Folding@Home PMD Core
[20:37:17] Version 1.03 (September 7, 2005)
[20:37:17]
[20:37:17] Preparing to commence simulation
[20:37:17] - Looking at optimizations...
[20:37:17] - Created dyn
[20:37:17] - Files status OK
[20:37:17] - Expanded 13219 -> 80392 (decompressed 608.1 percent)
[20:37:17]
[20:37:17] Project: 4621 (Run 3, Clone 24, Gen 84)
[20:37:17]
[20:37:17]
[20:37:17] Assembly optimizations on if available.
[20:37:17] Entering M.D.
[20:37:23] Protein: p4621_T0_ww-8_minout
[20:37:23]
[20:37:23] Completed 0 out of 2500000 steps  (0%)
[20:48:39] Writing local files
[20:48:39] Completed 25000 out of 2500000 steps  (1%)
I'm counting for science.
Points just make me sick.
Re: Project: 4620 (Run 1, Clone 4, Gen 67) -- EUE
There are 6 reports for immediate EUE in the DB. I've marked the WU as bad.
