Project: 5765 (Run 0, Clone 347, Gen 394)
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Post by MtM »
[01:35:49] + Processing work unit
[01:35:49] Core required: FahCore_11.exe
[01:35:49] Core found.
[01:35:49] Working on queue slot 04 [April 15 01:35:49 UTC]
[01:35:49] + Working ...
[01:35:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 4004 -version 623'
[01:35:49]
[01:35:49] *------------------------------*
[01:35:49] Folding@Home GPU Core - Beta
[01:35:49] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[01:35:49]
[01:35:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:35:49] Build host: amoeba
[01:35:49] Board Type: Nvidia
[01:35:49] Core      :
[01:35:49] Preparing to commence simulation
[01:35:49] - Looking at optimizations...
[01:35:50] - Created dyn
[01:35:50] - Files status OK
[01:35:50] - Expanded 46661 -> 252912 (decompressed 542.0 percent)
[01:35:50] Called DecompressByteArray: compressed_data_size=46661 data_size=252912, decompressed_data_size=252912 diff=0
[01:35:50] - Digital signature verified
[01:35:50]
[01:35:50] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:35:50]
[01:35:50] Assembly optimizations on if available.
[01:35:50] Entering M.D.
[01:35:56] Working on Protein
[01:35:57] Client config found, loading data.
[01:35:57] mdrun_gpu returned
[01:35:57] NANs detected on GPU
[01:35:57]
[01:35:57] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:36:01] CoreStatus = 7A (122)
[01:36:01] Sending work to server
[01:36:01] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:36:01] - Read packet limit of 540015616... Set to 524286976.
[01:36:01] - Error: Could not get length of results file work/wuresults_04.dat
[01:36:01] - Error: Could not read unit 04 file. Removing from queue.
[01:36:01] Trying to send all finished work units
[01:36:01] + No unsent completed units remaining.
[01:36:01] - Preparing to get new work unit...
[01:36:01] + Attempting to get work packet
[01:36:01] - Will indicate memory of 8190 MB
[01:36:01] - Connecting to assignment server
[01:36:01] Connecting to http://assign-GPU.stanford.edu:8080/
[01:36:02] Posted data.
[01:36:02] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[01:36:02] + News From Folding@Home: GPU folding beta
[01:36:02] Loaded queue successfully.
[01:36:02] Connecting to http://171.67.108.11:8080/
[01:36:03] Posted data.
[01:36:03] Initial: 0000; - Receiving payload (expected size: 47173)
[01:36:04] - Downloaded at ~46 kB/s
[01:36:04] - Averaged speed for that direction ~49 kB/s
[01:36:04] + Received work.
[01:36:04] Trying to send all finished work units
[01:36:04] + No unsent completed units remaining.
[01:36:04] + Closed connections
[01:36:09]
[01:36:09] + Processing work unit
[01:36:09] Core required: FahCore_11.exe
[01:36:09] Core found.
[01:36:09] Working on queue slot 05 [April 15 01:36:09 UTC]
[01:36:09] + Working ...
[01:36:09] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 15 -verbose -lifeline 4004 -version 623'
[01:36:09]
[01:36:09] *------------------------------*
[01:36:09] Folding@Home GPU Core - Beta
[01:36:09] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[01:36:09]
[01:36:09] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:36:09] Build host: amoeba
[01:36:09] Board Type: Nvidia
[01:36:09] Core      :
[01:36:09] Preparing to commence simulation
[01:36:09] - Looking at optimizations...
[01:36:10] - Created dyn
[01:36:10] - Files status OK
[01:36:10] - Expanded 46661 -> 252912 (decompressed 542.0 percent)
[01:36:10] Called DecompressByteArray: compressed_data_size=46661 data_size=252912, decompressed_data_size=252912 diff=0
[01:36:10] - Digital signature verified
[01:36:10]
[01:36:10] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:36:10]
[01:36:10] Assembly optimizations on if available.
[01:36:10] Entering M.D.
[01:36:17] Working on Protein
[01:36:17] Client config found, loading data.
[01:36:17] mdrun_gpu returned
[01:36:17] NANs detected on GPU
[01:36:17]
[01:36:17] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:36:21] CoreStatus = 7A (122)
[01:36:21] Sending work to server
[01:36:21] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:36:21] - Read packet limit of 540015616... Set to 524286976.
[01:36:21] - Error: Could not get length of results file work/wuresults_05.dat
[01:36:21] - Error: Could not read unit 05 file. Removing from queue.
