Project: 4607 (Run 1, Clone 42, Gen 36)
shiryunaga
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post by shiryunaga »
EUE after get Fahcore
[19:03:48] Initial: 88DA; + 706560 bytes downloaded
[19:03:50] Initial: 2C06; + 716479 bytes downloaded
[19:03:52] Verifying core Core_82.fah...
[19:03:52] Signature is VALID
[19:03:52]
[19:03:52] Trying to unzip core FahCore_82.exe
[19:03:52] Decompressed FahCore_82.exe (1683456 bytes) successfully
[19:03:57] + Core successfully engaged
[19:04:02]
[19:04:02] + Processing work unit
[19:04:02] Core required: FahCore_82.exe
[19:04:02] Core found.
[19:04:02] Working on queue slot 01 [April 15 19:04:02 UTC]
[19:04:02] + Working ...
[19:04:02] - Calling '.\FahCore_82.exe -dir work/ -suffix 01 -checkpoint 30 -forceasm -verbose -lifeline 3288 -version 623'
[19:04:02]
[19:04:02] *------------------------------*
[19:04:02] Folding@Home PMD Core
[19:04:02] Version 1.03 (September 7, 2005)
[19:04:02]
[19:04:02] Preparing to commence simulation
[19:04:02] - Assembly optimizations manually forced on.
[19:04:02] - Not checking prior termination.
[19:04:02] - Expanded 18132 -> 115016 (decompressed 634.3 percent)
[19:04:02]
[19:04:02] Project: 4607 (Run 1, Clone 42, Gen 36)
[19:04:02]
[19:04:02] Assembly optimizations on if available.
[19:04:02] Entering M.D.
[19:04:09] Going to send back what have done.
[19:04:09] logfile size: 5649
[19:04:09] - Writing 6169 bytes of core data to disk...
[19:04:09]   ... Done.
[19:04:09]
[19:04:09] Folding@home Core Shutdown: EARLY_UNIT_END
[19:04:12] CoreStatus = 72 (114)
[19:04:12] Sending work to server
[19:04:12] Project: 4607 (Run 1, Clone 42, Gen 36)
[19:04:12] + Attempting to send results [April 15 19:04:12 UTC]
[19:04:12] - Reading file work/wuresults_01.dat from core
[19:04:12]   (Read 6169 bytes from disk)
[19:04:12] Connecting to http://169.230.26.30:8080/
[19:04:15] Posted data.
[19:04:17] Initial: 0000; - Uploaded at ~1 kB/s
[19:04:17] - Averaged speed for that direction ~1 kB/s
[19:04:17] + Results successfully sent
[19:04:17] Thank you for your contribution to Folding@Home.
Folding@Home user since Feb 2009
Re: Project: 4607 (Run 1, Clone 42, Gen 36)
There are 6 reports of instant EUE in the DB. I've marked the WU as bad.