[01:36:21] Trying to send all finished work units
[01:36:21] + No unsent completed units remaining.
[01:36:21] - Preparing to get new work unit...
[01:36:21] + Attempting to get work packet
[01:36:21] - Will indicate memory of 8190 MB
[01:36:21] - Connecting to assignment server
[01:36:21] Connecting to http://assign-GPU.stanford.edu:8080/
[01:36:22] Posted data.
[01:36:22] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[01:36:22] + News From Folding@Home: GPU folding beta
[01:36:22] Loaded queue successfully.
[01:36:22] Connecting to http://171.67.108.11:8080/
[01:36:23] Posted data.
[01:36:23] Initial: 0000; - Receiving payload (expected size: 47173)
[01:36:24] - Downloaded at ~46 kB/s
[01:36:24] - Averaged speed for that direction ~48 kB/s
[01:36:24] + Received work.
[01:36:24] Trying to send all finished work units
[01:36:24] + No unsent completed units remaining.
[01:36:24] + Closed connections
[01:36:29]
[01:36:29] + Processing work unit
[01:36:29] Core required: FahCore_11.exe
[01:36:29] Core found.
[01:36:29] Working on queue slot 06 [April 15 01:36:29 UTC]
[01:36:29] + Working ...
[01:36:29] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -checkpoint 15 -verbose -lifeline 4004 -version 623'
[01:36:29]
[01:36:29] *------------------------------*
[01:36:29] Folding@Home GPU Core - Beta
[01:36:29] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[01:36:29]
[01:36:29] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:36:29] Build host: amoeba
[01:36:29] Board Type: Nvidia
[01:36:29] Core      :
[01:36:29] Preparing to commence simulation
[01:36:29] - Looking at optimizations...
[01:36:29] - Created dyn
[01:36:29] - Files status OK
[01:36:29] - Expanded 46661 -> 252912 (decompressed 542.0 percent)
[01:36:29] Called DecompressByteArray: compressed_data_size=46661 data_size=252912, decompressed_data_size=252912 diff=0
[01:36:29] - Digital signature verified
[01:36:29]
[01:36:29] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:36:29]
[01:36:29] Assembly optimizations on if available.
[01:36:29] Entering M.D.
[01:36:36] Working on Protein
[01:36:37] Client config found, loading data.
[01:36:37] mdrun_gpu returned
[01:36:37] NANs detected on GPU
[01:36:37]
[01:36:37] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:36:41] CoreStatus = 7A (122)
[01:36:41] Sending work to server
[01:36:41] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:36:41] - Read packet limit of 540015616... Set to 524286976.
[01:36:41] - Error: Could not get length of results file work/wuresults_06.dat
[01:36:41] - Error: Could not read unit 06 file. Removing from queue.
[01:36:41] Trying to send all finished work units
[01:36:41] + No unsent completed units remaining.
[01:36:41] - Preparing to get new work unit...
[01:36:41] + Attempting to get work packet
[01:36:41] - Will indicate memory of 8190 MB
[01:36:41] - Connecting to assignment server
[01:36:41] Connecting to http://assign-GPU.stanford.edu:8080/
[01:36:42] Posted data.
[01:36:42] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[01:36:42] + News From Folding@Home: GPU folding beta
[01:36:42] Loaded queue successfully.
[01:36:42] Connecting to http://171.67.108.11:8080/
[01:36:43] Posted data.
[01:36:43] Initial: 0000; - Receiving payload (expected size: 47173)
[01:36:44] - Downloaded at ~46 kB/s
[01:36:44] - Averaged speed for that direction ~48 kB/s
[01:36:44] + Received work.
[01:36:44] Trying to send all finished work units
[01:36:44] + No unsent completed units remaining.
[01:36:44] + Closed connections
[01:36:49]
[01:36:49] + Processing work unit
[01:36:49] Core required: FahCore_11.exe
[01:36:49] Core found.
[01:36:49] Working on queue slot 07 [April 15 01:36:49 UTC]
[01:36:49] + Working ...
[01:36:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -checkpoint 15 -verbose -lifeline 4004 -version 623'
[01:36:49]
[01:36:49] *------------------------------*
[01:36:49] Folding@Home GPU Core - Beta
[01:36:49] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[01:36:49]
[01:36:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:36:49] Build host: amoeba
[01:36:49] Board Type: Nvidia
[01:36:49] Core      :
[01:36:49] Preparing to commence simulation
[01:36:49] - Looking at optimizations...
[01:36:49] - Created dyn
[01:36:49] - Files status OK
[01:36:49] - Expanded 46661 -> 252912 (decompressed 542.0 percent)
[01:36:49] Called DecompressByteArray: compressed_data_size=46661 data_size=252912, decompressed_data_size=252912 diff=0
[01:36:49] - Digital signature verified
[01:36:49]
[01:36:49] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:36:49]
[01:36:49] Assembly optimizations on if available.
[01:36:49] Entering M.D.
[01:36:56] Working on Protein
[01:36:57] Client config found, loading data.
[01:36:57] mdrun_gpu returned
[01:36:57] NANs detected on GPU
[01:36:57]
[01:36:57] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:37:01] CoreStatus = 7A (122)
[01:37:01] Sending work to server
[01:37:01] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:37:01] - Read packet limit of 540015616... Set to 524286976.
[01:37:01] - Error: Could not get length of results file work/wuresults_07.dat
[01:37:01] - Error: Could not read unit 07 file. Removing from queue.
[01:37:01] Trying to send all finished work units
[01:37:01] + No unsent completed units remaining.
[01:37:01] - Preparing to get new work unit...
[01:37:01] + Attempting to get work packet
[01:37:01] - Will indicate memory of 8190 MB
[01:37:01] - Connecting to assignment server
[01:37:01] Connecting to http://assign-GPU.stanford.edu:8080/
[01:37:02] Posted data.
[01:37:02] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[01:37:02] + News From Folding@Home: GPU folding beta
[01:37:02] Loaded queue successfully.
[01:37:02] Connecting to http://171.67.108.11:8080/
[01:37:03] Posted data.
[01:37:03] Initial: 0000; - Receiving payload (expected size: 47173)
[01:37:04] - Downloaded at ~46 kB/s
[01:37:04] - Averaged speed for that direction ~47 kB/s
[01:37:04] + Received work.
[01:37:04] Trying to send all finished work units
[01:37:04] + No unsent completed units remaining.
[01:37:04] + Closed connections
[01:37:09]
[01:37:09] + Processing work unit
[01:37:09] Core required: FahCore_11.exe
[01:37:09] Core found.
[01:37:09] Working on queue slot 08 [April 15 01:37:09 UTC]
[01:37:09] + Working ...
[01:37:09] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 15 -verbose -lifeline 4004 -version 623'
[01:37:09]
[01:37:09] *------------------------------*
[01:37:09] Folding@Home GPU Core - Beta
[01:37:09] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[01:37:09]
[01:37:09] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:37:09] Build host: amoeba
[01:37:09] Board Type: Nvidia
[01:37:09] Core      :
[01:37:09] Preparing to commence simulation
[01:37:09] - Looking at optimizations...
[01:37:09] - Created dyn
[01:37:09] - Files status OK
[01:37:09] - Expanded 46661 -> 252912 (decompressed 542.0 percent)
[01:37:09] Called DecompressByteArray: compressed_data_size=46661 data_size=252912, decompressed_data_size=252912 diff=0
[01:37:09] - Digital signature verified
[01:37:09]
[01:37:09] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:37:09]
[01:37:09] Assembly optimizations on if available.
[01:37:09] Entering M.D.
[01:37:16] Working on Protein
[01:37:17] Client config found, loading data.
[01:37:17] mdrun_gpu returned
[01:37:17] NANs detected on GPU
[01:37:17]
[01:37:17] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:37:21] CoreStatus = 7A (122)
[01:37:21] Sending work to server
[01:37:21] Project: 5765 (Run 0, Clone 347, Gen 394)
[01:37:21] - Read packet limit of 540015616... Set to 524286976.
[01:37:21] - Error: Could not get length of results file work/wuresults_08.dat
[01:37:21] - Error: Could not read unit 08 file. Removing from queue.
[01:37:21] EUE limit exceeded. Pausing 24 hours.
[07:19:04] - Autosending finished units... [April 15 07:19:04 UTC]
[07:19:04] Trying to send all finished work units
[07:19:04] + No unsent completed units remaining.
[07:19:04] - Autosend completed
MtM
Re: 5765 Run 0 Clone 347 Gen 394
Post by MtM »
Wondering if anyone else has submitted this wu succesfully? If so I need to look at my card but it's been flawless before this one came along and hasn't given problems since either.
There's no data for this WU in the DB yet ...
